Поломал Techege 8ch на модуле якобы NBD7808T-PL
Re: Поломал Techege 8ch на модуле якобы NBD7808T-PL
hisilicon # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
decjpg - jpgd - decode jpeg picture.
fload - fload - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
lload - lload - load logo file
logoload- logoload - load binary file from a filesystem image for system boot
md - memory display
mii - MII utility commands
mw - memory write (fill)
setvobg - setvobg - set vo backgroud color.
- setvobg [dev color]
sf - SPI flash sub-system
squashfsload- fsload - load binary file from a filesystem image
startgx - startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - startvo - open interface of vo device.
- startvo [dev type sync]
stopgx - stopgx - close graphics layer.
- stopgx [layer]
stopvo - stopvo - close interface of vo device.
- stopvo [dev]
usb - USB sub-system
в env типа как записывает, но после перезагрузки ничего там нет
hisilicon # setenv test test
hisilicon # saveenv
Saving Environment to SPI Flash...
Erasing SPI flash, offset 0x00020000 size 64K ...done
Writing to SPI flash, offset 0x00020000 size 64K ...done
hisilicon # print
bootcmd=sf probe 0;sf read 84000000 770000 10000;logoload 84000000;decjpg;sf read 82000000 30000 400000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=132M console=ttyAMA0,115200 root=1f01 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),1984K(romfs),3776K(usr),1664K(custom),64K(logo),512K(mtd)
appVideoStandard=PAL
appSystemLanguage=Russian
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn342 (Jan 20 2016 - 10:18:45)
test=test
Environment size: 1353/65532 bytes
hisilicon # reset
resetting ...
Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"
Set lock level: 2, start of bottom address
Spi is locked. lock address[0x0 => 0x20000]
envcrc 0x74a780e
ENV_SIZE = 0xfffc
In: serial
Out: serial
Err: serial
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
Press CTRL-C to abort autoboot in 0 secondshisilicon # print
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
ipaddr=192.168.1.10
stdin=serial
stdout=serial
stderr=serial
verify=n
Environment size: 1343/65532 bytes
hisilicon #
cp - memory copy
md - memory display
- stopgx [layer]
- stopvo [dev]
hisilicon # saveenv
hisilicon # print
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
ipaddr=192.168.1.10
stdin=serial
stdout=serial
stderr=serial
verify=n
test=test
hisilicon # reset
resetting ...
envcrc 0x74a780e
ENV_SIZE = 0xfffc
In: serial
Out: serial
Err: serial
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
ipaddr=192.168.1.10
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
Да, лок стоит на сам бут, но енв у него почему-то тоже не сохраняется, пробовали ж уже. и чтение оттуда выдаёт мусор.
Посмотрите на sf , может help sf , нет ли там lock/unlock
гугление на тему u-boot sf lock
дает, некое пояснение на эту тему
http://u-boot.10912.n7.nabble.com/PATCH ... 33141.html" onclick="window.open(this.href);return false;
т.е. в вашем случае можно попробовать следующее:
Код: Выделить всё
Many SPI flashes have protection bits (BP2, BP1 and BP0) in the
status register that can protect selected regions of the SPI NOR.
Take these bits into account when performing erase operations,
making sure that the protected areas are skipped.
Tested on a mx6qsabresd:
=> sf probe
SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB
=> sf protect lock 0x3f0000 0x10000
=> sf erase 0x3f0000 0x10000
offset 0x3f0000 is protected and cannot be erased
SF: 65536 bytes @ 0x3f0000 Erased: ERROR
=> sf protect unlock 0x3f0000 0x10000
SF: 65536 bytes @ 0x3f0000 Erased: OK
Код: Выделить всё
sf probe 0
sf protect unlock 0x20000 0x10000
sf erase 0x20000 0x10000
также там написано про механизм защиты
из которого как будто следует, что защита накладывается блоками 0,128к,256к,512к,1М,2М,4М и 8М
первые 128к - это и есть 0х20000 область U-boot
Но если кетайцы ошиблись раскладкой битов, то может быть оказаться защищена область в 256К, это и есть область ENV и еще плюсом 0х10000 байт, т.е. область 0 - 0х40000, т.е. начало области rom-fs.
это все лишь мои предположения, которые как-то объясняют причину не стирания ENV и ошибки при попытке записать ядро от другой прошивки
если что можно попробовать разлочить верхние 0х40000 байт
Код: Выделить всё
+ * Lock a region of the flash. Compatible with ST Micro and similar flash.
