Что-то даже в веб показывает
Остановить загрузку в UART не могу.
Подскажите, пожалуйста, можно ли его перезалить?
Вот лог:
[spoiler]
U-Boot 2008.10-svn4828 (Jan 12 2011 - 14:26:13)
DRAM: 128 MB
Flash: 16 MB
UpgradeSoftware:ffffffff
CheckUpgrade invalid addr(0xffffffff)
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 1 0
in showlogo system...
VIDEO_DATA_BASE is cf000000
jpeg_size is 20000
logo_addr is 80fc0000
decode success!!!!
[Get_TV_System]norm:1
[Get_VGA_Connect_State]vga_conn_state:1
env_vga_state:1
>>>> start_vo:u32BgColor:2682735(0028EF6F)
HAL_DISP_CHANNEL_DSD
VO_INTF_CVBS-VO_DEV_SD
HAL_DISP_CHANNEL_DHD
VO_INTF_VGA-VO_DEV_HD
> with fpga keypad <
## Booting kernel from Legacy Image at 80060000 ...
Image Name: hilinux
Data Size: 1249592 Bytes = 1.2 MB
Load Address: c0800000
Entry Point: c0800000
Loading Kernel Image ... OK
OK
console=ttyAMA0,115200 root=1f02 rootfstype=jffs2 mtdparts=physmap-flash.0:384K(boot),1280K(kernel),5M(rootfs),9M(app),128K(para) busclk=220000000 mem=44M
Starting kernel ...
Uncompressing Linux................................................................................. done, booting the kernel.
Linux version 2.6.24-rt1-hi3515v100 (vincetsai@ubuntu) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #8 Fri Dec 10 15:00:49 CST 2010
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3515v100
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 11176
Kernel command line: console=ttyAMA0,115200 root=1f02 rootfstype=jffs2 mtdparts=physmap-flash.0:384K(boot),1280K(kernel),5M(rootfs),9M(app),128K(para) busclk=220000000 mem=44M
PID hash table entries: 256 (order: 8, 1024 bytes)
Memory: 44MB = 44MB total
Memory: 41952KB available (2316K code, 229K data, 80K init)
HI_VERSION=LINUX_2_6_24-M01C06FB02F @Hi3515v100R001_C_0_0_0 2010-03-16 10:41:14
net_namespace: 64 bytes
Hisilicon clock system V0.01
SCSI subsystem initialized
Time: hisi_timer1 clocksource has been installed.
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
JFFS2 version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
yaffs Nov 22 2010 20:14:46 Installing.
io scheduler noop registered
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
uart:2: ttyAMA2 at MMIO 0x200b0000 (irq = 13) is a AMBA/PL011
RAMDISK driver initialized: 4 RAM disks of 16384K size 4096 blocksize
loop: module loaded
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
physmap platform flash device: 04000000 at 80000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
5 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 5 MTD partitions on "physmap-flash.0":
0x00000000-0x00060000 : "boot"
0x00060000-0x001a0000 : "kernel"
0x001a0000-0x006a0000 : "rootfs"
0x006a0000-0x00fa0000 : "app"
0x00fa0000-0x00fc0000 : "para"
hi3515v100-ehci hi3515v100-ehci.0: hi3515v100-ehci
hi3515v100-ehci hi3515v100-ehci.0: new USB bus registered, assigned bus number 1
hi3515v100-ehci hi3515v100-ehci.0: irq 23, io mem 0x100b0000
hi3515v100-ehci hi3515v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hi3515v100-ohci hi3515v100-ohci.0: hi3515v100-ohci
hi3515v100-ohci hi3515v100-ohci.0: new USB bus registered, assigned bus number 2
hi3515v100-ohci hi3515v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver hiddev
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
TCP cubic registered
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 80K
я
init started: BusyBox v1.1.2 (2010.03.16-02:37+0000) multi-call binary
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S15mmcfg
Hisilicon ETH net controler(ver Mar 16 2010 10:47:13).
Hisilicon ETH MDIO Bus: probed
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: AA:A3:AA:DC:D7:41
modprobe mmz.
read /dev/mtdblock0 ok...
