longse LS-CVR5216
aavan
longse LS-CVR5216
Сообщение aavan » 27 апр 2016, 15:30
Сегодня ремонтировал longse LS-CVR5216,проблемы с "железом",ремонт удался.Решил слить прошивку для коллекции.И тут вылезла проблема-подключившись к UART ,вместо привычного U-Boot увидел такое:
start to copy FC7500 core boot image...
done, FA6 core now is booting.
ARM eCos 13:48:21
Dec 18 2014
[GM8210] eCos version: 2014_1218_1116, minor version: 1218_1116
<ECOS> Dump Heap 1 Memory information (malloc):
<ECOS> total size of entire pool = 7167512
<ECOS> number of chunks free for use = 1
<ECOS> total allocated space in bytes = 528
<ECOS> total space in bytes not in use = 7166964
<ECOS> size of largest unused block = 7166964
<ECOS> log buffer address: 0x12a400, size: 524288
ECOS: Wait Host core to provide the mbox .Booting Linux on physical CPU 0
Linux version 3.3.0 SVN:5530 (jenkins@localhost.localdomain) (gcc version 4.4.0 20100318 (experimental) (Buildroot 2012.02) ) #1 PREEMPT Mon Sep 7 10:37:05 CST 2015
CPU: FA6 [66056262] revision 2 (ARMv5TE), cr=0000397f
CPU VIPT aliasing data cache, unknown instruction cache
Machine: Grain-Media GM8210
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 164592
Kernel command line: initrd=0x37800000,0x300000 ramdisk_size=10240 root=/dev/ram rw init=/init mem=256M@0x10000000 gmmem=190M console=ttyS0,115200 mem=392M@0x20000000
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 648MB = 648MB total
Memory: 648800k/648800k available, 14752k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0xa9000000 - 0xff000000 (1376 MB)
lowmem : 0x80000000 - 0xa8800000 ( 648 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x804f4894 (5043 kB)
.init : 0x804f5000 - 0x80518000 ( 140 kB)
.data : 0x80518000 - 0x8053d0a0 ( 149 kB)
.bss : 0x8053d0c4 - 0x80585978 ( 291 kB)
NR_IRQS:128
Timer use APB0 clock
gm_jiffies_init, system HZ: 100, pClk: 46500000
console [ttyS0] enabled
Calibrating delay loop... 738.09 BogoMIPS (lpj=3690496)
Setting up static identity map for 0x103ac698 - 0x103ac704
devtmpfs: initialized
FMEM: 48640 pages(0xbe00000 bytes) from bank0 are reserved for Frammap.
FMEM: 96256 pages(0x17800000 bytes) from bank1 are reserved for Frammap.
FMEM: Logical memory ends up at 0xa8800000, init_mm:0x80004000(0x10004000), PAGE_OFFSET:0x80000000(phys:0x10000000),
Fmem hooks external data-abort handler.
PMU: Mapped at 0xfe000000
IC: GM8210, version: 0x11
PCIE PMU: Mapped at 0xfe00a000
IC: GM8312(1)
iotable: VA: 0xfe000000, PA: 0x99000000, Length: 4096
iotable: VA: 0xfe001000, PA: 0x98300000, Length: 4096
iotable: VA: 0xfe002000, PA: 0x98400000, Length: 4096
iotable: VA: 0xfe003000, PA: 0x98500000, Length: 4096
iotable: VA: 0xfe004000, PA: 0x98800000, Length: 4096
iotable: VA: 0xfe005000, PA: 0x98900000, Length: 4096
iotable: VA: 0xfe006000, PA: 0x82600000, Length: 4096
iotable: VA: 0xfe007000, PA: 0x99100000, Length: 4096
iotable: VA: 0xfe008000, PA: 0x98d00000, Length: 4096
iotable: VA: 0xfe009000, PA: 0x96000000, Length: 4096
iotable: VA: 0xfe00a000, PA: 0xc2700000, Length: 4096
iotable: VA: 0xfe00b000, PA: 0xc2800000, Length: 4096
8210 PCIE: 0xa9008000(0x99e00000), 8312 PCIE: 0xa900a000(0xc3700000)
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.24.
Switching to clocksource fttmr010:1
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 3072K
Video Timer(timer3) Max 92000ms in 0xfefd1980 HZ.
JFFS2 version 2.2. (NAND) A© 2001-2006 Red Hat, Inc.
msgmni has been set to 1273
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
gpiochip_add: registered GPIOs 0 to 31 on device: ftgpio010.0
probe ftgpio010.0 OK, at 0xa987c000
gpiochip_add: registered GPIOs 32 to 63 on device: ftgpio010.1
probe ftgpio010.1 OK, at 0xa987e000
Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xfe002000 (irq = 10) is a 16550A
brd: module loaded
loop: module loaded
FTSATA100_AHCI driver version 0.15
bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
nice use GMAC0
ftgmac100: Loading version 0.1 ...
