Забыл пароль на китайский рег
Re: Забыл пароль на китайский рег
Что это? Нужно включить регистратор и с самого начала записывать лог и потом его куда-нибудь выложить. По окончанию загрузки попытаться получить доступ к консоли
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.04.12 15:42:12 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 2010.06 (May 26 2014 - 14:41:35)
NAND: Check nand flash controller v504. found
Special NAND id table Version 1.36
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
In: serial
Out: serial
Err: serial
(Re)start USB search...
USB: scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot: 1 0
saveaddr: 82000000
MAC: 00-00-23-34-45-66
JVUpd Start
OurPort: 3004
starting...
packet not correct: des: 137, our: 3004
time out resend: 0
after resend data
JVUpdTimeout When CMD_TRY
sf probe 0;sf read 0x86000000 0x60000 0x20000
vo 0,picwh:800 600, addr=9ff00000, xywh:0 0 800 600
vo 2,picwh:800 600, addr=9ff096a0, xywh:0 0 720 576
setenv jpeg_addr 0x86000004
setenv jpeg_size 0xcfd0
setenv vobuf 0x9ff00000
jpeg decoding ...
<<addr=0x86000004, size=0xcfd0, vobuf=0x9ff00000>>
mmu_enable
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg!
dev 0 opened!
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-3.4.35_hi3535
Data Size: 3503920 Bytes = 3.3 MiB
Load Address: 80008000
Entry Point: 80008000
## Loading init Ramdisk from Legacy Image at 82000000 ...
Image Name: RAM disk
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 2238946 Bytes = 2.1 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Booting Linux on physical CPU 0
Linux version 3.4.35_hi3535 (qy@bob-lfx) (gcc version 4.4.1 (Hisilicon_v200(gcc4.4-290+glibc-2.11+eabi+nptl)) ) #3 SMP Tue Apr 15 11:02:52 CST 2014
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3535
Truncating memory at 0x80000000 to fit in 32-bit physical address space
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c08c7000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 73914
Kernel command line: mem=291M console=ttyAMA0,115200 root=0100 rootfstype=ext2 logo_addr=9FF00000 mtdparts=hi_sfc:1M(boot),3584K(kernel),2560K(rootfs),7M(APP),2M(config) pcimod=host logo_w=800
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 291MB = 291MB total
Memory: 286340k/286340k available, 11644k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0xd2800000 - 0xff000000 ( 712 MB)
lowmem : 0xc0000000 - 0xd2300000 ( 291 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc05fc000 (6096 kB)
.init : 0xc05fc000 - 0xc0629980 ( 183 kB)
.data : 0xc062a000 - 0xc0659300 ( 189 kB)
.bss : 0xc0659324 - 0xc067a8dc ( 134 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:128
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
Initializing cgroup subsys freezer
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x804c55a0 - 0x804c55d4
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x72430001, Cache size: 262144 B
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3981.31 BogoMIPS).
update_logo 9
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
console [ttyAMA0] enabled
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
uart:3: ttyAMA3 at MMIO 0x200b0000 (irq = 43) is a PL011 rev2
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
Switching to clocksource timer0
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
update_logo 10
update_logo 11
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 2184K
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 563
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 3 ports 6 Gbps 0x7 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
scsi2 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x100 irq 63
ata2: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x180 irq 63
ata3: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x200 irq 63
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
5 cmdlinepart partitions found on MTD device hi_sfc
Creating 5 MTD partitions on "hi_sfc":
0x000000100000-0x000000480000 : "kernel"
0x000000480000-0x000000700000 : "rootfs"
0x000000700000-0x000000e00000 : "APP"
0x000000e00000-0x000001000000 : "config"
Found Nand Flash Controller V504.
hiusb-ehci hiusb-ehci.0: irq 54, io mem 0x10040000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 53, io mem 0x10030000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci-hcd hiusb3.0: xHCI Host Controller
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 3
xhci-hcd hiusb3.0: irq 64, io mem 0x12000000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
usbhid: USB HID core driver
TCP: cubic registered
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
usb 2-2: new low-speed USB device number 2 using hiusb-ohci
input: USB OPTICAL MOUSE as /devices/platform/hiusb-ohci.0/usb2/2-2/2-2:1.0/input/input0
generic-usb 00030007.0001: input: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-hiusb-ohci-2/input0
ata3: SATA link down (SStatus 0 SControl 300)
RAMDISK: gzip image found at block 0
update_logo 12
update_logo 13
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 180K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (550): /proc/550/oom_adj is deprecated, please use /proc/550/oom_score_adj instead.
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S81toe
STMMAC driver:
platform registration...
done!
Set system config register 0x200300ec with value 0x003f003f
done!
DWMAC1000 - user ID: 0x10, Synopsys ID: 0x36
Enhanced descriptor structure
MACADDR in get is 0:0:0:0:0:0
eth0 - (dev. name: stmmaceth - id: 0, IRQ #59
IO base addr: 0xfe0a0000)
STMMAC MII Bus: probed
eth0: PHY ID 001cc915 at 0 IRQ 0 (1:00)
eth0: PHY ID 001cc915 at 1 IRQ -6 (1:01) active
no valid MAC address for MAC 1;please, use ifconfig or nwhwconfig!
eth1 - (dev. name: stmmaceth - id: 0, IRQ #59
IO base addr: 0xfe0a4000)
eth1: PHY ID 001cc915 at 0 IRQ 0 (1:00)
eth1: PHY ID 001cc915 at 1 IRQ -6 (1:01)
stmmac_reset: RESET COMPLETE!
