Помогите с регистратором SV Plus R-704
chpok
Сообщение chpok » 17 окт 2018, 02:38
Рег "SV Plus R-704" загружается, потом черный экран.
часть вывода с UART
Код: Выделить всё
i2c i2c-0: I2C TX data 0x40 timeout!
CX25930#0 i2c write failed!!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x50 timeout!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x60 timeout!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x29 timeout!
CX25930#0 i2c read failed!!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x10 timeout!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x15 timeout!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: I2C TX data 0x1a timeout!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
i2c i2c-0: NAK!
CX25930#0 Init...Fail!
insmod: can't insert '/lib/modules/cx25930.ko': Operation not permitted
insmod: can't insert '/lib/modules/nvp1914.ko': No such file or directory
[VCAP_INFO]: VCAP300 Version: 0.3.7A
vcap300_cx25930: Unknown symbol cx25930_notify_vfmt_deregister (err 0)
vcap300_cx25930: Unknown symbol cx25930_get_device_num (err 0)
vcap300_cx25930: Unknown symbol cx25930_notify_vlos_register (err 0)
vcap300_cx25930: Unknown symbol cx25930_get_vch_id (err 0)
vcap300_cx25930: Unknown symbol cx25930_notify_vfmt_register (err 0)
vcap300_cx25930: Unknown symbol cx25930_get_vout_format (err 0)
vcap300_cx25930: Unknown symbol cx25930_notify_vlos_deregister (err 0)
insmod: can't insert '/lib/modules/vcap300_cx25930.ko': unknown symbol in module, or unknown parameter
osg canvas is static allocate mode
SWOSG ver 0.1.7
SCALER version 141119, temp_width: 1280, temp_height: 720
fscaler300_init_one [0] NCNB
FTDI220 registers 64 entities to videograph.
FTDI220 Driver v3.9 (1 engine(s))
MCP100 GM8287, built @ Jan  9 2015 14:33:17
FAVC Encoder v0.1.120, built @ Mar 17 2015 14:07:51 (GM8287)
H264 rate control(VG) version: 1.1.11, built @ Jan  9 2015 14:34:35
Decoder v1.0.2, built @ Jan  9 2015 14:32:27
FAVC Decoder IRQ mode(30) PLT:828X, version 0.2.140.0 built @ Jan  9 2015 14:33:48
GM8287 MJPEG, encoder v4.0.21, decoder v4.0.9, built @ Jan  9 2015 14:33:22
audio_init: audio driver is inserted, minor version: 0108_1051
Record(SSP:0): stream->dma_buffer = 1ad0000(ffd80000), size:2000, dma_ch: 0
Playback(SSP:0): stream->dma_buffer = 1af0000(ffd70000), size:2000, dma_ch: 1
Playback(SSP:1): stream->dma_buffer = 1e80000(ffd40000), size:3000, dma_ch: 2
gs.ko v1.5_fixed_timestamp_order Sep 15 2015 17:11:33
GS driver, log: level(0) category(0) bmp width(64)
loop_comm.ko v0.5 Jan 13 2015 17:57:37
vpd_slave.ko v1.6_fixup_layout_rmmod Sep 14 2015 15:29:38
config_path="/mnt/mtd/"
loopcomm slave init: Bus(101) getcp_bus(103) query_bs_bus(105) pack_membus(107)
Parsing CAP vg_info version: 0.3.7
vplib v2.0 Sep 14 2015 15:29:40
config_init v0.18 Sep 14 2015 15:29:48 /mnt/mtd//gmlib.cfg
; GM8283_4CH_720P Product Configuration
[VERSION]
VERSION = 0.1
[GRAPH_TYPE]
; graph type: 1(DVR with display 3DI), 2(IPCAM)
graph_type = 1
[DISPLAY_GROUP]
; GROUP0 = lcd_vch0, lcd_vch1
; Display group method:
;   0(FRAME), 2(2FRAME), 3(2FRAME_2FRAME), 4(FRAME_FRAME)
GROUP0 = 0, 1
METHOD0 = 4
[BITRATE]
min_compressed_ratio = 15
max_bitrate = 720P/4096K, D1/4096K
[PLAYBACK]
; CONFIG1 = resolution_keywords/channels/total_fps/ddr_channel, ...
