вот что он выдаёт по ctrl+c
Код:
U-Boot 2010.06 (Sep 24 2013 - 20:39:26
U_BOOT:7204XQ_VA UBOOT T20130924 20:39:19
main_board_ver 0
DRAM: 256 MiB
Check spi flash controller v300. found
Spi(cs1) ID: 0x01 0x20 0x18 0x4D 0x01 0x80
Get match S25FL129P1/S25FL128S 0x1C 0x0
Spi(cs1): Block:64KB Chip:16MB Name:"S25FL127S1"
In: serial
Out: serial
Err: serial
judge ddr init
user init finish.
Hit CTRL + C to stop autoboot: 0
Streaming3520A # <INTERRUPT>
Streaming3520A # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
decjpg - jpgd - decode jpeg picture.
fatwrite- write file into a dos filesystem
md - memory display
mii - MII utility commands
mw - memory write (fill)
setvobg - setvobg - set vo backgroud color.
- setvobg [dev color]
sf - SPI flash sub-system
startgx - startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - startvo - open interface of vo device.
- startvo [dev type sync]
stopgx - stopgx - close graphics layer.
- stopgx [layer]
stopvo - stopvo - close interface of vo device.
- stopvo [dev]
usb - USB sub-system
Streaming3520A # print
bootargs=mem=92M console=ttyAMA0,115200 UartConfig=1 EtherConfig=1 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:640K(boot+3Logo),1792K(Kernel),13M(Root+App),64K(SysConfig),64K(SysStatus),512K(SysPara)
bootcmd=sf probe 0;sf read 0x82000000 0xA0000 0x1C0000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:09:24:**:**:**
ipaddr=192.168.2.234
serverip=192.168.2.56
netmask=255.255.254.0
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
вот лог загрузки
Код:
U-Boot 2010.06 (Sep 24 2013 - 20:39:26)
main_board_ver 0
DRAM: 256 MiB
In: serial
Out: serial
Err: serial
judge ddr init
user init finish.
[MachineTypeCheck, 1692]:DeviceType 24
[UpgradeSoftware, 1709]:Check Upgrade At Momory Address 0x00000000
[VerifyMmpValid, 229]:Bad memory Addr 0x00000000
[CommonUpgrade, 1230]:Invalid Upgrade Addr 0x00000000
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
No device found. Not initialized?
[USBSoftwareUpgrade, 309]:SoftwareUpgrade: Cann't Initialize Usb Devices for Upgrade
[UpgradeSoftware, 1719]:USBSoftwareUpgrade: No Upgrade
[UpgradeSoftware, 1728]:Free Flash
[HAL_LAYER_SetRegUp, 5215]:pVoReg->G0UPD.u32 0x205C9004
[HAL_LAYER_EnableLayer, 3205]:pVoReg->G0CTRL.u32 0x205C9000
graphic layer 0 closed!
dev 0 closed!
jpeg decoding ...
<<addr=0x83000000, size=0x20000, vobuf=0x8f400000>>
mmu_enable
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
dev 0 opened!
graphic layer 0 opened!
jpeg decoding ...
<<addr=0x83000000, size=0x20000, vobuf=0x8f000000>>
mmu_enable
<<imgwidth=720, imgheight=576, linebytes=1440>>
decode success!!!!
decode jpeg!
dev 2 opened!
graphic layer 2 opened!
Image Name: Linux-3.0.8
Data Size: 1336772 Bytes = 1.3 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@ubuntu) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #82 Sun Sep 15 21:20:22 PDT 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: godarm
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 23368
Kernel command line: mem=92M console=ttyAMA0,115200 UartConfig=1 EtherConfig=1 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:640K(boot+3Logo),1792K(Kernel),13M(Root+App),64K(SysConfig),64K(SysStatus),512K(SysPara)
UartConfig_setup:1(1)
EtherConfig_setup:1(1)[0: 3521==>7216XH_VA 8608XH_VA; 1: 3520A==>8604XQ_VA]; 2: 3521 NVR; 3: 3520A NVR
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 92MB = 92MB total
Memory: 89596k/89596k available, 4612k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc6000000 - 0xfe000000 ( 896 MB)
lowmem : 0xc0000000 - 0xc5c00000 ( 92 MB)
.init : 0xc0008000 - 0xc0025000 ( 116 kB)
.text : 0xc0025000 - 0xc0359000 (3280 kB)
.data : 0xc035a000 - 0xc0376b00 ( 115 kB)
.bss : 0xc0376b24 - 0xc03a47c0 ( 184 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 155MHz, resolution 6ns, wraps every 27709ms
sched_clock: wrong multiply/shift: 432960413>>26 vs calculated 3463683303>>29
sched_clock: fix multiply/shift to avoid scheduler hiccups
Calibrating delay loop... 1849.75 BogoMIPS (lpj=9248768)
console [ttyAMA0] enabled
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
uart:3: ttyAMA3 at MMIO 0x200b0000 (irq = 43) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
L2cache cache controller enabled
fuse init (API version 7.16)
msgmni has been set to 174
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 68
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 68
Spi id table Version 1.22
Hisilicon Spi Flash Controller V300 New Device Driver, Version 1.10
Check Spi Flash Controller V300 New.