* TNK driver built on Jun 6 2014 at 15:07:29
* TNK driver mode is TOE
stmmac: Rx Checksum Offload Engine supported
update_logo 14
update_logo 15
hi3535_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3535...OK!
Load tde.ko ...OK!
load vgs.ko for Hi3535...OK!
load venc.ko for Hi3535...OK!
load chnl.ko for Hi3535...OK!
load h264e.ko for Hi3535...OK!
load rc.ko for Hi3535...OK!
load jpege.ko for Hi3535...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load hi3535_jpegd.ko success. (SDK_VERSION:[jpeg6bv1.0] Build Time:[Jul 8 2014, 09:08:18])
HISI_IRDA-MF @Hi3535V100R001
hiir: init ok. ver=Jun 10 2014, 16:36:59.
HDMI_1080P30
acodec inited!
setMac:E0:62:90:e0:6f:42
MACADDR in set is e0:62:90:e0:6f:42
have Network.cfg
192.168.1.173
255.255.255.0
192.168.1.1
0
run app!!
do you want to run app.out(y or n)?
NVR16,version:V1.0.1.3082, release time: Sep 24 2014, 14:37:55
onvif version: 2.4.1549
system: insmod /usr/ko_hi3535/extdrv/wdt.ko default_margin=120 nodeamon=Hisilicon Watchdog Timer: 0.01 initialized. default_margin=120 sec (nowayout= 0, nodeamon= 1)
1
system: insmod /usr/ko_hi3535/extdrv/wdt.ko default_margin=120 nodeamon=1, ret:0
y=2014,m=8,d=18
Set_Panel_Play_Light_clear_xm: enter
Є Set_Panel_Disk_Light_clear_xm: enter
Є Set_Panel_Disk1_Light_clear_xm: enter
Є Set_Panel__Light_clear_xm: enter
ЄC Set_Panel_Speed_Light_clear_xm: enter
ЄB Set_Panel_Suspend_Light_clear_xm: enter
ЄA Set_Panel_right1_Light_clear_xm: enter
Є Set_Panel_right2_Light_clear_xm: enter
Є Set_Panel_Time_xm: enter
Set_Panel_Time_xm: 00 00 00
Э 4 read netuser, index=0, gp.nNetUserCount=0
read netuser, index=1, gp.nNetUserCount=1
initchnmap: start=0,mode=9
_jvlive_thread==================================
chn map:0 1 2 3 4 5 6 7 8 -1 -1 -1 -1 -1 -1 -1
name=admin; passwd:428
name=admin; passwd:400
JVLive Starting...
"live0.264" stream, from the source "0"
Play this stream using the URL "rtsp://192.168.1.173:8854/live0.264"
"live1.264" stream, from the source "1"
Play this stream using the URL "rtsp://192.168.1.173:8854/live1.264"
"live2.264" stream, from the source "2"
Play this stream using the URL "rtsp://192.168.1.173:8854/live2.264"
"live3.264" stream, from the source "3"
Play this stream using the URL "rtsp://192.168.1.173:8854/live3.264"
"live4.264" stream, from the source "4"
Play this stream using the URL "rtsp://192.168.1.173:8854/live4.264"
"live5.264" stream, from the source "5"
Play this stream using the URL "rtsp://192.168.1.173:8854/live5.264"
"live6.264" stream, from the source "6"
Play this stream using the URL "rtsp://192.168.1.173:8854/live6.264"
"live7.264" stream, from the source "7"
Play this stream using the URL "rtsp://192.168.1.173:8854/live7.264"
"live8.264" stream, from the source "8"
Play this stream using the URL "rtsp://192.168.1.173:8854/live8.264"
"live9.264" stream, from the source "9"
Play this stream using the URL "rtsp://192.168.1.173:8854/live9.264"
"live10.264" stream, from the source "10"
Play this stream using the URL "rtsp://192.168.1.173:8854/live10.264"
"live11.264" stream, from the source "11"
Play this stream using the URL "rtsp://192.168.1.173:8854/live11.264"
"live12.264" stream, from the source "12"
Play this stream using the URL "rtsp://192.168.1.173:8854/live12.264"
"live13.264" stream, from the source "13"
Play this stream using the URL "rtsp://192.168.1.173:8854/live13.264"
"live14.264" stream, from the source "14"
Play this stream using the URL "rtsp://192.168.1.173:8854/live14.264"
"live15.264" stream, from the source "15"
Play this stream using the URL "rtsp://192.168.1.173:8854/live15.264"
"live16.264" stream, from the source "16"
Play this stream using the URL "rtsp://192.168.1.173:8854/live16.264"
"live17.264" stream, from the source "17"
Play this stream using the URL "rtsp://192.168.1.173:8854/live17.264"
"live18.264" stream, from the source "18"
Play this stream using the URL "rtsp://192.168.1.173:8854/live18.264"
"live19.264" stream, from the source "19"
Play this stream using the URL "rtsp://192.168.1.173:8854/live19.264"
"live20.264" stream, from the source "20"
Play this stream using the URL "rtsp://192.168.1.173:8854/live20.264"
"live21.264" stream, from the source "21"
Play this stream using the URL "rtsp://192.168.1.173:8854/live21.264"
"live22.264" stream, from the source "22"
Play this stream using the URL "rtsp://192.168.1.173:8854/live22.264"
"live23.264" stream, from the source "23"
Play this stream using the URL "rtsp://192.168.1.173:8854/live23.264"
"live24.264" stream, from the source "24"
Play this stream using the URL "rtsp://192.168.1.173:8854/live24.264"
"live25.264" stream, from the source "25"
Play this stream using the URL "rtsp://192.168.1.173:8854/live25.264"
"live26.264" stream, from the source "26"
Play this stream using the URL "rtsp://192.168.1.173:8854/live26.264"
"live27.264" stream, from the source "27"
Play this stream using the URL "rtsp://192.168.1.173:8854/live27.264"
"live28.264" stream, from the source "28"
Play this stream using the URL "rtsp://192.168.1.173:8854/live28.264"
"live29.264" stream, from the source "29"
Play this stream using the URL "rtsp://192.168.1.173:8854/live29.264"
"live30.264" stream, from the source "30"
Play this stream using the URL "rtsp://192.168.1.173:8854/live30.264"
"live31.264" stream, from the source "31"
Play this stream using the URL "rtsp://192.168.1.173:8854/live31.264"
SetSdRectParam,w=720,h=576
FUNC:JV_VIO_SetFrameRate,LINE:1211,failed! a00f804a
FUNC:JV_VIO_SetFrameRate,LINE:1216,failed! a00f804a
devMouse=/dev/mice,devPanel=/dev/jovi_keyPHY: 1:01 - Link is Up - 100/Full
,type=30,devRc=/dev/Hi_IR
PANEL_TYPE----->24,dev=/dev/ttyAMA3
init surface:hd osd
Resource size=4686256
load lang 7
success to load 1089 string
open: fail
open:res/popmenu-voColor.dat fail
open:res/popmenu-voColor-h.dat fail
open:res/popmenuview-view36.dat fail
open:res/popmenuview-view36-h.dat fail
jvclient************v2.0.76.1[private:v2.0.75.1 20140730.1]
./JVNC/CLanSerch.cpp:152..............new PingLanIpProc !
