Теперь понятно почему не сработало?!vova99 писал(а): Unknown command 'sip' - try 'help'
Unknown command 'lip' - try 'help'
hi3516 сброс настроек
- VirtualLink
Re: hi3516 сброс настроек
Так эти команды на линк никак не повлияют.
На рабочей камере та же команда.
Код: Выделить всё
hisilicon # sip 192.168.1.40;lip 192.168.1.10;sf probe 0;sf read 0x82000000 0x0 0x1000000;tftp 0x82000000 dump.bin 0x1000000
Hisilicon ETH net controler
miiphy_register: non unique device name '0:1'
miiphy_register: non unique device name '0:2'
MAC: 00-9A-9B-9C-9D-9E
UP_PORT : phy status change : LINK=UP : DUPLEX=HALF : SPEED=100M
TFTP to server 192.168.1.40; our IP address is 192.168.1.10
Upload Filename 'dump.bin'.
Upload from address: 0x82000000, 16.000 MB to be send ...
Uploading: # [ Connected ]
################################ [ 1.000 MB]
################################ [ 2.000 MB]
################################ [ 3.000 MB]
################################ [ 4.000 MB]
############################%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%#%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%# [ 5.000 MB]
%%%... %%%# [16.000 MB]
16.000 MB upload ok.
- VirtualLink
Маки в логах двух камер!
Всем спасибо.
Камера работает. Проблема била в железе.
Cгорел трансформатор Lan TRXCOM TRC1102NL бил заменен на Pulse H1102NL.
После замени камера начала работать по Lan.
- VirtualLink
Тут тебе виднее, ведь камера у тебя на руках!