Found
Spi(cs1):
Block:64KB
Chip:16MB
[hisfc300_probe, 1019]: Install Lock & unLock func V2.0
6 cmdlinepart partitions found on MTD device hi_sfc
Creating 6 MTD partitions on "hi_sfc":
0x000000000000-0x0000000a0000 : "boot+3Logo"
0x0000000a0000-0x000000260000 : "Kernel"
0x000000260000-0x000000f60000 : "Root+App"
0x000000f60000-0x000000f70000 : "SysConfig"
0x000000f70000-0x000000f80000 : "SysStatus"
0x000000f80000-0x000001000000 : "SysPara"
Fixed MDIO Bus: probed
STMMAC driver:
platform registration...
done!
Set system config register 0x200300ec with value 0x003f003f
done!
DWMAC1000 - user ID: 0x10, Synopsys ID: 0x36
Enhanced descriptor structure
MACADDR in get is 0:0:0:0:0:0
no valid MAC address for MAC 0;please, use ifconfig or nwhwconfig!
eth0 - (dev. name: stmmaceth - id: 0, IRQ #119
IO base addr: 0xc6140000)
Register STMMAC MII Bus for 1
STMMAC MII Bus: probed
eth0: PHY ID 00008201 at 1 IRQ -6 (1:01) active
stmmac_reset: RESET COMPLETE!
* TNK driver built on Sep 15 2013 at 21:16:16
* TNK driver mode is BYPASS
stmmac: Rx Checksum Offload Engine supported
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
cdc_ncm: 04-Aug-2011
usbcore: registered new interface driver cdc_ncm
hiusb-ehci hiusb-ehci.0: irq 63, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 64, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
ata1: SATA link down (SStatus 0 SControl 300)
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
usbhid: USB HID core driver
TCP cubic registered
▒ata2: SATA link down (SStatus 0 SControl 300)
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 116K
init started: BusyBox v1.16.1 (2012-11-13 16:20:01 CST)
starting pid 451, tty '': '/etc/init.d/rcS'
BusyBox: 8608XQ_VA ROOTFS NTPL T20121016 10:54:31
udevd (459): /proc/459/oom_adj is deprecated, please use /proc/459/oom_score_adj instead.
hi3520A_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3520A...OK!
Load tde.ko ...OK!
load venc.ko for Hi3520A...OK!
load group.ko for Hi3520A...OK!
load chnl.ko for Hi3520A...OK!
load h264e.ko for Hi3520A...OK!
load rc.ko ....OK!
load jpege.ko for Hi3520A...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load jpeg6b.ko success. (SDK_VERSION:[jpeg6bv1.0] Build Time:[Nov 28 2012, 18:48:49])
eth0: generated random MAC address 96:c3:af:7b:7e:1d
MACADDR in set is 96:c3:af:7b:7e:1d
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 1)
Welcome to Streaming Linux.
mount: mounting /dev/mtdblock8 on /usr/local failed: No such device
Run App Finish
starting pid 735, tty '': '/sbin/getty -L ttyS000 115200 vAuto login as root ...
Jan 1 00:00:03 login[735]: root login on 'ttyS000'
BusyBox v1.16.1 (2012-11-13 16:20:01 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
None of nfsroot found in cmdline.