....start lanSerch return 1
....start BroadCastSvr return 1, strlen 0
Thread Func: _Run, pid: 960
system: sync;echo 3 > /proc/sys/vm/drop_caches
system: sync;echo 3 > /proc/sys/vm/drop_caches, ret:0
Thread Func: StartDdns, pid: 965
Ddns thread create
jvserver************v2.0.76.1[private:v2.0.75.1 20140730.1]
_StartTransmit===============7777
Start ie web server
system: /progs/bin/thttpd -d /progs/html/ -p 8030 -c "/cgi-bin/*" -u root -T utf-8&
system: /progs/bin/thttpd -d /progs/html/ -p 8030 -c "/cgi-bin/*" -u root -T utf-8&, ret:0
AddUdisk: can't find /dev/sda
AddUdisk: can't find /dev/sdb
AddUdisk: can't find /dev/sdc
AddUdisk: can't find /dev/sdd
AddUdisk: can't find /dev/sde
AddUdisk: can't find /dev/sdf
AddUdisk: can't find /dev/sdg
AddUdisk: can't find /dev/sdh
AddUdisk: can't find /dev/sdi
AddUdisk: can't find /dev/sdj
Thread Func: _TaldBackThread, pid: 1079
Thread Func: _ActiveYstThread, pid: 1078
disk init: nCurDisk=-1,nCurPart=-1
Thread Func: HotplugEventThread, pid: 1085
AEC_Init error framelen(320)
[Func]:MPI_AI_AecInit [Line]:369 [Info]:aec open fail.
[Func]:HI_MPI_AI_EnableAnr [Line]:1283 [Info]:AiDev: 0, anr should be 80 or 160 point per frm!
FUNC:_Ai_Start,LINE:222,failed!
Rec_UpdaterecBuf,old=0,new=1
-------Jmp4pkg date: 2014-09-17 Ver: 1.0.1.16
Thread Func: ThreadRecord, pid: 1086
Thread Func: _CheckRecordThread, pid: 1087
Thread Func: _WorkThread, pid: 1088
Thread Func: OnPtzPatrolThread, pid: 1089
Thread Func: OnAlmInDetectThread, pid: 1090
Thread Func: OnAlarmCheckStatus, pid: 1091
Thread Func: _AlarmQueueThread, pid: 1092
weber.running
debug#vs run
....................lanserdevice timeout;3000
YST Off Line!
yst search :result=0,timeout=3000,parm=0x3
onvif search,addr==NULL
timeout happened in discovery...
