DS-2CD2443G0-I как обновить с cd карты?
Камера по сети не видится. В терминале пишет
Boot 3.1.6-453221 (Nov 2 2018-15:53:17)
boards:445940
Boot From: NAND 2048 RC BCH 6bit
SYS_CONFIG: 0x2007005B POC: 101
Cortex freq: 816000000
ENET freq: 50000000
iDSP freq: 348000000
Dram freq: 840000000
Core freq: 360000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
dev_model:DS-2CD2443G0-I
[boot] In release mode!
Hit Ctrl+u to stop autoboot: 0
|BIND err|
cmd 'null' is not supported.
flash booting ...
booting from pri part...
load kernel...
[ 1.546265] Card authentication succeeded
init started: BusyBox v1.19.3 (2017-09-23 13:28:19 CST)
starting pid 59, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
create static device nodes under /dev dir
>>>run pre_app_hook
UBI device number 1, total 270 LEBs (34283520 bytes, 32.7 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
find net_node, loop : 1
Not find initrun.sh!
starting pid 352, tty '': '-/bin/psh'
BusyBox v1.2.1-303841 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
При попытке обновления не видит тфтп сервер
HKVS # help setenv
Help for 'setenv':
ipaddr - network ip address
serverip - tftp server ip address
netmask - network ip mask
gatewayip - gateway ip address
ethaddr - ethernet mac address
bootdelay - boot delay time
dbg - debug level
HKVS # ipaddr 192.0.0.64
cmd 'ipaddr' is not supported.
HKVS # help ipaddr 192.0.0.128
HKVS # help serverip 1
cmd 'help' is not supported.
HKVS # help 192.0.0.64
HKVS # help serverip 192.0.0.128
HKVS # help saveenv
Help for 'saveenv':
save environments to flash
HKVS # help update
Help for 'update':
update digicap.dav
HKVS # u
'u' is a ambiguous command! Exec the shortest command
***** UPDATE START *****
do_tftp_load:bld_udp_bind failed!
error: tftp.
error: upm.
error: upf.
***** UPDATE FAIL *****
HKVS # help tftp
HKVS # u
error: tftp.
error: upm.
error: upf.
HKVS #
HKVS # Boot 3.1.6-453221 (Nov 2 2018-15:53:17)
cmd 'Boot' is not supported.
HKVS # boards:445940
cmd 'boards:445940' is not supported.
HKVS # Boot From: NAND 2048 RC BCH 6bit
HKVS # SYS_CONFIG: 0x2007005B POC: 101
cmd 'SYS_CONFIG:' is not supported.
HKVS # Cortex freq: 816000000
cmd 'Cortex' is not supported.
HKVS # ENET freq: 50000000
cmd 'ENET' is not supported.
HKVS # 000
cmd '000' is not supported.
HKVS # Core freq: 360000000
cmd 'Core' is not supported.
HKVS # AHB freq: 180000000
cmd 'AHB' is not supported.
HKVS # APB freq: 90000000
cmd 'APB' is not supported.
HKVS # UART freq: 24000000
cmd 'UART' is not supported.
HKVS # SD freq: 50000000
cmd 'SD' is not supported.
HKVS # SDXC freq: 50000000
cmd 'SDXC' is not supported.
HKVS #
HKVS # [boot] In release mode!
cmd '[boot]' is not supported.
HKVS # Hit Ctrl+u to stop autoboot: 1
cmd 'Hit' is not supported.
HKVS # HKVS # help
cmd 'HKVS' is not supported.
HKVS # The following commands are supported:
cmd 'The' is not supported.
HKVS # trspt boot erase help
Usage:trspt set|get disable|enable
HKVS # reset saveenv printenv setenv
Есть ли возможность залить прошивку с сд карты и как это сделать?
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
|BIND err|
flash booting ...
load kernel...
>>>run pre_app_hook
HKVS # help setenv
Help for 'setenv':
dbg - debug level
HKVS # help saveenv
Help for 'saveenv':
HKVS # help update
Help for 'update':
update digicap.dav
HKVS # u
error: tftp.
error: upm.
error: upf.
HKVS # help tftp
HKVS # u
error: tftp.
error: upm.
error: upf.
HKVS #
HKVS # 000
HKVS #
HKVS # HKVS # help
Re: DS-2CD2443G0-I как обновить с cd карты?