# Start cash language
create folder /tmp/webcash
Get config json
[GetSystemCfgJson-GetFileSize] len 40, {
"DataLen":12978,
"DataCrc":44
Start Cash web.config
result={"APP_TYPE":"formal","BUZZER_ENABLE":null,"CHANNEL_NUM":4,"CUSTOMER_ID":0,"CUSTOMER_NAME":"CUSTOMER_04323","DDNS":[{"SELECT":"true","TYPE":"REELINK","VALUE":24},{"SELECT":"true","TYPE":"88110","VALUE":16},{"SELECT":"true","TYPE":"3322","VALUE":0},{"SELECT":"true","TYPE":"DYNDNS","VALUE":1},{"SELECT":"false","TYPE":"LTSCCTV","VALUE":2},{"SELECT":"false","TYPE":"LOREXDDNS","VALUE":3},{"SELECT":"true","TYPE":"DNSEXIT","VALUE":4},{"SELECT":"false","TYPE":"MYQ-SEE.COM","VALUE":5},{"SELECT":"false","TYPE":"ANPVISION","VALUE":6},{"SELECT":"false","TYPE":"VISIONICA","VALUE":7},{"SELECT":"false","TYPE":"JINSANJIA","VALUE":8},{"SELECT":"false","TYPE":"CCTVGOV","VALUE":9},{"SELECT":"false","TYPE":"NIGHTOWL","VALUE":10},{"SELECT":"false","TYPE":"FFBBCC","VALUE":11},{"SELECT":"false","TYPE":"ZHIJING","VALUE":12},{"SELECT":"true","TYPE":"NO-IP","VALUE":13},{"SELECT":"true","TYPE":"CHANGEIP","VALUE":15},{"SELECT":"false","TYPE":"DDNSDVR","VALUE":17},{"SELECT":"false","TYPE":"PORTAL ECOTRONIC","VALUE":18},{"SELECT":"false","TYPE":"DFSEC","VALUE":19},{"SELECT":"false","TYPE":"SANLLON.COM","VALUE":20},{"SELECT":"false","TYPE":"WISOL","VALUE":21},{"SELECT":"false","TYPE":"88110_NIGHTOWL","VALUE":22},{"SELECT":"false","TYPE":"CAMSEC","VALUE":23},{"SELECT":"false","TYPE":"UNICAM","VALUE":25},{"SELECT":"false","TYPE":"SECURUS","VALUE":26},{"SELECT":"false","TYPE":"LINKDVR","VALUE":27},{"SELECT":"false","TYPE":"IPCAMEYE.NET","VALUE":28}],"DEVICE_ALARM_OUTPUT":1,"DEVICE_AUDIO_NUM":4,"ENC_RESOURCE":[{"NTSC_TOTAL_RES":480,"PAL_TOTAL_RES":400,"TYPE":"MAINSTREAM","UNIT":"CIF-FRAME"},{"NTSC_TOTAL_RES":120,"PAL_TOTAL_RES":100,"TYPE":"SUBSTREAM","UNIT":"CIF-FRAME"},{"NTSC_TOTAL_RES":24,"PAL_TOTAL_RES":24,"TYPE":"MOBILESTREAM","UNIT":"CIF-FRAME"}],"FTP_SWITCH":"false","HDD_NUM":1,"IE_CUR_LAN":null,"IE_LOGDIR":"IE_04.323.png","IE_LOGIN_LOG":"logo_viewdvr.png","IE_MAINSTREAM_SELECT":null,"IE_NIGHT_CUSTOMER_LOGO":null,"IE_OCXVER":"V1216#version=1,2,1,6","IE_PLAYBACK_NUM":null,"IE_PRIWE":"true","LOG_SWITCH":"true","MAX_ONLINE_USER_NUM":4,"MOBSTREAM_RES":null,"NET_3G":"true","NET_CMS":"false","NET_WIFI":"false","PREVIEW_PERMISSION":null,"PRODUCT_TYPE":"7204XQ_VA","RAILWAY_SWITCH":null,"REC_RES":[{"SELECT":"true","TYPE":"CIF","VALUE":0},{"SELECT":"true","TYPE":"HD1","VALUE":1},{"SELECT":"true","TYPE":"D1","VALUE":2},{"SELECT":"true","TYPE":"WCIF","VALUE":11},{"SELECT":"true","TYPE":"WHD1","VALUE":12},{"SELECT":"true","TYPE":"WD1(960H)","VALUE":13},{"SELECT":"false","TYPE":"720P","VALUE":6},{"SELECT":"false","TYPE":"1080P","VALUE":7}],"SENSOR_NUM":4,"SG_PLATFORM":null,"SPOT_SWITCH":"false","SUBSTREAM_RES":null,"SUPPORT_960H":null,"SUPPORT_IRREGULAR_SPLIT":"true","SUPPORT_RAID":null,"TEMPER_ALARM_SWITCH":null,"TIME_SYNC_SERVER":[{"NAME":"time.windows.com"},{"NAME":"time.nist.gov"},{"NAME":"time-nw.nist.gov"},{"NAME":"time-a.nist.gov"},{"NAME":"time-b.nist.gov"}],"Talkback":"false","UI_FRAMERATE_CFG":[{"NAME":"PAL","VALUE":25},{"NAME":"NTSC","VALUE":30}],"UI_LANG_CFG":[{"CFG_FILE":"ui/language/chinese.ini","FONT_LIB":"FZYaoTi","FONT_LIB_FILE":"fonts/FZYTK.TTF","ICON_DIR":"ui/icons/chinese","LANG":"中文","SELECT":"true","VALUE":0},{"CFG_FILE":"ui/language/english.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","LANG":"English","SELECT":"true","VALUE":1},{"CFG_FILE":"ui/language/korean.ini","FONT_LIB":"New Gulim","FONT_LIB_FILE":"fonts/NewGulim.ttf","ICON_DIR":"ui/icons/korean","LANG":"한국어","SELECT":"false","VALUE":2},{"CFG_FILE":"ui/language/italian.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/italian","LANG":"Italiano","SELECT":"true","VALUE":3},{"CFG_FILE":"ui/language/german.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/german","LANG":"Deutsch","SELECT":"false","VALUE":4},{"CFG_FILE":"ui/language/thai.ini","FONT_LIB":"Tahoma","FONT_LIB_FILE":"fonts/tahoma.ttf","ICON_DIR":"ui/icons/thai","LANG":"ไทย","SELECT":"false","VALUE":5},{"CFG_FILE":"ui/language/turkish.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/turkish","LANG":"Türkçe","SELECT":"false","VALUE":6},{"CFG_FILE":"ui/language/portuguese.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/portuguese","LANG":"Português","SELECT":"true","VALUE":7},{"CFG_FILE":"ui/language/spanlish.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/spanlish","LANG":"Español","SELECT":"true","VALUE":8},{"CFG_FILE":"ui/language/romanian.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/romanian","LANG":"Română","SELECT":"false","VALUE":9},{"CFG_FILE":"ui/language/greek.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","LANG":"Ελληνικά","SELECT":"false","VALUE":10},{"CFG_FILE":"ui/language/french.