Вот лог загрузки камеры.
Код: Выделить всё
Terminal log file
Date: 30.09.2021 - 15:20:54
hi3516cv300 System startup
U-Boot 2010.06 (Jun 01 2020 - 08:37:05)
Check Flash Memory Controller v100 ... Found
SPI Nand(cs 0) ID: 0xc8 0x21 Name:"F50L1G41A"
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:8bit/512
ECC provided by Flash Memory Controller
SPI Nand total size: 128MB
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 1 0
Set gpio: 60->0
Set gpio: 0->0
Set gpio: 72->1
Set gpio: 27->1
Set gpio: 73->1
No mmc found
NAND read: device 0 offset 0x200000, size 0x500000
5242880 bytes read: OK
Image Name: Linux-3.18.20
Data Size: 4691075 Bytes = 4.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Linux version 3.18.20 (root@runner-moogncr-project-22-concurrent-0) (gcc version 4.9.4 20150629 (prerelease) (Hisilicon_v500_20170615) ) #1 Fri Jul 10 15:16:29 UTC 2020
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
Machine model: Hisilicon Hi3516CV300 DEMO Board
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: mem=64M console=ttyAMA0,115200 rootfstype=ramfs mtdparts=hinand:1024K(boot),1024K(tech),5120K(kernel),16384K(app),-(config) hw_type=407 ubi.mtd=3,2048
Memory: 57236K/65536K available (4177K kernel code, 192K rwdata, 1116K rodata, 1808K init, 290K bss, 8300K reserved, 0K highmem)
Virtual kernel memory layout:
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0533a48 (5295 kB)
.init : 0xc0534000 - 0xc06f8000 (1808 kB)
.data : 0xc06f8000 - 0xc0728360 ( 193 kB)
.bss : 0xc0728360 - 0xc0770c18 ( 291 kB)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:16 nr_irqs:16 16
VIC @c4800000: id 0x00641190, vendor 0x41
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Calibrating delay loop... 398.13 BogoMIPS (lpj=1990656)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x803fe3a0 - 0x803fe3f8
devtmpfs: initialized
VFP support v0.3: not present
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
12100000.uart: ttyAMA0 at MMIO 0x12100000 (irq = 21, base_baud = 0) is a PL011 rev2
console [ttyAMA0] enabled
SCSI subsystem initialized
ssp-pl022 12120000.spi: ARM PL022 driver, device ID: 0x00800022
ssp-pl022 12120000.spi: mapped registers from 0x12120000 to c486c000
Switched to clocksource arm,sp804
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
futex hash table entries: 256 (order: -1, 3072 bytes)
jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
msgmni has been set to 111
io scheduler noop registered
io scheduler cfq registered
pinctrl-single 12040000.pinmux: 66 pins at pa c48d4000 size 264
pinctrl-single 12040800.pinconf: 76 pins at pa c48d6800 size 304
pl061_gpio 12140000.gpio: PL061 GPIO chip @0x12140000 registered
pl061_gpio 12141000.gpio: PL061 GPIO chip @0x12141000 registered
pl061_gpio 12142000.gpio: PL061 GPIO chip @0x12142000 registered
pl061_gpio 12143000.gpio: PL061 GPIO chip @0x12143000 registered
pl061_gpio 12144000.gpio: PL061 GPIO chip @0x12144000 registered
pl061_gpio 12145000.gpio: PL061 GPIO chip @0x12145000 registered
pl061_gpio 12146000.gpio: PL061 GPIO chip @0x12146000 registered
pl061_gpio 12147000.gpio: PL061 GPIO chip @0x12147000 registered
pl061_gpio 12148000.gpio: PL061 GPIO chip @0x12148000 registered
brd: module loaded
hisi-sfc hisi_spi_nor.0: unrecognized JEDEC id bytes: ff, c8, 21
hisi-sfc hisi_spi_nor.0: spi nor register fail!