default onvif pass:admin 9999,manufacture=ONVIF,ip=192.168.1.20
default onvif pass:admin 9999,manufacture=ONVIF,ip=192.168.1.47
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.77
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.40
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.88
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.60
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.46
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.165
default onvif pass:admin 12345,manufacture=H264,ip=192.168.1.92
onvif search :result=9,timeout=3000,parm=0
destroy vs0, stream0, nPlayerID=-1,bOpenStream=0
ch0,nConnectStream=0
VSOP Disconnect ch0,ret=-4
destroy vs0, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.20,N17132515,bDestroy=1,ret=0
destroy vs3, stream0, nPlayerID=-1,bOpenStream=0
ch3,nConnectStream=0
VSOP Disconnect ch3,ret=-4
destroy vs3, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.47,N17132884,bDestroy=1,ret=3
destroy vs5, stream0, nPlayerID=-1,bOpenStream=0
ch5,nConnectStream=0
VSOP Disconnect ch5,ret=-4
destroy vs5, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.77,N307949582,bDestroy=1,ret=5
destroy vs1, stream0, nPlayerID=-1,bOpenStream=0
ch1,nConnectStream=0
VSOP Disconnect ch1,ret=-4
destroy vs1, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.40,N306397808,bDestroy=1,ret=1
destroy vs6, stream0, nPlayerID=-1,bOpenStream=0
ch6,nConnectStream=0
VSOP Disconnect ch6,ret=-4
destroy vs6, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.88,N304047300,bDestroy=1,ret=6
destroy vs4, stream0, nPlayerID=-1,bOpenStream=0
ch4,nConnectStream=0
VSOP Disconnect ch4,ret=-4
destroy vs4, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.60,N309527773,bDestroy=1,ret=4
destroy vs2, stream0, nPlayerID=-1,bOpenStream=0
ch2,nConnectStream=0
VSOP Disconnect ch2,ret=-4
destroy vs2, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.46,N306407044,bDestroy=1,ret=2
destroy vs8, stream0, nPlayerID=-1,bOpenStream=0
ch8,nConnectStream=0
VSOP Disconnect ch8,ret=-4
destroy vs8, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.165,N308842334,bDestroy=1,ret=8
destroy vs7, stream0, nPlayerID=-1,bOpenStream=0
ch7,nConnectStream=0
VSOP Disconnect ch7,ret=-4
destroy vs7, stream1, nPlayerID=-1,bOpenStream=0
Push onvif:ip=192.168.1.92,N304047528,bDestroy=1,ret=7
Check_To_start, connect:ch0,stream0,status=1,nConnectStream=0
!!!!!!http://192.168.1.20:85/onvif/Events_service
http://192.168.1.20:85/onvif/Imaging_service" onclick="window.open(this.href);return false;
http://192.168.1.20:85/onvif/Media_service" onclick="window.open(this.href);return false;
http://192.168.1.20:85/onvif/PTZ_service" onclick="window.open(this.href);return false;
http://192.168.1.20:85/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.20:85/onvif/Imaging_service
=http://192.168.1.20:85/onvif/Media_service
=0_VSC
=0_VEC_main
=0_main
[/home/SDK/onvif_testnewnew/nvc/OvfNvcVenc.cpp]:216 type=0,addr=,port=0,TTL=0,autostart=0,0
manufacture:ONVIF
_onvif_get_normal_setting,name=,position=0
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28d1a5c
VS_onvif_load_iamge_setting,nBrightness=128,nContrast=128,nSaturation=128,nSharpness=0
_Onvif_Connect, ch0, dev=0x28d18e0, acId=admin,pw=9999,ret=0
VSOP Connect ch0,ret=0
get onvif stream setting:maxW=2592,maxH=1920,maxFr=30
add info:0x1cbac30,linkid=1
rtsp run,linkID=1,info=0x1cbac30,rtsp_client=0x28c7040
add socket:8a, at0
_Onvif_StartStream, ch0,ret=0
StartStream Result:i0,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch0 stream0,ret=0
Check_To_start, connect:ch0,stream1,status=1,nConnectStream=1
get onvif stream setting:maxW=704,maxH=576,maxFr=30
StartStream Result:i0,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch0 stream1,ret=0
Check_To_start, connect:ch1,stream0,status=1,nConnectStream=0
!!!!!!http://192.168.1.40:8899/onvif/Events
http://192.168.1.40:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.40:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.40:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.40:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.40:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.40:8899/onvif/imaging
=http://192.168.1.40:8899/onvif/Media
=000
=000
=000
[/home/SDK/onvif_testnewnew/nvc/OvfNvcVenc.cpp]:216 type=0,addr=224.1.2.3,port=0,TTL=0,autostart=0,0
manufacture:H264
ch1 startRec,euStatus Error:1:1
ch2 startRec,euStatus Error:1:1
ch3 startRec,euStatus Error:1:1
ch4 startRec,euStatus Error:1:1
ch5 startRec,euStatus Error:1:1
ch6 startRec,euStatus Error:1:1
ch7 startRec,euStatus Error:1:1
ch8 startRec,euStatus Error:1:1
_onvif_get_normal_setting,name=NVT,position=0
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28c9004
VS_onvif_load_iamge_setting,nBrightness=128,nContrast=128,nSaturation=128,nSharpness=136
_Onvif_Connect, ch1, dev=0x28c8e88, acId=admin,pw=12345,ret=0
VSOP Connect ch1,ret=0
get onvif stream setting:maxW=1920,maxH=1080,maxFr=25
_Onvif_StartStream, ch1,ret=0
StartStream Result:i1,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch1 stream0,ret=0
Check_To_start, connect:ch1,stream1,status=1,nConnectStream=1
get onvif stream setting:maxW=704,maxH=576,maxFr=25
StartStream Result:i1,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch1 stream1,ret=0
Check_To_start, connect:ch2,stream0,status=1,nConnectStream=0
!!!!!!http://192.168.1.46:8899/onvif/Events
