Подключил по UART видна загрузка:
Код: Выделить всё
U-Boot 3.1.6-27151 (Dec 7 2017-10:57:50)
boards:10459
Boot From: NAND 2048 RC
SYS_CONFIG: 0x3006005B POC: 101
Cortex freq: 600000000
iDSP freq: 216000000
Dram freq: 528000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
Hit Ctrl+u to stop autoboot: 0
cmd 'null' is not supported.
nand booting ...
kernel update_flag=aa
app update_flag=aa
booting from pri part...
load kernel...
cmdline: console=ttyS0 KRN_PRT=pri APP_PRT=pri
cpux_jump: 0x00000000
initrd2_start: 0x00000000 initrd2_size: 0x00000000
kernelp: 0x00200000 kernels: 0x07E00000
idspp: 0x08000000 idsps: 0x08000000
Booting Linux on physical CPU 0x0
Linux version 3.10.73+ (chenfuming@Cpl-Civil-Camera) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #3 PREEMPT Mon Jul 11 16:28:30 CST 2016
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
memory scan node memory, reg size 8, data: 2000 e007 2000000 1000000,
- 200000 , 7d00000
Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0
Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0
Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9
Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0
Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0
Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0
Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0
Ambarella: IAVMEM = 0x08000000[ ],0x08000000
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 31750
Kernel command line: console=ttyS0 KRN_PRT=pri APP_PRT=pri
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 125MB = 125MB total
Memory: 118292k/118292k available, 9708k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0x88000000 - 0xff000000 (1904 MB)
lowmem : 0x80000000 - 0x87d00000 ( 125 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x805474a0 (5374 kB)
.init : 0x80548000 - 0x807eddbc (2712 kB)
.data : 0x807ee000 - 0x8082ca98 ( 251 kB)
.bss : 0x8082ca98 - 0x8084cb1c ( 129 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:240
sched_clock: 32 bits at 54MHz, resolution 18ns, wraps every 79536ms
console [ttyS0] enabled
Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
Setting up static identity map for 0x803e4638 - 0x803e4674
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
ambarella-gpio gpio.0: Ambarella GPIO driver registered
bio: create slab <bio-0> at 0
ambarella-dma e0005000.dma: Ambarella DMA Engine
SCSI subsystem initialized
ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
Advanced Linux Sound Architecture Driver Initialized.
register_netdev: name = lo
Switching to clocksource ambarella-cs-timer
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 231
alg: No test for stdrng (krng)
io scheduler noop registered (default)
e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
ambarella-nand e0001000.nand: in ecc-[1]bit mode
ambarella_nand: Use On Flash BBT
NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
18 ofpart partitions found on MTD device amba_nand
Creating 18 MTD partitions on "amba_nand":
0x000000000000-0x000000020000 : "bst"
0x000000020000-0x000000120000 : "bld"
0x000000120000-0x000000200000 : "ptb"
0x000000200000-0x000000280000 : "env"
0x000000280000-0x000000380000 : "dpt"
0x000000380000-0x000000400000 : "param"
0x000000400000-0x000000500000 : "sysflg"
0x000000500000-0x000000f00000 : "rcvy"
0x000000f00000-0x000001700000 : "krn_pri"
0x000001700000-0x000001f00000 : "krn_sec"
0x000001f00000-0x000004100000 : "app_pri"
0x000004100000-0x000006300000 : "app_sec"
0x000006300000-0x000006900000 : "cfg_pri"
0x000006900000-0x000006f00000 : "cfg_sec"
0x000006f00000-0x000007700000 : "dsp"
0x000007700000-0x000007d00000 : "syslog"
0x000007d00000-0x000007e00000 : "adc"
0x000007e00000-0x000007f00000 : "res"
libphy: Ambarella MII Bus: probed
ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
register_netdev: name = eth%d
ambarella-eth e000e000.ethernet: MAC Address[64:db:8b:d8:15:50].
ambarella-ehci e0018000.ehci: EHCI Host Controller
ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.73+ ehci_hcd
usb usb1: SerialNumber: AmbUSB
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ambarella-udc e0006000.udc: ambarella_udc: version 2 August 2011
ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
i2c /dev entries driver
ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
register_netdev: name = sit0
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
ThumbEE CPU extension supported.
ambarella-rtc e8015000.rtc: setting system clock to 2024-11-01 16:13:40 UTC (1730477620)
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 2708K (80548000 - 807ed000)
init started: BusyBox v1.22.1 (2016-04-01 18:38:14 CST)
exec /usr/sbin/mount_ubifs_prt.sh 10 1 /dav
UBI: attaching mtd10 to ubi1
UBI: scanning is finished
UBI: attached mtd10 (name "app_pri", size 34 MiB) to ubi1
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 272, bad PEBs: 0, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 474/232, WL threshold: 4096, image sequence number: 1248276509
UBI: available PEBs: 0, total reserved PEBs: 272, PEBs reserved for bad PEB handling: 10
UBI: background thread "ubi_bgt1d" started, PID 63
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
mount /dev/ubi1_UBIFS: background thread "ubifs_bgt1_0" started, PID 67
0 in /dav
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 1, volume 0, name "app_pri"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs)
UBIFS: reserved for root: 1487352 bytes (1452 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 434569FE-05EC-4801-B0E7-52BA93A0DA23, small LPT model
exec /usr/sbin/mount_ubifs_prt.sh 11 2 /dav_sec
UBI: attaching mtd11 to ubi2
UBI: attached mtd11 (name "app_sec", size 34 MiB) to ubi2
UBI: max/mean erase counter: 97/58, WL threshold: 4096, image sequence number: 1532831103
UBI: background thread "ubi_bgt2d" started, PID 76
UBI device number 2, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi2_0.
mount /dev/ubi2_UBIFS: background thread "ubifs_bgt2_0" started, PID 80
0 in /dav_sec
UBIFS: mounted UBI device 2, volume 0, name "app_sec"
UBIFS: media format: w4/r0 (latest is w4/r0), UUID F289530A-40DE-47F6-A349-47D53AD4ED50, small LPT model
UBI: attaching mtd12 to ubi3
UBI: attached mtd12 (name "cfg_pri", size 6 MiB) to ubi3
UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
UBI: max/mean erase counter: 12585/10625, WL threshold: 4096, image sequence number: 361133478
UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
UBI: background thread "ubi_bgt3d" started, PID 87
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
mount /dev/ubi3_0 inUBIFS: background thread "ubifs_bgt3_0" started, PID 91
/davinci
UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"
UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 143937 bytes (140 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 50417557-5C2B-443D-8068-E97AC4663724, small LPT model
Check dir /davinci ok! (0)
UBI: attaching mtd13 to ubi4
UBI: attached mtd13 (name "cfg_sec", size 6 MiB) to ubi4
UBI: max/mean erase counter: 5216/4059, WL threshold: 4096, image sequence number: 132466126
UBI: background thread "ubi_bgt4d" started, PID 99
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
mount /dev/ubi4_0 inUBIFS: background thread "ubifs_bgt4_0" started, PID 103
/config
ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000005
ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000002
ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
ЗЫ: Может у кого то дамп завалялся?
