не позволяет очистеть раздел "config" камера Hi3518C
nik58
Re: не позволяет очистеть раздел "config" камера Hi3518C
Сообщение nik58 » 03 мар 2019, 09:43
добрый день.Вот лог после очистки,как знал сохранил.
U-Boot 2010.06 (May 19 2014 - 14:51:10)
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
In: serial
Out: serial
Err: serial
UpgradeSoftware:8346B000 V1.2
CheckUpgrade invalid maigc(0xd6f63aba, 0xaa5555aa)
hisilicon # sf probe 0
hisilicon # sf erase f80000 80000
Erasing at 0x1000000 -- 100% complete.
hisilicon # reset
resetting ...
0 MiB
In: serial
Out: serial
Err: serial
Image Name: Linux-3.0.8
Data Size: 2890856 Bytes = 2.8 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (pub@BVT-SDK-SERVER3) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Tue Mar 11 17:36:34 HKT 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 200000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10160
Kernel command line: mem=40M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),3M(kernel),11776K(rootfs),512K(config)
Memory: 40MB = 40MB total
Memory: 35088k/35088k available, 5872k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc3000000 - 0xfe000000 ( 944 MB)
lowmem : 0xc0000000 - 0xc2800000 ( 40 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc0513000 (5032 kB)
.data : 0xc0514000 - 0xc0537fa0 ( 144 kB)
.bss : 0xc0537fc4 - 0xc0555240 ( 117 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.16)
msgmni has been set to 68
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000f80000 : "rootfs"
0x000000f80000-0x000001000000 : "config"
Fixed MDIO Bus: probed
himii: probed
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
▒VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 132K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (510): /proc/510/oom_adj is deprecated, please use /proc/510/oom_score_adj instead.
[RCS]: /etc/init.d/S10mpp
/etc/init.d/S10mpp: line 15: set_path_before: not found
/etc/init.d/S10mpp: line 16: set_path_before: not found
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20090030: 0x00000300 --> 0x00004F01
[END]
0x2005003c: 0x000001E0 --> 0x000001E2
[END]
----Sensor Type: ar0130 ----
Set GPIO9_0
0x200F00C8: 0x00000001 --> 0x00000001
[END]
Set GPIO9_1
0x200F00CC: 0x00000001 --> 0x00000001
[END]
Set GPIO9_4
0x200F00D8: 0x00000001 --> 0x00000001
[END]
Set GPIO5_3
0x200F00C0: 0x00000001 --> 0x00000000
[END]
Set GPIO0_1
0x200F0124: 0x00000000 --> 0x00000000
[END]
Set GPIO0_2
0x200F0128: 0x00000000 --> 0x00000000
[END]
Set GPIO0_7
0x200F013C: 0x00000000 --> 0x00000001
[END]
Set GPIO0_3
0x200F012C: 0x00000000 --> 0x00000000
[END]
Set GPIO0_4
0x200F0130: 0x00000000 --> 0x00000000
[END]
0x200f0138: 0x00000001 --> 0x00000000
[END]
0x20140400: 0x00000020 --> 0x00000061
[END]
0x20140100: 0x00000040 --> 0x00000040
[END]
hi3518_base: module license 'Proprietary' taints kernel.
pa:82800000, va:c3200000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok! add for 24c04
gpio_0_base_addr_virtual:0xc3500000 !
Set Gpio0_6 dir to 1!
Set Gpio0_6 bit to 0!
Set Gpio0_6 bit to 1!
hi_gpio_init_hrtimer!
insmod: can't insert 'extdrv/ssp_ad9020.ko': No such file or directory
acodec inited!
insert audio
==== Your input Sensor type is ar0130 ====
entry jb_hi_authen0104_init
DMS_Read0104Data failed
no ic ack
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 1, nodeamon= 0)
ln: /usr/lib/libnetpt.so: File exists
no log server config file
read log config ok
[RCS]: /etc/init.d/S80network
(none) login: [01-01-08:00:12][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-08:00:12][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-08:00:12][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
[01-01-08:00:12][TRACE][main] ========== HI3518 PLATFORM BAICMODULE Build:Dec 4 2014 15:23:08 ==============
#### I2C_24C04_Write_Data, nPart=0, nPos=120, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=122, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=124, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=126, nSizeSet=2
#### I2C_24C04_Read_Data, nPart=0, nPos=120, nSizeGet=8
wait write ack ok timeout--4097!
[error -- File: ic_at0104.c, Line: 403, Function: CheckIsOnline] Check Is Online Failed Return 0
[01-01-08:00:36][TRACE][main] check_encrypt err .............................................(-1)
[01-01-08:00:36][TRACE][main] MAC [0x0:0xc3:0x40:0xf2:0x38:0x7c]
[01-01-08:00:36][WARNING][main] [jiabo video][APP]: chek encrypt chip fail!
[01-01-08:00:36][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-08:00:36][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-08:00:36][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-08:00:36][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-08:00:36][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-08:00:36][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-08:00:36][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-08:00:36][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
SystemCall_msg cli_pid 768
[01-01-08:00:36][ERR][main] can't open mt9d131
[01-01-08:00:36][ERR][main] can't open ov10630
[01-01-08:00:36][ERR][main] can't open ip2986
[01-01-08:00:36][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-08:00:36][ERR][main] can't open xf_ov2715
[01-01-08:00:36][ERR][main] can't open nvp2400
[01-01-08:00:36][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-08:00:36][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = ,m_nHi3518VIChip = 30!
[01-01-08:00:36][TRACE][main] DMS_vadc_hi3518_Open-318: s32Ret=0x00000000,u32ChipId=0x3518E100!
