Код: Выделить всё
U-Boot 2010.06-svn198 (Dec 08 2014 - 09:53:48)
Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"слил полную прошивку командами
пока, не уверен, что правильно мыслю...
Код: Выделить всё
hisilicon # sf probe 0
hisilicon # sf read 0x82000000 0x0000000 0x800000
hisilicon # tftp 0x82000000 fw1.img 0x800000
Hisilicon ETH net controler
miiphy_register: non unique device name '0:3'
miiphy_register: non unique device name '0:2'
MAC: 00-0B-3F-00-00-01
TFTP to server 192.168.1.120; our IP address is 192.168.1.10
Upload Filename 'fw1.img'.
Upload from address: 0x82000000, 8.000 MB to be send ...
Uploading: # [ Connected ]
################################ [ 2.888 MB]
################################ [ 5.752 MB]
8.000 MB upload ok.
hisilicon # команду erase U-boot не знает
Код: Выделить всё
hisilicon # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
decjpg - jpgd - decode jpeg picture.
fload - fload - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
lload - lload - load logo file
logoload- logoload - load binary file from a filesystem image for system boot
md - memory display
mii - MII utility commands
mw - memory write (fill)
setvobg - setvobg - set vo backgroud color.
- setvobg [dev color]
sf - SPI flash sub-system
squashfsload- fsload - load binary file from a filesystem image
startgx - startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - startvo - open interface of vo device.
- startvo [dev type sync]
stopgx - stopgx - close graphics layer.
- stopgx [layer]
stopvo - stopvo - close interface of vo device.
- stopvo [dev]
usb - USB sub-system
hisilicon #
hisilicon #help erase
Unknown command 'erase' - try 'help' without arguments for list of all known commands
