Сообщение
m31 » 09 мар 2019, 14:48
Спасибо большое, VirtualLink !!!
Пошла загрузка, но потом затыкается и крутит по кругу ошибку...
Я предполагаю из за того что нет одного из сетевых чипов M88E6071-NNC2 ?
Заказал на Алиэхпресс, буду ждать,
как поставлю - отпишусь...
Еще раз спасибо.
Bootrom start
Boot Media: SPI_NAND
Decrypt auxiliary code ...OK
Entry boot auxiliary code
Auxiliary code - v1.00
DDR code - V1.1.2 20160205
Build: Apr 19 2016 - 20:18:19
Reg Version: v1.5.1\
Reg Time: 2017/04/10 14:34:20
Reg Name: hi3798cv2dmd_hi3798cv200_DDR3-1866_1GB_16bitx2_4layers.reg
Boot auxiliary code success
Bootrom success
System startup
Relocate Boot
Jump to C code
Compressed-boot v1.0.0
Uncompress.....................Ok
System startup
Relocate Boot
Jump to C code
Fastboot 3.3.0-svn2968 (jenkins@centos234) (Nov 10 2017 - 15:29:37)
Fastboot: Version 3.3.0
Build Date: Nov 10 2017, 15:30:08
CPU: Hi3798Cv200
Boot Media: SPI-NAND
DDR Size: 1GB
Found flash memory controller hifmc100.
Nand ID: 0xEF 0xAA 0x21 0x00 0x00 0x00 0x00 0x00
maxclk:70M
Nand: WINBOND W25N01GV
Nand(HW-Auto): Block:128KB Page:2KB OOB:64B ECC:4bit/512 Chip:128MB*1
Boot Env on NAND
Env Offset: 0x00300000
Env Size: 0x00020000
Env Range: 0x00100000
SDK Version: HiSTBLinuxV100R005C00SPC031_20160601
logo........... Logo_Main!
--LT8612_Reset Success! Reset Count:0.
BMP_GetPixelFmt : 32
Cnfigure For SATA
CFG_COMBPHY: 0x1010
start_armboot LINE 599 0x1063
Hit any key to stop autoboot: 1 0
higmac_init(969): Get PhyId 0x1410db0
higmac_net_adjust_link(679): port_mode 0x9f
ETH1: PHY(phyaddr=0, rmii) link UP: DUPLEX=FULL : SPEED=100M
MAC: 14-A7-8B-93-6D-70
NET_autoLipDetect timeout
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'ID_3K02F73PAZ3DA51.txt'.
Download to address: 0x1000000
Downloading: *T T T
Retry count exceeded; starting again
NAND read: device 0 offset 0x500000, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 01000000 ...
Image Name: Linux-3.18.24_hi3798cv2x
Data Size: 4969806 Bytes = 4.7 MiB
Load Address: 02000000
Entry Point: 02000000
Verifying Checksum ... OK
Loading Kernel Image from 0x16777280 to 0x33554432 ... OK
OK
ATAGS [0x00000100 - 0x000003CC], 716Bytes
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.18.24_hi3798cv2x (jenkins@centos235) (gcc version 4.9.2 20140904 (prerelease) (gcc-4.9.2 + eglibc-2.19 (Build by czyong) Mon Mar 9 14:14:50 CST 2015) ) #1 SMP Sat Sep 2 10:31:38 CST 2017, svn:8109
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Hisilicon
[ 0.000000] cma: Reserved 52 MiB at 0x3bc00000
[ 0.000000] cma: Reserved 4 MiB at 0x3fc00000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] DT missing boot CPU MPIDR[23:0], fall back to default cpu_logical_map
[ 0.000000] PERCPU: Embedded 10 pages/cpu @df3c2000 s10944 r8192 d21824 u40960
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261128
[ 0.000000] Kernel command line: mem=1G console=ttyAMA0,115200 root=/dev/mtdblock3 rootfstype=squashfs rootwait mtdparts=hinand:3M(boot),2M(env),10M(kernel),54M(rootfs),10M(web),2M(custom),3M(logo),6M(logs),10M(config),8M(extend1),12M(backup),8M(extend2) mmz=ddr,0,0,50M vmalloc=500M dh_keyboard=0 load_modules=1
[ 0.000000] ==>start:"=0 load_modules=1" use_console:1
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14144(86%)
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 966456K/1048576K available (7256K kernel code, 424K rwdata, 2144K rodata, 450K init, 391K bss, 82120K reserved, 465808K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0000000 - 0xff000000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfc00000 ( 508 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0936528 (9402 kB)