; default resolution keywords: 8M, 5M, 4M, 3M, 2M, 1.3M, 1M, nHD, 1080P, 720P, D1, VGA, CIF, QCIF
CONFIG1 = 720P/1/15/0
[PLAYBACK_3DI]
[ENCODE_STREAMS]
CONFIG1 = 720P/4/60/0,CIF/4/20/0
[ENCODE_CAPTURE]
[ENCODE_SCALER]
; CONFIG1 = resolution keywords = channels/total_fps/ddr_channel, ...
CONFIG1 = CIF/4/20/0
[ENCODE_DIDN]
[RAW_OUT]
; CONFIG1 = channels/total_fps/ddr_channel, ...
[LDC_OUT]
[AUDIO]
; CONFIG1 = audio_keyword/channels/sample_rate/stereo/bits/ddr_vch
CONFIG1 = au_grab/4/16K/mono/16/0, au_render/4/16K/mono/16/0
max_frame_samples = 2048
grab_buffer_time = 768
render_buffer_time = 768
[BUFFER_DISPLAY]
; Display count lcd_vch/count/ddr_channel, lcd_vch/count/ddr_channel, ...
display_count = 0/8/0
; Playback 3DI input buffer count per channel
playback_3di_input_count = 0
; Playback scaler input buffer count per channel
playback_scaler_input_count = 2
;playback_scaler_input_count = 3
[BUFFER_BITSTREAM]
; Playback bitstream data buffer: time/ddr_vch
datain_buffer_time = 66/0
; Record bitstream data buffer: time/ddr_vch
dataout_buffer_time = 165/0
[BUFFER_CAPTURE]
; Encode capture buffer three slop: fps/count, fps/count, fps/count
CONFIG1 = 720P/18/4, 720P/9/3, 720P/1/2
CONFIG2 = 960H/18/4, 960H/9/3, 960H/1/2
CONFIG3 = CIF/5/2, CIF/2/1, CIF/1/1
capture_max_fps = 15
[BUFFER_ENCODE_DIDN]
; Encode substream scaler out buffer time
encode_didn_out_buffer_count = 0
[BUFFER_SUBSTREAM]
encode_scaler_out_buffer_count = 1
[BUFFER_RAW]
raw_out_buffer_count = 0
[BUFFER_LDC]
ldc_out_buffer_count = 0
[ENCODE_MOTION]
; Enable motion data under specified resolution by "motion_resolution = D1, CIF..."
; motion_resolution = CIF
[SNAPSHOT]
;yuv_max_width = 352
;yuv_max_height = 288
;max_bitstream_size = 81920
[RESERVED_BUFFER]
; Reserved buffer ratio for seamless switching usage, such as 4CH 720P->4CH 1080P without any stop
reserved_ratio = 0
No support encode motion data information
   8M  3840x2160  max_frame: 1866240  average:  65979  motion:      0
   7M  3264x2176  max_frame: 1598054  average:  16315  motion:      0
   6M  3072x2048  max_frame: 1415577  average: 262144  motion:      0
   5M  2592x1952  max_frame: 1138406  average: 210816  motion:      0
   4M  2304x1728  max_frame:  895795  average: 165888  motion:      0
   3M  2048x1536  max_frame:  707788  average: 131072  motion:      0
1080P  1920x1088  max_frame:  470016  average:  87040  motion:      0
 1.3M  1280x1024  max_frame:  294912  average:  54613  motion:      0
 1.2M  1280x 960  max_frame:  276480  average:  51200  motion:      0
1080I  1920x 544  max_frame:  235008  average:  43520  motion:      0
   1M  1280x 800  max_frame:  230400  average:  42666  motion:      0
 720P  1280x 720  max_frame:  207360  average:  17476  motion:      0
 960H   960x 576  max_frame:  124416  average:  23040  motion:      0
 SVGA   800x 608  max_frame:  109440  average:  20266  motion:      0
 720I  1280x 368  max_frame:  105984  average:  19626  motion:      0
   D1   720x 576  max_frame:   93312  average:  17476  motion:      0
  VGA   640x 480  max_frame:   69120  average:  12800  motion:      0
  nHD   640x 368  max_frame:   52992  average:   9813  motion:      0
 2CIF   368x 608  max_frame:   50342  average:   9322  motion:      0
  HD1   720x 288  max_frame:   46656  average:   8640  motion:      0
  CIF   368x 288  max_frame:   23846  average:   4416  motion:      0
 QCIF   176x 144  max_frame:   20480  average:   2048  motion:      0
