IP камера Hikvision DS-2CD2345F-IS
Re: IP камера Hikvision DS-2CD2345F-IS
Сообщение 128203 » 04 мар 2022, 06:35
Прошу поделиться дампом... :smile:
128203
Сообщение 128203 » 04 мар 2022, 07:22
по UART вываливаются ошибки и циклично повторяются :
[11:58:21 03.03.2022] I: Staring agent updater, version v1.0.53-11-g2df56ce-b12639
[11:58:21 03.03.2022] I: Read config file /opt/etc/ag-upd.json
[11:58:21 03.03.2022] I: Added updater url: 'https://camera-updater.videocomfort.ru/ ... rsion.json'
[11:58:22 03.03.2022] I: [TRUSTED CA] Reading '/opt/share/vc/cacert.pem'
[11:58:22 03.03.2022] I: [TRUSTED CA] Loaded 7 root certificates
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0303 11:58:22.266304 901 InterConn.cc:532] Connecting to 127.0.0.1:10000
I0303 11:58:22.267313 901 InterConn.cc:644] TcpConn error
[11:58:22 03.03.2022] E: resetRootPassword() error: Connection refused
I0303 11:58:22.393317 898 LogCache.cc:23] Log cache initialized, size = 500000 bytes
I0303 11:58:22.393914 898 Main.cc:52] Starting VC-HAL, version v0.5.5-198-ga6d0b8b-b12639 (built on Mar 12 2018 at 08:22:19) ...
W0303 11:58:22.880043 898 HalServer.cc:1908] System may be unstable! Counter is 5 of 5
W0303 11:58:22.880406 898 HalServer.cc:1913] System is unstable. VC-HAL will be run in safe mode for 1 hour
I0303 11:58:23.049499 898 DevInfo.cc:242] Tech json: {
"sn": "161*******",
"hw-type": "6******",
"eth-mac": "64:*******"
I0303 11:58:23.059003 898 VideoInputImpl.cc:1707] VB Pool (re)inited: total size is 10324272 bytes in 15 blocks.
I0303 11:58:23.230094 898 InterConn.cc:493] Bound to 127.0.0.1:10000
I0303 11:58:23.230652 898 App.cc:1316] Started watchdog with timeout 60 seconds
^Cudhcpc: sending discover
I0303 11:58:24.280148 901 InterConn.cc:532] Connecting to 127.0.0.1:10000
I0303 11:58:24.280555 901 InterConn.cc:621] Tcp connected.
I0303 11:58:24.281381 898 InterConn.cc:598] Accepting conn from 127.0.0.1:46352
I0303 11:58:24.281833 898 App.cc:112] New client #1
I0303 11:58:24.282423 898 App.cc:134] Hello from #1. Version is: v1.0.53-11-g2df56ce-b12639
I0303 11:58:24.282698 898 App.cc:136] Sending HELLO ACK...
I0303 11:58:24.283869 898 App.cc:714] #1 initializing ROOT password
I0303 11:58:24.328410 898 App.cc:1152] #1 init ROOT password result: success
[11:58:24 03.03.2022] I: SetState (0)
[11:58:24 03.03.2022] I: AgentGuard init
[11:58:24 03.03.2022] I: Check ag-cfg update: /config/vc/ag-cfg.json - exists; bundled md5=,current md5=0b0618b3d0d83d9dc53d16a7919b0b63
[11:58:24 03.03.2022] W: Rewriting ag-cfg
[11:58:24 03.03.2022] I: Trying to start agent: /var/AgentGreen/AgentGreen /config/vc/ag-cfg.json
[11:58:24 03.03.2022] I: Checking network url=http://google.ru
[11:58:24 03.03.2022] E: Http client error: DNS failed (-6), http code 0
I0303 11:58:24.340179 898 InterConn.cc:711] ProtoConn closed
I0303 11:58:24.340571 898 App.cc:124] Client #1 gone...
[11:58:24 03.03.2022] I: [SCAN QR] Reason: Network is not okay
[11:58:24 03.03.2022] I: SetState (1)
I0303 11:58:24.362556 898 InterConn.cc:598] Accepting conn from 127.0.0.1:46353
I0303 11:58:24.362977 898 App.cc:112] New client #1
I0303 11:58:24.363451 901 InterConn.cc:532] Connecting to 127.0.0.1:10000
I0303 11:58:24.363844 901 InterConn.cc:621] Tcp connected.
