hi3521a, Chip:32MB
Помогите с дампом или его частью, пожалуйста.
ю
U-Boot 2010.06 (Dec 29 2015 - 13:49:24)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc2 0x20 0x19
Block:64KB Chip:32MB Name:"MX25L(256/257)35(E/F)"
SPI Nor total size: 32MB
In: serial
Out: serial
Err: serial
current hi3521a version 201512291350
current spi flash size = 2000000
current used param offset 11111111111111111
current do_check_flash_boot_param
current prod net 1000m
current logo file len 0x6514
jpeg decoding ...
<<addr=0x80080000, size=0x6514, vobuf=0x94000000>>
mmu_enable
PicType: 6 ,Output Addr, Y: 94000000,UV: 94028000
<<imgwidth=480, imgheight=320, linebytes=512>>
decode success!!!!
USB: scanning bus for devices... 2 USB Device(s) found
usb_stor_get_info->1436,blksz:512
1 Storage Device(s) found
usb_stor_scan number = 1
Interface: USB
Device 0: Vendor: JetFlash Rev: 1.00 Prod: TS64MJF2A
Type: Removable Hard Disk
Capacity: 61.2 MB = 0.0 GB (125400 x 512)
Partition 1: Filesystem: FAT16 "NO NAME "
reading updateforcekra
reading u2boot21a
reading k2ern21a
reading r2ootfs21a
HDMI has been Disconnected.
hisilicon # print
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.255.0
bootfile="uImage"
bootcmd=sf probe 0;sf read 0x82000000 0x0C0000 0x400000;bootm 0x82000000
phyintfx=0
update_force_others=1
auversion0=56821f22
update_uboot=0
auversion1=5682463c
auversion2=56947442
bootargs=mem=232M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:768K(boot),2304K(sdr020000),28M(rootfs)
stdin=serial
stdout=serial
stderr=serial
verify=n
jpeg_addr=0x80080000
jpeg_size=0x6514
vobuf=0x94000000
ver=U-Boot 2010.06 (Dec 29 2015 - 13:49:24)
Environment size: 599/131068 bytes
hisilicon #
Image Name: Linux-3.10.0
Data Size: 2164744 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.10.0 (gjz@localhost.localdomain) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #3 Tue Dec 29 16:35:18 CST 2015
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: bigfish
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 58928
Kernel command line: mem=232M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:768K(boot),2304K(sdr020000),28M(rootfs)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 232MB = 232MB total
Memory: 229860k/229860k available, 7708k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0xcf000000 - 0xff000000 ( 768 MB)
lowmem : 0xc0000000 - 0xce800000 ( 232 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc04fe868 (5083 kB)
.init : 0xc04ff000 - 0xc0520a1c ( 135 kB)
.data : 0xc0522000 - 0xc05556e0 ( 206 kB)
.bss : 0xc05556e0 - 0xc05778d0 ( 137 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128
GIC CPU mask not found - kernel will fail to boot.
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 2190.54 BogoMIPS (lpj=10952704)
Initializing cgroup subsys freezer
Setting up static identity map for 0xc03ac048 - 0xc03ac0a0
DMA: preallocated 256 KiB pool for atomic coherent allocations
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
uart:0: ttyAMA0 at MMIO 0x12080000 (irq = 38) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x12090000 (irq = 39) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x120a0000 (irq = 40) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
hi-spi-master hi-spi-master.0: with 2 chip select slaves attached
Switching to clocksource timer0
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP: reno registered
CPU PMU: probing PMU on CPU 0
hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 448
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
hiahci: initializing
ahci ahci.0: can't get clock
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x100 irq 49
ata2: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x180 irq 49
Check Flash Memory Controller v100 ... Found.
3 cmdlinepart partitions found on MTD device hi_sfc
Creating 3 MTD partitions on "hi_sfc":
0x000000000000-0x0000000c0000 : "boot"
0x0000000c0000-0x000000300000 : "sdr020000"
0x000000300000-0x000001f00000 : "rootfs"
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 1
hiusb-ohci hiusb-ohci.0: irq 50, io mem 0x10030000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
i2c /dev entries driver
hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed!
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
яata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing unused kernel memory: 132K (c04ff000 - c0520000)
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
SatVision SDR-6425AH kernel panic.
Re: SatVision SDR-6425AH kernel panic.
Практически в режиме экстрасенса, лучше слить текущее содержимое, перед залитием: https://ufile.io/znlnp" onclick="window.open(this.href);return false;
ЭКСТРАСЕНСИЩЕ!
Спасибо огромное!
Залил только r2ootfs21a, почистив версию в auversion2.
Завелось.
Я на данный момент смог отыскать только несколько файлов r2ootfs21 (без а), с ними, естественно, были ошибки при загрузке.
Спасибо огромное!
Завелось.