  disp0_in DDR0 1024x768+720x576, method(4)
    (1536KB x 1 + 810KB x 1)  x 8
    ==> 18784KB (ddr0)
  disp_scl_in DDR0 1280x720 1CH scl_in_decuple(20)
    1800KB x 2
    450KB x 2
    ==> 4508KB (ddr0)
  dec_in DDR0 1280x720 1CH fps(15) time(66) aver_sz(17476) max_sz(207360) count(1)
    613KB x 1 (win=202KB x2 aver=17KB x1)
    ==> 613KB (ddr0)
  enc_cap_out DDR0 1280x720 4CH fps(60) factor(100)
           total_fps(60) aver(4CH/15fps/3)
    1800KB x 12
    ==> 21624KB (ddr0)
  enc_out DDR0 1280x720 4CH fps(60) time(66) aver_sz(17476) max_sz(207360) count(2)
  enc_out DDR0 368x288 4CH fps(20) time(200) aver_sz(4416) max_sz(23846) count(1)
    613KB x 4 (win=202KB x2 aver=17KB x1)
    75KB x 4 (win=23KB x2 aver=4KB x1)
    ==> 2757KB (ddr0)
  enc_scl_out DDR0 368x288 4CH fps(20) decuple(10)
    207KB x 4
    ==> 836KB (ddr0)
  au_grab_out DDR0 4CH 16K tracks(1) bits(16) samples(2048) latency(768) count(6)
    32KB x 6
    ==> 204KB (ddr0)
  au_render_in DDR0 4CH 16K tracks(1) bits(16) samples(2048) latency(768) count(6)
    16KB x 6
    ==> 204KB (ddr0)
  Reserved buffer ratio=0
  DDR0 size=49530KB
#### Capture Count ####
 RES/FPS  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 40 45 50 55 60
3840x2160 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
3264x2176 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  1  1
3072x2048 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  1  1  1
2592x1952 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  1  1  1  1  1
2304x1728 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  1  1  1  1  1  1  1  1
2048x1536 0 0 0 0 0 0 0 0 0  0  0  0  0  0  0  0  0  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  2  2  2
1920x1088 0 0 0 0 0 0 0 0 1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  2  2  2  2  2  3  3  3
1280x1024 1 1 1 1 1 1 1 1 2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  3  3  3  4  4  4  5  5
1280x 960 1 1 1 1 1 1 1 1 2  2  2  2  2  2  2  2  2  3  3  3  3  3  3  3  3  3  3  3  3  3  4  4  5  6  6
1920x 544 1 1 1 1 1 1 1 1 2  2  2  2  2  2  2  2  2  3  3  3  3  3  3  3  3  3  3  4  4  4  5  5  6  7  7
1280x 800 1 1 1 1 1 1 1 1 2  2  2  2  2  2  2  2  2  3  3  3  3  3  3  3  3  3  3  4  4  4  5  5  6  7  7
1280x 720 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 960x 576 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 800x 608 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
1280x 368 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 720x 576 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 640x 480 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 640x 368 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 368x 608 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 720x 288 2 2 2 2 2 2 2 2 3  3  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  5  5  5  6  6  7  8  8
 368x 288 1 1 1 1 2 2 2 2 3  3  3  4  4  4  5  5  5  6  6  6  7  7  7  8  8  8  9  9  9 10 13 15 16 18 20
 176x 144 1 1 1 1 2 2 2 2 3  3  3  4  4  4  5  5  5  6  6  6  7  7  7  8  8  8  9  9  9 10 13 15 16 18 20
bufferSea_ddr0     49530 KB + 0 KB(reserved)
                   (cacheable)
   disp0_in 18784 KB (DDR0)
                  fill disp0_in pattern 0x10801080
                  DDR0 pool free size 30746KB.
disp_scl_in  4508 KB (DDR0)
                  DDR0 pool free size 26238KB.
  dec_bs_in   613 KB (DDR0)
                  DDR0 pool free size 25625KB.
