На предмет автономной работы-настройки.
по UART такое---
U-Boot 2010.06-svn37124 (Jul 09 2018 - 14:42:59)
DRAM: 128 MiB
SF: Got idcode c8 40 18 c8 40
WARNING: Get BOARD_INFO failed.
Using SZ_16M flash partition choice.
MMC: FH_MMC: 0
Card did not respond to voltage select!
No EMMC device found!!!
Net: WARNING: Get BOARD_INFO failed.
set to RMII
fh8830_fh_gmac_initialize
FH EMAC
Hit Ctrl+u to stop autoboot: 2
HKVS # help
? - alias for 'help'
arc_go - start application at address 'addr'
bdinfo - print Board Info structure
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
editenv - edit environment variable
format - format flash except bootloader area
go - go xxx.bin thru network
gos - go xxx.bin thru serial
iminfo - print header information for application image
imxtract- extract a part of a multi-image
loadk - load kernel to DRAM
loadm - load mini to DRAM
loads - load S-Record file over serial line
loadss - load safe system
md - memory display
mmc - MMC sub system
mmcinfo - mmcinfo <dev num>-- display MMC info
mw - memory write (fill)
nfs - boot image via network using NFS protocol
pinctrl - Pin Ctrl
sf - SPI flash sub-system
sleep - delay execution for some time
source - run script from memory
sspi - SPI utility commands
tftpboot- boot image via network using TFTP protocol
upa - update app image
update - update digicap.dav with net
updateb - update bootloader with net
updatebsd- update bootloader with sd
updatesd- update digicap.dav with sd
upf - update firmware with net, format and update (factory use)
upfsd - update firmware with sd, format and updatesd (factory use)
upk - update uImage
wdt - WDT utility commands
HKVS #
HKVS # printenv
bootcmd=loadss;run runargs;bootm
bootdelay=3
baudrate=115200
bldfile="u-boot_e4.bin"
runargs=set bootargs console=ttyS0,115200 root=/dev/ram0 mem=64M boot_from=${boot_from} ethaddr=${ethaddr} ip=${ipadd r}:${serverip} dbg=0
phymode=RMII
ethact=FH EMAC
serverip=192.0.0.128
update_source=net
filesize=602D10
fileaddr=A1000000
ipaddr=192.0.0.64
app_verify=y
boot_from=PART_BKUP
update_flag=update_
wifi_mode=ap
stdin=serial
stdout=serial
stderr=serial
verify=n
ethaddr=44:47:cc:1f:fa:23
Environment size: 486/65532 bytes
HKVS #
DRAM: 128 MiB
MMC: FH_MMC: 0
set to RMII
FH EMAC
Hit Ctrl+u to stop autoboot: 0
auto update with sd is supported
FH_MMC: 0
*No SD card found!
error: auto_update_digicap_with_sd-read from mmc.
load kernel to 0xa1000000 ... Done!
Verify app img successfully...
Done!
## Booting kernel from Legacy Image at a1000000 ...
Image Name: Linux-3.0.8
Data Size: 2500696 Bytes = 2.4 MiB
Load Address: a0008000
Entry Point: a0008000
Loading Kernel Image ... OK
OK
Starting kernel ...