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/french","LANG":"Français","SELECT":"true","VALUE":11},{"CFG_FILE":"ui/language/russian.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/russian","LANG":"Русский","SELECT":"true","VALUE":12},{"CFG_FILE":"ui/language/nederlands.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","LANG":"Nederlands","SELECT":"false","VALUE":13},{"CFG_FILE":"ui/language/hebrew.ini","FONT_LIB":"Arial","FONT_LIB_FILE":"fonts/arial.ttf","ICON_DIR":"ui/icons/hebrew","LANG":"עברית","SELECT":"false","VALUE":14},{"CFG_FILE":"ui/language/chinesetrad.ini","FONT_LIB":"msf","FONT_LIB_FILE":"fonts/msf.ttf","ICON_DIR":"ui/icons/traditional","LANG":"中文繁体","SELECT":"false","VALUE":15},{"CFG_FILE":"ui/language/polish.ini","FONT_LIB":"CALIBRI","FONT_LIB_FILE":"fonts/CALIBRI.TTF","ICON_DIR":"ui/icons/polish","LANG":"Polski","SELECT":"false","VALUE":16}],"UI_SUB_FRAMERATE_CFG":[{"NAME":"PAL","VALUE":8},{"NAME":"NTSC","VALUE":10}]}
Cash web.config ok len=5890
Cash lan=中文 ini=./ui/language/chinese.ini
Cash base english path=./ui/language/english.ini
index=13
customini=./ui/language/CUSTOMER_04323_chinese.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/中文/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/中文/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/中文/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/中文/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/中文/proxy/, filename=../liveView.html, fd=0x13bad78
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/中文/proxy/, filename=../playback.html, fd=0x13bad78
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/中文/proxy/, filename=../left.html, fd=0x13bad78
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/中文/, filename=liveView.html, fd=0x13bad78
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/中文/, filename=playback.html, fd=0x13bad78
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/中文/, filename=left.html, fd=0x13bad78
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/中文/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/中文/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/中文/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/中文/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/中文/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/中文/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/中文/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/中文/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/中文/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/中文/JS/
Cash lan=English ini=./ui/language/english.ini
index=13
customini=./ui/language/CUSTOMER_04323_english.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/English/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/English/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/English/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/English/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/English/proxy/, filename=../liveView.html, fd=0x13bb360
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/English/proxy/, filename=../playback.html, fd=0x13bb360
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/English/proxy/, filename=../left.html, fd=0x13bb360
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/English/, filename=liveView.html, fd=0x13bb360
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/English/, filename=playback.html, fd=0x13bb360
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/English/, filename=left.html, fd=0x13bb360
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/English/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/English/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/English/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/English/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/English/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/English/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/English/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/English/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/English/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/English/JS/
language 한국어 is not select
Cash lan=Italiano ini=./ui/language/italian.ini
index=13
customini=./ui/language/CUSTOMER_04323_italian.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/Italiano/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/Italiano/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/Italiano/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/Italiano/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/Italiano/proxy/, filename=../liveView.html, fd=0x13db648
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/Italiano/proxy/, filename=../playback.html, fd=0x13db648