I0303 11:58:24.364504 898 App.cc:134] Hello from #1. Version is: v1.0.53-11-g2df56ce-b12639
I0303 11:58:24.364831 898 App.cc:136] Sending HELLO ACK...
I0303 11:58:24.365926 898 App.cc:156] #1 subscribing for QR. Well, OK.
I0303 11:58:24.445346 898 VideoInputImpl.cc:402] Loading SNS lib "libsns_ov4689.so"
linear mode
-------OV4689 Sensor 720180fps Linear Mode Initial OK!-------
I0303 11:58:24.878769 898 IspParams.cc:1443] ISP WDR MODE = 0
I0303 11:58:24.880735 898 VideoInputImpl.cc:568] RAW VIDEO SETTINGS: 1280x720, 25 fps
I0303 11:58:25.600473 898 InterConn.cc:598] Accepting conn from 127.0.0.1:46354
I0303 11:58:25.600940 898 App.cc:112] New client #2
I0303 11:58:25.601790 898 InterConn.cc:711] ProtoConn closed
I0303 11:58:25.602124 898 App.cc:124] Client #2 gone...
I0303 11:58:25.633670 936 App.cc:20] Starting...
^CI0303 11:58:25.782405 936 StateCache.cc:191] state cache loaded from /config/vc/agent-state-cache.json
I0303 11:58:25.910382 936 NetUtils.cc:1083] local: 0.0.0.0 => 127.0.0.1
I0303 11:58:25.919896 936 NetUtils.cc:898] NEW ADDR: lo idx: 1 mac: 00:00:00:00:00:00 mtu: 16436 ip: 127.0.0.1 mask: 255.0.0.0 IF_OPER_UNKNOWN IFF_UP IFF_LOOPBACK IFF_RUNNING IFF_LOWER_UP
PHY: mdio0:03 - Link is Up - 100/Full
I0303 11:58:26.080358 898 InterConn.cc:598] Accepting conn from 127.0.0.1:46355
I0303 11:58:26.080793 898 App.cc:112] New client #2
I0303 11:58:26.081231 936 InterConn.cc:551] Connecting to 127.0.0.1:10000
I0303 11:58:26.246963 936 Agent.cc:165] AgentGreen v2.7.22-1-g33e161ef-b12639
I0303 11:58:26.352952 936 RequestQueue.cc:48] enqueued agent_green::GetDeviceInfoRequest (queue size = 1)
I0303 11:58:26.353528 936 RequestQueue.cc:48] enqueued agent_green::GetDeviceCapabilitiesRequest (queue size = 2)
I0303 11:58:26.354444 936 RequestQueue.cc:63] executing agent_green::GetDeviceInfoRequest
I0303 11:58:26.354864 936 InterConn.cc:644] Tcp connected.
I0303 11:58:26.355136 936 ProtoHal.cc:293] connected
I0303 11:58:26.355958 898 App.cc:134] Hello from #2. Version is: v2.7.22-1-g33e161ef-b12639
I0303 11:58:26.356299 898 App.cc:136] Sending HELLO ACK...
I0303 11:58:26.357986 898 App.cc:283] #2 getting device info
I0303 11:58:26.358364 898 App.cc:913] #2 get device info result: success
I0303 11:58:26.358748 898 App.cc:276] #2 subscribed for alert notifications
I0303 11:58:26.359659 936 DeviceControlImpl.cc:202] {"agent_version":"","boot_version":"","encoder_version":"","firmware_version":"v0.9.8-115-g5566287-b12639 180312","hardware_version":"","mac":"64*******","model":"DS-2CD2345FB","serial":"16********","soft_meta_version":"","vendor":"Hikvision"}
I0303 11:58:26.394507 936 RequestQueue.cc:75] completed agent_green::GetDeviceInfoRequest (queue size = 1)
I0303 11:58:26.394873 936 RequestQueue.cc:63] executing agent_green::GetDeviceCapabilitiesRequest
I0303 11:58:26.395622 898 App.cc:435] #2 getting device caps
I0303 11:58:26.395977 898 App.cc:1016] #2 get device caps result: success
I0303 11:58:26.397043 898 App.cc:293] #2 getting video caps
I0303 11:58:26.397629 898 App.cc:920] #2 get video caps result: success
I0303 11:58:26.417148 936 RequestQueue.cc:48] enqueued agent_green::SetDeviceNameRequest (queue size = 2)
I0303 11:58:26.417601 936 RequestQueue.cc:48] enqueued agent_green::SetDirectAccessModeRequest (queue size = 3)
I0303 11:58:26.417912 936 RequestQueue.cc:48] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 4)