[01-01-08:00:36][TRACE][main] :::::::::::::::::: VICHIP HI3518 OV9712B
[01-01-08:00:36][ERR][main] DMS_TW2866_VAD_Open Failed!
[01-01-08:00:36][TRACE][main] :::::::::::::::::: AICHIP JB_TLV320
[01-01-08:00:36][TRACE][main] nChannelNum [1], nKeyCheckRes [1]
[01-01-08:00:36][TRACE][main] end of free..
[01-01-08:00:36][TRACE][main] globelMalloc ChannelCount:1
umount: tmpfs busy - remounted read-only
[01-01-08:00:36][TRACE][main] end of malloc..
#### dms_read_protect_key_information_config 1983
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_protect_key_info.json) fail(2)
[01-01-08:00:36][ERR][main] paramcfg.c(145) - 2 , No such file or directory
Error before: [(null)], cfgbuf:
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_protect_key_info.config) fail(2)
Enter Start_udhcpc_Func thread!
umount: can't remount /dev/root read-only
umount: can't remount rootfs read-only
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
Restarting system.
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
0x2005003c: 0x000001E2 --> 0x000001E2
[END]
----Sensor Type: ovb9712 ----
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
Jan 1 08:00:04 udevd-event[615]: udev_node_mknod: mknod(/dev/sys, 020660, 10, 56) failed: File exists
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
==== Your input Sensor type is ovb9712 ====
no ic ack
read log config ok
(none) login: [01-01-08:00:11][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-08:00:11][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-08:00:11][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
[01-01-08:00:35][TRACE][main] check_encrypt err .............................................(-1)
[01-01-08:00:35][TRACE][main] MAC [0x0:0xc3:0x40:0xf2:0x38:0x7c]
[01-01-08:00:35][WARNING][main] [jiabo video][APP]: chek encrypt chip fail!
[01-01-08:00:35][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-08:00:35][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-08:00:35][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-08:00:35][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-08:00:35][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-08:00:35][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-08:00:35][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-08:00:35][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
[01-01-08:00:35][ERR][main] can't open mt9d131
[01-01-08:00:35][ERR][main] can't open ov10630
[01-01-08:00:35][ERR][main] can't open ip2986
[01-01-08:00:35][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-08:00:35][ERR][main] can't open xf_ov2715
[01-01-08:00:35][ERR][main] can't open nvp2400
[01-01-08:00:35][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-08:00:35][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = sensortype=ovb9712,m_nHi3518VIChip = 30!
Exit Start_udhcpc_Func thread!
[01-01-08:00:36][TRACE][main] dms_netplatform_init_config(305) ########## buff:lrwxrwxrwx 1 root root 34 Jan 1 08:00 /usr/lib/libnetpt.so -> /usr/netview/app/lib/libnetpt.so.3
[01-01-08:00:36][TRACE][main] dms_netplatform_init_config(321) ########## enPlatManufacture:3
[01-01-08:00:36][TRACE][main] exit InitDefaultConfigFile!
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_dev_fatal.json) fail(2)
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_dvs.fatal.config) fail(2)
[01-01-08:00:36][TRACE][main] +++++++++==========++++++ g_fatal_param.default_flag = 0
[01-01-08:00:36][TRACE][main] +++++++++==========+++++ g_fatal_param.fatal_param_len = 0
[01-01-08:00:36][TRACE][main] [4]: initialize the system parameter with HARDRESET default value.
[01-01-08:00:36][TRACE][main] initSystem call JB_initDefaultSet
#### dms_default_Channel_AlarmOut 680
[01-01-08:00:36][TRACE][main] +++++++++++++++++ dwStreamFormat:6
[01-01-08:00:36][TRACE][main] NAME-DEFAULT-1!
[01-01-08:00:36][TRACE][main] DEVICE_MAC-DEFAULT--1!
[01-01-08:00:36][TRACE][main] PRODUCT_IP_SET-DEFAULT-1!
[01-01-08:00:36][TRACE][main] VIDEOSTARDAD-DEFAULT-1!
[01-01-08:00:36][TRACE][main] DDNS-DEFAULT-1!
[01-01-08:00:36][TRACE][main] UPNP-DEFAULT-1!
[01-01-08:00:36][TRACE][main] WIFI-DEFAULT-1!
[01-01-08:00:36][TRACE][main] PLATFORM-DEFAULT-1!
[01-01-08:00:36][TRACE][main] COLOR_PARA-DEFAULT-1!
#### dms_write_Channel_AlarmOut 721
[01-01-08:00:36][TRACE][main] jiabo video startup watchdog ok
[01-01-08:00:36][TRACE][main] jb_set_wdt_timeout cur_margin is 3c
[01-01-08:00:36][TRACE][main] jb_get_wdt_timeout cur_margin is 3c
#### dms_read_sensor_type 2756
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_sensor.json) fail(2)
[01-01-08:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_sensor.config) fail(2)
[01-01-08:00:37][TRACE][main] uiSensor=6090552
[01-01-08:00:37][ERR][main] JB_Check_Sensor_Type: LastViChip value(6090552) failure!
[01-01-08:00:37][TRACE][main] 1.wWidth1 = 1280, wHeight1 = 720!
[01-01-08:00:37][TRACE][main] 2.wWidth1 = 1280, wHeight1 = 720!
[01-01-08:00:37][TRACE][main] [DMS_DEV_GPIO_Init ,540]: 1.0--GPIO_I2C_GetDir nDevAddr:2 nRegAddr:2 nvalue:0
[01-01-08:00:37][TRACE][main] baud is 2400
[01-01-08:00:37][TRACE][main] [lg][APP]: Start up tty OK!
