Re: Необходима помощь Dahua IPC HFW1200SP-0360B
Добрый день.
Перепрошивкой через веб-интерфейс опять удачно положил камеру Dahua IPC HFW1200SP-0360B. Прошивку-на 16MB памяти, перерыл инет, не нашел.
Через UART подключился на команды реагирует. serverip и localip прописал, с камеры пытаюсь пингануть сервер -нифига, как поднять Ethernet интерфейс, . Спасибо
Checking DDR......OK
UBL Version: 1.43t(DM368 30/5/2012)
Oscillator: 24MHZ
ARM Rate: 270 MHZ
DDR Rate: 216 MHZ
BootMode: SPI
Starting SPI Memory Copy...
DONE
U-Boot 1.3.6 (jerry) (May 30 2012 - 11:05:27)
DRAM: 128 MB
SF: Got idcode 01 20 18
SF: Detected S25FL128P with page size 256, total 16 MB
In: serial
Out: serial
Err: serial
Ethernet PHY: GENERIC @ 0x05,id:221513
total gio 2
gio[22]=1
gio[25]=1
Fail: can't get cramfs super block.
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0x80100000
Loading: *
Retry count exceeded.
Failed to get info.txt
==>use default images
Wrong Image Format for bootm command
ERROR: can't get kernel image!
DHBOOT# printenv
bootargs=console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=cramfs ,nolock mem=80M video=davincifb:vid0=OFF:vid1=OFF:osd0=OFF:osd1=OFF
bootcmd=fsload;bootm 80800000
bootdelay=3
baudrate=115200
bootfile="uImage"
dh_keyboard=1
appauto=1
single=0
da=protect off all;tftp 81a00000 dm365_ubl_boot_16M.bin.img;flwrite
dc=tftp 81a00000 custom-x.cramfs.img; flwrite
dr=tftp 81a00000 romfs-x.cramfs.img; flwrite
du=tftp 81a00000 user-x.cramfs.img; flwrite
dd=tftp 81a00000 data-x.cramfs.img; flwrite
dw=tftp 81a00000 web-x.cramfs.img; flwrite
up=tftp 81a00000 update.img; flwrite
tk=tftp 80800000 uImage; bootm 80800000
gionum=22.25
gioval=1.1
dh_com=0
autosip=192.168.254.254
autolip=192.168.1.108
autogw=192.168.1.1
autonm=255.255.255.0
armrate=270
HWID=080000000530002d
ID=TZC3AV04100115
filesize=7040
fileaddr=81A00000
gatewayip=192.168.1.1
servserip=192.168.1.157
netmask=255.255.255.0
ipaddr=192.168.1.108
ethaddr=90:02:a9:09:6d:bd
serverip=192.168.1.157
stdin=serial
stdout=serial
stderr=serial
ver=U-Boot 1.3.6 (jerry) (May 30 2012 - 11:05:27)
Environment size: 1046/16380 bytes
DHBOOT# ping $serverip
Usage:
DHBOOT# ping 192.168.1.157
ping failed; host 192.168.1.157 is not alive
Oscillator: 24MHZ
ARM Rate: 270 MHZ
DDR Rate: 216 MHZ
BootMode: SPI
DONE
DRAM: 128 MB
In: serial
Out: serial
Err: serial
total gio 2
gio[22]=1
gio[25]=1
Loading: *
DHBOOT# printenv
bootdelay=3
baudrate=115200
bootfile="uImage"
dh_keyboard=1
appauto=1
single=0
gionum=22.25
gioval=1.1
dh_com=0
autogw=192.168.1.1
armrate=270
ID=TZC3AV04100115
filesize=7040
fileaddr=81A00000
stdin=serial
stdout=serial
stderr=serial
Usage:
- VirtualLink
Re: Re: Необходима помощь Dahua IPC HFW1200SP-0360B
Чем положил?!
Решил сделать апдейт через web морду, похоже залил не то
- VirtualLink
Вопрос был конкретный, а не то залить не просто!HardMan писал(а):Решил сделать апдейт через web морду, похоже залил не то
Скачал из интернета DH_IPC-HX3(2)XXX_Eng_P_V2.420.0000.1.R.20161208.bin через web - интерфейс сделал upgrade, получил -кирпич. Разобрал подключил UART - все читается и управляется, TFTP сервер запустил, файлы распаковал положил в папку к серверу, IP- в камеру, маска, IP -сервера руками прописал, даю ping $serverip - не ответа, другие команды давай не давай нет, такое впечатление как будто Ethernet -лежит. Хотя на свиче все светодиоды горят и Tx и Rx c физикой вроде все в порядке. Че та заблудился в паре сосен
Да по идее камера должна пинговаться с компа ?
- VirtualLink
https://support.vidimost.com/comment.php?dlid=527" onclick="window.open(this.href);return false;
и более ранние!
Лог загрузки!?
и более ранние!
Лог загрузки!?
Oscillator: 24MHZ
ARM Rate: 270 MHZ
DDR Rate: 216 MHZ
BootMode: SPI
DONE
DRAM: 128 MB
In: serial
Out: serial
Err: serial
total gio 2
gio[22]=1
gio[25]=1
Loading: WARN: emac_send_packet: No link
DHBOOT# run dr
TFTP from server 192.168.1.157; our IP address is 192.168.1.108
Filename 'romfs-x.cramfs.img'.
Load address: 0x81a00000
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Oscillator: 24MHZ
ARM Rate: 270 MHZ
DDR Rate: 216 MHZ
BootMode: SPI
DONE
DRAM: 128 MB
In: serial
Out: serial
Err: serial
total gio 2
gio[22]=1
gio[25]=1
DHBOOT# run dr
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
Loading: *
а флешь на плате камеры точно 16Мб? Очень похоже, что бут залит не от этой камеры, смущает размер флеши указанной в буте и HWID не соответствует
- VirtualLink
Главное понять, чем прошивал!
с большой долей вероятности прошивал этим DH_IPC-HX3(2)XXX_Eng_P_V2.211.0001.0.T.20170807
DH_IPC-HX3(2)XXX_Eng_P_V2.420.0000.1.R.20161208.bin вот этим я прошивал