http://192.168.1.46:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.46:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.46:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.46:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.46:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.46:8899/onvif/imaging
=http://192.168.1.46:8899/onvif/Media
=000
=000
=000
Illegal character in NPT string n
Couldn't decode range from npt now-
open ok
play good
add info:0x1cbacb8,linkid=2
rtsp run,linkID=2,info=0x1cbacb8,rtsp_client=0x2921728
add socket:82, at1
manufacture:H264
open ok
play good
add info:0x1cbad40,linkid=3
rtsp run,linkID=3,info=0x1cbad40,rtsp_client=0x287af30
add socket:8d, at2
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28cb634
Not processing response header: x-Accept-Retransmit: our-retransmit
Not processing response header: x-Accept-Dynamic-Rate: 1
Garbage at end of frame rate `S'
Not processing response header: x-Dynamic-Rate: 1
open ok
_Onvif_Connect, ch2, dev=0x28cb4b8, acId=admin,pw=12345,ret=0
VSOP Connect ch2,ret=0
[/home/SDK/onvif_testnewnew/nvc/OvfNvcStream.cpp]:334 info.mediaName: video
===PlayByLinkID===,get data O, chn:0, stream:1, W:176, H:144,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i0,j1,len=17449,wh=1280X720,176X144
Create play chn, chn:0, stream:1
TestPayload, cur:0, want:37, max:1312
Vdec_CreateChn:0, cur:0, want:1, max:400,w=176,h=144
creatchn return------------->0=====================w176,,,h144
_CreatePlayChn,i0,j1,ret=0,bOpenStream=1
play good
_Onvif_StartStream, ch2,ret=0
StartStream Result:i2,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
add info:0x1cbadc8,linkid=4
VSOP StartStream ch2 stream0,ret=0
Check_To_start, connect:ch2,stream1,status=1,nConnectStream=1
rtsp run,linkID=4,info=0x1cbadc8,rtsp_client=0x290c068
add socket:97, at3
StartStream Result:i2,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch2 stream1,ret=0
Check_To_start, connect:ch3,stream0,status=1,nConnectStream=0
open ok
===PlayByLinkID===,get data O, chn:0, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
play good
add info:0x1cbae50,linkid=5
rtsp run,linkID=5,info=0x1cbae50,rtsp_client=0x29150e0
add socket:7f, at4
===PlayByLinkID===,get data O, chn:1, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
open ok
play good
add info:0x1cbaed8,linkid=6
rtsp run,linkID=6,info=0x1cbaed8,rtsp_client=0x2916150
add socket:99, at5
!!!!!!http://192.168.1.47:85/onvif/Events_service
http://192.168.1.47:85/onvif/Imaging_service" onclick="window.open(this.href);return false;
http://192.168.1.47:85/onvif/Media_service" onclick="window.open(this.href);return false;
http://192.168.1.47:85/onvif/PTZ_service" onclick="window.open(this.href);return false;
http://192.168.1.47:85/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.47:85/onvif/Imaging_service
=http://192.168.1.47:85/onvif/Media_service
=0_VSC
=0_VEC_main
=0_main
open ok
manufacture:ONVIF
===PlayByLinkID===,get data O, chn:2, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28cf4bc
_Onvif_Connect, ch3, dev=0x28cf340, acId=admin,pw=9999,ret=0
VSOP Connect ch3,ret=0
play good
add info:0x1cbaf60,linkid=7
rtsp run,linkID=7,info=0x1cbaf60,rtsp_client=0x2917c08
add socket:98, at6
===PlayByLinkID===,get data O, chn:1, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i1,j1,len=33473,wh=1280X720,704X576
Create play chn, chn:1, stream:1
TestPayload, cur:37, want:37, max:1312
Vdec_CreateChn:1, cur:1, want:16, max:400,w=704,h=576
creatchn return------------->0=====================w704,,,h576
_CreatePlayChn,i1,j1,ret=0,bOpenStream=1
_Onvif_StartStream, ch3,ret=0
StartStream Result:i3,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch3 stream0,ret=0
Check_To_start, connect:ch3,stream1,status=1,nConnectStream=1
open ok
StartStream Result:i3,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch3 stream1,ret=0
play good
add info:0x1cbafe8,linkid=8
rtsp run,linkID=8,info=0x1cbafe8,rtsp_client=0x29327a8
add socket:9b, at7
open ok
play good
Check_To_start, connect:ch4,stream0,status=1,nConnectStream=0
===PlayByLinkID===,get data O, chn:3, stream:1, W:352, H:288,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i3,j1,len=30858,wh=1280X720,352X288
Create play chn, chn:3, stream:1
TestPayload, cur:74, want:37, max:1312
Vdec_CreateChn:3, cur:17, want:4, max:400,w=352,h=288
creatchn return------------->0=====================w352,,,h288
_CreatePlayChn,i3,j1,ret=0,bOpenStream=1
!!!!!!http://192.168.1.60:8899/onvif/Events
http://192.168.1.60:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.60:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.60:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.60:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.60:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.60:8899/onvif/imaging
=http://192.168.1.60:8899/onvif/Media
=000
=000
=000
===PlayByLinkID===,get data O, chn:2, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i2,j1,len=59537,wh=1280X720,704X576
Create play chn, chn:2, stream:1
TestPayload, cur:111, want:37, max:1312
Vdec_CreateChn:2, cur:21, want:16, max:400,w=704,h=576
_CreatePlayChn,i2,j1,ret=0,bOpenStream=1
===PlayByLinkID===,get data O, chn:3, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
manufacture:H264
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28cc0cc
_Onvif_Connect, ch4, dev=0x28cbf50, acId=admin,pw=12345,ret=0
VSOP Connect ch4,ret=0
_Onvif_StartStream, ch4,ret=0