[ 0.000000] .init : 0xc0937000 - 0xc09a7ac0 ( 451 kB)
[ 0.000000] .data : 0xc09a8000 - 0xc0a120e4 ( 425 kB)
[ 0.000000] .bss : 0xc0a120e4 - 0xc0a73edc ( 392 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:352
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[ 0.000010] Switching to timer-based delay loop, resolution 41ns
[ 0.000089] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000214] Console: colour dummy device 80x30
[ 0.000227] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.000234] pid_max: default: 32768 minimum: 301
[ 0.000300] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000305] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000574] CPU: Testing write buffer coherency: ok
[ 0.000591] ftrace: allocating 23669 entries in 70 pages
[ 0.021298] 1970-1-1 0:0:0 CPU is alive
[ 0.021344] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.021390] Setting up static identity map for 0x6938b8 - 0x693910
[ 0.022775] CPU: hi3798cv200
[ 0.023150] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.023487] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.023814] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.023838] Brought up 4 CPUs
[ 0.023845] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.023849] CPU: All CPU(s) started in SVC mode.
[ 0.026366] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.027020] regulator-dummy: no parameters
[ 0.028426] NET: Registered protocol family 16
[ 0.028693] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.032388] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.032395] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032411] Serial: AMBA PL011 UART driver
[ 0.032473] f8b00000.uart: ttyAMA0 at MMIO 0xf8b00000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.445966] console [ttyAMA0] enabled
[ 0.449778] f8b02000.uart: ttyAMA1 at MMIO 0xf8b02000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.475198] hisilicon-pcie: probe of f9860000.pcie failed with error -1
[ 0.481971] vgaarb: loaded
[ 0.484833] SCSI subsystem initialized
[ 0.488826] usbcore: registered new interface driver usbfs
[ 0.494341] usbcore: registered new interface driver hub
[ 0.499676] usbcore: registered new device driver usb
[ 0.504807] media: Linux media interface: v0.10
[ 0.509362] Linux video capture interface: v2.00
[ 0.514417] hisi_iommu_ptable_addr:phy 0x1e000000 size:0x400000
[ 0.520595] hisi_iommu_err_rdaddr :phy 0x1ee88800 size:0x200
[ 0.526507] hisi_iommu_err_wraddr :phy 0x1ee88a00 size:0x200
[ 0.532529] in hisi_iommu_domain_init start
[ 0.537905] in hisi_iommu_domain_init end
[ 0.542098] Advanced Linux Sound Architecture Driver Initialized.
[ 0.548769] Switched to clocksource arch_sys_counter
[ 0.565975] NET: Registered protocol family 2
[ 0.570675] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.577744] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.584212] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.590593] TCP: reno registered
[ 0.593816] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.599648] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.605983] NET: Registered protocol family 1
[ 0.610454] RPC: Registered named UNIX socket transport module.
[ 0.616369] RPC: Registered udp transport module.
[ 0.621067] RPC: Registered tcp transport module.
[ 0.625763] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.632443] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.639489] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.650147] VFS: Disk quotas dquot_6.5.2
[ 0.654273] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.662189] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.668479] ntfs: driver 2.1.31 [Flags: R/O].
