CPU: Hi3520
EEPROM/FLASH: 25q64
на заставки зависает
лог
- Check spi flash controller v350... Found
Spi(cs1) ID: 0xEF 0x40 0x17 0x00 0x00 0x00
Spi(cs1): Block:64KB Chip:8MB Name:"W25Q64FV"
In: serial
Out: serial
Err: serial
enable_mmu_accelerate
<<addr=0x84800000, size=0x40000, vobuf=0x85a00000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
<<addr=0x84900000, size=0x40000, vobuf=0x85b00000>>
<<imgwidth=720, imgheight=576, linebytes=1440>>
decode success!!!!
disable_mmu_accelerate
Image Name: Linux-3.0.8
Data Size: 1720148 Bytes = 1.6 MiB
Load Address: 80008000
Entry Point: 80008000
## Loading init Ramdisk from Legacy Image at 81000000 ...
Image Name: JUAN root filesystem(19/11/2013)
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4370432 Bytes = 4.2 MiB
Load Address: 81000000
Entry Point: 81000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@archlinux) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-2 90+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Mon Sep 23 15:00:49 SGT 2013
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 18288
Kernel command line: mem=72M console=ttyAMA0,115200 root=0100 init=/linuxrc mtdp arts=hi_sfc:128K(U),64K(E),128K(L),128K(C),1728K(K),6016K(R) ramdisk_size=4300
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 72MB = 72MB total
Memory: 64052k/64052k available, 9676k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5000000 - 0xfe000000 ( 912 MB)
lowmem : 0xc0000000 - 0xc4800000 ( 72 MB)
.init : 0xc0008000 - 0xc002a000 ( 136 kB)
.text : 0xc002a000 - 0xc0445000 (4204 kB)
.data : 0xc0446000 - 0xc0471180 ( 173 kB)
.bss : 0xc04711a4 - 0xc0492398 ( 133 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms
Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
console [ttyAMA0] enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
FS-Cache: Loaded
CacheFiles: Loaded
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 4268K
L2cache cache controller enabled
fuse init (API version 7.16)
msgmni has been set to 133
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Loading iSCSI transport class v2.0-870.
SCSI Media Changer driver v0.25
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
6 cmdlinepart partitions found on MTD device hi_sfc
Creating 6 MTD partitions on "hi_sfc":
0x000000000000-0x000000020000 : "U"
0x000000020000-0x000000030000 : "E"
0x000000030000-0x000000050000 : "L"
0x000000050000-0x000000070000 : "C"
0x000000070000-0x000000220000 : "K"
0x000000220000-0x000000800000 : "R"
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: DA:33:67:BD:7A:95
bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
bonding: Warning: either miimon or arp_interval and arp_ip_target module paramet ers must be specified, otherwise bonding will not detect link failures! see bond ing.txt for details.
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
SLIP linefill/keepalive option.
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-cypress
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums_eneub6250
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-karma
usbcore: registered new interface driver ums-onetouch
usbcore: registered new interface driver ums-realtek
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
RAMDISK: squashfs filesystem found at block 0
RAMDISK: Loading 4265KiB [1 disk] into ram disk... done.
VFS: Mounted root (squashfs filesystem) readonly on device 1:0.
SQUASHFS error: xz_dec_run error, data probably corrupt
SQUASHFS error: squashfs_read_data failed to read block 0x429142
SQUASHFS error: Unable to read metadata cache entry [429142]
SQUASHFS error: Unable to read directory block [429142:998]
devtmpfs: error mounting -5
Freeing init memory: 136K
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
Backtrace:
[<c0033cbc>] (dump_backtrace+0x0/0x110) from [<c0338d54>] (dump_stack+0x18/0x1c)
r6:c0044770 r5:c002326c r4:c0471550 r3:c044cb94
[<c0338d3c>] (dump_stack+0x0/0x1c) from [<c0338db4>] (panic+0x5c/0x17c)
[<c0338d58>] (panic+0x0/0x17c) from [<c002a550>] (init_post+0xa8/0xcc)
r3:c4024000 r2:c1229300 r1:c04b7520 r0:c03e6cbd
r7:00000013
[<c002a4a8>] (init_post+0x0/0xcc) from [<c000845c>] (kernel_init+0xec/0x11c)
r4:c04711c0 r3:c3c02080
[<c0008370>] (kernel_init+0x0/0x11c) from [<c0044770>] (do_exit+0x0/0x614)
r5:c0008370 r4:00000000