+ * Supports only the block protection bits BP{0,1,2} in the status register
+ * (SR). Does not support these features found in newer SR bitfields:
+ * - TB: top/bottom protect - only handle TB=0 (top protect)
+ * - SEC: sector/block protect - only handle SEC=0 (block protect)
+ * - CMP: complement protect - only support CMP=0 (range is not complemented)
+ * Sample table portion for 8MB flash (Winbond w25q64fw):
+ * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion
+ * X | X | 0 | 0 | 0 | NONE | NONE
+ * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64
+ * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32
+ * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16
+ * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8
+ * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4
+ * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2
+ * X | X | 1 | 1 | 1 | 8 MB | ALL
Код: Выделить всё
srcAddr 0x82000000, dstAddr 0x82000000
Input is not in the XZ format (wrong magic bytes)xz_wrapper.c[unxz]:94
xz uncompress failed with error code 5
read_block: failed to read block @0xffffffffffffffff
Код: Выделить всё
sf probe 0
sf protect unlock 0x00000 0x40000
Фрагмент загрузки NBD7804T-F
Фрагмент загрузки NBD7808T-PL
Код: Выделить всё
Spi id table Version 1.22
Hisilicon Spi Flash Controller V350 Device Driver, Version 1.10
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
6 cmdlinepart partitions found on MTD device hi_sfc
Creating 6 MTD partitions on "hi_sfc":
0x000000000000-0x000000030000 : "boot"
0x000000030000-0x000000220000 : "romfs"
0x000000220000-0x0000005d0000 : "usr"
0x0000005d0000-0x000000770000 : "custom"
0x000000770000-0x000000780000 : "logo"
0x000000780000-0x000000800000 : "mtd"
Fixed MDIO Bus: probed
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-7: GB0500EAFJH, HPG8, max UDMA/133
ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA GB0500EAFJH HPG8 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sd 0:0:0:0: Attached scsi generic sg0 type 0
Код: Выделить всё
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
Read MXIC configR:status[0x0] [0x2]
* Set BP bottom level 2 start.
Read CR:SR[0x2] 0 0
Set DATABUF0[0x400]0x80a
Set INS[0x308]0x1
Set CONFIG[0x300]0x283
* Set BP level end.
Read cmp:level 0 0 MX25L6406E
ata1.00: ATA-8: WDC WD10EALX-009BA0, 15.01H15, max UDMA/133
ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
scsi 0:0:0:0: Direct-Access ATA WDC WD10EALX-009 15.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: unknown partition table
Не, шибко заколдован, видимо как в анекдоте отсасать надо, не дается env, а если попробовать env от другой коробки прошить?
Код: Выделить всё
envcrc 0x74a780e
ENV_SIZE = 0xfffc
In: serial
Out: serial
Err: serial
hisilicon # sf probe 0
hisilicon # sf protect unlock 0x00000 0x40000
hisilicon # sf erase 0x20000 0x10000
Erasing at 0x30000 -- 100% complete.
hisilicon # saveenv
hisilicon # print
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
ipaddr=192.168.1.10
stdin=serial
stdout=serial
stderr=serial
verify=n
test=test
hisilicon # reset
resetting ...
envcrc 0x74a780e
ENV_SIZE = 0xfffc
In: serial
Out: serial
Err: serial
hisilicon # print
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
ipaddr=192.168.1.10
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
Как вы прошьете от другой, если запись не работает в эту область?
Есть иной вариант, делаете setenv, какой вам там нужно было, а потом boot или run bootcmd и он загрузится, и потом может сам уже сможет поменять
пришлите в личку полный бэкап всей флеш памяти, в личку
посмотреть надо, что у вас.
А вообще надо копать в сторону, как в u-boot снять корректно protect.
Как я понял сделать
тоже пробовали?
Как я понял сделать
Код: Выделить всё
sf probe 0
Пробовал,
сейчас еще отследил откуда начинает стирать команда
так вот по какойто причине начинает стирать с 0x50000
Код: Выделить всё
hisilicon # sf protect unlock 0x20000 0x10000
hisilicon #
Код: Выделить всё
sf probe 0
sf erase 0x20000 0x7E0000
И как то странно дамп снимается, это после стирания
Код: Выделить всё
hisilicon # <INTERRUPT>
hisilicon # sf read 0x82000000 0x0000000 0x800000
hisilicon # tftp 0x82000000 fw3.img 0x800000
Hisilicon ETH net controler
MAC: 00-0B-3F-00-00-01
TFTP to server 192.168.1.1; our IP address is 192.168.1.10
Upload Filename 'fw3.img'.
Upload from address: 0x82000000, 8.000 MB to be send ...
Uploading: # [ Connected ]
################################ [ 1.000 MB]
################################ [ 2.000 MB]
################################ [ 3.000 MB]
################################ [ 4.000 MB]
############################%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%# [ 5.000 MB]
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#[ 6.000 MB]
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#[ 7.000 MB]
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%# [ 8.000 MB]
8.000 MB upload ok.
А вот после прошивки
Код: Выделить всё
hisilicon # tftp 0x82000000 fw4.img 0x800000
Upload Filename 'fw4.img'.
8.000 MB upload ok.
hisilicon #
точней с 0x40000 видимо просто очень быстро 4 проскакивает и это подтвердил дамп с 20000 идет енв с 30000 какойто мусор а вот с 40000 уже идут FFromicom писал(а):Пробовал,сейчас еще отследил откуда начинает стирать командаКод: Выделить всё
hisilicon # sf probe 0 8192 KiB hi_sfc at 0:0 is now current device hisilicon # sf protect unlock 0x20000 0x10000 sf - SPI flash sub-system hisilicon # sf erase 0x20000 0x10000 Erasing at 0x30000 -- 100% complete. hisilicon #
так вот по какойто причине начинает стирать с 0x50000Код: Выделить всё
sf probe 0 sf erase 0x20000 0x7E0000