[01-01-08:00:37][TRACE][main] Entry JB_initCodec
[01-01-08:00:37][TRACE][tty] ================== Entry thread detectTtyThread pthread_self 1086325952 getpid() 768
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_init 505: m_nHi3518VIChip = 30!
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_init 506: stImageAttr.u16Width = 1280!
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_init 507: stImageAttr.u16Height = 720!
[01-01-08:00:37][TRACE][main] DMS_Vadc_OV9712B_ISP_Init: stIspAeAttr.bByPassAE = 0!
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_ISP_OV9712_Init Success!
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_init: init success!
[01-01-08:00:37][TRACE][main] maxChNum=1, mode=1, enDeviceType=0
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:117 VideoOsdInit....
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:165 VideoOsdInit...ok
[01-01-08:00:37][TRACE][main] EnableVi ViDevId:0, ViChn:0
[01-01-08:00:37][TRACE][main] EnableVi stCapSize u32Width:1280, u32Height:720
[01-01-08:00:37][TRACE][main] EnableVi stDestSize u32Width:1280, u32Height:720
[01-01-08:00:37][TRACE][main] bit_rate:3072,framerate:25,Quality:0,gop_size:50,RateType:1
[01-01-08:00:37][TRACE][main] InitVenc VpssGrp:0 VpssChn:0 VeGrpChn:0 VeChn:0
[01-01-08:00:37][TRACE][main] InitVenc encode stream 0:0 format is 6 u32BitRate:3072
[01-01-08:00:37][TRACE][main] Enable Encode VeGroup:0 VeChn:0 ViDev:0 ViChn:0
[01-01-08:00:37][TRACE][main] DMS_Enable_Encode OK!!!!!!!!!!!!!!!!
[01-01-08:00:37][TRACE][main] bit_rate:512,framerate:9,Quality:0,gop_size:50,RateType:1
[01-01-08:00:37][TRACE][main] InitVenc VpssGrp:0 VpssChn:1 VeGrpChn:1 VeChn:1
[01-01-08:00:37][TRACE][main] InitVenc encode stream 0:1 format is 15 u32BitRate:512
[01-01-08:00:37][TRACE][main] Enable Encode VeGroup:1 VeChn:1 ViDev:0 ViChn:1
[01-01-08:00:37][TRACE][main] jb_init_venc DMS_SECOND_STREAM OK ##################
[01-01-08:00:37][TRACE][main] MD chinnel 0 OK
[01-01-08:00:37][TRACE][main] init_hi_video_mask[0]: bshow(0),start_x(0), start_y(0), width(0), hight(0)
[01-01-08:00:37][TRACE][main] DMS_Video_Mask-hiVencWidth=1280, hiVencHeight=720!
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:ShowVideoOsd_Time LINE:1008 ShowVideoOsd_Time...chn=0, type=0...
[01-01-08:00:37][TRACE][main] xoffset=18,yoffset=12,w=304,h=32!
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:OsdCreateRegion LINE:2699 OsdCreateRegion chngroup 0:index(0),handle(0)
[01-01-08:00:37][TRACE][main] main group is 0 sub is 1
[01-01-08:00:37][TRACE][main] SUB setosd
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:ShowVideoOsd_Time LINE:1008 ShowVideoOsd_Time...chn=0, type=1...
[01-01-08:00:37][TRACE][main] xoffset=9,yoffset=6,w=304,h=32!
[01-01-08:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:OsdCreateRegion LINE:2699 OsdCreateRegion chngroup 1:index(0),handle(8)
[01-01-08:00:37][TRACE][main] JB_Video_Update_OSD--pInfo->dwChannel=0!
[01-01-08:00:37][TRACE][main] pInfo->stOsd[0].bOsdEnable = 0!
[01-01-08:00:37][TRACE][main] pInfo->stOsd[1].bOsdEnable = 0!
[01-01-08:00:37][TRACE][main] pInfo->stOsd[2].bOsdEnable = 0!
[01-01-08:00:37][TRACE][main] pInfo->stOsd[3].bOsdEnable = 0!
[01-01-08:00:37][TRACE][main] pInfo->stOsd[4].bOsdEnable = 0!
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00400000 nVal:0
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetAIAttr val:0
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000001 nVal:50
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000002 nVal:50
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000004 nVal:128
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000008 nVal:50
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000200 nVal:128
[01-01-08:00:37][TRACE][main] stSharpenAttr.bEnable=1,stSharpenAttr.bManualEnable=0!
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000800 nVal:1
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetDenoiseAttr bEnable:1
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00001000 nVal:44
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetDenoiseAttr u8ThreshTarget:44
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000020 nVal:128
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetAWBAttr u8RGStrength:128
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000040 nVal:128
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetAWBAttr u8BGStrength:128
[01-01-08:00:37][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00004000 nVal:1
[01-01-08:00:37][TRACE][main] HI_MPI_ISP_SetMEAttr u32ExpLine:1
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00010000 nVal:1
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00020000 nVal:8
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00040000 nVal:0
[01-01-08:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00080000 nVal:0
[01-01-08:00:37][TRACE][main] DMS_vadc_hi3518_DNSet enDNAction:0 bManul:0 WaitDNAction:2, tNow:37 LastDNActionTime:0
[01-01-08:00:37][TRACE][main] DMS_DEV_GPIO_SetIRCutState_Ex-986: nDay=0!
[01-01-08:00:38][TRACE][main] Set ircut to day mode!
[01-01-08:00:38][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-08:00:38][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00100000 nVal:0
[01-01-08:00:38][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000400 nVal:0
[01-01-08:00:38][TRACE][main] jb_start_adec--wType=19!