enc_cap_out 21624 KB (DDR0)
                  fill enc_cap_out pattern 0x10801080
                  DDR0 pool free size 4001KB.
 enc_bs_out  2757 KB (DDR0)
                  DDR0 pool free size 1244KB.
enc_scl_out   836 KB (DDR0)
                  DDR0 pool free size 408KB.
au_grab_out   204 KB (DDR0)
                  DDR0 pool free size 204KB.
au_render_in   204 KB (DDR0)
                  DDR0 pool free size 0KB.
datain v0.2 Sep 14 2015 15:29:47
dataout v0.6 Sep 14 2015 15:29:52
osd_mg_database_init......osd_type:0
osd_mg_database_init......osd_type:1
osd_mg_database_init......osd_type:2
usr_clearwin v0.21 Sep 14 2015 15:29:58
usr_clearwin init fd(0x60000000) idx(0) buffer(0x8396c400/0x396c400)
usr_clearwin init fd(0x60000000) idx(1) buffer(0x83bb7000/0x3bb7000)
usr_clearwin init fd(0x60000000) idx(2) buffer(0x83e01c00/0x3e01c00)
usr_clearwin init fd(0x60000000) idx(3) buffer(0x8404c800/0x404c800)
usr_clearwin init fd(0x60000000) idx(4) buffer(0x84297400/0x4297400)
usr_clearwin init fd(0x60000000) idx(5) buffer(0x844e2000/0x44e2000)
usr_clearwin init fd(0x60000000) idx(6) buffer(0x8472cc00/0x472cc00)
usr_clearwin init fd(0x60000000) idx(7) buffer(0x84977800/0x4977800)
usr_decode v0.1 Sep 14 2015 15:29:59
usr_snapshot v0.18 Sep 14 2015 15:29:59 (960x540, 1023KB)
usr_getraw v0.5 Sep 14 2015 15:30:00
usr_cap_source v0.5 Sep 14 2015 15:30:00
usr_osg v1.9 Sep 14 2015 15:30:01
usr_osg: (ch_table) 0 ,4 ,8 ,12 ,-1 ,-1 ,-1 ,-1 ,
usr_process v0.1 Sep 14 2015 15:29:56
videograph ioctl v0.44
vpd_master.ko v1.2_fixup_rmmod Sep 14 2015 15:29:32
vpd_master: chipnr=0.
loopcomm master init: pack_membus(8106)
Slave 0:1 is ready(1).
vpslv set vpslv_dbglevel=0
vpd_master 22565
9 0 - Live 0x7f43d000 (PO)
vpd_slave 733674 0 -Frammap: 2615 pages in DDR0 are freed.
 Live 0x7f36f000
 (PO)
loop_commwrite engine 0 2Ch tdn_var_y as 6 (0x00002206)
 14375 2 vpd_mas
ter,vpd_slave, Lwrite engine 0 2Ch temporalEn as 1 (0x80002206)
ive 0x7f367000 (
PO)
gs 203736 1write engine 0 30h spatialEn as 1 (0x80400000)
 vpd_slave, Live 0x7f328000 (PO)
audio_drv 200758 1 vpd_slave, Live 0x7f2f1000 (O)
codec 220421 1 audio_drv, Live 0x7f2b6000 (PO)
fmjpeg_drv 74941 0 - Live 0x7f29f000 (O)
favc_dec 199141 0 - Live 0x7f267000 (O)
decoder 10603 2 fmjpeg_drv,favc_dec, Live 0x7f261000 (O)
favc_rc 29431 0 - Live 0x7f256000 (O)
favc_enc 379797 1 favc_rc, Live 0x7f1f4000 (O)
fmcp_drv 109324 2 fmjpeg_drv,favc_enc, Live 0x7f1d5000 (O)
osd_dispatch 6427 1 vpd_slave, Live 0x7f1cf000 (O)
ftdi220 225195 0 - Live 0x7f194000 (O)
fscaler300 227011 1 osd_dispatch, Live 0x7f155000 (O)
sw_osg 78212 1 vpd_slave, Live 0x7f13e000 (O)
vcap0 1646 0 - Live 0x7f135000 (O)
vcap300_common 295413 2 vpd_slave,osd_dispatch, Live 0x7f0e5000 (O)
fe_common 6823 1 audio_drv, Live 0x7f0d2000 (O)
sli10121 36599 0 - Live 0x7f0c5000 (O)
flcd200_pip2 101864 0 - Live 0x7f0a6000 (O)
flcd200_pip 101865 0 - Live 0x7f087000 (O)
flcd200_commonSet EM debug level(0) (0:quiet 1:get/put 2:property 3:semaphore)
 28774 12 sli101
Set GraphService debug level(0). (0 for error, 1 for flow, 2 for detail.)