[ 0.673013] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.679497] fuse init (API version 7.23)
[ 0.683785] msgmni has been set to 977
[ 0.687950] bounce: pool size: 64 pages
[ 0.691900] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.699295] io scheduler noop registered
[ 0.703216] io scheduler deadline registered (default)
[ 0.708362] io scheduler cfq registered
[ 0.715615] brd: module loaded
[ 0.720288] loop: module loaded
[ 0.723748] platform f9900000.hiahci: Driver ahci requests probe deferral
[ 0.730787] hifmc100: registerd new interface driver hifmc100.
[ 0.736682] hifmc100: Found flash memory controller hifmc100.
[ 0.749815] spinand: id: 0xEF 0xAA 0x21 0x00
[ 0.754109] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa
[ 0.760456] nand: Winbond W25N01GV
[ 0.763868] spinand: Block:128KB Page:2KB OOB:64B ECC:4bits/512 Chip:128MB maxclk:50M
[ 0.771798] flashcache: initialize spinand flash cache feature.
[ 0.777734] flashstats: Create spinand flash statistics interface.
[ 0.783925] flashstats: spinand:-read,-write,-erase,-ecc,
[ 0.789329] 12 cmdlinepart partitions found on MTD device hinand
[ 0.795327] Creating 12 MTD partitions on "hinand":
[ 0.800205] 0x000000000000-0x000000300000 : "boot"
[ 0.805369] 0x000000300000-0x000000500000 : "env"
[ 0.810404] 0x000000500000-0x000000f00000 : "kernel"
[ 0.815712] 0x000000f00000-0x000004500000 : "rootfs"
[ 0.890471] 0x000004500000-0x000004f00000 : "web"
[ 0.907899] 0x000004f00000-0x000005100000 : "custom"
[ 0.915658] 0x000005100000-0x000005400000 : "logo"
[ 0.924453] 0x000005400000-0x000005a00000 : "logs"
[ 0.929571] 0x000005a00000-0x000006400000 : "config"
[ 0.934851] 0x000006400000-0x000006c00000 : "extend1"
[ 0.940227] 0x000006c00000-0x000007800000 : "backup"
[ 0.945526] 0x000007800000-0x000008000000 : "extend2"
[ 0.950940] mtd-regop: Create spinand register operation interface, buffer size:8566
[ 0.959309] platform f9841000.ethernet: Driver hi_gmac_v200 requests probe deferral
[ 0.967317] PPP generic driver version 2.4.2
[ 0.971659] PPP BSD Compression module registered
[ 0.976359] PPP Deflate Compression module registered
[ 0.981409] NET: Registered protocol family 24
[ 0.985921] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.992453] ehci-pci: EHCI PCI platform driver
[ 0.996921] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.003100] ohci-pci: OHCI PCI platform driver
[ 1.007604] usbcore: registered new interface driver usb-storage
[ 1.013715] mousedev: PS/2 mouse device common for all mice
[ 1.019463] i2c /dev entries driver
[ 1.023007] usbcore: registered new interface driver uvcvideo
[ 1.028749] USB Video Class driver (1.1.1)
[ 1.032941] registered new interface driver himciv200
[ 1.502775] f9c40000.himciv200.SD: eMMC/MMC/SD Device NOT detected!
[ 1.541229] usbcore: registered new interface driver usbhid
[ 1.546797] usbhid: USB HID core driver
[ 1.554245] hiahci-phy: registered new sata phy driver
[ 1.559693] vdd-gpu: 650 <--> 1150 mV at 880 mV
[ 1.564486] usbcore: registered new interface driver snd-usb-audio
[ 1.570816] oprofile: hardware counters not available
[ 1.575861] oprofile: using timer interrupt.
[ 1.580156] Netfilter messages via NETLINK v0.30.
[ 1.584860] nfnl_acct: registering with nfnetlink.