channel=4
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[Sep 29 2010, 16:06:06]
hifb info: video:vram2_size=4194304,vram0_size=8388608,vram1_size=2048,vram4_size=2048
hifb info: succeed in registering the fb0: ovl2 frame buffer device
hifb info: succeed in registering the fb1: ovl0 frame buffer device
hifb info: succeed in registering the fb2: ovl1 frame buffer device
hifb info: succeed in registering the fb3: ovl4 frame buffer device
*** Board tools : ver0.0.1_20060106 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20110104: 0x00009654 --> 0x00009654
0x20110100: 0x00000887 --> 0x00000887
0x2011010c: 0x00000003 --> 0x00000003
0x20110110: 0x00000007 --> 0x00010303
0x20110114: 0x00000007 --> 0x00010303
0x20110118: 0x00010F01 --> 0x00000007
0x2011011c: 0x00010F01 --> 0x00000007
0x20110128: 0x00010020 --> 0x00010020
0x2011012c: 0x000103A2 --> 0x00010601
0x20110130: 0x00000005 --> 0x00010803
0x20110134: 0x00000007 --> 0x00000007
0x20110138: 0x00010804 --> 0x00010804
0x2011013c: 0x00000007 --> 0x00000007
0x20050078: 0x00000000 --> 0x00008002
0x20050054: 0x00004000 --> 0x00001573
0x200f0094: 0x00000001 --> 0x00000001
0x200f0098: 0x00000001 --> 0x00000001
TDE_MAIN_VERSION[v2.0.0.0] Build Time[Sep 29 2010, 16:06:09]
TDE_ADP_VERSION[hi3515adp v2.0.0.0] Build Time[Sep 29 2010, 16:06:09]
tde run on master arm
tde run for graphic service
tde map reg:basePhyAddr:20140000 baseVirAddr:c3078000 size:3000
Hisilicon UMAP device driver interface: v3.00
Chip Version: Hi35150100
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
************ load hi3515 mpp ok **************
get Board Type:"FP00883"
gBorad_type:0
[F:cpu_gpio_init,L:284]-=========start of cpu_gpio_init initial=========
[F:get_tv_mode_from_gpio,L:105]-gpio0_6 regaddr:20150100, val:0x00000040
[F:cpu_gpio_init,L:298]-=========end of fuho_cpu_gpio initial=========
[F:cpu_gpio_fops_open,L:111]-
[F:cpu_gpio_fops_ioctl,L:144]-ioctl cmd:CPU_GPIO_GET_TV_SYSTEM
[F:cpu_gpio_fops_ioctl,L:146]-gTV_mode:1
[F:cpu_gpio_fops_release,L:117]-
tv_mode:1
>> PAL mode
[F:tw2864_hardware_version,L:409]-Chip address:0x50
[F:tw2864_hardware_version,L:410]-Device ID =0x0D
[F:tw2864_hardware_version,L:411]-Revision ID =0x03
[F:tw2864_hardware_version,L:409]-Chip address:0x52
[F:tw2864_hardware_version,L:410]-Device ID =0x7F
[F:tw2864_hardware_version,L:411]-Revision ID =0x07
[F:tw2864_module_init,L:444]-tw2864 driver init successful!
[F:isl1208_rtc_init,L:360]-=========start of isl1208 initial=========
[F:isl1208_rtc_init,L:373]-=========end of isl1208 initial=========
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48<6>HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48
NULL
hiir: init ok. ver=Jan 12 2011, 14:28:29.
gBorad_type:0
>> FP00883V2
3)fpga not found......
set default fpga state to WITH_FPGA
gFpga_state:1
with FPGA
at88sc driver init successful!
mice: PS/2 mouse device common for all mice
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
hi3515-ahci-device hi3515-ahci-device.: controller can't do NCQ, turning off CAP_NCQ
scsi0 : hi3515-ahci-device
scsi1 : hi3515-ahci-device
ata1: SATA max UDMA/133 irq 29
ata2: SATA max UDMA/133 irq 29
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
0x200f00b4: 0x00000000 --> 0x00000001
a
find: /dev/sda: No such file or directory
b
find: /dev/sdb: No such file or directory
c
find: /dev/sdc: No such file or directory
d
find: /dev/sdd: No such file or directory
[RCS]: /etc/init.d/S20usb3g
usbcore: deregistering interface driver usb-storage
usbcore: registered new interface driver usbserial
/home/vincetsai/work/3515_co_110112/src/drv/trunk/driver/usb3g/serial/../../../../../../SDK/linux-2.6.24/drivers/usb/serial/usb-serial.c: USB Serial Driver core
/home/vincetsai/work/3515_co_110112/src/drv/trunk/driver/usb3g/serial/../../../../../../SDK/linux-2.6.24/drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
/home/vincetsai/work/3515_co_110112/src/drv/trunk/driver/usb3g/serial/option.c: USB Driver for GSM modems: v0.7.1
[RCS]: /etc/init.d/S80network
Auto login as root ...
Jan 1 00:00:11 login[587]: root login on `ttyS000'
BusyBox v1.1.2 (2010.03.16-02:37+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
[1;32mWelcome to HiLinux.[0;39m
None of nfsroot found in cmdline.