21,flcd200_pip2,Set MemoryService debug level(0).
flcd200_pip, LivSet datain debug level(0)
e 0x7f07b000 (O)Set dataout debug level(0)
think2d 14824 vpslv set vpslv_dbglevel=0
1 sw_osg, Live 0Set VPD debug level(0).
x7f074000 (O)
eDebug Level:0
m 160975 12 vpd_slave,gs,audio_drv,fmjpeg_drv,favc_dec,decoder,favc_enc,ftdi220,fscaler300,vcap300_common,flcd200_pip2,flcd200_pip, Live 0x7f042000 (PO)
ms 120946 2 vpd_slave,gs, Live 0x7f01c000 (PO)
log 18946 18 vpd_master,vpd_slave,loop_comm,gs,audio_drv,fmjpeg_drv,favc_dec,decoder,favc_rc,favc_enc,fmcp_drv,ftdi220,fscaler300,vcap300_common,flcd200_pip2,flcd200_pip,em,ms, Live 0x7f012000 (PO)
frammap 20494 14 vpd_master,vpd_slave,loop_comm,audio_drv,favc_dec,favc_enc,fmcp_drv,fscaler300,sw_osg,vcap300_common,flcd200_common,think2d,em,ms, Live 0x7f000000 (O)
0x07F45D02
0x00401850
0x00000088
0x32351424
0x00002050
0x9F000009
0x06060606
0x00630012
SQUASHFS error: Unable to read data cache entry [fba4c]
SQUASHFS error: Unable to read page, block fba4c, size 15984
pgd = 81a94000
[0041f8d0] *pgd=0158b831, *pte=00000000, *ppte=00000000
Pid: 279, comm:            Challenge
CPU: 0    Tainted: P           O  (3.3.0 #73)
PC is at 0x41f8d0
LR is at 0x4ccdb8
pc : [<0041f8d0>]    lr : [<004ccdb8>]    psr: 20000010
sp : 7ee30cb8  ip : 005ff278  fp : 00000000
r10: 00000000  r9 : 00000000  r8 : 00000000
r7 : 00000000  r6 : 005fd8d0  r5 : 000000d0  r4 : 005ff278
r3 : 0041f8d0  r2 : 006b4700  r1 : 00000001  r0 : 00000000
Flags: nzCv  IRQs on  FIQs on  Mode USER_32  ISA ARM  Segment user
Control: 0000397f  Table: 01a94000  DAC: 00000015
[<8000ee84>] (unwind_backtrace+0x0/0xf4) from [<8000fb7c>] (__do_user_fault+0x94/0xa0)
[<8000fb7c>] (__do_user_fault+0x94/0xa0) from [<8000fdc4>] (do_page_fault+0x1b8/0x360)
[<8000fdc4>] (do_page_fault+0x1b8/0x360) from [<80008278>] (do_PrefetchAbort+0x34/0x98)
[<80008278>] (do_PrefetchAbort+0x34/0x98) from [<800097d4>] (ret_from_exception+0x0/0x10)
Exception stack(0x815bffb0 to 0x815bfff8)
ffa0:                                     00000000 00000001 006b4700 0041f8d0
ffc0: 005ff278 000000d0 005fd8d0 00000000 00000000 00000000 00000000 00000000
ffe0: 005ff278 7ee30cb8 004ccdb8 0041f8d0 20000010 ffffffff
Bus error
RTC is 8563
RTC-PCF8563C4307 init...OK
Current RTC dateSQUASHFS error: Unable to read data cache entry [fba4c]
/time is 2000-18SQUASHFS error: Unable to read page, block fba4c, size 15984
-42 00:16:53
##pgd = 81468000
###########Read [0041dcfc] *pgd=015f0831RTC is Error####, *pte=00000000###########
, *ppte=00000000
Pid: 285, comm:            Challenge
PC is at 0x41dcfc
LR is at 0x4044ec
pc : [<0041dcfc>]    lr : [<004044ec>]    psr: 20000010
sp : 7ef9aaa0  ip : 004bffb0  fp : 7ef9ab4c
r7 : 00000000  r6 : 000000d9  r5 : 005fd56c  r4 : 005ff278
r3 : 00724020  r2 : 00000000  r1 : 00724020  r0 : 00000000