[ 1.589775] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.595091] arp_tables: (C) 2002 David S. Miller
[ 1.599714] TCP: cubic registered
[ 1.603424] NET: Registered protocol family 10
[ 1.608288] NET: Registered protocol family 17
[ 1.612878] Registering SWP/SWPB emulation handler
[ 1.618212] open /SigFilePartition error
[ 1.720929] ahci f9900000.hiahci: SSS flag set, parallel bus scan disabled
[ 1.727813] ahci f9900000.hiahci: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 1.736510] ahci f9900000.hiahci: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
[ 1.746142] scsi host0: ahci_platform
[ 1.749972] ata1: SATA max UDMA/133 mmio [mem 0xf9900000-0xf9900fff] port 0x100 irq 102
[ 1.772818] libphy: higmac_mii_bus: probed
[ 1.777087] libphy: get_phy_device phyid 0xff000713
[ 1.782427] Higmac dma_sg_phy: 0x3fc7a000
[ 1.787360] ALSA device list:
[ 1.790326] No soundcards found.
[ 2.076783] ata1: SATA link down (SStatus 0 SControl 320)
[ 2.083608] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 2.090868] Freeing unused kernel memory: 448K (c0937000 - c09a7000)
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S99dahua
[ 2.501059] yaffs: dev is 32505864 name is "mtdblock8" rw
[ 2.506464] yaffs: passed flags ""
[ 2.552186] yaffs: dev is 32505863 name is "mtdblock7" rw
[ 2.557600] yaffs: passed flags ""
rm: can't remove '/mnt/mtd/Config/udhcpd.leases': No such file or directory
7z ANSI-C Decoder 9.20 : Igor Pavlov : Public domain : 2010-11-18
Extracting lib/ahci_platform.ko
Extracting lib/avs.ko
Extracting lib/dh_switch.ko
Extracting lib/dh_switch_common.ko
Extracting lib/driverbox.ko
Extracting lib/ehci-platform.ko
Extracting lib/hi_adec.ko
Extracting lib/hi_adsp.ko
Extracting lib/hi_advca.ko
Extracting lib/hi_aenc.ko
Extracting lib/hi_aflt.ko
Extracting lib/hi_aiao.ko
Extracting lib/hi_cipher.ko
Extracting lib/hi_common.ko
Extracting lib/hi_demux.ko
Extracting lib/hi_fb.ko
Extracting lib/hi_gpio.ko
Extracting lib/hi_gpio_i2c.ko
Extracting lib/hi_hdmi.ko
Extracting lib/hi_i2c.ko
Extracting lib/hi_ir.ko
Extracting lib/hi_jpeg.ko
Extracting lib/hi_jpge.ko
Extracting lib/hi_keyled.ko
Extracting lib/hi_mce.ko
Extracting lib/hi_media.ko
Extracting lib/hi_mmz.ko
Extr[ 3.399790] Load hi_media.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:25])
acting lib/hi_omxvdec.ko
Extracting lib[ 3.413918] Load hi_mmz.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:25])
/hi_otp.ko
Extracting lib/hi_pdm.ko
Extracting[ 3.429621] Load hi_common.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:27])
lib/hi_pmoc.ko
Extracting lib/hi_png.ko
Extracting lib/hi_pq.ko
Extr[ 3.447256] Load hi_tde.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:18])
acting lib/hi_pvr.ko
Extracting[ 3.461415] Load hi_otp.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:28])
lib/hi_pwm.ko
Extracting lib/hi_svdec.[ 3.476011] ko
Extracting l
ib/hi_sync.ko
E[ 3.480377] xtracting lib/hi_tde.ko
Extract[OSA-DRV] OSA Build on Nov 6 2017 at 16:33:46.
ing lib/hi_vdec.[ 3.491234] ko
Extracting lib/hi_venc.ko
E[OSA-DRV] SVN NUM: 6732.