[01-01-08:00:40][TRACE][main] jb_start_aenc--wType=19!
[01-01-08:00:40][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_AI_Init @@@@@@@@@
[01-01-08:00:40][TRACE][main] 1_____gain_mic=0x0b!_____
[01-01-08:00:40][TRACE][main] 2_____gain_mic=0x00!_____
[01-01-08:00:40][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_Aenc_Init @@@@@@@@@
[01-01-08:00:40][TRACE][main] Befor JB_Video_jpegThread_Initial
[01-01-08:00:40][TRACE][main] JB_Video_jpegThread_Initial create JB_Video_jpegThread
[01-01-08:00:40][TRACE][main] Leave JB_initCodec
[01-01-08:00:40][TRACE][main] ================== thread JB_Video_jpegThread pthread_self 1141179584 getpid() 768
[01-01-08:00:40][TRACE][main] jiabo video startup rtc ok
[01-01-08:00:40][TRACE][JpegSnap] ................... Entry Video_jpegThread
[01-01-08:00:40][TRACE][main] ================== thread JB_Video_Auto_jpegThread pthread_self 1150145728 getpid() 768
[01-01-08:00:40][TRACE][main] DMS_InsertLog
[01-01-08:00:40][TRACE][main] PRODUCT_IP_SET-DEFAULT-1!
[01-01-08:00:40][TRACE][main] ================== thread JB_Alarm_Thread pthread_self 1167631552 getpid() 768
[01-01-08:00:40][TRACE][dms_alarmproces] ================== thread dms_alarmprocess_thread pthread_self 1176630464 getpid() 768
[01-01-08:00:40][TRACE][dms_exceptalarm] ================== thread dms_exceptalarmprocess_thread pthread_self 1185678528 getpid() 768
[01-01-08:00:40][TRACE][JpegSnap] InitVenc VpssGrp:0 VpssChn:0 VeGrpChn:3 VeChn:3
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.bByFrame = 1
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.bVIField = 0
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.u32BufSize = 1382400
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.u32Priority = 1
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.u32PicWidth = 1280
[01-01-08:00:40][TRACE][JpegSnap] stJpegAttr.u32PicHeight = 720
[01-01-08:00:40][TRACE][JpegSnap] Enable Encode VeGroup:3 VeChn:3 ViDev:0 ViChn:0
[01-01-08:00:40][TRACE][JpegSnap] DMS_Enable_Encode OK!!!!!!!!!!!!!!!!
[01-01-08:00:40][TRACE][JpegSnap] Get-stJpegParam.u32Qfactor = 90!
[01-01-08:00:40][TRACE][JpegSnap] Set-u32Quality[2] = 80!
[01-01-08:00:40][TRACE][JpegSnap] ShowSnapVideoOsd VeGrpChn:3
[01-01-08:00:40][TRACE][JpegSnap] FILE:HI3511Osd.c FUNCTION:ShowSnapVideoOsd LINE:2542 Put bitmap to region 0 failed while displaying 0xa0128003
[01-01-08:00:40][TRACE][JpegSnap] ShowSnapVideoOsd--OK
[01-01-08:00:40][TRACE][JpegSnap] ShowSnapVideo_Text--OK
[01-01-08:00:40][TRACE][main] NAME-DEFAULT--1!
[01-01-08:00:40][TRACE][JpegSnap] DMS VENC SNAPSHOT len:115049
[01-01-08:00:40][TRACE][main] cmd = ifconfig eth0 hw ether 00:c3:40:f2:38:7c!
[01-01-08:00:40][TRACE][JpegSnap] DeleteSnapVideo_Text--OK
[01-01-08:00:40][TRACE][JpegSnap] DeleteSnapVideoOsd--OK
[01-01-08:00:40][TRACE][JpegSnap] Video Jpeg Snap toclientMsg->nID [0] nChannel:0 nErrorCode:7 nCommand:536870921
[01-01-08:00:40][TRACE][snap_process_th]ADDRCONF(NETDEV_UP): eth0: link is not ready
snap_process_thread 206, start process data.SnapTarget:0x8,g_snapnum:1
[01-01-08:00:40][ERR][snap_process_th] jbnet.c(520) - 0 , Success
[01-01-08:00:40][TRACE][main] set_net_phyaddr cmd [ifconfig eth0 hw ether 00:c3:40:f2:38:7c]
udhcpc (v1.16.1) started
Sending discover...
[01-01-08:00:41][TRACE][main] ================== thread sysTimeThread pthread_self 1158939840 getpid() 768
PHY: himii:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[01-01-08:00:42][TRACE][sysTime] dhcp_tick=1!
SYS_GetLocalCurPts hi_sched_clock error u64TimeNow=3075260,u64TimeLast=42949678380
[01-01-08:00:43][TRACE][sysTime] dhcp_tick=2!
Sending discover...
[01-01-08:00:44][TRACE][dms_alarmproces] DMS_vadc_hi3518_DNSet enDNAction:1 bManul:0 WaitDNAction:2, tNow:44 LastDNActionTime:37
[01-01-08:00:44][TRACE][dms_alarmproces] DMS_DEV_GPIO_SetIRCutState_Ex-986: nDay=1!
[01-01-08:00:44][TRACE][sysTime] dhcp_tick=3!
Sending select for 192.168.1.100...
