сброс пароля на NVR NBD8008T-Q
как сбросить пароль для admin, NVR заблокировался. Ошибка: В процессе облуживания....
bootcmd=nand read 0x2000000 0x300000 0x1400000;squashfsload 0x2000000;bootm 0x2000000
bootdelay=1
baudrate=115200
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
bootfile="uImage"
da=mw.b 0x2000000 ff 4000000;tftp 0x2000000 u-boot.bin.img;flwrite
du=mw.b 0x2000000 ff 4000000;tftp 0x2000000 user-x.squashfs.img;flwrite
dr=mw.b 0x2000000 ff 4000000;tftp 0x2000000 romfs-x.squashfs.img;flwrite
dw=mw.b 0x2000000 ff 4000000;tftp 0x2000000 web-x.squashfs.img;flwrite
dl=mw.b 0x2000000 ff 4000000;tftp 0x2000000 logo-x.squashfs.img;flwrite
dc=mw.b 0x2000000 ff 4000000;tftp 0x2000000 custom-x.squashfs.img;flwrite
up=mw.b 0x2000000 ff 4000000;tftp 0x2000000 update.img;flwrite
tk=mw.b 0x2000000 ff 4000000;tftp 0x2000000 zImage.img;bootm 0x2000000
dd=mw.b 0x2000000 ff 4000000;tftp 0x2000000 mtd-x.yaffs2.img;flwrite
appVideoStandard=PAL
appSystemLanguage=Russian
bootargs=mem=512M console=ttyAMA0,115200 root=/dev/romblock1 rootfstype=squashfs mtdparts=hinand:3M(boot),20M(rootfs),20M(user),4M(web),6M(custom),2M(logo),6M(mtd),2M(baseparam),1M(startlogo) mmz=ddr,0,0,344M coherent_pool=2M
stdin=serial
stdout=serial
stderr=serial
ver=Fastboot 3.3.0-svn697 (chenwenrong@localhost.localdomain) (Feb 28 2017 - 09:44:46)
Environment size: 1254/131068 bytes
.Loading 'kernel' image.
Reserve Memory
Start Addr: 0x1FFFE000
Bound Addr: 0x8D7B000
Free Addr: 0x1E9B6000
Alloc Block: Addr Size
0x1FBFD000 4194304
0x1F8FC000 3145728
0x1F8F9000 8192
0x1F8C4000 212992
0x1F7C3000 1048576
0x1F7BF000 12288
0x1F43A000 3686400
0x1F0B5000 3686400
0x1EDB7000 3133440
0x1E9B6000 4194304
System startup
DDRS
Reg Version: v1.1.0
Reg Time: 2016/1/18 14:00:27
Reg Name: hi3798mdmo1f_hi3798mv100_ddr3_1gbyte_16bitx2_2layers_nand.reg
Relocate Boot to DDR
Jump to DDR
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
Reserve Memory
0x1FBFD000 4194304
0x1F8FC000 3145728
0x1F8F9000 8192
0x1F8C4000 212992
0x1F7C3000 1048576
0x1F7BF000 12288
0x1F43A000 3686400
0x1F0B5000 3686400
0x1EDB7000 3133440
0x1E9B6000 4194304
System startup
DDRS
Reg Version: v1.1.0
Jump to DDR
Re: сброс пароля на NVR NBD8008T-Q
Стереть вот это 6M(mtd), предварительно сделав бэкап
напишите, пожалуйста, как сделать сбросdede писал(а):Стереть вот это 6M(mtd), предварительно сделав бэкап
бэкап сделал так:
nand read 0x2000000 0 0x8000000
tftp 0x2000000 nvr265.bin 0x8000000
fastboot# ?
? - alias for 'help'
clear_bootf- clear Hibernate!! bootflag
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
ddr - ddr training function
flwrite - Nand flash sub-system
hibernate- Hibernate!! boot
md - memory display
mii - MII utility commands
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
otp_burntoecurechipset- Burn to secure chipset, please be careful !!!
otp_getcustomerkey- otp_getcustomerkey
otp_getstbprivdata- otp_getstbprivdata
otp_setstbprivdata- StbPrivData
otpreadall- read otp ,for example otpreadall
otpwrite- write otp ,for example otpwrite adddress value
squashfsload- fsload - load binary file from a filesystem image
unzip - unzip a memory region
uploadx - upload binary file over serial line (xmodem mode)
usb - USB sub-system
usbburn - burn file from USB device
проблем добавилось (((
Entry usb bootstrap
No found fastboot.bin in host:1
No found fastboot.bin in host:2
Starting fastboot ...
Entry usb bootstrap
Как это случилось?
Nand erase
Мда... как конкретно выполнена была?
Fastboot# nand erase
Потом перезагрузка reset
Тогда можно считать, что на этом ремонт окончен. Первый загрузчик никак прервать нельзя? Команд никаких у него нету?
А через программатор если шить?
Команд нет, он пытается на флешке найти этот файл
Последний раз редактировалось andrew01 29 сен 2017, 20:53, всего редактировалось 1 раз.
Если дамп снят корректно - то да. Но у вас нанд память, программатор нужен далеко не рядовой
У меня wizardpro87i память на плате 25l512e