xtracting lib/hi[ 3.500266] _vfmw.ko
Extrac
ting lib/hi_vou.[ 3.503277] ko
Extracting l
[ 3.507683] ------------------------------------------------------------
ib/hi_vpss.ko
E[ 3.507686] driverbox.ko SVN version:23896 build date: Mon, 06 Nov 2017 16:28:12 +0800
xtracting lib/hi[ 3.507687] ------------------------------------------------------------
_wdg.ko
Extract[ 3.507871] open hwid config file failed
ing lib/kds.ko
[ 3.508558] ProlicyTable[0] = 0
[ 3.508558] ProlicyTable[1] = 2
[ 3.508558] ProlicyTable[2] = 1
[ 3.508558] ProlicyTable[3] = 0
[ 3.508558] ProlicyTable[4] = 0
[ 3.508558] ProlicyTable[5] = 0
[ 3.508558] ProlicyTable[6] = 0
[ 3.508558] ProlicyTable[7] = 0
[ 3.508558] ProlicyTable[8] = 0
[ 3.508558] [DRVBOX] Default product_pre_deal
Extracting lib/l[ 3.514153] system gpio infor:10111000
ibahci.ko
Extra[ 3.514167] [DRVBOX] our product ID: 0x000002D8
cting lib/libahc[ 3.514170] [DRVBOX] our board ID: 0x00000307
i_platform.ko
E[ 3.514173] [DRVBOX] our product Type: NVR41XX_8P_4KS2
xtracting lib/ma[ 3.514176] host_hwid_value:[0x0020001900008566][0x0000000200000a84]
li_kbase.ko
Ext[ 3.514180] [DRVBOX] NICE, This System Has No I2c SwitchChips.
racting lib/ohci[ 3.514184] [DRVBOX] NICE, This System Has No Signal Selector.
-platform.ko
Ex[ 3.514278] Hisilicon Watchdog Timer: 0.01 initialized. default_margin=180 sec (nowayout= 0, nodeamon= 1)
tracting lib/osa[ 3.514301] [DRVBOX] Total 0 spi bus registered
.ko
Extracting [ 3.514305] [ExpComDriver]: NICE, This System Has No ExpandComs.
lib/tntfs.ko
Ex[ 3.514308] This Machine Has No Expand Coms.
tracting lib/usb[ 3.514311] This Machine Has No LCD devices.
serial.ko
Extra[ 3.514315] [INFRARED]: NICE, This Machine Doesn't Support INFRARED.
cting lib/xhci-p[ 3.514319] [DRVBOX] WARN (dh_misc_init_device|149): UNKONW TYPE. Using Default.
lat-hcd.ko
Extr[ 3.514323] [DRVBOX] WARN (default_misc_init|66): Default default_misc_init
acting lib/
E[ 3.514374] NICE, The Kernel Supports BPA, But We Don't Use it.
verything is Ok
[ 3.514378] NICE, This System Has No EDMA FUNCTION.
[ 3.514435] [DRVBOX] WARN (plat_rtc_init|76): System has no SOC RTC module.
[ 3.514485] No TouchScreen
[ 3.514630] [DRVBOX] [MBUS]: NICE, This Machine Doesn't Support MBUS.
[ 3.514707] [DRVBOX] [PSTN]: NICE, This Machine Doesn't Support PSTN.
[ 3.514785] [DRVBOX] monitor num 0
[ 3.514895] [DRVBOX] WARN (rocker_init_dev|1392): The Rocker res type is ROCKER_TYPE_UNKNOW!
[ 3.515042] [DRVBOX] WARN (touchkey_init_dev|408): The Touchkey res type is TOUCHKEY_TYPE_UNKNOW!