hisi-sfc: probe of hisi_spi_nor.0 failed with error -2
SPI Nand ID Table Version 2.2
nand: device found, Manufacturer ID: 0xc8, Chip ID: 0x21
nand: GD/ESMT F50L1G41A
nand: 128MiB, SLC, page size: 2048
Nand(Auto): OOB:64B ECC:8bit/512
nand: ECC provided by Flash Memory Controller
5 cmdlinepart partitions found on MTD device hinand
Creating 5 MTD partitions on "hinand":
0x000000100000-0x000000200000 : "tech"
0x000000200000-0x000000700000 : "kernel"
0x000000700000-0x000001700000 : "app"
0x000001700000-0x000008000000 : "config"
libphy: hisi_femac_mii_bus: probed
hisi-femac 10050000.ethernet: phy_id=0x001cc816, phy_addr=1, phy_mode=rmii
hisi-femac 10050000.ethernet: using random MAC address 5e:e5:95:4e:d3:f7
ehci-platform: EHCI generic platform driver
ehci-platform 10120000.ehci: EHCI Host Controller
ehci-platform 10120000.ehci: new USB bus registered, assigned bus number 1
ehci-platform 10120000.ehci: irq 31, io mem 0x10120000
ehci-platform 10120000.ehci: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci-platform: OHCI generic platform driver
ohci-platform 10110000.ohci: Generic Platform OHCI controller
ohci-platform 10110000.ohci: new USB bus registered, assigned bus number 2
ohci-platform 10110000.ohci: irq 32, io mem 0x10110000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
i2c /dev entries driver
hibvt-i2c 12110000.i2c: hibvt-i2c0@100000hz registered
hibvt-i2c 12112000.i2c: hibvt-i2c1@100000hz registered
himci: mmc host probe
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 10
UBI: attaching mtd3 to ubi0
UBI: scanning is finished
UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 20
UBI: attached mtd3 (name "app", size 16 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 146250124
UBI: available PEBs: 0, total reserved PEBs: 128, PEBs reserved for bad PEB handling: 16
UBI: background thread "ubi_bgt0d" started, PID 37
Freeing unused kernel memory: 1808K (c0534000 - c06f8000)
Код: Выделить всё
printenv
bootargs=mem=64M console=ttyAMA0,115200 rootfstype=ramfs mtdparts=hinand:1024K(boot),1024K(tech),5120K(kernel),16384K(app),-(config) hw_type=407 ubi.mtd=3,2048
bootcmd=hi_gpio $(hi_gpios); fwupdate mmc 0:1 firmware.bin --enable-legacy-fw --with-props; nand read 0x82000000 0x200000 0x500000; bootm 0x82000000; setenv bootargs $(bootargs) bkp=1; nand read 0x82000000 0x700000 0x500000; bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.255.0
bootfile="uImage"
hi_gpios=60! 0! 72 27 73
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06 (Jun 01 2020 - 08:37:05)
Environment size: 656/131068 bytes
hi3516cv300-vc #
Код: Выделить всё
>printenv
bootdelay=3
baudrate=115200
ipaddr=192.168.1.108
autoload=yes
gatewayip=192.168.1.1
dh_keyboard=1
appauto=1
sysbackup=1
logserver=127.0.0.1
loglevel=4
autosip=192.168.254.254
autolip=192.168.1.108
autogw=192.168.1.1
autonm=255.255.255.0
pd=tftp 0x02000000 pd-x.squashfs.img; flwrite
ethact=ambarella mac
BSN=2F04BC4PAA01112
HWID=IPC-HFW2220R-VFS:01:02:02:33:18:00:01:00:00:00:04:258:00:00:00:00:00:00:00:00:100
hwidEx=00:01:00:00:00:00:00:00:00:00:00:00:00:00:00:00
devalias=IPC-HFW2220R-VFS
da=tftp 0x2000000 dhboot.bin.img; flwrite; tftp dhboot-min.bin.img;flwrite
dr=tftp 0x2000000 romfs-x.squashfs.img; flwrite
dk=tftp 0x2000000 kernel.img; flwrite
du=tftp 0x2000000 user-x.squashfs.img; flwrite
dw=tftp 0x2000000 web-x.squashfs.img; flwrite
dc=tftp 0x2000000 custom-x.squashfs.img; flwrite
dt=tftp 0x2000000 data-x.squashfs.img; flwrite
dp=tftp 0x02000000 partition-x.cramfs.img;flwrite
up=tftp 0x2000000 update.img; flwrite
tk=tftp 0x200100 hawthorn.dts.dtb;tftp 0x2000000 uImage;bootm 0x2000000
bootcmd=sf read 0x200100 0x8000 0x8000;sf read 0x2000000 0xf0000 0x180000;bootm 0x2000000
bootargs=console=ttyS0,115200 mem=110M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
ID=
ethaddr=3C:EF:8C:CC:A9:06
filesize=20040
fileaddr=2000000
serverip=192.168.1.70
stdin=serial
stdout=serial
stderr=serial
Environment size: 1348/131068 bytes
В ней файлы
- check.img
dhboot.bin.img
dhboot-min.bin.img
dhboot-min-halfstart.bin.img
Install
kernel.img
pd-x.squashfs.img
sign.img
user-x.squashfs.img
web-x.squashfs.img