Control: 0000397f  Table: 01468000  DAC: 00000015
ffa0:                                     00000000 00724020 00000000 00724020
ffc0: 005ff278 005fd56c 000000d9 00000000 00000000 00000000 00000000 7ef9ab4c
ffe0: 004bffb0 7ef9aaa0 004044ec 0041dcfc 20000010 ffffffff
Bus error
 gpio_offset1_virtul_addr = 0xFE00004C
 gpio_offset2_virtul_addr = 0xFE000050
 gpio_offset3_virtul_addr = 0xFE000058
 gpio_offset4_virtul_addr = 0xFE00005C
register gpio_drv on minor = 255 (0)
 * Welcome to use irda_dev,        *
 * dev_data_alloc_specific done
 * gpio 16, protocol 0 ver VER:1.1
 * driver_probe done, irq_no 48 io_vadr 0x88FFE000, io_padr 0x99C00000 0x81E67980
Welcome to use ks_dev, 20120731
 * module_init_func
 * register_driver
 * driver_probe
set_pinmux set as 0x50 0x00001401 OK
gpio in 37
gpio in 38
gpio in 40
gpio in 33
gpio in 35
gpio out 36
gpio out 39
gpio out 45
gpio out 46
gpio out 49
key_o_bits 0x01D20000 key_i_bits 0x062C0000
 * register_cdev
driver_probe done, io_vadr 0x89566000, io_padr 0x99D00000 0x81E67880
netint [ethname] [Ipaddress] [Netmask] [Gateway]
Example for set all(ip, netmask, gateway):
netinit eth0 192.168.1.100 255.255.0.0 192.168.1.1
Example for set ip :
netinit 192.168.1.34
Example for set netmask :
netinit NULL 255.255.0.0(keep original ip)
LIBDVR(NetSetMAC 1203):ifconfig eth0 down Successful
LIBDVR(NetSetMAC 1216):ifconfig eth0 hw ether 00:c6:85:b5:1e:dc Successful
HW reset
LIBDVR(NetSetMACnetinit uses obsolete (PF_INET,SOCK_PACKET)
 1237):ifconfig eth0 up Successful
mac : 0-c6-85-b5-1e-dc
Utils : Current Network Seting===>
Ip = 192.168.1.15
Netmask = 255.255.255.0
Gateway = 192.168.1.1
Mac = 00:c6:85:b5:1e:dc
SQUASHFS error: xz_dec_run error, data probably corrupt
SQUASHFS error: squashfs_read_data failed to read block 0xfba4c
cp: read error: Input/output error
   Press q -> ENTER to exit boot procedure? phy speed is 10, half duplex
HW reset
  Video Front End: cx25930
  Video Mode: PAL
  Chip Version: 82830002
  RootFS Version: 00_2015-01-13
  MTD Version:
BusyBox v1.19.4 (2014-12-04 20:13:15 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Такое впечатление что прошивка стоит не от него. Зачем он ищет cx25930? насколько я понял это преобразователь, но там стоит nvp6114.
В общем просьба поставить меня на путь истенный.
Re: Помогите с регистратором SV Plus R-704
Сообщение dede » 17 окт 2018, 08:39
Содержимое флеш побито, ищите прошивку, у спецвижена спрашивали уже? Что-то на GM, похоже. Лог с самого начала выкладывайте
chpok
Сообщение chpok » 17 окт 2018, 11:11
Написал в сапорт spezvision, жду ответ.
Лог полностью не могу выложить не хватает буфера в putty.
Сообщение dede » 17 окт 2018, 20:12
Ну поставьте больше scrollback в путти, это же не проблема
Fluffykrsk
Сообщение Fluffykrsk » 18 окт 2018, 07:45
Какой-то клон CTV что ли. Их реги на таких платформах шли вроде.