starting pid 57, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
Input 'q' to exit initrun.sh~
chmod: 8192es.ko: Read-only file system
chmod: PHY_REG_PG.txt: Read-only file system
chmod: TXPWR_LMT.txt: Read-only file system
chmod: ac.ko: Read-only file system
chmod: ac_test: Read-only file system
chmod: audio.dat: Read-only file system
chmod: bgm.ko: Read-only file system
chmod: certs.tar.gz: Read-only file system
chmod: da_info: Read-only file system
chmod: default.script: Read-only file system
chmod: dhcpd.conf: Read-only file system
chmod: dummy_sensor_attr.hex: Read-only file system
chmod: enc.ko: Read-only file system
chmod: execSystemCmd: Read-only file system
chmod: ezapp: Read-only file system
chmod: ezdsp: Read-only file system
chmod: fd.ko: Read-only file system
chmod: fh8812.sh: Read-only file system
chmod: fh_fw_loader.ko: Read-only file system
chmod: font_asc16.hex: Read-only file system
chmod: font_gb2312.hex: Read-only file system
chmod: hik_aes_app: Read-only file system
chmod: hostapd: Read-only file system
chmod: initrun.sh: Read-only file system
chmod: isp.ko: Read-only file system
chmod: jpeg.ko: Read-only file system
chmod: jxf22_mipi_day_hdr.hex: Read-only file system
chmod: jxf22_mipi_day_lnr.hex: Read-only file system
chmod: jxf22_mipi_nig_lnr.hex: Read-only file system
chmod: libdadsp.so: Read-only file system
chmod: libdata_pack.so: Read-only file system
chmod: libdewarp.so: Read-only file system
chmod: libezDevSDK_Common_Module.so: Read-only file system
chmod: libezDevSDK_boot.so: Read-only file system
chmod: libf2_isp.so: Read-only file system
chmod: libmicrokernel.so: Read-only file system
chmod: libnl-genl.so.2.0.0: Read-only file system
chmod: libnl.so.2.0.0: Read-only file system
chmod: libsys.so: Read-only file system
chmod: load_modules.sh: Read-only file system
chmod: logoblack.hex: Read-only file system
chmod: logowhite.hex: Read-only file system
chmod: media_process.ko: Read-only file system
chmod: pwmtor.ko: Read-only file system
chmod: regrw: Read-only file system
chmod: rtthread.bin: Read-only file system
chmod: rtthread_arc.bin: Read-only file system
chmod: rtvbus.ko: Read-only file system
chmod: sample_vlcview: Read-only file system
chmod: t1: Read-only file system
chmod: t2_fh_88: Read-only file system
chmod: udhcpd: Read-only file system
chmod: vbus_ac.ko: Read-only file system
chmod: vbus_loader: Read-only file system
chmod: vmm.ko: Read-only file system
chmod: voice.tar.gz: Read-only file system
chmod: vou.ko: Read-only file system
chmod: vpu.ko: Read-only file system
chmod: wpa_cli: Read-only file system
chmod: wpa_supplicant: Read-only file system
chmod: xbus.ko: Read-only file system
8192es.ko PHY_REG_PG.txt TXPWR_LMT.txt ac.ko ac_test audio.dat bgm.ko certs.tar.gz da_info default.script dhcpd.conf dummy_sensor_attr.hex enc.ko execSystemCmd ezapp ezdsp fd.ko fh8812.sh fh_fw_loader.ko font_asc16.hex font_gb2312.hex hik_aes_app hostapd initrun.sh isp.ko jpeg.ko jxf22_mipi_day_hdr.hex jxf22_mipi_day_lnr.hex jxf22_mipi_nig_lnr.hex libdadsp.so libdata_pack.so libdewarp.so libezDevSDK_Common_Module.so libezDevSDK_boot.so libf2_isp.so libmicrokernel.so libnl-genl.so.2.0.0 libnl.so.2.0.0 libsys.so load_modules.sh logoblack.hex logowhite.hex media_process.ko pwmtor.ko regrw rtthread.bin rtthread_arc.bin rtvbus.ko sample_vlcview t1 t2_fh_88 udhcpd vbus_ac.ko vbus_loader vmm.ko voice.tar.gz vou.ko vpu.ko wpa_cli wpa_supplicant xbus.ko
mkdir: can't create directory '–p': Read-only file system
