ip камера GRAND VISION
aavan
Сообщение aavan » 31 окт 2018, 14:56
Доброго всем времени суток!Привезли ip камеру GRAND VISION .На наклейке MODEL: 580.,SYSTEM:PAL 4MP.
Help & printenv:
GK7101 # help
[PROCESS_SEPARATORS] help
? - alias for 'help'
bootz - boot Linux zImage image from memory
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
download- Download FileSystem by FanCong
env - environment handling commands
md - memory display
mw - memory write (fill)
run - run commands in an environment variable
sf - SPI flash sub-system
tftpboot- boot image via network using TFTP protocol
version - print monitor, compiler and linker version
GK7101 # printenv
[PROCESS_SEPARATORS] printenv
arm_freq=0x00112032
baudrate=115200
bootargs=console=ttySGK0,115200 mem=46M rootfstype=cramfs root=/dev/mtdblock2 init=/linuxrc mtdparts=gk7101_flash:256K(uboot),3328K(kernel),2368K(app),1664K(web),192K(custom),384K(config)
bootcmd=setenv bootargs ${bootargs}; sf probe;sf read c1000000 40000 340000;bootm c1000000
bootdelay=2
bootfile=zImage
bsbsize=2M
ethact=gk7101
gatewayip=192.168.1.1
hostname="zview"
ipaddr=192.168.1.254
loadaddr=0xC1000000
mem=46M
netmask=255.255.255.0
phytype=0
serverip=192.168.1.252
sfkernel=0x50000
soctype=0
stderr=serial
stdin=serial
stdout=serial
лог загрузки:
U-Boot 2012.10 (Feb 29 2016 - 09:09:39) for GK7101 rb imx222 v1.00 (GOKE)
HAL: 20151223
DRAM: 128 MiB
Flash: not support 4X mode read:0xe52081ff
8 MiB
8 MiB
SF: Detected MX25L6465E with page size 256 B, sector size 64 KiB, total size 8 MiB
ERROR: Cannot import environment: errno = 0
at env_sf.c:337/env_relocate_spec()
env_import failedIn: serial
Out: serial
Err: serial
Net: arm_freq(600MHz)..............0x112032
use int MII..............
gk7101
encrypt success!
Hit Ctrl+C to stop autoboot: 0
[PROCESS_SEPARATORS] setenv bootargs ${bootargs}; sf probe;sf read c1000000 40000 340000;bootm c1000000
put param to memory
mem size (46)
bsb size (2)
the kernel image is zImage or Image
entry = 0xc1000000
## Transferring control to Linux (at address c1000000)...
Starting kernel ...
machid = 3988 r2 = 0xc0000100
Uncompressing Linux...
LZMA data is corrupt
-- System halted
Кто может опознать модель и подобрать прошивку?
Re: ip камера GRAND VISION
Сообщение dede » 31 окт 2018, 21:38
http://videon.spb.ru/forum/viewtopic.ph ... 1&start=12" onclick="window.open(this.href);return false;