~ $ main thread pid=555
keypad=___HA4200B
[gDVR_ch_num:4]
[gKeyPad_type:9]
[pgIrpgIrStyle[0].ir_codeStyle:a35ce608]
</home/vincetsai/work/3515_co_110112/src/app/trunk/modules/osadpt/hi_adpt_memmng.c>(727)HI_MemMng_RegisterUnit(MCTP) :rtn=0x0
</home/vincetsai/work/3515_co_110112/src/app/trunk/modules/osadpt/hi_adpt_memmng.c>(727)HI_MemMng_RegisterUnit(CLI) :rtn=0x0
[u8VoutEnable = 1]
[u8VspotEnable = 0]
[u8VgaEnable = 1]
[u8AudioEnalbe = 1]
[u8ImageAdjustEnable = 1]
[u8MDEnable = 1]
[u32SubStreamBitRate = 512]
open /dev/cpu_gp[F:cpu_gpio_fops_ioctl,L:144]-ioctl cmd:CPU_GPIO_GET_TV_SYSTEM
io opened ok!
>>>>>>>get PAL>>>>>
>>>> tv_system:0(PAL)
vga_state=1
>>>>tv setting is the same
InitSystemParameter VerifySysPara ok
ethaddr=00:16:55:03:9e:89
m_pSysPara->state.DeviceType=HA4200B
InitSystemParameter:00:16:55:03:9e:89(ffffffff)
GetRtcThreadEntry pid=596
timezone env:GMT+0
InitRtc finished
InitMemoryDevice m_HddInfo[0].[F:keypad_open,L:353]-
exist=0, DevName[F:keypad_ioctl,L:382]-KEYPAD_SET_ENABLE_REPKEY >>>>>
=<>, DvrfsPartit[F:keypad_ioctl,L:385]-KEYPAD_SET_ENABLE_REPKEY chk2 >>>>>
ionDevName=<>, E[F:keypad_ioctl,L:395]-copy data from user space fail
xt2PartitionDevName=<>
InitMemoryDevice m_HddInfo[1].exist=0, DevName=<>, DvrfsPartitionDevName=<>, Ext2PartitionDevName=<>
InitMemoryDevice no hdd!!!
OpenPtzSerial open success(/dev/ttyAMA1) !
ReadRemoteEntry pid=597
set enable repkey error!!
HIDVR_HAL_KEYBOARD_EnableRepKey(./devhal.c):1266
InitHal Finished
disp w:704,h:576,imagesize w:704,h:576
InitMal Finished
client : sendbuf=2048, recvbuf=512
network Thread Runing...PID:614,nice=5
1service_ip=168.95.1.1
create Failover Thread. 10251
create Searcher Thread. 11276
InitNetConnection : ifconfig eth0 hw ether 00:16:55:03:9e:89 up
killall: udhcpc: no process killed
adsl-stop: No ADSL connection appears to be running
mv: unable to rename `/tmp/tmpfs/resolv.conf-bak': No such file or directory
killall: pppoe: no process killed
/sbin/ifconfig eth0 192.168.0.100 netmask 255.255.255.0 up
/sbin/route add default gw 192.168.0.1
>>>>>>>get PAL>>>>>
>>>>>>>get PAL>>>>>
>>>>>>>get PAL>>>>>
>>>>>>>get PAL>>>>>
>>>TW2865_AUDIO_INPUT_GAIN:13
>>>TW2865_AUDIO_INPUT_GAIN:4
InitVideoInput Finished
[F]:EnableWndAudio [L]:1658 [Info]:EnableWndAudio start,dev:1,wnd:0
HIDVR_HAL_AUDIO_PLAYBACK:chn:0
[F]:EnableWndAudio [L]:1831 [Info]:EnableWndAudio success,dev:1,wnd:0
InitPreview dev:0, Mode:1 success
InitPreview enIntfType=2 enIntfSync=8 enVgaDev=0
disp w:1024,h:768,imagesize w:1024,h:768
[F]:EnableWndAudio [L]:1658 [Info]:EnableWndAudio start,dev:0,wnd:0
[F]:EnableWndAudio [L]:1831 [Info]:EnableWndAudio success,dev:0,wnd:0
InitPreview dev:2, Mode:1 success
InitVideoOutput Finished
InitIPChn Finished
blair:</home/vincetsai/work/3515_co_110112/src/app/trunk/modules/mainthread/mainthread.cpp>(1183)
Disk(id=0) invalid: 0(exist),-1(groupno),""(name).