I0303 11:58:26.418190 936 RequestQueue.cc:48] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 5)
I0303 11:58:26.418431 936 RequestQueue.cc:48] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 6)
I0303 11:58:26.419029 936 RequestQueue.cc:48] enqueued agent_green::SetMotionDetectorParamsRequest (queue size = 7)
I0303 11:58:26.419639 936 RequestQueue.cc:48] enqueued agent_green::SetIntrusionDetectorParamsRequest (queue size = 8)
I0303 11:58:26.432837 936 RequestQueue.cc:48] enqueued agent_green::SetTamperDetectorParamsRequest (queue size = 9)
I0303 11:58:26.433506 936 RequestQueue.cc:48] enqueued agent_green::SetLineCrossingDetectorParamsRquest (queue size = 10)
I0303 11:58:26.434027 936 RequestQueue.cc:48] enqueued agent_green::SetSoundDetectorParamsRequest (queue size = 11)
I0303 11:58:26.434394 936 RequestQueue.cc:48] enqueued agent_green::SetFaceDetectorParamsRequest (queue size = 12)
I0303 11:58:26.434768 936 RequestQueue.cc:48] enqueued agent_green::SetPlateDetectorParamsRequest (queue size = 13)
I0303 11:58:26.523619 936 RequestQueue.cc:48] enqueued agent_green::SetTimeSettingsRequest (queue size = 14)
I0303 11:58:26.524102 936 MemoryCardKeeper.cc:179] new cleanup params: mode: AUTO, threshold: 95
I0303 11:58:26.524602 941 MemoryCardKeeper.cc:351] memory card (/dev/mmcblk0) not found
I0303 11:58:26.524935 936 RequestQueue.cc:75] completed agent_green::GetDeviceCapabilitiesRequest (queue size = 13)
I0303 11:58:26.525257 936 RequestQueue.cc:63] executing agent_green::SetDeviceNameRequest
W0303 11:58:26.525830 936 MemoryCardKeeper.cc:306] UNKNOWN => NOT_FOUND
I0303 11:58:26.526644 898 App.cc:330] #2 setting camera name: 1********
I0303 11:58:26.527004 898 App.cc:948] #2 set camera name result: success
Сообщение oleglevsha » 04 мар 2022, 08:59
Выкинь эту подделку, или смотри в сторону openipc, https://openipc.org
Дамп не поможет
128203
Сообщение 128203 » 04 мар 2022, 09:40
oleglevsha писал(а):
04 мар 2022, 08:59
Дамп не поможет
Сенсор ov4689, непонятен процессор, какую прошивку использовать ???
в логах мелькает :
Machine: hi3516a
Linux version 3.4.35 (root@runner-8e7d6cd8-project-22-concurrent-0) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) )
можно ли сделать вывод, что проц hi3516AV300 ???
на теле процесса непонятные цифры (на первых фото этого форума )...
Какая из прошивок openipc (для какого проца) ???
Сообщение oleglevsha » 05 мар 2022, 08:58
https://github.com/OpenIPC/firmware
hi3516Аv300 вероятней всего
128203
Сообщение 128203 » 05 мар 2022, 10:15
на теле процессора читается надпись : HK-2015-1 CP8PD1737 1737
вроде в 2015 еще не вышли V300
Hi3516a, в конце наименования чипа указывают номера:
для V100: 1511, 1522,
для V200: 1750,
для V300: 1907...
можно сделать вывод, что скорее Hi3516AV200 :oops:
и чип должен называться Hi3516ACP8PDV200 1737 :oops: ?
128203
Сообщение 128203 » 05 мар 2022, 11:06
исправлюсь, Hi3516A**СV200CP8PD1737 1737
128203
Сообщение 128203 » 08 мар 2022, 16:12
Доброго времени суток! Случилась неприятность. При очередной прошивке потер загрузчик. :dash:
Любезно прошу поделиться дампом... :oops:
Программатор с прищепкой имеется...
Сообщение oleglevsha » 08 мар 2022, 21:39
128203 писал(а):
08 мар 2022, 16:12
какой прищепкой, там нанд память...
128203
Сообщение 128203 » 09 мар 2022, 04:06
это не оно?
Сообщение 128203 » 09 мар 2022, 04:07
08 мар 2022, 21:39
подскажите, куда копать...
128203
Сообщение 128203 » 09 мар 2022, 06:06
Так вот она какая NAND :cry:
Подскажите, куда копать ?
