byman002
Сообщение byman002 » 17 дек 2017, 21:58
залил на карту прошивку,
write uImage len: 3499884 ok
file app.img too big!(9576448)
error: update pack error!
выдает ошибку, я так понимаю дело в прошивке?
VirtualLink
Сообщение VirtualLink » 17 дек 2017, 22:49
Полные логи будут интересней!
Какую именно прошивка выбрана для восстановления?
byman002
Сообщение byman002 » 17 дек 2017, 23:07
Прошивки взял отсюда
http://www.hikvisioneurope.com/portal/? ... 2CD1X02%29
U-Boot 2010.06-189285 (Apr 18 2016 - 18:06:24)
DRAM: 128 MiB
Flash: 16 MiB
MMC: MID:0x27 RBlock:512 WBlock:512 Chip:30028MB Name:"SD32G"
SD: Ver:2.0 High Capacity Speed:25000000Hz Bus Width:4bit
Hit Ctrl+u to stop autoboot: 0
Up/Down PHY not link.
TFTP server auto connect disabled
load kernel to 0x80007fc0 ... Done!
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-3.0.8
Data Size: 3497336 Bytes = 3.3 MiB
Load Address: 80008000
Entry Point: 80008000
XIP Kernel Image ... OK
byman002
Сообщение byman002 » 17 дек 2017, 23:09
HKVS # reset
resetting ...
DRAM: 128 MiB
Flash: 16 MiB
HKVS # upfsd
Erasing [cfg] ...................................................done
Interface: MMC
Device 0: Vendor: Man 275048 Snr 7c539c3a Rev: 3.0 Prod: SD32G
Type: Removable Hard Disk
Capacity: 30028.0 MB = 29.3 GB (61497344 x 512)
Partition 1: Filesystem: FAT32 "NO NAME "
reading digicap.dav
Found 1 packets.
Skip file _cfgUpgSecPls
Skip file _cfgUpgClass
Erasing [sys] .........................................................done
Writing [sys] .................................................................done
write uImage len: 3497400 ok
file app.img too big!(10788864)
error: upfsd.
HKVS #
byman002
Сообщение byman002 » 17 дек 2017, 23:13
HKVS # updatesd
Interface: MMC
reading digicap.dav
Found 1 packets.
byman002
HKVS # printenv
bootargs=console=ttyAMA0,115200
bootcmd=loadk;bootm 0x80007fc0
bootdelay=3
baudrate=115200
netmask=255.255.255.0
bootfile="uImage"
bldfile="u-boot_r2.bin"
filesize=C6A4
gatewayip=192.168.2.1
ipaddr=192.168.2.151
serverip=192.168.2.71
stdin=serial
stdout=serial
stderr=serial
verify=n
ethaddr=54:c4:15:10:9c:7a
ver=U-Boot 2010.06-189285 (Apr 18 2016 - 18:06:24)
Environment size: 361/65532 bytes
VirtualLink
Сообщение VirtualLink » 18 дек 2017, 01:22
Все логично по материалам из дампа и логов!
Карта разметки флеша изменена в загрузчике от оригинального в данном случае и размеры слегка перераспределены!
Видится 2 варианта:
1.Найти оригинальный хик-загрузчик и обновить
2. "Подрезать" образ, который не влезает и обновить
byman002
Сообщение byman002 » 18 дек 2017, 02:47
Разобрал прошивку на части хиктулзом. Файл uImage это и есть загрузчик?
Или конкретно нужно искать u-boot_r2.bin?
byman002
Сообщение byman002 » 18 дек 2017, 09:17
Загрузчик не могу найти. Образ подрезаю в конце, камера полностью не загружается. Как и что нужно подрезать?)
VirtualLink
Сообщение VirtualLink » 18 дек 2017, 13:21
byman002 писал(а):Разобрал прошивку на части хиктулзом. Файл uImage это и есть загрузчик?
На сколько я понимаю это ядро, которое грузит загрузчик!
byman002 писал(а):Или конкретно нужно искать u-boot_r2.bin?
Логично бы искать загрузчик с оригинальной хик-камеры и наверное упаковать и потом переименовать!
byman002
Сообщение byman002 » 18 дек 2017, 18:59
Загрузчик пока найти не могу, может подскажете как подрезать app.img?
byman002
Сообщение byman002 » 18 дек 2017, 19:21
Ищу загрузчик на камеру DS-2CD1402FD-IW