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/Italiano/proxy/, filename=../left.html, fd=0x13db648
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/Italiano/, filename=liveView.html, fd=0x13daf28
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/Italiano/, filename=playback.html, fd=0x13daf28
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/Italiano/, filename=left.html, fd=0x13daf28
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/Italiano/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/Italiano/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/Italiano/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/Italiano/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/Italiano/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/Italiano/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/Italiano/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/Italiano/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/Italiano/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/Italiano/JS/
language Deutsch is not select
language ไทย is not select
language Türkçe is not select
Cash lan=Português ini=./ui/language/portuguese.ini
index=13
customini=./ui/language/CUSTOMER_04323_portuguese.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/Português/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/Português/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/Português/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/Português/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/Português/proxy/, filename=../liveView.html, fd=0x13de8a8
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/Português/proxy/, filename=../playback.html, fd=0x13de8a8
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/Português/proxy/, filename=../left.html, fd=0x13de8a8
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/Português/, filename=liveView.html, fd=0x13de8a8
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/Português/, filename=playback.html, fd=0x13de8a8
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/Português/, filename=left.html, fd=0x13de8a8
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/Português/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/Português/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/Português/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/Português/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/Português/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/Português/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/Português/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/Português/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/Português/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/Português/JS/
Cash lan=Español ini=./ui/language/spanlish.ini
index=13
customini=./ui/language/CUSTOMER_04323_spanlish.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/Español/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/Español/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/Español/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/Español/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/Español/proxy/, filename=../liveView.html, fd=0x13d6d58
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/Español/proxy/, filename=../playback.html, fd=0x13d6d58
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/Español/proxy/, filename=../left.html, fd=0x13d6d58
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/Español/, filename=liveView.html, fd=0x13d6d58
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/Español/, filename=playback.html, fd=0x13d6d58
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/Español/, filename=left.html, fd=0x13d6d58
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/Español/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/Español/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/Español/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/Español/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/Español/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/Español/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/Español/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/Español/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/Español/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/Español/JS/
language Română is not select
language Ελληνικά is not select
Cash lan=Français ini=./ui/language/french.ini
index=13
customini=./ui/language/CUSTOMER_04323_french.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/Français/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/Français/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/Français/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/Français/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/Français/proxy/, filename=../liveView.html, fd=0x13cda28
