iptrinic ahdr0420h
Re: iptrinic ahdr0420h
Сообщение AlienP666 » 06 мар 2019, 06:32
Sonya писал(а):Готовьте UART адаптер или программатор, если есть.
Fluffykrsk писал(а):В данном случае Вы - мастер... вам и флаг в руки))))
:good:
scals
Сообщение scals » 06 мар 2019, 09:05
Подключился через uart.
Выдал:
U-Boot 2010.06 (May 31 2016 - 12:19:57)
Spi(cs1) ID: 0xC2 0x20 0x19 0xC2 0x20 0x19
Spi(cs1): Block:64KB Chip:32MB Name:"MX25L25635E/735E/635F"
In: serial
Out: serial
Err: serial
32768 KiB hi_sfc at 0:0 is now current device
jpeg decoding ...
<<addr=0x82000000, size=0xc0000, vobuf=0x9f000000>>
mmu_enable
<<imgwidth=1280, imgheight=720, linebytes=2560>>
decode success!!!!
decode jpeg!
dev 0 opened!
graphic layer 0 opened!
## watch dog open
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
Image Name: Linux-3.0.8
Data Size: 3230132 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@rong) (gcc version 4.4.1 (Hisilicon_v200(gcc4.4-290+gl
ibc-2.11+eabi+nptl)) ) #2 Tue Apr 19 15:31:01 KST 2016
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960
Kernel command line: mem=240M console=ttyAMA0,115200 initrd=0x82400000,0xA00000
root=/dev/ram0 init=linuxrc mtdparts=hi_sfc:1M(boot),4M(kernel),10M(rootfs),10M(
app),4M(www),1M(data),1M(config),1M(logo)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 240MB = 240MB total
Memory: 227012k/227012k available, 18748k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xcf800000 - 0xfe000000 ( 744 MB)
lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
.init : 0xc0008000 - 0xc002c000 ( 144 kB)
.text : 0xc002c000 - 0xc05b3000 (5660 kB)
.data : 0xc05b4000 - 0xc05d72c0 ( 141 kB)
.bss : 0xc05d72e4 - 0xc0631b08 ( 363 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
console [ttyAMA0] enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 10240K
L2cache cache controller enabled
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 463
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:32MB
spi size: 32MB
chip num: 1
8 cmdlinepart partitions found on MTD device hi_sfc
Creating 8 MTD partitions on "hi_sfc":
0x000000100000-0x000000500000 : "kernel"
0x000000500000-0x000000f00000 : "rootfs"
0x000000f00000-0x000001900000 : "app"
0x000001900000-0x000001d00000 : "www"
0x000001d00000-0x000001e00000 : "data"
0x000001e00000-0x000001f00000 : "config"
0x000001f00000-0x000002000000 : "logo"
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: 4A:02:5D:FF:C2:7A
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 6672KiB [1 disk] into ram disk... done.
VFS: Mounted root (cramfs filesystem) readonly on device 1:0.
Freeing init memory: 144K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd[578]: mainudevd (578): /proc/578/oom_adj is deprecated, please use /proc/5
78/oom_score_adj instead.
: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S80network
mount: mounting /dev/mtdblock3 on /app failed: Invalid argument
ADDRCONF(NETDEV_UP): eth0: link is not ready
cp: can't stat '/app/resolv.conf': No such file or directory
mkdir: can't create directory '/var/run': File exists
cp: can't create '/var/ppp': File exists
SDK_TYPE type is 8d1
hi3520D_base: module license 'Proprietary' taints kernel.
Hisilicon UMAP device driver interface: v3.00
load sys.ko ...OK!
Load tde.ko ...OK!
load venc.ko ...OK!
load group.ko ...OK!
load chnl.ko ...OK!
load h264e.ko ...OK!
load rc.ko ...OK!
load jpege.ko ...OK!
load viu.ko ...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load hi_jpegdec.ko success. (SDK_VERSION:[SDK_VERSION] Build Time:[Apr 15 20
15, 20:29:31])
HISI_IRDA-MF @Hi3520Dv100R00
hiir: init ok. ver=Sep 30 2014, 10:56:00.
