Камеры на процессоре Ingenic T10
Re: Камеры на процессоре Ingenic T10
Thanks NeiroN,
WOrks great.
regards
						WOrks great.
regards
Hello, I am new here and having some problems with 2 cameras same model with ingenic T10 processor.
Followed the process and installed the Noboot.bin file via UART connection to serial interface. The camera starts booting but there is no movement, the voice saying ready to connect, neither the reset button works.
If anybody could help.
Post transcript from serial interface after uploading Noboot.bin file as Paul_B description in 1st of july post.
this is my camera:
U-Boot SPL 2013.07 (Sep 22 2016 - 21:41:56)
pll_init:347
l2cache_clk = 450000000
pll_cfg.pdiv = 8, pll_cfg.h2div = 4, pll_cfg.h0div = 4, pll_cfg.cdiv = 1, pll_cfg.l2div = 2
nf=36 nr = 1 od0 = 1 od1 = 1
cppcr is 02404900
CPM_CPAPCR 0470890d
nf=50 nr = 1 od0 = 1 od1 = 1
cppcr is 03204900
CPM_CPMPCR 0320490d
cppcr 0x9a7b5510
apll_freq 860160000
mpll_freq 1200000000
ddr sel mpll, cpu sel apll
ddrfreq 400000000
cclk 860160000
l2clk 430080000
h0clk 300000000
h2clk 300000000
pclk 150000000
CPM_DDRCDR(0000002c) = a0000002
U-Boot 2013.07 (Sep 22 2016 - 21:41:56)
Board: ISVP (Ingenic XBurst T10 SoC)
DRAM: 64 MiB
Top of RAM usable for U-Boot at: 84000000
Reserving 423k for U-Boot at: 83f94000
Reserving 32784k for malloc() at: 81f90000
Reserving 32 Bytes for Board Info at: 81f8ffe0
Reserving 124 Bytes for Global Data at: 81f8ff64
Reserving 128k for boot params() at: 81f6ff64
Stack Pointer at: 81f6ff48
Now running in RAM - U-Boot at: 83f94000
MMC: msc: 0
the manufacturer c2
SF: Detected MX25L64**E
In: serial
Out: serial
Err: serial
Net: CPM_MACCDR(54) = a0000017
Jz4775-9161
the manufacturer c2
SF: 2621440 bytes @ 0x40000 Read: OK
## Booting kernel from Legacy Image at 80600000 ...
Image Name: Linux-3.10.14
Image Type: MIPS Linux Kernel Image (gzip compressed)
Data Size: 2036771 Bytes = 1.9 MiB
Load Address: 80010000
Entry Point: 80399e10
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.14 (root@aplink-desktop) (gcc version 4.7.2 (Ingenic 2015.02) ) #28 PREEMPT Thu Jun 16 13:06:04 CST 2016
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 RESET ERROR PC:A54718E1
[ 0.000000] CPU0 revision is: 00d00100 (Ingenic Xburst)
[ 0.000000] FPU revision is: 00b70000
[ 0.000000] CCLK:860MHz L2CLK:430Mhz H0CLK:200MHz H2CLK:200Mhz PCLK:100Mhz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 00439000 @ 00010000 (usable)
[ 0.000000] memory: 00037000 @ 00449000 (usable after init)
[ 0.515050] jz_mac jz_mac.0: MII Probe failed!
[ 0.992337] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
mdev is ok......
ifconfig: SIOCGIFFLAGS: No such device
apk-link login: ifconfig: wlan0: error fetching interface information: Device not found
not find mac===Get wifi ap mac:===
not find mac===Get wifi mac:===
===NetWorkSetMac===00:02:B2:35:B3:A8
sscanf return 6
@@@@ APSSID APCAM_35FFFFFFB3FFFFFFA8 @@@@
===Get wifi ap mac:00:0C:00:09:08:BA===
===Get wifi mac:00:0C:00:09:08:BA===
SysParamRead system.ini
RTSP Port 10554
ONVIF Port 10080
SysLanguageRead language.ini
Now Language is English !
