Код: Выделить всё
hisilicon # sf probe 0
hisilicon # sf read 0x82000000 0x580000 0x200000
hisilicon # tftp 0x82000000 kernel.img 0x200000
Это я так понимаю не полная прошивка будет?
Код: Выделить всё
# dmesg
Linux version 3.0.8 (pub@BVT-SDK-SERVER3) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Fri Mar 15 13:04:56 CST 2013
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 220000000.
On node 0 totalpages: 16384
free_area_init_node: node 0, pgdat c0535728, node_mem_map c0554000
Normal zone: 128 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 16256 pages, LIFO batch:3
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: mem=64M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),3M(kernel),11776K(rootfs),512K(config)
Memory: 64MB = 64MB total
Memory: 59480k/59480k available, 6056k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc4800000 - 0xfe000000 ( 920 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc0512000 (5028 kB)
.data : 0xc0512000 - 0xc0535da0 ( 144 kB)
.bss : 0xc0535dc4 - 0xc0553040 ( 117 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 110MHz, resolution 9ns, wraps every 39045ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.16)
yaffs: yaffs built Mar 15 2013 13:04:54 Installing.
msgmni has been set to 116
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Spi id table Version 1.22
Hisilicon Spi Flash Controller V350 Device Driver, Version 1.10
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000f80000 : "rootfs"
0x000000f80000-0x000001000000 : "config"
Fixed MDIO Bus: probed
himii: probed
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
lib80211_crypt: registered algorithm 'NULL'
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 132K
udevd (498): /proc/498/oom_adj is deprecated, please use /proc/498/oom_score_adj instead.
hi3518_base: module license 'Proprietary' taints kernel.
pa:84000000, va:c4a00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load vou.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok!
gpio_0_base_addr_virtual:0xc4d00000 !
Set Gpio0_6 dir to 1!
Set Gpio0_6 bit to 0!
Set Gpio0_6 bit to 1!
Kernel: ssp initial ok!
acodec inited!
rtusb init rtusbSTA --->
usbcore: registered new interface driver rtusbSTA
entry jb_hi_authen0104_init
DMS_Read0104Data failed
no ic ack
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 1, nodeamon= 0)
?????????????????? i2c_setgpio
It is JB_AUTHEN_READ_DATA!
It is JB_AUTHEN_WRITE_DATA!
wait write ack ok timeout, i=6!
ADDRCONF(NETDEV_UP): eth0: link is not ready
PHY: himii:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
hirtc_set_time->394:
check state error!
check state error!
eth0: no IPv6 routers present