Lease of 192.168.1.100 obtained, lease time 7200
deleting routers
route: SIOCDELRT: No such process
adding dns 192.168.1.1
[01-01-08:00:44][TRACE][main] system udhcpc -n return 0,g_bkill_dhcp=0
[01-01-08:00:44][TRACE][main] 1.Get Network IP :192.168.1.100
[01-01-08:00:44][TRACE][main] 1.Get NetMask IP :255.255.255.0
[01-01-08:00:44][TRACE][main] 1.Get Gateway IP :192.168.1.1
[01-01-08:00:44][TRACE][main] Get DNSServer IP :192.168.1.1
[01-01-08:00:44][TRACE][main] @@@@@@@@@ port=80
Thttpd Module Build:Oct 31 2014 11:33:27
[01-01-08:00:44][TRACE][main] g_iconv = 42704224!
thttpd_start port:80
[01-01-08:00:44][TRACE][main] p1=IPCAM, size1 = 5!
[01-01-08:00:44][TRACE][main] p2=IPCAM, size2 = 1018!
[01-01-08:00:44][TRACE][main] timer:0,outputbytes:105,writebytes:105,totalbytes:105!
[01-01-08:00:44][TRACE][main] <!--
var vPort = 8200;
var vUPnPPort = 8200;
var vDevIP = "192.168.1.100";
var ServerName = "IPCAM";
[01-01-08:00:45][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbsysinit.c, 117
@@@@@@@@@@DDNSServer_Start 16 DDNS START!!!!!!!!
[01-01-08:00:45][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1303
NewDDNSSetting.stDDNS[0].nUpdateTime=1800!
nSleepCount=60!
connect to ddns server http://www.dvripc.cn:80" onclick="window.open(this.href);return false;
[01-01-08:00:45][TRACE][main] ================== thread JB_MailSend_Thread pthread_self 1220256960 getpid() 768
[01-01-08:00:45][TRACE][MailSend] Send Email Thread Begin Run.
[01-01-08:00:45][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1076
[01-01-08:00:45][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1166(port:8200)
VS_BUF Module Build:May 22 2014 13:55:25
[01-01-08:00:45][TRACE][main] ================== thread TcpListenNatThread pthread_self 1230435520 getpid() 768
[01-01-08:00:45][TRACE][TcpListenNatThr] TcpListenNatThread Thread Start.
[01-01-08:00:45][TRACE][UdpSend] ================== thread UdpSendThread pthread_self 1238860992 getpid() 768
[01-01-08:00:45][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1266238656 getpid() 768
[01-01-08:00:45][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1274979520 getpid() 768
[01-01-08:00:45][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1257157824 getpid() 768
[01-01-08:00:45][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1284134080 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpMsgQuitThread pthread_self 1292780736 getpid() 768
[01-01-08:00:45][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1248515264 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataSendThread pthread_self 1301783744 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataSendThread pthread_self 1310790848 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataSendThread pthread_self 1319818432 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataSendThread pthread_self 1328473280 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataSendThread pthread_self 1337533632 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread TcpDataQuitThread pthread_self 1346290880 getpid() 768
PresetManage_Load: fopen failed:/jb_config/jb_rootfs/channel0_preset.config!
CruiseManage_Load: fopen failed:/jb_config/jb_rootfs/channel0_cruise.config!
ptzmng_control 25, dwCommand=13,dwParam=0
Call point:0, speed:0
[01-01-08:00:45][TRACE][main] ================== thread UdpPortListenThread pthread_self 1355629760 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread ListenThread pthread_self 1364174016 getpid() 768
[01-01-08:00:45][TRACE][main] ### Write_PtzData2Rs485...
[01-01-08:00:45][TRACE][OsdTime] [DMS_UpdateLog]--index=0,start:1970-1-1 0:0:0,run:1970-1-1 8:0:45,system running!!
[01-01-08:00:45][TRACE][main] JB_Wireless_Wifi_Start,wifi dev product id:2
[01-01-08:00:45][TRACE][main] fun:load_drivers line:1060,unsupport device:2!
[01-01-08:00:45][TRACE][ARP] ================== thread start_arp pthread_self 1399870656 getpid() 768
[01-01-08:00:45][TRACE][main] ================== thread jb_upnp_thread pthread_self 1391011008 getpid() 768
[01-01-08:00:45][TRACE][ARP] TTTTTTTTTTTTTTTTTTTTTTTTTT eth0 192.168.1.100 192.168.1.100 jbarping.c, 119
[01-01-08:00:45][TRACE][main] ================== thread wifiDaemon pthread_self 1381864640 getpid() 768
Hd_mng Module Build:Oct 20 2014 15:25:22
[01-01-08:00:45][TRACE][main] dms_sysnetapi_inter_start(78) ########## Config nPlatManufacture(3) != ln nPlatManufacture(0) buff:lrwxrwxrwx 1 root root 34 Jan 1 08:00 /usr/lib/libnetpt.so -> /usr/netview/app/lib/libnetpt.so.3
[01-01-08:00:45][ERR][main] Get stat on /usr/netview/app/lib/libnetpt.so.0 Error:No such file or directory
libmt version: v0.4build20090319-1732
HI_MT_Init: g_pMTConfig->rtspsvr.listen_port=554!
s32ValidChnNum:3,u32TotalUserNum=6!
src/hi_buf_abstract/hi_buffer_abstract.c:HI_BufAbstract_Init(166)-LIVE_MODE_1CHN1USER-success
Hi_mtrans Module Build:Sep 29 2014 17:12:22
MTRANS Init:conn num=6 minport-maxport=6000-7000,pack len=1452.
Start HI_VOD_Init.vod Successed.
HI_MT_StartSvr: g_pMTConfig->rtspsvr.listen_port=554!
rtsp listen port: 554!
open file error
RTSP Live svr Init ok.
Start MediaTrans.rtsp_streamsvr Successed.