/usr/bin/unzip -o /system/www/audio_en.zip -d /tmp
kernelversion = Thu Jun 16 13:06:04 CST 2016
user0: pwd:
user1: pwd:
user2:admin pwd:9999
SysDefaultVoiceInit : 2
sysversion:A70.9.1.16.76E
SysParamRead factory.ini
ssid:smurf2G wifiauth 4 wifikey:9811279128
killall: wpa_supplicant: no process killed
===wifi is run wpa_supplicant -B -Dwext -iwlan0 -c /tmp/wpa_supplicant.conf===
===NetWorkEthInitMac===00:02:B2:35:B3:A8
ifconfig: SIOCSIFHWADDR: No such device
========mac=00:02:B2:35:B3:A8===========
route: SIOCDELRT: No such process
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: No such device
dns1:8.8.8.8 dns2:192.168.1.1
===IpcSocketInit=6666===
===IpcSocketInit end=3===
===snetworkethmac:00:02:B2:35:B3:A8 snetworkwifimac:00:0C:00:09:08:BA===
SearchAppInit by zxh
ServiceInit by zxh
update Socket proc is start
update socket init
start app update thread
===SearchThreadProc===
Archive: /system/system/bin/encoder.zip
inflating: encoder
===wificam is start===
===wificam insmod ko is start===
Archive: /system/system/lib/tx-isp.ko.zip
inflating: tx-isp.ko
===wificam insmod ko is end ===
adc_max : 0
adc_min : 0
GpioDataGpioMux:0
GpioDataGpioMux:0
GPIO_PIN_DIR:0
GpioDataGpioDir:0
GpioMotoInit
GpioAduioOut 0
RTSP Port 10554
ONVIF Port 10080
user0: pwd:
user1: pwd:
sscanf return 6
alarm433 alarmcam.ini
===audio Codec Init===0
< Audio In Init Start >
Samplerate:16000 Bitwidth:16 Soundmode:1 FrmNum:20 NumPerFrm:320 ChnCnt:1
Audio In GetChnParam usrFrmDepth : 20
< Audio In Init End >
Audio In SetInPutVolume vol:11
===AudioInInit OK===
< Audio Out Init Start >
< Audio Out Init End >
===AudioOutInit OK===
AudioPlayProc:158
1AlarmTimerParamRead 4 0-0-0-0
===H264ParamInit===
H264ParamInit bright 134 hue 128 saturation 128 contrast 126 videomode 0 videoenv 0 bitrate 1024 framerate 25 ratemode 1 bitratesub 15 frameratesub 512 ratemodesub 1 bitratesubsub 15 frameratesubsub 128 ratemodesubsub 0
===H264StreamInit===
===cmd:route add default gw 192.168.1.1 wlan0===
=========mount start===========
mount -t vfat /dev/mmcblk0 /mnt
=========mount end===========
NetWorkSetInterface 0
killall: udhcpc: no process killed
##### sensor not found
g_sensor_type = 3
===InitVideoEncoder===
Encoder_Get_Video_Resolution : 0
#################################Sensor = jxh42 ####################################
[ 17.441338] jxh42 0-0030: chip found @ 0x30 (i2c-gpio0) is not an jxh42 chip.
===InitVideoEncoder end===-1
File size = 261702
Read size = 261702
===H264 osd init===-1
===H264 osd1 init===-1
H264EncoderThread
===ShowVideoOsd_Time===
===ShowVideoOsd===
channelname------------------:WIFICAM==len=7
===SIGSEGV===
Polling stream1 timeout iRet = -1
Polling stream0 timeout iRet = -1
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
dhcp isn't open...,ipaddr:192.168.1.173 netmask:255.255.255.0 gateway:192.168.1.1 dns1:8.8.8.8 dns2:192.168.1.1
===SIGSEGV===
===SIGSEGV===
===dhcp is start and note encoder network===
NetWorkParamSync in 0
route: SIOCADDRT: File exists
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
Sorry don't speak russian.
Thanks
this is my camera:
pll_init:347
cppcr is 02404900
CPM_CPAPCR 0470890d
cppcr is 03204900
CPM_CPMPCR 0320490d
cppcr 0x9a7b5510
apll_freq 860160000
ddrfreq 400000000
cclk 860160000
l2clk 430080000
h0clk 300000000
h2clk 300000000
pclk 150000000
DRAM: 64 MiB
MMC: msc: 0
the manufacturer c2
In: serial
Out: serial
Err: serial
Jz4775-9161
the manufacturer c2
Starting kernel ...
mdev is ok......
sscanf return 6
RTSP Port 10554
ONVIF Port 10080
user0: pwd:
user1: pwd:
ServiceInit by zxh
update socket init
inflating: encoder
adc_max : 0
adc_min : 0
GpioDataGpioMux:0
GpioDataGpioMux:0
GPIO_PIN_DIR:0
GpioDataGpioDir:0
GpioMotoInit
GpioAduioOut 0
RTSP Port 10554
ONVIF Port 10080
user0: pwd:
user1: pwd:
sscanf return 6
AudioPlayProc:158
===H264ParamInit===
g_sensor_type = 3
File size = 261702
Read size = 261702
H264EncoderThread
===ShowVideoOsd===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
===SIGSEGV===
Thanks
wi-fi adapter in your camera do not working with this firmware(or just die).
Thank you for the reply. the Hardware is the same in Annke  ig21, Wascam hw00036 and digoo bb-m2.
Do you know about another firmware that i can use to revive the camera?
i have tried this one IPcam25x64.bin with same result. and i have this one Wanscam A70.68.1.16.100-T11.68.1.17.6 for after camera is recovered.
Hi to all, sorry for my English but i do not speak Russian. I am having problem with a DIgoo BB-M2 which i erased all flash.. now i am trying to recovery as miky_man did... If i have the four files boot.bin, kernel.bin, rootfs.bin & system.bin, how can i burn them back through SPI programmer? Could anyone help please? Does anyone have a clean and full dump of Digoo BB-M2?
Thank you!
P.S. miky_man please if you read this and could help PM me.. thanks!
						Thank you!
First burn boot.bin from 0x000000, next you need find env for boot, if it not contains in boot.bin.
Env contains partition sizes and boot command. It may be recovered from sample cameras if boot.bin provide incorrect default env.
Hi again... thanks for your help... i managed to write the chip by Raspberry SPI programmer and now the camera boots... have a nice time