StartStream Result:i4,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch4 stream0,ret=0
Check_To_start, connect:ch4,stream1,status=1,nConnectStream=1
add info:0x1cbb070,linkid=9
rtsp run,linkID=9,info=0x1cbb070,rtsp_client=0x293b820
add socket:7e, at8
StartStream Result:i4,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch4 stream1,ret=0
Check_To_start, connect:ch5,stream0,status=1,nConnectStream=0
open ok
play good
add info:0x1cbb0f8,linkid=10
rtsp run,linkID=10,info=0x1cbb0f8,rtsp_client=0x2944898
add socket:9f, at9
!!!!!!http://192.168.1.77:8899/onvif/Events
http://192.168.1.77:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.77:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.77:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.77:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.77:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.77:8899/onvif/imaging
=http://192.168.1.77:8899/onvif/Media
=000
=000
=000
open ok
===PlayByLinkID===,get data O, chn:4, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
play good
===PlayByLinkID===,get data O, chn:4, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i4,j1,len=59753,wh=1280X720,704X576
Create play chn, chn:4, stream:1
TestPayload, cur:148, want:37, max:1312
Vdec_CreateChn:4, cur:37, want:16, max:400,w=704,h=576
_CreatePlayChn,i4,j1,ret=0,bOpenStream=1
manufacture:H264
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28c9c04
_Onvif_Connect, ch5, dev=0x28c9a88, acId=admin,pw=12345,ret=0
VSOP Connect ch5,ret=0
_Onvif_StartStream, ch5,ret=0
StartStream Result:i5,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch5 stream0,ret=0
Check_To_start, connect:ch5,stream1,status=1,nConnectStream=1
add info:0x1cbb180,linkid=11
rtsp run,linkID=11,info=0x1cbb180,rtsp_client=0x2946838
add socket:9c, at10
open ok
StartStream Result:i5,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch5 stream1,ret=0
Check_To_start, connect:ch6,stream0,status=1,nConnectStream=0
play good
add info:0x1cbb208,linkid=12
rtsp run,linkID=12,info=0x1cbb208,rtsp_client=0x29478a8
add socket:a2, at11
!!!!!!http://192.168.1.88:8899/onvif/Events
http://192.168.1.88:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.88:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.88:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.88:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.88:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.88:8899/onvif/imaging
=http://192.168.1.88:8899/onvif/Media
=000
=000
=000
open ok
===PlayByLinkID===,get data O, chn:5, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
play good
===PlayByLinkID===,get data O, chn:5, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i5,j1,len=36865,wh=1280X720,704X576
Create play chn, chn:5, stream:1
TestPayload, cur:185, want:37, max:1312
Vdec_CreateChn:5, cur:53, want:16, max:400,w=704,h=576
_CreatePlayChn,i5,j1,ret=0,bOpenStream=1
manufacture:H264
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28ca7f4
_Onvif_Connect, ch6, dev=0x28ca678, acId=admin,pw=12345,ret=0
VSOP Connect ch6,ret=0
get onvif stream setting:maxW=1280,maxH=720,maxFr=25
_Onvif_StartStream, ch6,ret=0
StartStream Result:i6,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch6 stream0,ret=0
Check_To_start, connect:ch6,stream1,status=1,nConnectStream=1
add info:0x1cbb290,linkid=13
rtsp run,linkID=13,info=0x1cbb290,rtsp_client=0x2980828
add socket:a1, at12
StartStream Result:i6,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch6 stream1,ret=0
Check_To_start, connect:ch7,stream0,status=1,nConnectStream=0
open ok
play good
add info:0x1cbb318,linkid=14
rtsp run,linkID=14,info=0x1cbb318,rtsp_client=0x2981898
add socket:a5, at13
!!!!!!http://192.168.1.92:8899/onvif/Events
http://192.168.1.92:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.92:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.92:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.92:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.92:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.92:8899/onvif/imaging
=http://192.168.1.92:8899/onvif/Media
=000
=000
=000
open ok
manufacture:H264
===PlayByLinkID===,get data O, chn:6, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
play good
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28a987c
[/home/SDK/onvif_testnewnew/nvc/OvfNvcChannel.cpp]:139 soap error: 0, errnum: 0, SOAP-ENV:Sender, Method 'timg:GetOptions' not implemented: method name or namespace not recognized,ret =1
===PlayByLinkID===,get data O, chn:6, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i6,j1,len=78243,wh=1280X720,704X576
Create play chn, chn:6, stream:1
TestPayload, cur:222, want:37, max:1312
Vdec_CreateChn:6, cur:69, want:16, max:400,w=704,h=576
_CreatePlayChn,i6,j1,ret=0,bOpenStream=1
[/home/SDK/onvif_testnewnew/nvc/OvfNvcChannel.cpp]:57 soap error: 0, errnum: 0, SOAP-ENV:Sender, Method 'timg:GetImagingSettings' not implemented: method name or namespace not recognized,ret =1
_Onvif_Connect, ch7, dev=0x28a9700, acId=admin,pw=12345,ret=0
VSOP Connect ch7,ret=0
_Onvif_StartStream, ch7,ret=0
StartStream Result:i7,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch7 stream0,ret=0
Check_To_start, connect:ch7,stream1,status=1,nConnectStream=1
add info:0x1cbb3a0,linkid=15
rtsp run,linkID=15,info=0x1cbb3a0,rtsp_client=0x29846a8
add socket:a4, at14
StartStream Result:i7,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch7 stream1,ret=0