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver cdc_ncm
i2c /dev entries driver
ftiic010 ftiic010.0: irq 18, mapped at a9882000
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 10
Mobile IPv6
IPv6 over IPv4 tunneling driver
RAMDISK: lzma image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing init memory: 140K
mount: mounting none on /dev/pts failed: No such file or directory
mdev: applet not found
mount: mounting tmpfs on /dev/shm failed: No such file or directory
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
mkdir: can't create directory '/dev/pts': File exists
/etc/init.d/S01udev: line 7: /sbin/mdev: not found
[RCS]: /etc/init.d/S81toe
[RCS]: /etc/init.d/S99dahua
S99dahua&...
Mounting root fs rw ...
/ # Mounting other filesystems ...
Setting hostname ...
/etc/init.d/S99dahua: line 11: hostname: not found
############## frammap.ko svn 25569 Sep 6 2015 18:26:38
Frammap: DDR0: memory base=0x14000000, memory size=0xbe00000, align_size = 4K.
Frammap: DDR1: memory base=0x20000000, memory size=0x17800000, align_size = 4K.
Frammap: version 1.1.2, and the system has 2 DDR.
Frammap: fail to open /mnt/mtd/config_8210, /tmp/template_8210 is created.
/etc/init.d/S99dahua: line 14: mdev: not found
rm: can't remove '/mnt/mtd/avss.info': No such file or directory
rm: can't remove '/mnt/mtd/Config/input_res': No such file or directory
*HOST FA626*
cpucomm svn 25569 Sep 6 2015 18:26:32
ep_cnt = 0, non_ep_cnt = 2
mem_alloc_init: physical memory begins at 0x14000000, ends at 0x15000000, 0x1000000 bytes.
cpucomm: use dmach mask: 0xc0
Wait Host core to provide the mbox .done
--- mbox paddr: 0xc800000, vaddr: 0xaa0ae000 ---
Wait FA726 core ready...done
--- ECOS: mbox paddr: 0xc800000, vaddr: 0xc800000 ---
ECOS: Wait FA626 core ready..done
cpucomm: board FA726, PoolMem:(paddr:0xc800000, size:0x2800000, vaddr:0xad000000, cbaddr:0xb0000000). ShareMem:(paddr:0xc801000, size:0x12000, vaddr:0xad001000)
Wait FC7500 core ready..done
cpucomm: board FC7500, PoolMem:(paddr:0x0, size:0x1000000, vaddr:0xb3000000, cbaddr:0xb5000000). ShareMem:(paddr:0xfde6f0, size:0x12000, vaddr:0xb3fde6f0)
ok, cpu_comm_2.7 driver is executed in FA626 core with dma_type: 1(1).
Begin recv file from FA726...
ECOS FC7500 for FA626 core, share memory phyaddr: 0x14016000, size: 0x12000, vaddr: 0x14016000
ECOS FC7500 for FA626 core, pool memory phyaddr: 0x14000000, size: 0x1000000, vaddr: 0x14000000
CPU_COMM version: 2.2 in FC7500
ecos_device_open -- FC7500 Record opens a channel for read/write.
ecos_device_open -- FC7500 Playback opens a channel for read/write.
ecos_device_open -- FC7500 Heart beat opens a channel for read/write.
End recv file from FA726...
video_system PAL
/mnt/mtd/avss.info
get_tv_support:0
get_dh9901_dev_num:2
ddr name: frammap0
base: 0x14000000
end: 0x1fe00000
memory allocated: 0x1000000 bytes
memory free: 0xae00000 bytes
max available slice: 0xae00000 bytes
memory allocate count: 1
clear address: 0x15000000
dirty pages: 4096
clear pages: 44544
size alignment: 0x1000
-------------------------------------------log: module license 'GM' taints kernel.
----------------Disabling lock debugging due to kernel taint
ddr name: frammap1
base: 0x20000000
e
log.ko:svn 25569 Sep 6 2015 18:26:25 (mmap 0x82810000 size 0xc000)
nd: 0x37800000
LOG base 0xaa0c3000 size 512K (start pointer 0x7f029314)
0 bytes
memory PAGE_OFFSET(0x80000000) VMALLOC START(0xa9000000) HZ(100)
allocated: 0x0 bytes
memory fropen /mnt/mtd/Config/vcapMode.cfg error
ee: 0x17800000 bcpu_type=18 video_chip=19 digital_chn_num=0 video_chn_num=16 speceial_custom 0,audio_chn_num=4 abroad=0 hwid=0x40000dd iva_support=0 mic_mux=1 tv_support=0 vstd=0 ad_dev_num=4 input_res 0 vcap_mode=-1
ytes
max available slice: 0x17800000 bytes
memory allocate count: 0
clear address: 0x20000000
dirty pages: 0
clear pages: 96256
ms.ko v0.8 svn 25569 Sep 6 2015 18:26:28
em.ko v0.26 svn 25569 Sep 6 2015 18:26:08
em_user v0.6 Sep 6 2015 18:26:08
Start EM thread 0(em_callback:0) with nice -20
Start EM thread 1(em_callback:1) with nice -20
EM Module Service Starting (callback_period = 3ms)
Start EM thread 2(em_callback:2) with nice -20
input_res = 7
output_type = 50
LCD platform: Hook GM8210 driver.
