Не грузится регистратор THB7016T-MH V2
Re: Не грузится регистратор THB7016T-MH V2
удалите все файлы в /mnt/mtd любым удобным вам способом
- VirtualLink
Ranger писал(а):rf -rf /mnt/mtd/ ругается на этот параметр и не исполняет
Код: Выделить всё
rm /mnt/mtd/* -rf
выдает ошибкиVirtualLink писал(а):Ranger писал(а):rf -rf /mnt/mtd/ ругается на этот параметр и не исполняетКод: Выделить всё
rm /mnt/mtd/* -rf
Код: Выделить всё
~ # rm /mnt/mtd/* -rf
rm: can't stat '/mnt/mtd/Config/ppp/pap-secrets': Input/output error
rm: can't stat '/mnt/mtd/Config/ppp/pppoe-enable': Input/output error
rm: can't remove '/mnt/mtd/Config/ppp': Directory not empty
rm: can't stat '/mnt/mtd/Config/Account2': Input/output error
rm: can't stat '/mnt/mtd/Config/RT2870STA.dat': Input/output error
rm: can't stat '/mnt/mtd/Config/dhcp.cfg': Input/output error
rm: can't stat '/mnt/mtd/Config/FlashProtectInfoFile': Input/output error
rm: can't stat '/mnt/mtd/Config/network': Input/output error
rm: can't stat '/mnt/mtd/Config/SysComs': Input/output error
rm: can't stat '/mnt/mtd/Config/networkipv6': Input/output error
rm: can't stat '/mnt/mtd/Config/StorageCfg': Input/output error
rm: can't stat '/mnt/mtd/Config/resolv.conf': Input/output error
rm: can't stat '/mnt/mtd/Config/uboot_env_lang_video': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/NetWork': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Uart': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/System': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Ability.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/General.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Record.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/SplitMode.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/fVideo': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Guide': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Detect': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/General': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/AVEnc.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/NetWork.second': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Media': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Ability': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/AVEnc': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/SplitMode': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/Record': Input/output error
rm: can't stat '/mnt/mtd/Config/Json/System.second': Input/output error
rm: can't remove '/mnt/mtd/Config/Json': Directory not empty
rm: can't stat '/mnt/mtd/Config/__tempinfo': Input/output error
rm: can't stat '/mnt/mtd/Config/Account1': Input/output error
rm: can't remove '/mnt/mtd/Config': Directory not empty
rm: can't stat '/mnt/mtd/Log/Log': Input/output error
rm: can't stat '/mnt/mtd/Log/ProductTrail': Input/output error
rm: can't stat '/mnt/mtd/Log/macRandNum': Input/output error
rm: can't stat '/mnt/mtd/Log/SysTime': Input/output error
rm: can't remove '/mnt/mtd/Log': Directory not empty
Наверное битый раздел с jffs2. Нужно затереть
- VirtualLink
Какая сейчас прошивка, раз доступен телнет или это консоль не заблокирована?
Дай вывод
Убрать основной процесс и попробовать снова удалить!
Дай вывод
Код: Выделить всё
mount
Код: Выделить всё
ps
это консоль, у него апп даже не стартует
- VirtualLink
Обычно консоль залочена, а вывод лога не предоставлен, вот и спросил!dede писал(а):это консоль, у него апп даже не стартует
я уже думал затереть все кроме U-BOOT, просто знаний не хватает. Есть вопрос, начальный загрузчик, в котором я останавливаю дальнейшую загрузку по ctrl+c, это он где находится? в процессоре? или это все находится во флешке 16 Мб? я слил полный дамп 16 метров на всякий случай.dede писал(а):Наверное битый раздел с jffs2. Нужно затереть
VirtualLink писал(а):Какая сейчас прошивка, раз доступен телнет или это консоль не заблокирована?
Я не очень понимаю, что Вы имеете ввиду, загружается ядро и все, больше ничего не прогружается, т.е. я спокойно хожу по папкам, запускаю приложения, но вот где сама графическая оболочка, не пойму, как ее запустить?
- VirtualLink
Ranger писал(а): я уже думал затереть все кроме U-BOOT, просто знаний не хватает. Есть вопрос, начальный загрузчик, в котором я останавливаю дальнейшую загрузку по ctrl+c, это он где находится? в процессоре? или это все находится во флешке 16 Мб? я слил полный дамп 16 метров на всякий случай.
Почитайте форум, вопросов будет меньше!
Остановить загрузку, воспользоваться командами интерфейса spi!
Я не очень понимаю, что Вы имеете ввиду, загружается ядро и все, больше ничего не прогружается, т.е. я спокойно хожу по папкам, запускаю приложения, но вот где сама графическая оболочка, не пойму, как ее запустить?[/quote]
Я в тоже не понимаю, что там происходит, не видя логов загрузки и всего остального!
вот полный лог, больше ничего не происходит, я могу обычными командами типа ls, cd, ./, ходить по папкам и запускать приложения, но самой загрузки системы не происходит, только на экране стоит заставка, из лога это понятно..,
"Почитайте форум, вопросов будет меньше!
Остановить загрузку, воспользоваться командами интерфейса spi!"
так вот и читаю форум, вопросов не меньше, неужели нельзя просто ответить, если знаете ответ или ткнуть конкретно в какой то пост? я не первый раз восстанавливаю разные железки, вот с регистраторами еще не сталкивался, поэтому и спрашиваю, а ответы, типа посмотри на форуме, это не ответ, мне и так это ясно. Я останавливаю загрузку и пользуюсь командами интерфейса, через него заливал и update.img и по отдельности все файлы из прошивки, толку ноль!
Код: Выделить всё
System startup
U-Boot 2010.06-svn270 (Nov 14 2015 - 10:16:16)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc2 0x20 0x18
Block:64KB Chip:16MB Name:"MX25L128XX"
SPI Nor total size: 16MB
In: serial
Out: serial
Err: serial
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds16384 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x5f000000
jpeg decoding ...
<<addr=0x5f000000, size=0xb85f9, vobuf=0x5f600000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
stMaxRect.u32Width800, stMaxRect.u32Height600.
srcAddr 0x42000000, dstAddr 0x42000000
find_squashfs_file: name bin, start_block 0, offset 2544, type 1
find_squashfs_file: name boot, start_block 0, offset 2648, type 1
read inode: name boot, sb 0, of 2648, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 2576, type 2
read inode: name zImage.img, sb 0, of 2576, type 2
### FS load complete: 2564440 bytes loaded to 0x42000000
## Booting kernel from Legacy Image at 42000000 ...
Image Name: linux
Data Size: 2564376 Bytes = 2.4 MiB
Load Address: 40008000
Entry Point: 40008000
Loading Kernel Image ... OK
OK
Starting kernel ...
▒Auto login as root ...
Welcome to Monitor Tech.
а как это правильно сделать?dede писал(а):Наверное битый раздел с jffs2. Нужно затереть
- VirtualLink
Претензии к себе предъявляйте!Ranger писал(а): так вот и читаю форум, вопросов не меньше, неужели нельзя просто ответить, если знаете ответ или ткнуть конкретно в какой то пост? я не первый раз восстанавливаю разные железки, вот с регистраторами еще не сталкивался, поэтому и спрашиваю, а ответы, типа посмотри на форуме, это не ответ, мне и так это ясно.
Этому точно есть причина!Ranger писал(а): Я останавливаю загрузку и пользуюсь командами интерфейса, через него заливал и update.img и по отдельности все файлы из прошивки, толку ноль!
Лог с воткнутой флешкой и попыткой восстановления, пожалуйста!