open ok
play good
add info:0x1cbb428,linkid=16
Check_To_start, connect:ch8,stream0,status=1,nConnectStream=0
rtsp run,linkID=16,info=0x1cbb428,rtsp_client=0x294ae78
add socket:a7, at15
===PlayByLinkID===,get data O, chn:7, stream:0, W:1280, H:720,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
open ok
play good
===PlayByLinkID===,get data O, chn:7, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i7,j1,len=65279,wh=1280X720,704X576
Create play chn, chn:7, stream:1
TestPayload, cur:259, want:37, max:1312
Vdec_CreateChn:7, cur:85, want:16, max:400,w=704,h=576
_CreatePlayChn,i7,j1,ret=0,bOpenStream=1
!!!!!!http://192.168.1.165:8899/onvif/Events
http://192.168.1.165:8899/onvif/imaging" onclick="window.open(this.href);return false;
http://192.168.1.165:8899/onvif/Media" onclick="window.open(this.href);return false;
http://192.168.1.165:8899/onvif/analytics_service" onclick="window.open(this.href);return false;
http://192.168.1.165:8899/onvif/PTZ" onclick="window.open(this.href);return false;
http://192.168.1.165:8899/onvif/device_service" onclick="window.open(this.href);return false;
token!!!!!!=http://192.168.1.165:8899/onvif/imaging
=http://192.168.1.165:8899/onvif/Media
=000
=000
=000
manufacture:H264
VS_onvif_load_iamge_setting,NSDev_Capabilities=0x28cc73c
_Onvif_Connect, ch8, dev=0x28cc5c0, acId=admin,pw=12345,ret=0
VSOP Connect ch8,ret=0
get onvif stream setting:maxW=1280,maxH=960,maxFr=25
_Onvif_StartStream, ch8,ret=0
StartStream Result:i8,j0,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch8 stream0,ret=0
Check_To_start, connect:ch8,stream1,status=1,nConnectStream=1
add info:0x1cbb4b0,linkid=17
rtsp run,linkID=17,info=0x1cbb4b0,rtsp_client=0x294d2f0
add socket:a8, at16
StartStream Result:i8,j1,status=3, vs:status=2,playStream=-1,bOpenStream=0
VSOP StartStream ch8 stream1,ret=0
open ok
play good
add info:0x1cbb538,linkid=18
rtsp run,linkID=18,info=0x1cbb538,rtsp_client=0x294e360
add socket:aa, at17
open ok
===PlayByLinkID===,get data O, chn:8, stream:0, W:1280, H:960,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
play good
===PlayByLinkID===,get data O, chn:8, stream:1, W:704, H:576,total:0,vformat:0,nFrameRates:0,nFlag:1053564a
vs fr=0,ext fr:0/0
====OnNormalData:i8,j1,len=51794,wh=1280X960,704X576
Create play chn, chn:8, stream:1
TestPayload, cur:296, want:49, max:1312
Vdec_CreateChn:8, cur:101, want:16, max:400,w=704,h=576
_CreatePlayChn,i8,j1,ret=0,bOpenStream=1
YST On Line!
Set_Panel_right2_Light_on_xm: enter
system: killall msntp; ./bin/msntp -ra 1 -P no time.nist.gov && hwclock -w -u
killall: msntp: no process killed
ch0,IPsecTime=1,sec=2~254
ch1,IPsecTime=1,sec=2~254
action,ch=0,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
time diff=2a30,timezone0=2a30,zone8=4650
VSOP SetTime,ch0,stream0,2017-4-12 14:42:48
action,ch=1,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
time diff=0,timezone0=2a30,zone8=4650
VSOP SetTime,ch1,stream0,2017-4-12 14:42:48
ch2,IPsecTime=1,sec=2~254
ch3,IPsecTime=1,sec=2~254
action,ch=2,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
VSOP SetTime,ch2,stream0,2017-4-12 14:42:49
action,ch=3,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
VSOP SetTime,ch3,stream0,2017-4-12 14:42:49
ch4,IPsecTime=1,sec=2~254
action,ch=4,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
VSOP SetTime,ch4,stream0,2017-4-12 14:42:50
ch5,IPsecTime=1,sec=2~254
action,ch=5,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
ch6,IPsecTime=1,sec=2~254
ch7,IPsecTime=1,sec=2~254
time diff=2,timezone0=2a30,zone8=4650
VSOP SetTime,ch5,stream0,2017-4-12 14:42:51
action,ch=6,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
VSOP SetTime,ch6,stream0,2017-4-12 14:42:53
action,ch=7,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
time diff=4650,timezone0=2a30,zone8=4650
VSOP SetTime,ch7,stream0,2017-4-12 14:42:53
ch8,IPsecTime=1,sec=2~254
action,ch=8,bIPSection=0,sec=2~254,bLock=0,bName=0,bTime=1
VSOP SetTime,ch8,stream0,2017-4-12 14:42:55
msntp: not enough valid responses received in time
system: killall msntp; ./bin/msntp -ra 1 -P no time.nist.gov && hwclock -w -u, ret:256
set all ipc time :2017-4-12 14:43:2,bTimeSetted=1,bntp=0,timezone=3,daylight=0
VSOP SetTime,ch0,stream1,2017-4-12 14:43:2
VSOP SetTime,ch1,stream1,2017-4-12 14:43:2
VSOP SetTime,ch2,stream1,2017-4-12 14:43:2
VSOP SetTime,ch3,stream1,2017-4-12 14:43:2
VSOP SetTime,ch4,stream1,2017-4-12 14:43:2
VSOP SetTime,ch5,stream1,2017-4-12 14:43:2
VSOP SetTime,ch6,stream1,2017-4-12 14:43:2
VSOP SetTime,ch7,stream1,2017-4-12 14:43:2
VSOP SetTime,ch8,stream1,2017-4-12 14:43:2
Set_Panel_Time_xm: 0e 2b 0a
in OnCreateLoginWin
name=admin,pLast[0]=61,pLast=admin
Get Unicode(0x0) section err
0 MiB
In: serial
Out: serial
Err: serial
saveaddr: 82000000
JVUpd Start
OurPort: 3004
starting...
time out resend: 0
after resend data
jpeg decoding ...
mmu_enable
decode success!!!!
decode jpeg!
dev 0 opened!
OK
Starting kernel ...
Machine: hi3535
NR_IRQS:128
Brought up 2 CPUs
update_logo 9
vgaarb: loaded
update_logo 10
update_logo 11
brd: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
update_logo 12
update_logo 13
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
STMMAC driver:
done!
done!
update_logo 14
update_logo 15
Load tde.ko ...OK!
load vou.ko ....OK!
load vda.ko ....OK!
load vdec.ko ....OK
HDMI_1080P30
acodec inited!
have Network.cfg
192.168.1.173
255.255.255.0
192.168.1.1
0
run app!!