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/Français/proxy/, filename=../playback.html, fd=0x13cda28
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/Français/proxy/, filename=../left.html, fd=0x13cda28
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/Français/, filename=liveView.html, fd=0x13cda28
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/Français/, filename=playback.html, fd=0x13cda28
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/Français/, filename=left.html, fd=0x13cda28
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/Français/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/Français/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/Français/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/Français/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/Français/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/Français/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/Français/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/Français/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/Français/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/Français/JS/
Cash lan=Русский ini=./ui/language/russian.ini
index=13
customini=./ui/language/CUSTOMER_04323_russian.ini
=======start scandir src=../www/HAPPLE/pages/ dst=/tmp/webcash/Русский/
=======start scandir src=../www/HAPPLE/pages/sysTips/ dst=/tmp/webcash/Русский/sysTips/
=======start scandir src=../www/HAPPLE/pages/sysTips/tipsImg/ dst=/tmp/webcash/Русский/sysTips/tipsImg/
=======start scandir src=../www/HAPPLE/pages/proxy/ dst=/tmp/webcash/Русский/proxy/
Cash include file ../www/HAPPLE/pages/proxy/../liveView.html to /tmp/webcash/Русский/proxy/, filename=../liveView.html, fd=0x13e1a60
Cash include file ../www/HAPPLE/pages/proxy/../playback.html to /tmp/webcash/Русский/proxy/, filename=../playback.html, fd=0x13e1a60
Cash include file ../www/HAPPLE/pages/proxy/../left.html to /tmp/webcash/Русский/proxy/, filename=../left.html, fd=0x13e1a60
Cash include file ../www/HAPPLE/pages/liveView.html to /tmp/webcash/Русский/, filename=liveView.html, fd=0x13e19e8
Cash include file ../www/HAPPLE/pages/playback.html to /tmp/webcash/Русский/, filename=playback.html, fd=0x13e19e8
Cash include file ../www/HAPPLE/pages/left.html to /tmp/webcash/Русский/, filename=left.html, fd=0x13e19e8
=======start scandir src=../www/HAPPLE/pages/images/ dst=/tmp/webcash/Русский/images/
=======start scandir src=../www/HAPPLE/pages/WAP/ dst=/tmp/webcash/Русский/WAP/
=======start scandir src=../www/HAPPLE/pages/Styles/ dst=/tmp/webcash/Русский/Styles/
=======start scandir src=../www/HAPPLE/pages/LoadPage/ dst=/tmp/webcash/Русский/LoadPage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemMessage/ dst=/tmp/webcash/Русский/LoadPage/SystemMessage/
=======start scandir src=../www/HAPPLE/pages/LoadPage/SystemManagement/ dst=/tmp/webcash/Русский/LoadPage/SystemManagement/
=======start scandir src=../www/HAPPLE/pages/LoadPage/NetworkService/ dst=/tmp/webcash/Русский/LoadPage/NetworkService/
=======start scandir src=../www/HAPPLE/pages/LoadPage/EncodingSetting/ dst=/tmp/webcash/Русский/LoadPage/EncodingSetting/
=======start scandir src=../www/HAPPLE/pages/LoadPage/AlarmSet/ dst=/tmp/webcash/Русский/LoadPage/AlarmSet/
=======start scandir src=../www/HAPPLE/pages/JS/ dst=/tmp/webcash/Русский/JS/
language Nederlands is not select
language עברית is not select
language 中文繁体 is not select
language Polski is not select
Free CCashLanguage
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.602]terminate Process name=/usr/local/bin/StreamGui
killall: /usr/local/bin/StreamGui: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.608]exit child: pid: 740 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.608]terminate Process name=/usr/local/bin/DeviceManage
killall: /usr/local/bin/DeviceManage: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.613]exit child: pid: 741 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.613]terminate Process name=/usr/local/bin/avStreaming
killall: /usr/local/bin/avStreaming: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.618]exit child: pid: 742 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.618]terminate Process name=/usr/local/bin/EventManage
killall: /usr/local/bin/EventManage: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.622]exit child: pid: 743 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.623]terminate Process name=/usr/local/bin/Storage
