восстановление MBD6816T-B
sl.314
Re: восстановление MBD6816T-B
Сообщение sl.314 » 06 май 2017, 20:41
dede писал(а):Я уже спрашивал, телнет есть?
да старая прошивка с телнетом ставится .
кстати вот этот вывод из телнета нормален:
Код: Выделить всё
j[color=#FF0040]ffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0xe87e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x27f4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x9fa5 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x0885 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x01c1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x601e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x3008 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x8104 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000028: 0x0d50 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000002c: 0x8840 instead
Further such events for this erase block will not be printed
Old JFFS2 bitmask found at 0x00001670
You cannot use older JFFS2 filesystems with newer kernels
Old JFFS2 bitmask found at 0x00004190
Old JFFS2 bitmask found at 0x0000647c
Old JFFS2 bitmask found at 0x0000b008
Old JFFS2 bitmask found at 0x0000bfd8
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010000: 0x4d03 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010004: 0x4542 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010008: 0x0434 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001000c: 0x0f53 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010010: 0xbb51 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010014: 0xe006 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010018: 0x7db1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001001c: 0xd4f6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010020: 0x5a1b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010024: 0x6aea instead
Old JFFS2 bitmask found at 0x00018964
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0x45d6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0xf147 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020008: 0xc88e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002000c: 0x0104 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020010: 0x0283 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020014: 0x289b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020018: 0x0008 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002001c: 0x8000 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020020: 0x81a0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020028: 0xa000 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030000: 0x0080 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030008: 0x5a98 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0003000c: 0x2101 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030010: 0xd088 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030014: 0x003e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030018: 0x45aa instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0003001c: 0x4986 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030020: 0x2000 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030024: 0x080b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00030028: 0x0124 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040000: 0x0983 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040004: 0x3031 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040008: 0x2531 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004000c: 0x5985 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040010: 0x0020 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040014: 0x4403 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040018: 0x21d7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004001c: 0x2084 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040020: 0x8014 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040024: 0x8bf1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050000: 0xc100 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050004: 0x0034 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050008: 0x0a10 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0005000c: 0x20a0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050010: 0x6401 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050014: 0xe188 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050018: 0x1428 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0005001c: 0x0b0e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050020: 0x4880 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00050024: 0x2020 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060000: 0x1804 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060004: 0x000c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060008: 0x0010 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006000c: 0xca3f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060010: 0xae22 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060014: 0xde2b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060018: 0x764b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006001c: 0x74b7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060020: 0x31bf instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060024: 0x1c2d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070000: 0xc716 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070004: 0xa008 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070008: 0x783c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0007000c: 0xa008 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070010: 0x2003 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070014: 0x0100 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070018: 0xa46d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0007001c: 0x050c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070020: 0x904a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00070024: 0xc000 instead
Old JFFS2 bitmask found at 0x0007654c
You cannot use older JFFS2 filesystems with newer kernels[/color]
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
empty_blocks 0, bad_blocks 0, c->nr_blocks 8
Сообщение dede » 06 май 2017, 20:47
пишите fla и жмите таб
OMYx
Сообщение OMYx » 11 июл 2017, 07:18
Доброго времени суток.
Прошу прощения за свою неосведомлённость, но что делать после того как выскакивает "в процессе обслуживания, соединить с инженеров пожалуйста! SN: ******"?
Я не знаю, что такое uBoot и прочие вещи. Телефоны разные шил раз 200, так что опыт в прошивке чего-то есть, а вот DVR всю жизнь стоял коробочкой и работал. А тут решил вдруг перестать. Руки у меня прямые, но гугл не даёт информации об этой проблеме. Может ли кто-нибудь развёрнуто объяснить порядок действий для разморозки из этого состояния.
Прошивался месяца 1-2 назад на прошивку SimpGeneral_General_MBD6816T-B_V4.02.R11.Nat.OnvifC.20161104_NT.bin, видимо из-за нее это и вылетает теперь, т.к. до этого 2 года работал DVR и ничего. А тут вот инженеров подавай.
OMYx
Сообщение OMYx » 19 июл 2017, 14:53
Добавлю, китаец прислал пароль, но после его ввода система спрашивает войти ли как админ. Отвечаешь да перезагрузка и снова не пускает, отвечаешь нет остаёшься у окна ввода пароля.
fireman
Сообщение fireman » 24 июл 2017, 19:51
OMYx писал(а):Доброго времени суток.
удалите всё из mnt/mtd, либо шейте нормальный образ.
NeiroN
Сообщение NeiroN » 24 июл 2017, 20:22
в том то и дело что /mnt/mtd нет в образах - он создается в процессе работы.
fireman
Сообщение fireman » 25 июл 2017, 08:15
NeiroN писал(а):в том то и дело что /mnt/mtd нет в образах - он создается в процессе работы.
Вы шутите? полагаю, что у Вас не полный образ и не полная прошивка, поэтому вы утверждаете то, что лишь смогли найти, а это неверно.
Сообщение dede » 25 июл 2017, 09:26
Нет, не шутит. Конечно же нету и быть не может mtd-x в прошивках, ибо он создается простым форматированием области в jffs2. Можно создать специальный образ для прошивки через tftp или флешку, а проще всего через uboot очистить область и всё.
OMYx
Сообщение OMYx » 25 июл 2017, 19:05
Как сделать то, о чем вы пишите? DVR крайне необходим на нашей базе, без него никакого контроля за персоналом.
Сообщение oleglevsha » 25 июл 2017, 19:18
OMYx писал(а):Как сделать то, о чем вы пишите? DVR крайне необходим на нашей базе, без него никакого контроля за персоналом.
лучший способ отдать регистратор в сервис...
OMYx
Сообщение OMYx » 26 июл 2017, 14:19
oleglevsha писал(а):лучший способ отдать регистратор в сервис...
У нас в городе цена сопоставима с новым с алика.
fireman
Сообщение fireman » 26 июл 2017, 16:07
нужен доступ к регу телнет или терминал, чтобы восстановить его, мысленно никак...