ln: prtHardInfo: File exists
ln: taskShow: File exists
starting pid 378, tty '': '-/bin/sh'
BusyBox v1.19.3 (2019-01-16 16:40:05 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
Linux version 3.0.8[svn 47874] (renweibin@Cpl-Civil-Camera) (gcc version 4.3.2 (crosstool-NG 1.19.0) ) #23 Thu Jan 24 20:59:08 CST 2019
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: HIK IPC
devinfo=fh8830_c5s
mem=77594624 byte
On node 0 totalpages: 18944
free_area_init_node: node 0, pgdat c04b0960, node_mem_map c04db000
Normal zone: 148 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 18796 pages, LIFO batch:3
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 18796
Kernel command line: console=ttyS0,115200 root=/dev/ram0 mem=64M boot_from=PART_BKUP ethaddr=44:47:cc:1f:fa:23 ip=192.0.0.64:192.0.0.128 dbg=0 devinfo=fh8830_c5s rst=0
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB = 74MB total
Memory: 70056k/70056k available, 5720k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5000000 - 0xfe000000 ( 912 MB)
lowmem : 0xc0000000 - 0xc4a00000 ( 74 MB)
.init : 0xc0008000 - 0xc0139000 (1220 kB)
.text : 0xc0139000 - 0xc048d000 (3408 kB)
.data : 0xc048e000 - 0xc04b0fe0 ( 140 kB)
.bss : 0xc04b1004 - 0xc04da018 ( 165 kB)
NR_IRQS:128
timer mult: 0xfa000000, timer shift: 0x16
sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
console [ttyS0] enabled
Calibrating delay loop... 479.23 BogoMIPS (lpj=2396160)
hw perfevents: enabled with v6 PMU driver, 3 counters available
devtmpfs: initialized
fh_pinctrl_init selected_devices_c5s.
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
fh_dmac fh_dmac.0: FH DMA Controller, 8 channels
Advanced Linux Sound Architecture Driver Version 1.0.24.
Switching to clocksource fh_clocksource
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
msgmni has been set to 136
NET: Registered protocol family 38
io scheduler noop registered (default)
PWM driver, Number: 8, IO base addr: 0xc5078000
ttyS.0: ttyS0 at MMIO 0xf0700000 (irq = 30) is a ttyS
fh serial probe done
ttyS.2: ttyS2 at MMIO 0xf0880000 (irq = 35) is a ttyS
brd: module loaded
loop: module loaded
I2S probe
I2S :996
CLK misc driver init successfully
m25p80 spi0.0: found gd25q128, expected m25p80
m25p80 spi0.0: gd25q128 (16384 Kbytes)
Creating 10 MTD partitions on "spi_flash":
0x000000000000-0x000000040000 : "uboot"
0x000000040000-0x000000050000 : "uboot-env"
0x000000050000-0x000000060000 : "enc"
0x000000060000-0x000000360000 : "kernel"
0x000000360000-0x000000660000 : "kernel_backup"
0x000000660000-0x000000a60000 : "app"
0x000000a60000-0x000000e60000 : "app_backup"
0x000000e60000-0x000000f60000 : "config"
0x000000f60000-0x000000ff0000 : "log"
0x000000ff0000-0x000001000000 : "devinfo"
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
console [netcon0] enabled
netconsole: network logging started
i2c /dev entries driver
I2C driver:
platform registration...
Clock: 15000khz, Standard-mode HCNT:LCNT = 62:74
tx fifo depth: 16, rx fifo depth: 16
I2C - (dev. name: fh_i2c - id: 0, IRQ #42
IO base addr: 0xc50b0000)
I2C driver:
rtc-rx8130 1-0032: Trying to read RX8130_REG_EXT
fh_i2c fh_i2c.1: controller timed out
rtc-rx8130 1-0032: Unable to read registers #28..#30
i2c i2c-1: probing for rx8130 failed
fh8830_board_init_extern fh_rtc
fh_rtc fh_rtc.0: rtc core: registered rtc as rtc0
rtc-rx8130: probe of 1-0032 failed with error -110
I2C - (dev. name: fh_i2c - id: 1, IRQ #43
IO base addr: 0xc50b8000)
ALSA device list:
No soundcards found.