[01-01-08:00:45][TRACE][main] [lg][APP]: initSystem OK!
[01-01-08:00:45][TRACE][main] MTMNT Init cfg chnid 11 , max connect num 2, bufsize 0,wChannelNum:1
[01-01-08:00:45][TRACE][main] the live mode is:0
rtsp_o_http Live svr Init ok.
RtspOhttp init Successeful!.
HI_ICGI_Register_Proc(62): Register rtsp process function.
[01-01-08:00:45][TRACE][main] !!!!!!########### onvif_discover dwWebPort:80 dwServerVersion:67116582 !!!!!!!!!!!
Onvif discovery server Module Build:Nov 7 2014 10:12:19
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:21
[01-01-08:00:45][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0xcdbbc
HI_ICGI_Register_Proc(62): Register onvif process function.
Onvif Module Build:Nov 5 2014 11:42:26
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:6
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:17
=============== Entry lib_xmai_start Dec 3 2014 15:02:57
[01-01-08:00:45][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x555f28
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:23
HI_ICGI_Register_Proc(62): Register cgi process function.
[01-01-08:00:45][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x53ba08
!!!!!!!!!!!init_cgi sucessful end !!!!!!!!!!!!!!!!!!
############# REC_Init (Dec 2 2014 15:17:50) #############
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:10
[01-01-08:00:45][TRACE][dms_alarmproces] Set ircut to night mode!
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:26
<line:70 fun:mobile_OWSP_Start [mobile]> OWSP Server(mobile) Port:15961
<line:37 fun:MobileServer_Start [mobile]> MobileServer_Start Success
[01-01-08:00:45][TRACE][main] szServer: F2387C.dvripc.cn!
check record...
p2p_server_int pdevicename = F2387C.dvripc.cn openp2pflag = 1
p2p_server_int pusername = admin ppassword = admin
IOTC_Initialize VERSION[10A0800]...
IOTC_Get_Version version = 10a0800 avversion = 1040400
ANTS_SERVER Module Build:Dec 4 2014 15:20:51
[01-01-08:00:45][TRACE][main] dms_sysnetapi_open successed handle:flag:20
[01-01-08:00:45][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x40c038
[ANTS][./src/libants.cpp:00002942:antsNetServiceStart] Initialize Begin
[I8-SERVER] [src/AntsServerSDK.cpp:1514:ANTS_SERVER_Initialize] Call Begin
FUN:gfxGetParameterLINE:1229 ANTS_MID_GET_DEVICECFG
[I8-SERVER] [src/AntsServer.cpp:00000547:StartThread] Create MainThread Handle 0x5f35d4c0
[I8-SERVER] [src/AntsServer.cpp:00000548:StartThread] Create HeartThread Handle 0x5fc494c0
[I8-SERVER] [src/AntsSVRBroadCastSession.cpp:47:CSVRBroadCastSession] BroadCast RecvPort[10000] SendPort[20000]
[I8-SERVER] [src/AntsSVRBroadCastSession.cpp:54:CSVRBroadCastSession] Create BroadCastThread [0x605484c0]
[I8-SERVER] [src/AntsServerSDK.cpp:1641:ANTS_SERVER_Initialize] Create AlarmThread 0x60e1b4c0
[I8-SERVER] [src/AntsServerSDK.cpp:1652:ANTS_SERVER_Initialize] Call End
[ANTS][./src/libants.cpp:00002944:antsNetServiceStart] Initialize
[ANTS][./src/libants.cpp:00002945:antsNetServiceStart] Initialize End
================== thread ANTS_SERVER_MediaThread 0 pthread_self 1634600128 getpid() 768
================== thread ANTS_SERVER_MediaThread 1 pthread_self 1643893952 getpid() 768
================== thread ANTS_SERVER_DataThread pthread_self 1652454592 getpid() 768
Insert a new node(813--813--thttpd_start_main) success!
gethostbyname error
tmp_ip = 59.53.245.106
Insert a new node(833--833--OSDTimeUpdateThread) success!
connect the remote server ok sock = 41
centerddns_tcp_send send error sendlen:-1
[01-01-08:01:03][TRACE][ddns] 2here p2p_server_start()
p2p_client_getuid_by_easyeye deviceid = F2387C realservername = p2p.dvripc.cn
macc:00C340F2387C
here:
Insert a new node(831--831--UdpPortListenThread) success!
Insert a new node(832--832--ListenThread) success!
p2p_client_getuid_by_easyeye 3213 Error Success
macc:00C340F2387C
here:
macc:00C340F2387C
here:
macc:00C340F2387C
here:
gethostbyname error
[01-01-08:02:20][TRACE][ddns] 2here p2p_server_start()
macc:00C340F2387C
here:
[01-01-08:02:41][TRACE][Listen] hConnSock = 41
[01-01-08:02:41][TRACE][Listen] Start Logon accept()........... from 192.168.1.7:49169 accept_sock= 41, tid:1364174016
[01-01-08:02:41][TRACE][Listen] ================== thread access_listen_ret_thread pthread_self 1661387968 getpid() 768
[01-01-08:02:41][TRACE][Client] index=0, admin-admin
[01-01-08:02:41][TRACE][Client] 0x0 0x0 0x0 0x0 0x0 0x0====0x74 0xDE 0x2B 0x61 0xF7 0x15
[01-01-08:02:41][TRACE][Client] bNameCheck:1, bPasswordCheck:1, bUserIpCheck:1, bWetherCheck:0, bUserMac:1
[01-01-08:02:41][TRACE][Client] SOCK_LOGON ok...
