AHD DVR 1080P AHD-3908 висит на заставке.
yuri1958
Сообщение yuri1958 » 14 июл 2019, 10:10
1080P AHD-3908 процессор GM8287 флеш MX25L6405D . Надпись на майне FULL_HD AHD2.0_8CH V1.1 . Надпись на наклейке GM10808CH DATA:2015-08-19. Прошивку найти не смог. Лог загрузки
GM8287 SYSTEM go.................DR 1.6 256MB
MP SPI-NOR Bootstrap v0.1
SPI020 Revision:0x10001
SPI flash ID code:c2 20 17
SPI jump setting is 3 bytes mode
Boot image offset: 0x10000. size: 0x50000. Booting Image .....
U-Boot 2013.01 (Sep 18 2015 - 11:32:20)
DRAM: 128 MiB
ROM CODE has enable I cache
SPI mode
Flash: 6.6 MiB
SF: Got idcodes
00000000: c2 20 17 c2 . ..
SF: Detected MX25L6405D with page size 64 KiB, total 8 MiB
flash is 3byte mode
In: serial
Out: serial
Err: serial
AC: 396 HC: 297 P1:1188 P4: 768
C6: 792 DR:1584
J: 297 H1: 396 H2: 396
Net: GMAC set RMII mode
reset PHY
eth0
Warning: eth0 MAC addresses don't match:
Address in SROM is 30:30:20:75:73:65
Address in environment is 00:42:70:00:30:22
0x8287 setgpio = 0x 82
0x8287 muligpio8 = 0x 2
(Re)start USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1: USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
USB founded
** Bad device usb 0 **
kernel.img founded
all.img founded
SF: Got idcodes
flash is 3byte mode
start hdmi polling thread.
sli-hdmi is in 1920x1080 RGBI2C_IP1_init APB freq = 49500000
I2C_IP1_init: speed: 100000, div = 244
Please plug-in the HDMI cable, otherwise the system may keep wating the connection....
HDMI connection is dropped!
SF: Got idcodes
flash is 3byte mode
---mtdparts_init---
dev id: type = 1, num = 0, size = 0x00690000, mtd_id = single part
part : name = static, size = 0x00690000, offset = 0x00000000 sector_size 0x10000
--- jffs2_part_info: partition number 0 for device nor0 (single part)
### JFFS2 loading 'logo.jpg' to 0xe200000
Scanning JFFS2 FS: . done.
dir entries = 00000005
frag entries = 00000608
+4 increments = 00003e77
+file_offset increments = 00000619
### JFFS2 load complete: 60470 bytes loaded to 0xe200000
decode success!!!!
---mtdparts_init---
### JFFS2 loading 'uImage' to 0x2000000
### JFFS2 load complete: 3910576 bytes loaded to 0x2000000
## Booting kernel from Legacy Image at 02000000 ...
Image Name: gm828x
Data Size: 3910512 Bytes = 3.7 MiB
Load Address: 02000000
Entry Point: 02000040
Verifying Checksum ... Bad Data CRC
Считал дамп программатором , но не смог найти в нем раздел конфигурации.
Дамп тут https://yadi.sk/d/_gJen6NRfZAeFA" onclick="window.open(this.href);return false;
Прошу помощи разобраться с дампом. Если есть у кого прошивка поделитесь если есть возможность.
Re: AHD DVR 1080P AHD-3908 висит на заставке.
Сообщение dede » 14 июл 2019, 20:15
http://www.anko-tech.com/d/u/anko_8ch_87_2.3.54.update" onclick="window.open(this.href);return false;
yuri1958
Сообщение yuri1958 » 14 июл 2019, 21:03
Спасибо буду пробовать.
yuri1958
Сообщение yuri1958 » 16 июл 2019, 18:15
Скачал файл, записал на флешку ,при загрузке двр автоматом не обновляется. Пробовал лить через ТФТП сервер переименовав файл в AC100233.img как просил ДВР. файл двр тянет но при перезагрузке изменений нет.
0GM8287 SYSTEM go.................DR 1.6 256MB
SPI flash ID code:c8 40 17
DRAM: 128 MiB
SPI mode
Flash: 6.6 MiB
SF: Got idcodes
00000000: c8 40 17 c8 .@..
SF: Detected GD25Q64c with page size 64 KiB, total 8 MiB
flash is 3byte mode
In: serial
Out: serial
Err: serial
C6: 792 DR:1584
reset PHY
eth0
GM # help
? - alias for 'help'
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootlogo- show lcd bootlogo
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
dcache - enable or disable data cache
env - environment handling commands
erase - erase FLASH memory
exit - exit script
false - do nothing, unsuccessfully
flinfo - print FLASH memory information
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
fwupd - firmware upgrade from usb device for specified filename
icache - enable or disable instruction cache
l2cache_test- Perform test of L2 cache
ls - list files in a directory (default /)
md - memory display
memtester- memory tester
mii - MII utility commands
mw - memory write (fill)
protect - enable or disable FLASH write protection
run - run commands in an environment variable
sf - SPI flash sub-system
showvar - print local hushshell variables
sspi - SPI utility command
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
usb - USB sub-system
version - print monitor, compiler and linker version
GM # tftpboot
RMII mode
Phy ID = 0xc54
Link can't be completed, detect speed fail, please check Network cable
HALF
PHY_SPEED_10M
*** Warning: no boot file name; using 'AC100233.img'
Using eth0 device
TFTP from server 172.16.2.100; our IP address is 172.16.2.51
Filename 'AC100233.img'.
Load address: 0x2000000
Где ошибаюсь не пойму.
Сообщение dede » 16 июл 2019, 18:30
fwupd попоробовать, для обновления через usb
yuri1958
Сообщение yuri1958 » 17 июл 2019, 05:30
dede писал(а):fwupd попоробовать, для обновления через usb
fwupd не заливает обновление. Наверное прийдется дамп искать