[ 3.520354]
[ 3.520355] Load hi_demux.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:34])
[ 3.522435] Load hi_adec.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:54])
[ 3.528925] Load hi_vfmw.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:55])
[ 3.535454] [00:00:03:278 ERROR-HI_PQ]:DRV_PQ_GetFlashPqBin[3149]:PQ bin param may not burned
[ 3.539630] Load hi_pq.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:27])
[ 3.580211] Load hi_vpss.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:37:07])
[ 3.587882] Load hi_vdec.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:57])
[ 3.644925] Load hi_cipher.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:27])
[ 3.648264] Load hi_hdmi.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:44])
[ 3.651348] Load hi_adsp.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:45])
[ 3.655466] Load hi_aiao.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:46])
[ 3.665725] [00:00:03:408 ERROR-HI_HDMI]:HAL_HDMI_DispFmtGet[2007]:stDispParam.enVidOutMode=-1082127064
[ 3.896041] [OSA-DRV] Monitor Task pid=851 tid=851
[ 3.901432]
[ 4.948982] Load hi_vou.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:04])
[ 4.974338] Load hi_fb.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:16])
[ 4.993586] mali f9200000.gpu: GPU identified as 0x0720 r1p1 status 0
[ 5.000526] mali f9200000.gpu: Probed as mali0
[ 5.007642] Load hi_ir.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:35:22])
[ 5.021697] Load hi_jpegdec.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:23])
[ 5.035085] Load hi_jpegenc.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:37:14])
[ 5.048753] Load hi_png.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:36:24])
[ 5.062756] Load hi_venc.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:37:37])
[ 5.075819] Load hi_aenc.ko success. (SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:37:36])
[ 5.133734] Load hi_keyled.ko success.(SDK_VERSION:[HiSTBLinuxV100R005C00SPC031_20160601] Build Time:[Nov 6 2017, 16:37:32])
[ 5.147285] [00:00:04:890 ERROR-HI_MODULE]:HI_DRV_MODULE_GetFunction[973]:Not found module ID: 0x00000058
[ 5.156896] [00:00:04:900 ERROR-HI_PM]:PMOC_DRV_ModInit[2085]:Get GPIO function failed!
insmod: can't insert '/var/lib/h[ 5.190581] ehci-platform: EHCI generic platform driver
i_pmoc.ko': Operation not permitted
[ 5.202081] ehci-platform f9890000.ehci: EHCI Host Controller
[ 5.207846] ehci-platform f9890000.ehci: new USB bus registered, assigned bus number 1
[ 5.215854] ehci-platform f9890000.ehci: irq 98, io mem 0xf9890000
[ 5.232773] ehci-platform f9890000.ehci: USB 2.0 started, EHCI 1.00
[ 5.239463] hub 1-0:1.0: USB hub found
[ 5.243244] hub 1-0:1.0: 1 port detected
[ 5.249034] ohci-platform: OHCI generic platform driver
[ 5.254408] ohci-platform f9880000.ohci: Generic Platform OHCI controller
[ 5.261210] ohci-platform f9880000.ohci: new USB bus registered, assigned bus number 2
[ 5.269223] ohci-platform f9880000.ohci: irq 99, io mem 0xf9880000
[ 5.333197] hub 2-0:1.0: USB hub found
[ 5.337012] hub 2-0:1.0: 1 port detected
[ 5.347815] xhci-hcd f98a0000.xhci: xHCI Host Controller
[ 5.353155] xhci-hcd f98a0000.xhci: new USB bus registered, assigned bus number 3
[ 5.360742] xhci-hcd f98a0000.xhci: irq 101, io mem 0xf98a0000
[ 5.367386] hub 3-0:1.0: USB hub found
[ 5.371186] hub 3-0:1.0: 1 port detected
[ 5.375359] xhci-hcd f98a0000.xhci: xHCI Host Controller
[ 5.380689] xhci-hcd f98a0000.xhci: new USB bus registered, assigned bus number 4
[ 5.388540] hub 4-0:1.0: USB hub found
[ 5.392334] hub 4-0:1.0: 1 port detected
[ 5.401409] xhci-hcd f98b0000.xhci: xHCI Host Controller
[ 5.406736] xhci-hcd f98b0000.xhci: new USB bus registered, assigned bus number 5
[ 5.414335] xhci-hcd f98b0000.xhci: irq 117, io mem 0xf98b0000
[ 5.420518] hub 5-0:1.0: USB hub found
[ 5.424312] hub 5-0:1.0: 1 port detected
[ 5.428477] xhci-hcd f98b0000.xhci: xHCI Host Controller
[ 5.433817] xhci-hcd f98b0000.xhci: new USB bus registered, assigned bus number 6
[ 5.441736] hub 6-0:1.0: USB hub found
[ 5.445519] hub 6-0:1.0: 1 port detected
[ 5.451604] [AVS]
[ 5.454514] [AVS] ********************************************************************************************************
[ 5.466709] [AVS] * avs version: V00.001 SvnVersion BaseLine: 24444 Patch: 0 Compile at: Mon, 06 Nov 2017 16:29:33 +0800 *
[ 5.478893] [AVS] ********************************************************************************************************
[ 5.491078] [AVS] Find product (id=0x2d8, cpu index=0).