Поменял tftp сервер теперь выдает
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
Starting udev: ^_^_[ OK ]
modprobe: chdir(): No such file or directory
iptables v1.4.18: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
>>>run pre_app_hook
^_find net_node, loop : 1
Formatting ...................................................................................................................................................................................................... done!
[ INFO][MIN]TFTP: TFTP from server 192.168.1.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
tftp: falling back to blocksize 512
##############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################tftp: timeout
[ INFO][MIN]TFTP: Download File [FAIL] error: tftp.
!!!!! UPDATE FAIL !!!!!
BusyBox v1.2.1 Protect Shell (psh)
# reset
Sent SIGKILL to all processes
Requesting system reboot
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
>>>run pre_app_hook
что такое falling back to blocksize 512 понять не могу. или нанд флешь сдохла или хз что
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
>>>run pre_app_hook
# reset
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
>>>run pre_app_hook
- VirtualLink
Полный лог загрузки камеры как есть, без прерывания!
Boot 3.1.6-453221 (Nov 2 2018-15:53:17)VirtualLink писал(а):Полный лог загрузки камеры как есть, без прерывания!
boards:445940
ENET freq: 50000000
AHB freq: 180000000
APB freq: 90000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
|BIND err|
flash booting ...
load kernel...
[ 1.546497] Card authentication succeeded
>>>run pre_app_hook
# help
Support Commands:
taskShow printPart prtHardInfo
getPreviewStatus setIp setV6ip
setGateway dspStatus outputClose
outputOpen getDebug setDebug
debugLog getIrstate getMtu
camCmd getCamVer getLux
getMcuInfo getMotion getRawdata
setIrcmd setRectFrame updateCamera
setLaserMode getLaserMode setIrMode
getIrMode setBaiguangMode getBaiguangMode
setYTLock InquireFanSwitch StartLaser
CloseLaser LaserMotReset EnlargeCur
ReduceCur SetCur LaserMotDirect
LaserTeleOffset LaserWideOffset InqSwitch
InqCurrent InqCurMotDirect getMcuStateInfo
setFastFocus getTrackStatus getSelfcheckResult
setLdcMode getLdcMode appCmd
ezoomlens_start_t2_test prtLensCurve getLensCurve
getIp gdbcfg {Test1}
{Test2} {Test3} {Test4}
{TestN} {TestY} getisp
setisp regread regwrite
setAgingMode getAgingMode setAgingTime
getAgingTime setLensZoomPos getLensZoomPos
showKey showServer showUpnp
showStatus showDefence setLBS
setAlarm cloudService t1
ifconfig netstat ping
ping6 top iostat
mpstat ps reset
dmesg wl iwpriv
iperf setWifiEnable getWifiInfo
exit getDateInfo diagnose
help zhimakaimen
На этом останавливается
- VirtualLink
Теперь понятно!yuri1958 писал(а): ...
- VirtualLink
Гарантийный срок закончился.VirtualLink писал(а):Гарантия?
- VirtualLink
А сколько он был?yuri1958 писал(а):Гарантийный срок закончился.VirtualLink писал(а):Гарантия?
Клиент сказал в магазине давали 1 год. Загнулась дней пять назад. По гарантииVirtualLink писал(а):А сколько он был?yuri1958 писал(а):Гарантийный срок закончился.VirtualLink писал(а):Гарантия?
менять не стали. С прошлого года лежит еще одна, только двух мегапиксельная , та вообще не дышит клиент оставил на запчасти. Вообще возможность восстановления есть или нет. Я логах не силен разобраться сам не могу.
Если камера европейка, то гарантия 3 года. а продавцов таких которые занижают заводскую гарантию, жечь напалмом.
- VirtualLink
Что за магазин?yuri1958 писал(а): Клиент сказал в магазине давали 1 год. Загнулась дней пять назад. По гарантии
Конечно возможность есть, надо искать мастера и договариваться о стоимости!
Магазин в Самарканде. От них привозили пару хиковских двр с заставкой 999999 с хиковской прошивкой и наклейкой снизу 999999, залил туда дамп от ds-7104hghi-e1 все заработало. На этой камере вообще нет наклейки, что она DS-2CD2443G0-I узнал из лога. Клиент по русски говорит плохо поэтому толком ничего не понял.
