U-Boot 2008.10-svn (Mar 19 2012 - 17:14:13)
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
Get info failed, ret = 5
frontboard use 3
system reset
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
frontboard use 3
system reset
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
frontboard use 3
Подумал,что дело может в прошивке.
Снял NOR Flash S29GL064N90TAI04, подключил к программатору и залил прошивку,скачанного одного из форумов. Лучше не стало,все тот же вечный запуск в цикле.
Останавлюваю загрузку,ввожу 'help'
IVSS# 'help'
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
do_encrypt - write data into FLASH memory
erase - erase FLASH memory
flinfo - print FLASH memory information
flwrite - write data into FLASH memory
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
help - print online help
hwid - set hardware id and save to flash
lip - set local ip address but not save to flash
ls - list files in a directory (default /)
mac - set mac address and save to flash
md - memory display
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
protect - enable or disable FLASH write protection
run - run commands in an environment variable
sip - set server ip address but not save to flash
tftp - download or upload image via network using TFTP protocol
Ввожу printenv
IVSS# printenv
bootcmd=fsload; bootm 0xc1000000
bootdelay=3
baudrate=115200
xload=1
jpeg_addr=0xc0000000
jpeg_size=0x80000
vobuf=0xcff00000
da=tftp 0xc1000000 u-boot.bin.img;protect off all; flwrite
dr=tftp 0xc1000000 romfs-x.cramfs.img; flwrite
dc=tftp 0xc1000000 custom-x.cramfs.img; flwrite
du=tftp 0xc1000000 user-x.cramfs.img; flwrite
dw=tftp 0xc1000000 web-x.cramfs.img; flwrite
dl=tftp 0xc1000000 logo-x.cramfs.img; flwrite
up=tftp 0xc1000000 update.img; flwrite
tk=tftp 0xc1000000 uImage; bootm 0xc1000000
gatewayip=10.12.1.1
netmask=255.255.0.0
bootfile=boot/uImage
ethaddr=00:01:06:05:03:05
ID=600412200525
HWID=00000000000000
serverip=192.168.0.68
ipaddr=192.168.0.65
restore=0
bootargs=mem=64M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:256K(boot),2176K(rootfs),3584K(user),1280K(web),128K(custom),64K(logo),64K(tool),640K(config) busclk=220000000
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2008.10-svn (Mar 19 2012 - 17:14:13)
filesize=18f5f4
За тем ввожу bootm:
Wrong Image Format for bootm command ERROR: can't get kernel image!
А если ввести fsload, за тем bootm 0xC100000 , то выдается такой лог:
IVSS# fsload
### CRAMFS loading 'boot/uImage' to 0xc1000000
### CRAMFS load complete: 1635828 bytes loaded to 0xc1000000
IVSS# bootm 0xc1000000
## Booting kernel from Legacy Image at c1000000 ...
Image Name: Linux-2.6.24-rt1-hi3515v100
Data Size: 1635764 Bytes = 1.6 MB
Load Address: c0800000
Entry Point: c0800000
Loading Kernel Image ... OK
OK
Hisilicon ETH net controler
miiphy_register: non unique device name '0:7'
Starting kernel ...
Uncompressing Linux...................................................................................................... done, booting the kernel.
Auto login as root ...
warning: cannot change to home directory
root login on `ttyS000'
BusyBox v1.1.2 (2011.05.20-03:51+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to HiLinux.
На этом я застопорился. К сожалению в Linux я не силен.