TCP cubic registered
Bridge firewalling registered
lib80211_crypt: registered algorithm 'NULL'
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
mmc1 power register success!
Change SD state from STOR_OFFLINE to STOR_OFFLINE
GMAC driver:
platform registration... using random MAC address: 42:82:6b:4b:88:8d
fh_gmac fh_gmac.0: eth0: mixed HW and IP checksum settings.
fh_gmac fh_gmac.0: eth0: mixed no checksumming and other settings.
eth0 - (dev. name: fh_gmac - id: 0, IRQ #14
IO base addr: 0xc50d8000)
gmac_rmii: probed
eth0: PHY ID 001cc816 at 0 IRQ -1 (0:00) active
fh_rtc fh_rtc.0: setting system clock to 2020-01-22 22:32:41 UTC (1579732361)
mmc0: new high speed SDIO card at address 0001
aes driver registered
Freeing init memory: 1220K
PHY: 0:00 - Link is Up - 100/Full
Video Memory Manager
media_mem_parse_cmdline: s=anonymous,0,0xA4A00000,52M:huge,0,0xc0000000,128K.
media_mem_parse_cmdline: i=4.
vmm:anonymous,a4a00000,3400000.
vmm:huge,c0000000,20000.
load rtthread_arc.bin at 0xa7f00000, set ring buffer at 0xa7e00000 with size 0x10000
get irq offset: 0
chn0 dev nr: 253
VBus loaded: 255 in blocks, 255 out blocks
VBUS driver loaded.
VBUS load rtthread_arc.bin for rtvbus
firmware: rtthread_arc.bin loaded
firmware: rtthread_arc.bin started
ARC is running.
media_process: module license 'Proprietary' taints kernel.
media_process_module_init 229: media process init success!!
module->phys_addr=0xea000000 module->virt_addr=0xc5400000
isp - (dev. name: ipf - IRQ #3
IO base addr: 0xc5400000)
module->phys_addr=0xea000700 module->virt_addr=0xc5600700
isp - (dev. name: ipb - IRQ #0
IO base addr: 0xc5600700)
stat buffer size: 81KBytes
vpu_parse_cmdline 223: VPU Revc Command: cap_1_1280_720
vpu_parse_cmdline 285: set command success! (cap)
vpu_module_init 663: vpu init success!!
pae_cpu_reset 2349: [PAE]---RESET PAE---
pae_cpu_reset 2366: reset AXi
pae_load_firmware 34: START LOAD ENC FIRMWARE V2 ...
pae_load_firmware 37: LOAD ENC FIRMWARE FINISH!
pae_module_init 811: PAE init success!
vou_module_init 239: VOU init success!
jpeg_module_init 278: JPEG init success!
bgm_module_init 449: bgm init success!!
fd_module_init 273: FD init success!
fh8830_iomux_spi3_init pinmux to spi3.
SSI3:
dm9051 spi3.1: failed to read device ID
dm9051 spi3.1: not found (-19).
fh81_iomux_sd_init pinmux to sd.
SD0:
GPIO46:
GPIO47:
fh8830_board_init_extern sd0
card0 disconnected!
RTW: module init start
RTW: rtl8192es v5.2.12_xxxx.20190321
RTW: build time: Mar 21 2019 11:52:03
mmc0: card 0001 removed
rtw_drv_entry: set power on ~~~
[22 22:33:33][CLOUD][ERROR]ezdev_cloud_sche_start: status 1, param=1, bStart=0, cfg=0
mot_send_to_record_func, type 1, action 1
RTW: == SDIO Card Info ==
RTW: clock: 50000000 Hz
RTW: timing spec :sd high-speed
RTW: sd3_bus_mode: FALSE
RTW: ================
hik_wifi_preinit: enter
RTW: ERROR hik_wifi_preinit: pick=BR,len=2
found region code=BR in BR table.
