Есть камера C29s ей только 2 недели. Работала исправно,но в какой то момент смотрю,а диод вместо двух горит только один зеленый,оранжевый не горит. Я ей сброс нажал,реакции нет,ни звука,ни в чем не видна. Ничего не помогает. Смастерил uart и через putty выжал такую инфу:
IPL g40bd5ed
D-15
HW Reset
SPI 54M
64MB
BIST0_0001-OK
MXP found at 0x00020000
offset:00010000
Checksum OK
IPL_CUST g40bd5ed
offset:00030000
XZ decomp_size=0x000434f4
U-Boot 2015.01 (Nov 17 2020 - 10:56:56)
Version: I6g#######
I2C: ready
DRAM:
WARNING: Caches not enabled
MMC: MStar SD/MMC: 0
nor_flash_mxp allocated success!!
Unknown flash type (0x20, 0x40, 0x18) and use default flash type
please add flash info to serial flash driver
SF: Detected nor0 with total size 16 MiB
MXP found at mxp_offset[3]=0x00020000, size=0x1000
env_offset=0x4F000 env_size=0x1000
In: serial
Out: serial
Err: serial
Net:
k24 ks24 v10.0 build:2020-11-17
set common gpio dir
set common gpio output level
mstar sdk v1.0
MAC Address 00:30:1B:BA:02:DB
Auto-Negotiation...
retValue[4]
Link Status Speed:100 Full-duplex:1
sstar_emac
Saving Environment to SPI Flash...
Erasing SPI flash..._spi_flash_erase: addr 0x4f000, len 0x1000 (cost 42 ms)
Writing to SPI flash..._spi_flash_write to 0x4f000, len 0x1000 from 0x23b37950 100%(cost 10 ms)
done
SF: 2097152 bytes @ 0x50000 Read: OK
## Booting kernel from Legacy Image at 22000000 ...
Image Name: MVX4##I6B0g#######KL_LX409##[BR:
Image Type: ARM Linux Kernel Image (lzma compressed)
Data Size: 1534684 Bytes = 1.5 MiB
Load Address: 20008000
Entry Point: 20008000
Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
SigmaStar # printenv
SdUpgradeImage=SigmastarUpgradeSD.bin
baudrate=115200
bootargs=console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashfs ro init=/linuxrc LX_MEM=0x3fe0000 mma_heap=mma_heap_name0,miu=0,sz=0x1600000
bootcmd=sf probe 0;sf read 0x22000000 0x50000 0x200000; bootm 0x22000000
bootdelay=0
ethact=sstar_emac
ethaddr=00:30:1b:ba:02:db
sdautoupgrade=1
stderr=serial
stdin=serial
stdout=serial
Что с этим делать ,куда двигаться ,каким софтом? Оригинальная прошивка ,которая установлена в камере есть скачанная firmware_48.53.185.59_1631950669.bin
Расскажите,желательно подробнее.