1
y=2014,m=8,d=18
JVLive Starting...
init surface:hd osd
load lang 7
open: fail
Ddns thread create
Start ie web server
weber.running
debug#vs run
YST Off Line!
=0_VSC
=0_VEC_main
=0_main
manufacture:ONVIF
add socket:8a, at0
=000
=000
=000
manufacture:H264
=000
=000
=000
open ok
play good
add socket:82, at1
manufacture:H264
open ok
play good
add socket:8d, at2
open ok
vs fr=0,ext fr:0/0
play good
add socket:97, at3
open ok
vs fr=0,ext fr:0/0
play good
add socket:7f, at4
vs fr=0,ext fr:0/0
open ok
play good
add socket:99, at5
=0_VSC
=0_VEC_main
=0_main
open ok
manufacture:ONVIF
vs fr=0,ext fr:0/0
play good
add socket:98, at6
vs fr=0,ext fr:0/0
open ok
play good
add socket:9b, at7
open ok
play good
vs fr=0,ext fr:0/0
=000
=000
=000
vs fr=0,ext fr:0/0
vs fr=0,ext fr:0/0
manufacture:H264
add socket:7e, at8
open ok
play good
add socket:9f, at9
=000
=000
=000
open ok
vs fr=0,ext fr:0/0
play good
vs fr=0,ext fr:0/0
manufacture:H264
add socket:9c, at10
open ok
play good
add socket:a2, at11
=000
=000
=000
open ok
vs fr=0,ext fr:0/0
play good
vs fr=0,ext fr:0/0
manufacture:H264
add socket:a1, at12
open ok
play good
add socket:a5, at13
=000
=000
=000
open ok
manufacture:H264
vs fr=0,ext fr:0/0
play good
vs fr=0,ext fr:0/0
add socket:a4, at14
open ok
play good
add socket:a7, at15
vs fr=0,ext fr:0/0
open ok
play good
vs fr=0,ext fr:0/0
=000
=000
=000
manufacture:H264
add socket:a8, at16
open ok
play good
add socket:aa, at17
open ok
vs fr=0,ext fr:0/0
play good
vs fr=0,ext fr:0/0
YST On Line!
in OnCreateLoginWin
из uboot
help
printenv
base
help
printenv
base
help
cmd list and help information
help display help information
jump jump to the pointed addr and run
mem memory display or set
system system cmd
account account operation cmd
yst yst operation command
ptz ptz operation command
multimedia multimedia operation command
reboot reboot operation cmd
debug#printenv
cmd not found.[printenv]
printenv
debug#base
cmd not found.[base]
base
debug#system printenw
CMD: [printenw ]
system: printenw
sh: printenw: not found
system: printenw , ret:32512
debug#system base
CMD: [base ]
system: base
sh: base: not found
system: base , ret:32512
debug#
system system cmd
debug#printenv
printenv
debug#base
base
CMD: [printenw ]
system: printenw
debug#system base
CMD: [base ]
system: base
sh: base: not found
debug#
Хорошо, это не uboot , это уже консоль
пробуйте
system mount
system cat /proc/partitions
пробуйте
system mount
system mount
CMD: [mount ]
system: mount
rootfs on / type rootfs (rw)
/dev/root on / type ext2 (rw,relatime,errors=continue)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /dev type tmpfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock4 on /etc/conf.d type jffs2 (rw,relatime)
/dev/mtdblock3 on /progs type squashfs (ro,relatime)
system: mount , ret:0
debug#system cat /proc/patritions
CMD: [cat /proc/patritions ]
system: cat /proc/patritions
cat: can't open '/proc/patritions': No such file or directory
system: cat /proc/patritions , ret:256
debug#
CMD: [mount ]
system: mount
debug#
system ls /etc/conf.d
P.S. Вы невнимательно команды вводите
debug#system ls /etc/conf.d
CMD: [ls /etc/conf.d ]
system: ls /etc/conf.d
JVS_DBG_LOG jovision oem rec
system: ls /etc/conf.d , ret:0
debug#
debug#
system ls /etc/conf.d/jovision
system ls /etc/conf.d/oem
system ls /etc/conf.d/rec
CMD: [ls /etc/conf.d/jovision ]
system: ls /etc/conf.d/jovision
JdvrCfg.ini Language.cfg version.bin ystnum.ini
JdvrMailInfo.dat Network.cfg yst-home.dat
JdvrUser.dat jdvr.log yst-pos.dat
system: ls /etc/conf.d/jovision , ret:0
debug#system ls /etc/conf.d/oem
CMD: [ls /etc/conf.d/oem ]
system: ls /etc/conf.d/oem
system: ls /etc/conf.d/oem , ret:0
debug#system ls /etc/conf.d/rec
CMD: [ls /etc/conf.d/rec ]
system: ls /etc/conf.d/rec
00 01 02 03 04 05 06 07 08 09
system: ls /etc/conf.d/rec , ret:0
debug#
debug#
system rm /etc/conf.d/jovision/JdvrUser.dat
потом перезагрузка и пробуйте со стандартным паролем
debug#system rm /etc/conf.d/jovision/jdrvuser.dat
CMD: [rm /etc/conf.d/jovision/jdrvuser.dat ]
system: rm /etc/conf.d/jovision/jdrvuser.dat
rm: can't remove '/etc/conf.d/jovision/jdrvuser.dat': No such file or directory
system: rm /etc/conf.d/jovision/jdrvuser.dat , ret:256
debug#
debug#