[01-01-08:02:41][TRACE][TcpMsgRecv] ReceiveFun nCommand:0x10000007
[01-01-08:02:41][TRACE][TcpMsgRecv] channelcom:1
[01-01-08:02:41][TRACE][TcpMsgRecv] Sending All Uer
[01-01-08:02:41][TRACE][TcpMsgRecv] ReceiveFun nCommand:0x1000000b
szFileName:/usr/netview/app/ptz/pelco-d.cod
[01-01-08:02:41][TRACE][TcpMsgRecv] ### pPtz->szPTZData?? =0
[01-01-08:02:41][TRACE][TcpMsgRecv] ReceiveFun nCommand:0x5
[01-01-08:02:42][TRACE][OsdTime] [DMS_UpdateLog]--index=0,start:1970-1-1 0:0:0,run:1970-1-1 8:2:42,system running!!
[03-02-20:39:09][TRACE][TcpMsgRecv] DMS_InsertLog
[03-02-20:39:09][TRACE][TcpMsgRecv] DMS_VENC_Request_IFrame : HI_MPI_VENC_RequestIDR channel 0 stream 0
[03-02-20:39:09][TRACE][OsdTime] [DMS_UpdateLog]--index=1,start:1970-1-1 8:2:42,run:2019-3-2 20:39:9,system running!!
macc:00C340F2387C
here:
[03-02-20:39:20][TRACE][TcpMsgRecv] ReceiveFun nCommand:0x63
[03-02-20:39:20][TRACE][TcpMsgRecv] DMS_VENC_Request_IFrame : HI_MPI_VENC_RequestIDR channel 0 stream 0
[03-02-20:39:20][TRACE][Listen] hConnSock = 70
[03-02-20:39:20][TRACE][Listen] Start Logon accept()........... from 192.168.1.7:49173 accept_sock= 70, tid:1364174016
[03-02-20:39:20][TRACE][Listen] ================== thread access_listen_ret_thread pthread_self 1661387968 getpid() 768
[03-02-20:39:20][TRACE][Client] [1] Open Channel ret[24], socktype:0, stream:1
[03-02-20:39:20][TRACE][Client] [2] Open Channel [0]
s32Chn 0 enStreamType 1 reader 7516532 index 16 bufferid 0
GetLastWriteNIFramPos u32ValidNumber 0
BUF_GetDataPoint failed
[03-02-20:39:20][TRACE][TcpDataSend] dms_sysnetapi_MBUF_AddReader chn 0 streamtype1 readerId 7516532
[03-02-20:39:20][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7516532 Jump Iframe
[03-02-20:39:20][TRACE][Client] DMS_VENC_Request_IFrame : HI_MPI_VENC_RequestIDR channel 0 stream 1
[03-02-20:39:20][TRACE][Listen] hConnSock = 71
[03-02-20:39:20][TRACE][Listen] Start Logon accept()........... from 192.168.1.7:49174 accept_sock= 71, tid:1364174016
s32Chn 0 enStreamType 0 reader 7514484 index 0 bufferid 0
[03-02-20:39:20][TRACE][Client] [1] Open Channel ret[24], socktype:0, stream:0
[03-02-20:39:20][TRACE][TcpDataSend] dms_sysnetapi_MBUF_AddReader chn 0 streamtype0 readerId 7514484
[03-02-20:39:20][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7514484 Jump Iframe
[03-02-20:39:20][TRACE][TcpMsgRecv] DMS_VENC_Request_IFrame : HI_MPI_VENC_RequestIDR channel 0 stream 1
[03-02-20:39:20][TRACE][Client] DMS_VENC_Request_IFrame : HI_MPI_VENC_RequestIDR channel 0 stream 0
[03-02-20:39:21][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7514484 Jump Iframe
[03-02-20:39:21][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7516532 Jump Iframe
и так еще долго пишет,я часть удалил -превышает разрешенное кол-во знаков
Сообщение dede » 03 мар 2019, 10:50
Да, видимо, тут нельзя стирать конфиг, более того, почему-то даже на крипту ругается, после стирания конфига... Однозначно нужно возвращать старый дамп и подменять в нем область конфига на "не битую".
nik58
Сообщение nik58 » 03 мар 2019, 12:20
в общих чертах ясно,но я не знаю какими командами воспользоваться,как их правильно написать,чтобы залить старый дамп через ftp сервер.у меня есть только опыт с командой "run",а в этом загрузчике нет такой команды и подробной статьи по восстановлению с таким загрузчиком не нашел.Если не трудно напишите, как должны быть построены команды.Судя по вопросам на форуме это будет интересно не только для меня.Спасибо.
Сообщение dede » 03 мар 2019, 14:23
tftp 82000000 newjffs2
sf probe 0; sf erase f80000 80000; sf write 82000000 f80000 80000
https://dropmefiles.com/gHIPE" onclick="window.open(this.href);return false;
nik58
Сообщение nik58 » 03 мар 2019, 14:31
dede,спасибо буду пробовать,я скачал файл по ссылке - я так понимаю это мой дамп подрихтованный
nik58
Сообщение nik58 » 03 мар 2019, 15:28
вот загрузил ваш файл
0 MiB
In: serial
Out: serial
Err: serial
CheckUpgrade invalid maigc(0xc6c63a3a, 0xaa5555aa)
hisilicon # tftp 82000000 newjffs2
Hisilicon ETH net controler
MAC: 00-00-23-34-45-66
TFTP from server 192.168.1.7; our IP address is 192.168.1.9
Download Filename 'newjffs2'.
