Сброс пароля dvr/nvr Samsung
Сообщение GenaSPB » 10 июл 2018, 22:51
Достался тут залоченный DVR samsung, информации по ним мало, чем со мной поделились и до чего дошли, опишу тут, чтобы не потерялось.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
И еще
On the front panel, press MODE+ PTZ together for 5 seconds.
Press on remote control after a clean boot: FREEZE-ALARM-FREEZE-ALARM-FREEZE-RETURN.
This information doesn't apply to all Samsung recorders, either method could work or not at all. If after trying both ways you are still unable to login to the unit, consider returning it to the supplier. They will then forward it on to Samsung's service centre, who are the only people able to reset a recorder in this situation.
Но в нашем случае был DVR SVR-1670 и ни какие растапырки пальцев не помогали, особенно когда отсутствует кнопка Mode. Выручило то что в этом реге предустановленно с десяток пользователей и вот 8-ой оказался с дефолтным паролем и админскими правами.
Annadurdy
Re: Сброс пароля dvr/nvr Samsung
Сообщение Annadurdy » 09 янв 2019, 08:50
здравствуйте, не могли бы вы поделится этими пользователей с дефолтным паролем и админскими правами.
Сообщение GenaSPB » 09 янв 2019, 11:22
Шоб я помнил. Где-то нагуглили.
qaws33@rambler.ru
Сообщение qaws33@rambler.ru » 08 сен 2022, 11:04
Для сброса samsung svr-1670 на заводские установки есть две волшебные клавишы REC+ESC (круглые) -нажать одновременно на полминуты. Удачи!