killall: /usr/local/bin/Storage: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.627]exit child: pid: 744 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.627]terminate Process name=/usr/local/bin/StreamingProtocol
killall: /usr/local/bin/StreamingProtocol: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.632]exit child: pid: 745 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.632]terminate Process name=/usr/local/bin/NetworkService
killall: /usr/local/bin/NetworkService: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.637]exit child: pid: 746 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.637]terminate Process name=/usr/local/bin/httpd
killall: /usr/local/bin/httpd: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.642]exit child: pid: 747 status: 256
[CenterServer:SoftWatchdog.cpp:TerminateProcess:98:Time:5.642]terminate Process name=/usr/local/bin/NATStreamingProtocol
killall: /usr/local/bin/NATStreamingProtocol: no process killed
[CenterServer:SoftWatchdog.cpp:OnSignalSIGCHLD:31:Time:5.647]exit child: pid: 748 status: 256
[CenterServer:watchdog.cpp:create:26:Time:5.695]Version:RMCBB Hisi Watchdog 1.0.0 RC1
DeviceManage Version[HI3520A]:2013-10-15 03:53:39
"DataLen":12978,
"DataCrc":44
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000031]CDeviceManage::Dm_parse_system_config device type:7204XQ_VA 24
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000040]CDeviceManage::Dm_parse_system_config max hdd number:1
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000059]CDeviceManage::Dm_parse_system_config panel type:C1
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000071]CDeviceManage::Dm_parse_system_config P Hdelay 3
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000077]CDeviceManage::Dm_parse_system_config P hactive 0
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000083]CDeviceManage::Dm_parse_system_config P Vdelay 0
[DeviceManageSystemConfig.cpDriverHi35xxGpio Version[HI3520A]:2013-09-06 00:40:02
p][Dm_parse_system_config: 00000089]CDeviceManage::Dm_parse_system_config P vactive 0
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000095]CDeviceManage::Dm_parse_system_config N Hdelay 7
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000101]CDeviceManage::Dm_parse_system_config N hactive 0
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000107]CDeviceManage::Dm_parse_system_config N Vdelay 0
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000113]CDeviceManage::Dm_parse_system_config N vactive 0
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000122]CDeviceManage::Dm_parse_system_config APP TYPE:formal
[GetUartProtocalInfo:667]UARTPROTOCAL_LIST is not arrry[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000161]CDeviceManage::Dm_parse_system_config pSystem_config_parser->GetUartProtocalInfo FAILED
[DeviceManageSysDriverGpioI2c Version[HI3520A]:2013-09-06 00:40:19
temConfig.cpp][DGpioi2c_init config(bus_num:1):
m_parse_system_c Gpio i2c bus(0):[SCL:GPIO13_3][SDA:GPIO13_2]
onfig: 00000187]CDeviceManage::Dm_parse_system_config alarm input num 4
[DeviceManageSystemConfig.cpp][Dm_parse_system_config: 00000193]CDeviceManage::Dm_parse_system_config alarm output num 1
[DeviceManageSystemConfig.cpp][Dm_init_main_board_ver: 00002103]Main board Version: 0DriverCx2682x Version[HI3520A]:2013-10-10 01:33:21(chip_num:1)
x0
[main.cpp][Signal_handle: 00Cx2682x_module_init (dev_addr:0x88)(rev_id:0xffff)
000018]Signal_haKernel panic - not syncing: Fail to realize chip id 0xFFFF
ndle Children PrBacktrace: ocess Exit: 1077
172260
[DeviceG[<c002e8d4>] (dump_backtrace+0x0/0x110) from [<c028d068>] (dump_stack+0x18/0x1c)
pioI2c.cpp][Gpio r6:bf9e6898i2c_init: 000001 r5:0000000062]pCmd_line ins r4:c0376ef0mod /module/extd r3:c03601d4rv/DriverGpioI2c
.ko gpioi2c_bus_[<c028d050>] (dump_stack+0x0/0x1c) from [<c028d0c8>] (panic+0x5c/0x17c)
num=1 gpioi2c_sc[<c028d06c>] (panic+0x0/0x17c) from [<bf9ea1cc>] (Cx2682x_module_init+0x1cc/0x398 [DriverCx2682x])
l1_group=13 gpio r3:00006824i2c_scl1_bit=3 g r2:c03601f0pioi2c_sda1_grou r1:0000ffffp=13 gpioi2c_sda r0:bf9e63d81_bit=2
[main.c
pp][Signal_handl r7:00000000e: 00000018]Sign
al_handle Childr[<bf9ea000>] (Cx2682x_module_init+0x0/0x398 [DriverCx2682x]) from [<c00253b4>] (do_one_initcall+0xa0/0x170)
en Process Exit: r6:00000000 1077179896
[De r5:bf9ea000viceManage.cpp][ r4:bf9e6938Dm_init: 0000390
4]CDeviceManage:[<c0025314>] (do_one_initcall+0x0/0x170) from [<c00639a8>] (sys_init_module+0x7c/0x198)
:Dm_init NOT SUP r9:c4e64000PORT HARDWARE I2 r8:c002b1c8C
[DeviceManage r7:00011a7c.cpp][Dm_init: 0 r6:000000000003915]CDeviceM r5:00851060anage::Dm_init N
r4:bf9e6938OT SUPPORT At88s
c0104
[<c006392c>] (sys_init_module+0x0/0x198) from [<c002b020>] (ret_fast_syscall+0x0/0x30)
r7:00000080 r6:be9e2d44 r5:00000069 r4:be9e29d4