Download to address: 0x82000000
Downloading: #################################################
done
Bytes transferred = 524288 (80000 hex)
hisilicon # sf probe 0;sf erase f80000 80000;sf write 82000000 f80000 80000
Writing at 0x1000000 -- 100% complete.
hisilicon #
nik58
Сообщение nik58 » 03 мар 2019, 15:42
а вот лог после перегрузки камеры.Что характерно в Onvif менеджере видеосигнала нет,а вот картинка с камеры рядом с надписями настроек (живое видео,стринг видео есть)
resetting ...
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
(none) login: [01-01-06:00:11][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-06:00:11][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-06:00:11][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
[01-01-06:00:12][TRACE][main] ========== HI3518 PLATFORM BAICMODULE Build:Dec 4 2014 15:23:08 ==============
[01-01-06:00:35][TRACE][main] check_encrypt err .............................................(-1)
[01-01-06:00:35][TRACE][main] MAC [0x0:0xea:0x89:0x79:0xdf:0xa1]
[01-01-06:00:35][WARNING][main] [jiabo video][APP]: chek encrypt chip fail!
[01-01-06:00:35][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-06:00:35][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-06:00:35][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-06:00:35][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-06:00:35][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-06:00:35][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-06:00:35][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-06:00:35][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
[01-01-06:00:35][ERR][main] can't open mt9d131
[01-01-06:00:35][ERR][main] can't open ov10630
[01-01-06:00:35][ERR][main] can't open ip2986
[01-01-06:00:35][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-06:00:35][ERR][main] can't open xf_ov2715
[01-01-06:00:35][ERR][main] can't open nvp2400
[01-01-06:00:35][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-06:00:35][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = ,m_nHi3518VIChip = 30!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_Open-318: s32Ret=0x00000000,u32ChipId=0x3518E100!
[01-01-06:00:36][TRACE][main] :::::::::::::::::: VICHIP HI3518 OV9712B
[01-01-06:00:36][ERR][main] DMS_TW2866_VAD_Open Failed!
[01-01-06:00:36][TRACE][main] :::::::::::::::::: AICHIP JB_TLV320
[01-01-06:00:36][TRACE][main] nChannelNum [1], nKeyCheckRes [1]
[01-01-06:00:36][TRACE][main] end of free..
[01-01-06:00:36][TRACE][main] globelMalloc ChannelCount:1
[01-01-06:00:36][TRACE][main] end of malloc..
[01-01-06:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_protect_key_info.json) fail(2)
[01-01-06:00:36][ERR][main] paramcfg.c(145) - 2 , No such file or directory
[01-01-06:00:36][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_protect_key_info.config) fail(2)
Restarting system.
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
Empty flash at 0x00030288 ends at 0x00031000
CLEANMARKER node found at 0x00031000, not first node in block (0x00030000)
Empty flash at 0x0003100c ends at 0x00032000
CLEANMARKER node found at 0x00032000, not first node in block (0x00030000)
Empty flash at 0x0003200c ends at 0x00033000
CLEANMARKER node found at 0x00033000, not first node in block (0x00030000)
Empty flash at 0x0003300c ends at 0x00034000
CLEANMARKER node found at 0x00034000, not first node in block (0x00030000)
Empty flash at 0x0003400c ends at 0x00035000
CLEANMARKER node found at 0x00035000, not first node in block (0x00030000)
Empty flash at 0x0003500c ends at 0x00036000
CLEANMARKER node found at 0x00036000, not first node in block (0x00030000)
Empty flash at 0x0003600c ends at 0x00037000
CLEANMARKER node found at 0x00037000, not first node in block (0x00030000)
Empty flash at 0x0003700c ends at 0x00038000
CLEANMARKER node found at 0x00038000, not first node in block (0x00030000)
Empty flash at 0x0003800c ends at 0x00039000
CLEANMARKER node found at 0x00039000, not first node in block (0x00030000)
Empty flash at 0x0003900c ends at 0x0003a000
CLEANMARKER node found at 0x0003a000, not first node in block (0x00030000)
Empty flash at 0x0003a00c ends at 0x0003b000
CLEANMARKER node found at 0x0003b000, not first node in block (0x00030000)
Empty flash at 0x0003b00c ends at 0x0003c000
CLEANMARKER node found at 0x0003c000, not first node in block (0x00030000)
Empty flash at 0x0003c00c ends at 0x0003d000
CLEANMARKER node found at 0x0003d000, not first node in block (0x00030000)
Empty flash at 0x0003d00c ends at 0x0003e000
CLEANMARKER node found at 0x0003e000, not first node in block (0x00030000)
Empty flash at 0x0003e00c ends at 0x0003f000
CLEANMARKER node found at 0x0003f000, not first node in block (0x00030000)
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
(none) login: [01-01-06:00:12][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-06:00:12][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-06:00:12][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
w
[03-03-18:19:42][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7514484 Jump Iframe
[03-03-18:19:43][TRACE][TcpDataSend] dms_sysnetapi_MBUF_GetReadPtrPos ReaderId 7514484 Jump Iframe
Сообщение dede » 04 мар 2019, 06:50
Тут два лога, они оба после заливания нового конфига или один старый?
nik58
Сообщение nik58 » 04 мар 2019, 08:31
добрый день.Первый лог это как я заливал ваш файл,а второй лог - файл залился,а дальше я дал команду reset и вот что получилось
nik58
Сообщение nik58 » 04 мар 2019, 08:32
то есть оба лога новые
Сообщение dede » 04 мар 2019, 08:36
https://dropmefiles.com/dN2KW" onclick="window.open(this.href);return false; это ваш старый конфиг, залейте его и покажите лог старта после заливки
nik58
Сообщение nik58 » 04 мар 2019, 08:40
хорошо,спасибо большое,приду с работы залью и отпишусь