Disk(id=1) invalid: 0(exist),-1(groupno),""(name).
func:<InitLog>, line:<1191>
hifb info: vo max resolution w:720 h:576
InitOsd m_Fb.Dishifb info: The layer is show(1) now!
playPhy=0xc2c00000, m_Fb.DisplayMem=0x40454000
InitOsd (/dev/fb0) ok.<whifb info: vo max resolution w:1024 h:768
,h>=<704,576>
playPhy=0xc3000000, m_Fb.DisplayMem=0x40854000
InitOsd (/dev/fb1) ok.<w,h>=<1024,768>
pLangEnc is :CP1251
iconv from UTF8 ro CP1251
=====================GUI VERSION: 1.0.0.2================
DoParseGuiXml parse <xml0:./xml/4_vga_gui.xml> ok
pLangEnc is :CP1251
DoParseGuiXml parse <xml1:./xml/4_vga_gui.xml> ok
set reg alpha:0xff
dev 0 load ./font/ARIALN22_CP1251 ./font/simhei24_CP1252 0
LoadFont english(./font/simhei24_CP1252)(7544)
CGui LoadFont ok
have no font file specific:1
dev 0 load ./font/ARIALN16_CP1251 ./font/simhei16_CP1252 2
LoadFont english(./font/simhei16_CP1252)(3456)
CGui LoadFont ok
have no font file specific:3
set reg alpha:0xff
dev 2 load ./font/ARIALN22_CP1251 ./font/simhei24_CP1252 0
CGui LoadFont ok
dev 2 load ./font/ARIALN16_CP1251 ./font/simhei16_CP1252 2
CGui LoadFont ok
MouseThreadEntry pid=637
set reg alpha:0xb4
set reg alpha:0xb4
HIDVR_HAL_AUDIO_PLAYBACK:chn:TW2865_FIRST_STAGE_hifb info: vo max resolution w:720 h:576
CHIP
[F]:DisableWndAudio [L]:2026 [Info]:DisableWndAudio success,dev:1,wnd:0
ChangeGuiDisplayDevice current m_pGuiPage = 0x5b44d4
InitMouse Open file (/dev/fb3) success!
InitMouse success
GuiThreadEntry pid=638
______watermark user is empty!!_______
StartMainStream chnname=(CH1)
HIDVR_BUF_Create addr=0x41054200 size=(262144*5)
InitEncoder StartMainStream(0)success
StartSubStream chnname=(CH1)
HIDVR_BUF_Create addr=0x411e9200 size=(262144*2)
InitEncoder StartSubStream(0)success
StartMainStream chnname=(CH2)
HIDVR_BUF_Create addr=0x41283200 size=(262144*5)
InitEncoder StartMainStream(1)success
StartSubStream chnname=(CH2)
HIDVR_BUF_Create addr=0x4141c200 size=(262144*2)
InitEncoder StartSubStream(1)success
StartMainStream chnname=(CH3)
HIDVR_BUF_Create addr=0x414b6200 size=(262144*5)
InitEncoder StartMainStream(2)success
StartSubStream chnname=(CH3)
HIDVR_BUF_Create addr=0x4164f200 size=(262144*2)
InitEncoder StartSubStream(2)success
InitEncoder StartMainStream(3)failed
StartSubStream chnname=(CH4)
HIDVR_BUF_Create addr=0x416e9200 size=(262144*2)
InitEncoder StartSubStream(3)success
[F]:EncCommInitSnap [L]:1253 [Info]:InitSnap success
SnapThreadEntry pid=639
##############create snap thread!
InitEncoder finished
RecordThreadEntry pid=640
RecordThreadBody pid=640
VMS_start>>>>>>>>>>>>>>>
VMS_start Client port 9000>>>
HTTP_start>>>>>>>>>>>>>>>
HTTP_start Client port 80>>>
EnableNetworkTranslate main stream(0)
EnableNetworkTranslate sub stream(0)
EnableNetworkTranslate main stream(1)
EnableNetworkTranslate sub stream(1)
EnableNetworkTranslate main stream(2)
EnableNetworkTranslate sub stream(2)
EnableNetworkTranslate sub stream(3)
CreatHttpClientThreadPro:642
CreatNetclientThreadPro:641
INIT_MCTP_Listen...PID:645,nice=5
MainThread pid=555
hi_api_wdt_settimeout(60000ms)
FeedWatchDog!FeedWatchDog!FeedWatchDog!
SystemCall client send -> /mnt/bb_rtsp 4 9000&
SystemCall client recv -> 0 ...cmd finish
GetBeforeDay:09-08-26 11:21:41 tmyear:109,timep:1251285701,hours:1441
tm1year:109,timep:1246098101,hours:1441
(1441)hours ago is:09-06-27 10:21:41
3,cm_write error!
cm_sendcommand != 0, uc_return = 3
cm_writecommand error!
cm_authenencrypt error!
can not active_security!
arm_verify error !
DisableRecord StopRecord start: 1251285701, 374379
DisableRecord StopRecord succ!: 1251285701, 374571
NAND: No NAND device found!!!
0 MiB
DRAM: 128 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
jpeg_size is 20000
[/spoiler]