[mod0]fb0_num[1],fb1_num[1],fb2_num[1],output_type[50],input_res[7],lcd_disable[0],fb0_fb1_share[0],fb1_pan_display[0],vs_width[0],vs_height[0],bf[0],d1_3frame[0],gui_clone_fps[25]
GM_ffb: [ver:0.1.19]INIT flcd200 OK.
LCD0: PA = 0x9a800000, VA = 0xaa1e0000, size:0xd000 bytes
LCD0(SLI10121): Output resolution is 1280x1024/60HZ.
LCD0: Input resolution is 1280x1024(SXGA)
LCD0 registers 1 entities to video graph!
LCD0: Driver[Ver: 1.2.2] init ok. fb0_fb1_share:0, fb1_pan_display:0
zebra_device_open -- lcd0_drv opens a channel for read/write.
[mod1]fb0_num[1],fb1_num[1],fb2_num[1],output_type[1],input_res[1],lcd_disable[1],fb0_fb1_share[0],fb1_pan_display[0],vs_width[0],vs_height[0],bf[0],d1_3frame[1],gui_clone_fps[10]
GM_ffb: [ver:0.1.19]INIT flcd200_2 OK.
LCD2: PA = 0x9b800000, VA = 0xaa1f0000, size:0xd000 bytes
LCD2: Output resolution is D1 PAL.
Register codec TVE100.
LCD2: Input resolution is PAL
The standard clock is 27.0MHZ, but gets 558MHZ. Please correct PLL!
LCD2 joins D1 of 3frame.
LCD2: Driver[Ver: 1.2.2] init ok. fb0_fb1_share:0, fb1_pan_display:0
zebra_device_open -- lcd2_drv opens a channel for read/write.
HDMI sli10121 works in PCIe mode, pa = 0xc1900000, va = 0xaa1d8000.
Register codec sli10121-480P_BT1120.
Register codec sli10121-576P_BT1120.
Register codec sli10121-1024x768_RGB.
sli-hdmi is in 1280x1024 RGBLCD210: Input format to sli-hdmi is RGB888.
sli10121_polling_thread INIT = 0
HDMI_init, 1
Register codec sli10121-1280x1024_RGB.
Register codec sli10121-1920x1080_RGB.
Register codec sli10121-1280x720_RGB.
sli10121 sleep 100 ms
fe_common version 140714
zebra_device_open -- hdmi opens a channel for read/write.
i2c_test=0,dev_num=2,clk_used=0 clk_src=4 clk_freq=27000000 init=1 rstb_used=0 ch_map=0 sample_rate=0 sample_size=1 notify=1 audio_num=4 codec_type=2 hwid=67109085 isDev626=0 video_chip=19 encode_type=0 mic_mux=1 iaddr=60 =62 vout_format=0 =0 vout_mode=0 =0
adda.ko: Version: V0.00.074 Svn: 25569 Compile at Sep 6 2015 18:28:51
video_chip=19
audio_num=4
mic_mux=1
codec_type=2
res:7 brightness_value:-5 onoff:0
hdmi_test mode=0
SLI HDMI_interrupt, MASK_92h = 0xc0, INT_94h = 0x0
SANK_BAD_PCB
SANK_BAD_PCB
adda_sys_channel_maps: hwid=0x40000dd
dh9910_config_vdport: stDH9910VdPortConfig[0].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[1].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[2].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[3].ucVClkConfig = 0xaa
dh9910_video_init begin VD_PORT_MUX_MOD 0
dh9910_video_init ChipId 0 end
audio audio 9910!
dh9910_audio_init: first Stage of cascade
DH9910#0 Init...OK!
dh9910_video_init ChipId 1 end
audio audio 9910!
dh9910_audio_init: second Stage of cascade
DH9910#1 Init...OK!
cap_scl_up_disable =0
[VCAP_INFO]: VCAP300 Version: 0.3.5A svn 25569 Sep 6 2015 18:26:55
HOST626! insert vcap!\n
vi_mode [1 1 1 1], cap_md=1,grab_filter=0
vport= 0x4321,0x8765,inv_clk =0 0 data_swap 0 0
dhcvi_vport_map: vport[0]=0x5678
dhcvi_vport_map: vport[1]=0x1324
dhcvi_vport_map: vport[2]=0x0
dhcvi_vport_map: vport[3]=0x0
[VCAP_INFO]: Register DH9910#0 Input Device
[VCAP_INFO]: Register DH9910#1 Input Device
[VCAP_INFO]: Register Generic Input Device 8
max_vch_num=128,max_minors=100,temp_width=1920,temp_height=1080,scal_dmaparm=0
scaler300.ko:version 141017, svn 25569 Sep 6 2015 18:27:05
fscaler300_init_one [0] NCNB
fscaler300_init_one [1] NCNB
scaler_trans_init, version: 0x20140822
scaler_trans_init, Wait RC FA726 provides the directIO memory...
.a0?>?
Что это?И как в этом случае работать?
Пришлось сохранять дамп на программаторе.Пристёгиваю фото аппарата.