R2xxx V1.0.2.0
0x35210002
Enable RS422.
my_gpio_i2c: exports duplicate symbol gpio_i2c2_read (owned by gpioi2c)
insmod: can't insert 'my_gpio_i2c.ko': invalid module format
sh: 1: unknown operand
AHD2.0 EXT Driver 0.6.b(02.18)
AHD2.0 Device ID Error... ff
AHD2.0 Device (0x64) ID OK... 86
AHD2.0 Device (0x64) REV ... 0
AHD2.0 Count = 1
nvp6124b_system_init
ch 0 setted to 1080P PAL
ch 1 setted to 1080P PAL
ch 2 setted to 1080P PAL
ch 3 setted to 1080P PAL
nvp6124b_set_portmode portsel 0 portmode 16 setting
nvp6124b_set_portmode portsel 1 portmode 16 setting
111111111111111111111111
nvp6124 audio init,REC:MASTER,PB:MASTER
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0,
nodeamon= 0)
========== GPIO_SET_DIR:0x1
=== Init OK ===
Welcome to HiLinux.
app start
/root/init.sh: line 90: /app/appStart.sh: not found
(none) login: /root/init.sh: line 61: /app/bin/initf: not found
Login timed out (none) login:
Подскажите что делать дальше
scals
Сообщение scals » 06 мар 2019, 13:49
hisilicon # printenv
bootargs=mem=240M console=ttyAMA0,115200 initrd=0x82400000,0xA00000 root=/dev/ram0 init=linuxrc mtdparts=hi_sfc:1M(boot),4M(kernel),10M(rootfs),10M(app),4M(www),1M(data),1M(config),1M(logo)
bootcmd=sf probe 0;sf read 0x82000000 0x100000 0x400000;sf read 0x82400000 0x500000 0xA00000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.254.0
bootfile="uImage"
bootlogo=sf probe 0;sf read 0x82000000 0x1F00000 0x100000;decjpg;startvo 0 36 6;startgx 0 0x9f000000 2560 0 0 1280 720
jpeg_addr=0x82000000
jpeg_size=0xC0000
vobuf=0x9f000000
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06 (May 31 2016 - 12:19:57)
Environment size: 704/262140 bytes
scals
Сообщение scals » 06 мар 2019, 15:57
Это дамп что сейчас в реге
https://drive.google.com/open?id=1jzfI1 ... NuegGMXXyn" onclick="window.open(this.href);return false;
Подскажите что дальше
fobos
Сообщение fobos » 06 мар 2019, 23:01
показывайте прошивку, которой обновляли при отключении питания
fobos
Сообщение fobos » 07 мар 2019, 19:57
scals, https://yadi.sk/d/ftQ36Thu3YoUC4" onclick="window.open(this.href);return false;
загрузите файл на пустой USB носитель в корневой каталог, подключите носитель к регистратору и перезагрузите регистратор, установка прошивки начнётся автоматически.
После установки необходимо отключить носитель с автоустановщиком и обновить прошивку до актуальной. Актуальная прошивка https://yadi.sk/d/OfWr_29Ttlyqww" onclick="window.open(this.href);return false;
scals
Сообщение scals » 11 мар 2019, 09:34
Большое спасибо.
Всё получилось. Рег заработал.
Сообщение Sonya » 11 мар 2019, 14:21
fobos писал(а):Актуальная прошивка https://yadi.sk/d/OfWr_29Ttlyqww" onclick="window.open(this.href);return false;
Что это за зверь такой был?
fobos
Сообщение fobos » 12 мар 2019, 17:43
Sonya писал(а):Что это за зверь такой был?
да понятия не имею...какой-то Iptronic...
