Видеонаблюдение с помощью ВЕБ-камеры,помогите
Здравствуйте дорогие жители форума.У меня есть одна проблема-я хочу сделать видеонаблюдение на расстояние 15 метров от компьютера,я купил себе ВЕБ-камеру,кабель(15м.).Все соединил, а при подключению к компьютеру у меня пишется такая вот вещь:Устройство USB не опознано!.Притом когда камера была в "стандартном" виде,то она хорошо работала.Вот фотография чуть ниже.
- Site Admin
Re: Видеонаблюдение с помощью ВЕБ-камеры,помогите
расстояние
для тех, кто по русски не понимает - 5 метров.Cabling
A USB twisted pair, where the "Data +" and "Data −" conductors are twisted together in a double helix. The wires are enclosed in a further layer of shielding.
The data cables for USB 1.x and USB 2.x use a twisted pair to reduce noise and crosstalk. USB 3.0 cables contain twice as many wires as USB 2.x to support SuperSpeed data transmission, and are thus larger in diameter.[43]
The USB 1.1 Standard specifies that a standard cable can have a maximum length of 3 meters with devices operating at Low Speed (1.5 Mbit/s), and a maximum length of 5 meters with devices operating at Full Speed (12 Mbit/s).[citation needed]
USB 2.0 provides for a maximum cable length of 5 meters for devices running at Hi Speed (480 Mbit/s). The primary reason for this limit is the maximum allowed round-trip delay of about 1.5 μs. If USB host commands are unanswered by the USB device within the allowed time, the host considers the command lost. When adding USB device response time, delays from the maximum number of hubs added to the delays from connecting cables, the maximum acceptable delay per cable amounts to 26 ns.[44] The USB 2.0 specification requires cable delay to be less than 5.2 ns per meter (192,000 km/s, which is close to the maximum achievable transmission speed for standard copper wire).
The USB 3.0 standard does not directly specify a maximum cable length, requiring only that all cables meet an electrical specification: for copper cabling with AWG 26 wires the maximum practical length is 3 meters (9.8 ft).
Максимальное расстояние 5 метров?
- Site Admin
ага. бывает работает и больше, но это уже как повезет. вам не повезло
Я не думаю что все зависит от длины кабеля.Если компьютер выдал текст,то проблема не в кабеле
В следующий раз сначала спрашиваем потом покупаем.
Та все нормально-цена не главное!
Ну в конце концов есть активные удлинители УСБ. Только провода уже порезали.
Можно вернуть.Ну,а почему нельзя провести его через мой кабель?
Возможно что и можно только камеру запитать надо отдельно. Но тут опять же как повезет. Проще было аналоговую камеру от AT&T и usb-перехватывалку. Тут хоть на 5 километров гоните к камере... усилки только ставьте.
компюьер может и увидит что, к кабелю какая то хрень подключена, но ето не значит что она должна работать. По всей видимости из за : большой длинны кабеля, низкокачественной меди в нем, и издевательства над екраном етого кабеля, сильно падает скорость потока передачи данных. а так как вы подключаете не мышку, и не флешку а камеру, то для нее любое снижение потока ето критично, вот она и не конектится с компом.nezumi писал(а):Можно вернуть.Ну,а почему нельзя провести его через мой кабель?
Кстати если шнурок удлиннить еще метров на 50, то комп тоже будет говорить что ето неопознанное устройство, даже если к нему не подключать ничего.
И еще одно - вы для удлинения использовали сигнальный кабель, а нужно было брать витую пару, и подключать одну пару на один провод, и обязательно все ето хорошенько пропаять, тогда мог бы получится удлиннитель, хотя бы для мишки я себе так удлиннял когда еще в институте учился, тоже кстати на 15 метров.
Вот это уже лишнее. Раскладывать цифру на два проводника, а потом ее обратно складывать нельзя, можно получить весьма неожиданные результаты. Это касается любого интерфейса. И еще не задумывались зачем пара витая?подключать одну пару на один провод
