Есть некоторый прогресс.
Скачал отсюда
http://sigrand.ru/dl/camera/ti/firmware/0.2/" onclick="window.open(this.href);return false;
sigticam-dm368-0.2.8951.tar и подгрузил kernel в оперативку
лог изменился:
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.
U-Boot 1.3.4 (Aug 9 2013 - 00:26:09)
I2C: ready
DRAM: 128 MB
NETVIEW-1 NAND: NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit)
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
128 MiB
In: serial
Out: serial
Err: serial
Ethernet PHY: INST36X @ 0x00
Loading from NAND 128MiB 3,3V 8-bit, offset 0x700000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
NETVIEW IPNC:>tftp 0x80700000 uImage
TFTP from server 192.168.1.200; our IP address is 192.168.1.12
Filename 'uImage'.
Load address: 0x80700000
Loading: #################################################################
done
Bytes transferred = 1277952 (138000 hex)
NETVIEW IPNC:>bootm
## Booting kernel from Legacy Image at 80700000 ...
Image Name: Linux-2.6.18
Data Size: 1276736 Bytes = 1.2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux................................................................................ done, booting the kernel.
Linux version 2.6.18 (df@dfwork) (gcc version 4.3.6 (GCC) ) #1 PREEMPT
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: DaVinci DM368 IPNC
DaVinci DM0365 variant 0x8
PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000
PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 97142857
PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists. Total pages: 12288
Kernel command line: console=ttyS0,115200n8 noinitrd rw ip=192.168.1.134:192.168.1.1::::: root=/dev/mtdblock3 rw rootfstype=cramfs mem=48M eth=00:00:1b:00:00:11
PID hash table entries: 256 (order: 8, 1024 bytes)
Clock event device timer0_0 configured with caps set: 07
Memory: 48MB = 48MB total
Memory: 41856KB available (1900K code, 391K data, 240K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
DaVinci: 104 gpio irqs
Generic PHY: Registered new driver
usbcore: registered new driver usbfs
usbcore: registered new driver hub
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A
serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <
maxk@qualcomm.com>
i2c /dev entries driver
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
Creating 8 MTD partitions on "nand_davinci.0":
0x00000000-0x00100000 : "UBL"
0x00100000-0x00240000 : "U-Boot"
0x00240000-0x00300000 : "U-Boot Environment"
0x00300000-0x00500000 : "diagnostic"
0x00500000-0x00b00000 : "Kernel"
0x00b00000-0x02b00000 : "Root FS"
0x02f00000-0x07f00000 : "Conf FS"
0x07f00000-0x08000000 : "Bad Block Tables"
nand_davinci nand_davinci.0: hardware revision: 2.3
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: proc
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0
rtc wait time out !!!!!
TCP bic registered
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <
jketreno@linux.intel.com>
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-09-14 01:01:01 (968893261)
Freeing init memory: 240K
--------------------------- Initramfs script start ---------------------------
* Mounting /proc ... done
* Mounting /sys ... done
* Mounting /conf on /dev/mtdblock6 R/O ... jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x7e3a instead
donjffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x09e4 instead
e
*jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x8ce6 instead
Checking fjffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0xc6f8 instead
or updates jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x9d7e instead
... ffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x1a33 instead
mno
ffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x0050 instead
m* Mountingjffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x6a42 instead
/root on /dev/mjffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0xdd67 instead
tdblock5 ..jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x38fb instead
. Further such events for this erase block will not be printed
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0xc209 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0x1a74 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0020: 0xb8e7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0024: 0x5493 instead
Old JFFS2 bitmask found at 0x001e82cc
You cannot use older JFFS2 filesystems with newer kernels
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200000: 0x4b3e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200004: 0x37f5 instead