RTW: ERROR ##hik_set_country :: country_code:BR;rtw_channel_plan=29
RTW: 0x000: 29 81 00 7C 01 00 03 00 42 00 05 58 10 00 00 00
RTW: 0x010: 23 22 22 23 23 23 29 29 2A 29 29 00 EE 00 FF FF
RTW: 0x020: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x030: FF FF FF FF FF FF FF FF FF FF 26 27 27 26 26 26
RTW: 0x040: 2D 2D 2D 2D 2D 00 EE 00 FF FF FF FF FF FF FF FF
RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x0a0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x0b0: FF FF FF FF FF FF FF FF 20 1D 1D 00 00 00 FF FF
RTW: 0x0c0: 00 01 00 10 00 00 00 55 00 00 FF FF FF FF FF FF
RTW: 0x0d0: 3F 00 01 02 23 00 00 FC 20 04 4C 02 8B 81 21 02
RTW: 0x0e0: 0C 00 22 04 00 08 00 32 FF 21 02 0C 00 22 2A 01
RTW: 0x0f0: 01 00 00 00 00 00 00 00 00 00 00 00 02 00 FF FF
RTW: 0x100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
RTW: 0x110: 00 EB 00 6E 01 00 00 00 00 FF D4 B7 61 36 65 FE
RTW: 0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1a0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1b0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1c0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1d0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1e0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: 0x1f0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
RTW: hal_com_config_channel_plan chplan:0x29
RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
RTW: Wrong rate section: (CCK,2T)
RTW: Wrong rate section: (OFDM,2T)
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 01]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 01]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 01]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 02]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 02]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 02]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 20M][rate section HT][rf path 2T][chnl 11]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 11]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 11]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 12]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 12]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 20M][rate section HT][rf path 2T][chnl 13]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 20M][rate section HT][rf path 2T][chnl 13]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 03]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 04]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 05]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 06]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 07]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 08]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 09]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 10]
RTW: duplicate tx power limit combination [band 2.4G][regulation FCC][bw 40M][rate section HT][rf path 2T][chnl 11]
RTW: duplicate tx power limit combination [band 2.4G][regulation ETSI][bw 40M][rate section HT][rf path 2T][chnl 11]
RTW: duplicate tx power limit combination [band 2.4G][regulation MKK][bw 40M][rate section HT][rf path 2T][chnl 11]
RTW: rtw_ndev_init(wlan0) if1 mac_addr=d4:b7:61:36:65:fe
Wifi module SVN version: SVN@50489
RTW: module init ret=0
RTW: wlan0- hw port(0) mac_addr =d4:b7:61:36:65:fe
fh_media_open 79: media_process open success.
pae_enc_isr 4009: [PAE]---PAE RUN!!---
pae_open 611: pae open success!
vpu_open 486: vpu open success.
jpeg_open 123: jpeg open success.
vou_open 80: vou open success.
bgm_open 283: bgm open success.
fd_open 119: fd open success.
remap_pfn_range start~end: 0x40007000 0x40023000, pyh:0xa4a00 , nocached.
remap_pfn_range start~end: 0x41c86000 0x42599000, pyh:0xa4a1c , nocached.
remap_pfn_range start~end: 0x425a0000 0x42853000, pyh:0xa532f , nocached.
remap_pfn_range start~end: 0x40394000 0x403df000, pyh:0xa55e2 , nocached.
remap_pfn_range start~end: 0x42853000 0x42bd5000, pyh:0xa562d , nocached.
remap_pfn_range start~end: 0x42bf7000 0x4319e000, pyh:0xa59b0 , nocached.
vpu_reg_set_chn_size 795: chan 0 1920 1088 1920 1920
vpu_reg_set_chn_size 795: chan 1 768 432 768 768
vpu_reg_set_chn_size 795: chan 3 352 288 352 352
remap_pfn_range start~end: 0x44b77000 0x44f8f000, pyh:0xa5f57 , nocached.
