Videopark VP-C 8ch. Pro DVR нужна прошивка
fobos
Сообщение fobos » 15 май 2017, 23:19
Здравствуйте! Плата zndvr_m_6008_v1.2_20120312. Регистратор не стартовал, поиск прошивки ничего не дал, залил дамп от Spymax RA-2504L появился UART...через каждые 4 минуты перегружается по ватчдогу. логи u-boot, help, printenv прилагаются.
IVSS# help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
do_encrypt - write data into FLASH memory
erase - erase FLASH memory
flinfo - print FLASH memory information
flwrite - write data into FLASH memory
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
help - print online help
hwid - set hardware id and save to flash
lip - set local ip address but not save to flash
ls - list files in a directory (default /)
mac - set mac address and save to flash
md - memory display
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
protect - enable or disable FLASH write protection
sip - set server ip address but not save to flash
tftp - download or upload image via network using TFTP protocol
IVSS#
IVSS# printenv
bootcmd=fsload; bootm 0xc1000000
bootdelay=3
baudrate=115200
xload=1
jpeg_addr=0xc0000000
jpeg_size=0x80000
vobuf=0xcff00000
da=tftp 0xc1000000 u-boot.bin.img;protect off all; flwrite
dr=tftp 0xc1000000 romfs-x.cramfs.img; flwrite
dc=tftp 0xc1000000 custom-x.cramfs.img; flwrite
du=tftp 0xc1000000 user-x.cramfs.img; flwrite
dw=tftp 0xc1000000 web-x.cramfs.img; flwrite
dl=tftp 0xc1000000 logo-x.cramfs.img; flwrite
up=tftp 0xc1000000 update.img; flwrite
tk=tftp 0xc1000000 uImage; bootm 0xc1000000
gatewayip=10.12.1.1
netmask=255.255.0.0
bootfile=boot/uImage
ID=600412200525
HWID=00000000000000
serverip=192.168.0.68
ipaddr=192.168.0.65
restore=0
bootargs=mem=48M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:256K
(boot),2176K(rootfs),3584K(user),1280K(web),128K(custom),64K(logo),64K(tool),640K(config) busclk=220000000
ethaddr=e0:61:b2:11:b9:85
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2008.10-svn (Mar 19 2012 - 17:14:13)
Environment size: 993/65532 bytes
IVSS#
Если у кого то есть прошивка или ссылка на нее, сбросьте, пожалуйста.
Re: Videopark VP-C 8ch. Pro DVR нужна прошивка
Сообщение dede » 16 май 2017, 07:54
Заливайте текущую куда-нибудь, покопаем
P.S. и битую тоже
fobos
Сообщение fobos » 16 май 2017, 15:50
битая https://cloud.mail.ru/public/B9zu/pjXr97am7" onclick="window.open(this.href);return false;
текущая https://cloud.mail.ru/public/BoPv/9EptyVDW3" onclick="window.open(this.href);return false;
Сообщение dede » 16 май 2017, 17:33
Вы как хотите лить? С бутом все заново или по сети и пока без бута?
fobos
Сообщение fobos » 16 май 2017, 20:15
Конечно перепаивать NOR то еще удовольствие, но если имеющийся бут от Spymax-а не подходит, то могу залить все заново.
fobos
Сообщение fobos » 16 май 2017, 20:16
...по сети менее хлопотно :)
Сообщение dede » 16 май 2017, 20:53
если просто дам дамп с вырезанным бутом, пойдет? или могу попробовать update.img сделать
fobos
Сообщение fobos » 16 май 2017, 21:00
давайте попробуем update.img...всегда могу откатиться.
Сообщение dede » 16 май 2017, 21:20
https://ufile.io/n25ej" onclick="window.open(this.href);return false;
Заливать так:
tftp 0xc1000000 6008-new_noboot.bin.img; flwrite
Мог ошибиться в образе и в руссификации, но бут затереть не должно в любом случае, а остальное поправимо
fobos
Сообщение fobos » 16 май 2017, 22:42
залил...поведение рега не изменилось...перезагрузка с сохранением данных...в журнале "Reboot with flag [0x00]"
Сообщение dede » 16 май 2017, 22:50
это я так удачно все собрал, что кроме ребутов ничего и не изменилось? или может апдейт не залился просто?
fobos
Сообщение fobos » 16 май 2017, 22:55
...может быть существенным пояснение: изначально после прошивки дампа от Spymax появился не только UART, но и рег полноценно загрузился с восьмиканальной раскладкой (хотя дамп был от 4-х канального рега) и была перезагрузка через каждые 4 минуты, сейчас после прошивки Вашим *.img поведение рега осталось прежним.