[ 5.497444] [AVS] product resource found.
[ 5.502587] [AVS] Begin to Alloc avs cfg mem!
[ 5.508180] [AVS] board resoure found.
[ 5.513278] [AVS] Found the product, and init successfully.
[ 5.520119]
[ 5.533629] [SWITCH-23901] MSG (dh_switch_init|728): Netswitch_Poe Svn Version: 23901, Build Time: Nov 6 2017 16:30:19
[ 5.533629] [POE-23901] MSG (dh_poe_init|163): PoeRes_t size :128
[POE-23901] MSG (dh_poe_init|164): Chip Count :2
[POE-23901] MSG (dh_poe_init|165): Port Count :8
[POE-23901] MSG (dh_poe_init|166): Rated Power :120(W)
[POE-23901] MSG (PseDevInit|32): PSE MAX5980 initing...
[POE-23901] MSG (PseI2cMax5980SetMode|155): set chip1 PSE_AUTO_MODE, enable det and class
[POE-23901] MSG (PseI2cMax5980SetMode|155): set chip2 PSE_AUTO_MODE, enable det and class
[SWITCH-23901] MSG (dh_switch_init|769): NetSwitchRes_t_common size:644
[SWITCH-23901] MSG (dh_switch_init|773): speed: 100
[SWITCH-23901] MSG (dh_switch_init|774): duplex: 1
[SWITCH-23901] MSG (dh_switch_init|775): table_num: 1
[SWITCH-23901] MSG (dh_switch_init|776): bus_number: 2
[SWITCH-23901] MSG (dh_switch_init|777): bus_information[0].bus_id: 0
[SWITCH-23901] MSG (dh_switch_init|778): bus_information[0].bus_drv_name: kernel_bus
[ 5.704780] [SWITCH-23901] MSG (switch_config_init|531): switch_config_init is called
[ 5.704780] [SWITCH-23901] MSG (register_bus_dev|69): find this bus driver! bus_name:kernel_bus
[SWITCH-23901] MSG (register_bus_dev|69): find this bus driver! bus_name:smi_bus
[SWITCH-23901] MSG (switch_dev_conf_init|369): port_num: 0x8
[SWITCH-23901] MSG (mv6071_init|987): mv6071_init is called
[SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
[ 8.628788] Dahua crypto start ....
[ 8.718386] [SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
[ 10.719956] 1970-1-1 0:0:10 CPU is alive
[ 10.878234] [SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
[ 14.127460] random: nonblocking pool is initialized
[ 14.255766] [SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
[ 17.383288] Dahua crypto end ....
[ 17.510148] [SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
[ 20.883080] 1970-1-1 0:0:20 CPU is alive
[ 21.041885] [SWITCH-23901] ERR (smi_is_busy|176): mdio bus is busy