remap_pfn_range start~end: 0x45011000 0x45200000, pyh:0xa636f , nocached.
remap_pfn_range start~end: 0x400d7000 0x400d8000, pyh:0xa655e , nocached.
remap_pfn_range start~end: 0x40106000 0x40116000, pyh:0xa655f , nocached.
remap_pfn_range start~end: 0x40078000 0x40079000, pyh:0xa656f , nocached.
remap_pfn_range start~end: 0x40116000 0x40126000, pyh:0xa6570 , nocached.
remap_pfn_range start~end: 0x400bf000 0x400c0000, pyh:0xa6580 , nocached.
remap_pfn_range start~end: 0x403e0000 0x40460000, pyh:0xa6581 , nocached.
remap_pfn_range start~end: 0x4005b000 0x4005c000, pyh:0xa6601 , nocached.
remap_pfn_range start~end: 0x400d8000 0x400e8000, pyh:0xa6602 , nocached.
remap_pfn_range start~end: 0x4007b000 0x4007c000, pyh:0xa6612 , nocached.
remap_pfn_range start~end: 0x40173000 0x40183000, pyh:0xa6613 , nocached.
remap_pfn_range start~end: 0x40460000 0x40461000, pyh:0xa6623 , nocached.
remap_pfn_range start~end: 0x416af000 0x416bf000, pyh:0xa6624 , nocached.
remap_pfn_range start~end: 0x4183e000 0x4183f000, pyh:0xa6634 , nocached.
remap_pfn_range start~end: 0x4194f000 0x4195f000, pyh:0xa6635 , nocached.
remap_pfn_range start~end: 0x4196e000 0x4197e000, pyh:0xa6645 , nocached.
remap_pfn_range start~end: 0x45200000 0x453fb000, pyh:0xa6655 , nocached.
vpu_disable 2013: wait vpu stop...
vpu_disable 2024: vpu stop!
vpu_get_stream 1856: [drv-vpu] get stream timeout ret=0
[wdt] set topval: 8
[wdt] settime value 30
warning: process `ipc_sntptask' used the deprecated sysctl system call with 1.40.
# m_maxSessions=88
m_maxSessions=88,m_sessionNum=1
Rtspsession the svc start
connection closed by peer
Rtspsession the svc stop
g_rtsp_client_info[0].rtsp_socket = -1
stop successfully
RemoveSession m_maxSessions=88,m_sessionNum=0
RTSP message: OPTIONS rtsp://192.168.252.119:554/Streaming/Channels/101 RTSP/1.0
CSeq: 1
User-Agent: Rtsp Client/3.0
proc_rtsp_method 7
----user agent Rtsp Client/3.0 is UNKNOW
svc transmode 255 i0
RTSP message: DESCRIBE rtsp://192.168.252.119:554/Streaming/Channels/101 RTSP/1.0
CSeq: 2
Accept: application/sdp
proc_rtsp_method 5
the rtsp url is rtsp://192.168.252.119:554/Streaming/Channels/101
rtsp_req_url->base_url = rtsp://192.168.252.119:554/Streaming/Channels/101
rtsp_req_url->url_param =
track id == channels/101
track_id = 0, stream_id = 1, chan_id = 1, playback = 0, multicast = 0,anr_flag=0
URL=rtsp://192.168.252.119:554/Streaming/Channels/101, method=DESCRIBE
------------------plaintext
RTSP message: DESCRIBE rtsp://192.168.252.119:554/ROM: Use nor flash.
Кто нибудь ковырял прошивку cs-cv310?
Re: Кто нибудь ковырял прошивку cs-cv310?
выдернул из прошивки
passwd
root hiklinux
passwd_nfs
root duhao
admin 12345
passwd
root hiklinux
passwd_nfs
root duhao
admin 12345
dv1, вам таки удалось запустить камеру автономно или нет?
Два года прошло, да , тему никто не поддержал.
