Подключили к UART вот вывод, если остановить загрузку
Код: Выделить всё
hi3516c # printenv
bootcmd=sf probe 0;sf read 0x82000000 0x30000 0x300000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=D0:22:12:88:88:88
ipaddr=192.168.1.120
serverip=192.168.1.35
gatewayip=192.168.1.1
netmask=255.255.255.0
uuid=e052030e-9fe6-4982-beb9-8ae3abea04d5
bootargs=mem=72M console=ttyAMA0,115200 root=/dev/mtdblock3 rootfstype=squashfs rw init=/init mtdparts=hi_sfc:128k(u-boot)ro,64k(env),3m(kernel),4608k(rootfs),512k(config),-(app)
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-dirty (May 09 2014 - 15:00:56)
Environment size: 534/65532 bytes
hi3516c # run du
## Error: "du" not defined
hi3516c #Код: Выделить всё
resetting ...
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
In: serial
Out: serial
Err: serial
Image Name: Linux-3.0.8
Data Size: 2779180 Bytes = 2.7 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Linux version 3.0.8 (qin@ubuntu) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Fri Nov 21 20:31:57 CST 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: hi3518
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AXI bus clock 220000000.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 18288
[ 0.000000] Kernel command line: mem=72M console=ttyAMA0,115200 root=/dev/mtdblock3 rootfstype=squashfs rw init=/init mtdparts=hi_sfc:128k(u-boot)ro,64k(env),3m(kernel),4608k(rootfs),512k(config),-(app)
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 72MB = 72MB total
[ 0.000000] Memory: 67784k/67784k available, 5944k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc5000000 - 0xfe000000 ( 912 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc4800000 ( 72 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0028000 ( 128 kB)
[ 0.000000] .text : 0xc0028000 - 0xc04de000 (4824 kB)
[ 0.000000] .data : 0xc04de000 - 0xc04ff9a0 ( 135 kB)
[ 0.000000] .bss : 0xc04ff9c4 - 0xc051b3e0 ( 111 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:32 nr_irqs:32 32
.......................Тут много текста...........................................
[ssp_read:78]:Open /dev/ssp error:[ssp_read:78]:Open /dev/ssp error:[ssp_read:78]:Open /dev/ssp error:[ssp_read:78]:Open /dev/ssp error:[main:177]:we can't detect the sensor type, please check hardware config
## Error: "sensortype" not defined
rm: can't remove '/home/bvtech/lib/libsensor.so': No such file or directory
gpio write:3 status:0
gpio write:3 status:1
## Error: "serialno" not defined
[main:96]:reset serv start
System startup success.
[CheckUsbExtDev:522]:ipcam detect dev mask is 0
Auto login as root ...
[ipcam_sanity_check:92]:we detected system reboot abnormal last time
[check_ipcam_init_func:599]:ipcam init log success!
[check_ipcam_init_func:599]:ipcam init usermng success!
Jan 1 00:00:26 login[816]: root login on 'ttyS000'
Welcome to HiLinux.
# ip: RTNETLINK answers: Operation not supported
[main:62]:exec [ip addr del dev eth0] resq[-1]
[check_ipcam_init_func:599]:ipcam init network success!
[check_ipcam_init_func:599]:ipcam init osd success!
[CheckCaptureCfg:148]:get caputer capablity error
[StartAvServer:94]:get video capture para err, use default
[CalcMemMngTotalSize:283]:memmng need total memery size:11315712
[HisiSysVPssGrpInit:58]:HI_MPI_VPSS_CreateGrp failed with 0xa0088003!
[AvServSysInit:191]:can't init hisi vpss [0x0]
[InitAvServVideo:24]:get video codec para err, use default
[InitAvServVideo:29]:get mpeg codec para err, use default
[StartVideoStreams:578]:we must init av server first!
[InitAvServVideo:61]:StartVideoStreams main:0 sub:2 error!
[check_ipcam_init_func:596]:ipcam init av serv failed!
[check_ipcam_init_func:599]:ipcam init protocol port success!
[check_ipcam_init_func:599]:ipcam init ip filter success!
[check_ipcam_init_func:599]:ipcam init system time success!
[check_ipcam_init_func:599]:ipcam init disk serv success!
[check_ipcam_init_func:599]:ipcam init email serv success!
[check_ipcam_init_func:599]:ipcam init ftp client success!
[check_ipcam_init_func:599]:ipcam init web serv success!
[check_ipcam_init_func:599]:ipcam init ddns serv success!
[check_ipcam_init_func:599]:ipcam init upnp serv success!
[check_ipcam_init_func:599]:ipcam init onvif serv success!
[check_ipcam_init_func:599]:ipcam init bvcloud serv success!
[check_ipcam_init_func:599]:ipcam init tcp serv success!
[check_ipcam_init_func:599]:ipcam init schedule serv success!
[check_ipcam_init_func:599]:ipcam init alarm serv success!
[main:143]:ipcam main thread start.
[upnp_serv_device_start:174]:upnp serv success url:http://192.168.1.120:80/
Фото платы, если нужно, скину позже. Как видно из вывода не понимает команды на загрузку прошивки по частям. Подскажите пожалуйста, что можно еще предпринять? Спасибо.
