Здравствуйте. нужна прошивка на аппарат Novus DVR NDR-BA4104, безпрерывный ребут, все напряжение в норме. , может есть какой не будь клон. лог путту прилагаю
U-Boot 2008.10 (Apr 1 2012 - 03:19:33)
current ddr size 128m === c0000000,8000000
DRAM: 128 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
cuurent type u-boot-3515-22012816 version 201203311625
current is nvp1104a, will close audio loop
not find tw8832 0xff
buf_product_type[0] = 49
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
Press CTRL-C to abort autoboot in hilinux # <INTERRUPT>
hilinux # printenv
bootdelay=1
baudrate=115200
ethaddr=00:00:00:00:00:00
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
bootfile="uImage"
bootcmd=bootm 0x80100000
bootargs=busclk=220000000 mem=48M console=ttyAMA0,115200 root=1f01 rootfstype=jf fs2 mtdparts=physmap-flash.0:3M(boot),13M(rootfs) pcimod=host pciclksel=1
auversion0=4f7801d7
auversion1=4f61ae88
auversion2=4f953aad
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2008.10 (Apr 1 2012 - 03:19:33)
Environment size: 468/131068 bytes
hilinux # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
jpgd - decode jpeg picture.
erase - erase FLASH memory
flinfo - print FLASH memory information
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
help - print online help
ls - list files in a directory (default /)
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
protect - enable or disable FLASH write protection
setvobg - set vo backgroud color.
- setvobg [dev color]startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - open interface of vo device.
- startvo [dev type sync]stopgx - close graphics layer.
- stopgx [layer]stopvo - close interface of vo device.
- stopvo [dev]tftp - download or upload image via network using TFT P protocol
usb - USB sub-system
ydump - YAFFS device struct
yls - yaffs ls
ymkdir - YAFFS mkdir
ymount - mount yaffs
ymv - YAFFS mv
yrd - read file from yaffs
yrdm - read file to memory from yaffs
yrm - YAFFS rm
yrmdir - YAFFS rmdir
yumount - unmount yaffs
ywr - write file to yaffs
ywrm - write file from memory to yaffs
hilinux # NAND: No NAND device found!!!
0 MiB
Novus DVR NDR-BA4104 нужна прошивка
- Вложения
- BA4104-PuTTY.rar
- (1.62 КБ) 190 скачиваний
Re: Novus DVR NDR-BA4104 нужна прошивка
А клона нужно определить по фотографиям платы, которые вы не сделали?
Хотя бы уже до конца страницы досмотрели viewtopic.php?f=24&t=10467" onclick="window.open(this.href);return false;
фото я то зделал на пока не смог прикрепить (размер велик) а по поводу ссылочки эт не он у меня без -II
- Вложения
- P1010237-2.JPG (43.27 КБ) 2804 просмотра
