SD-9604AD-A не могу найти прошивку.
M - 16.
Принесли недозагружающийся четырёхканальник.
Помогите найти прошивку на похожий.
Обращение к USB-флешке есть.
Фотки прилагаю, заставка не факт, что родная.
M - 16.
Re: SD-9604AD-A не могу найти прошивку.
Лог загрузки и заставка.
- resetэNAND: No NAND device found!!!
0 MiB
U-Boot 2008.10 (Feb 25 2012 - 10:16:48)
DRAM: 128 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
USB: scanning bus for devices... 1 USB Device(s) found
norm:0
0 Storage Device(s) found
Press CTRL-C to abort autoboot in norm:0nds
UpgradeSoftware:00000000
CheckUpgrade invalid addr(0x00000000)
failure
jpeg decoding ...
<<addr=0x80f20000, size=0x20000, vobuf=0xcfc00000>>
LineBytes 33 == 1600
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg!
jpeg decoding ...
<<addr=0x80f40000, size=0x20000, vobuf=0xcfe00000>>
LineBytes 33 == 1440
<<imgwidth=720, imgheight=576, linebytes=1440>>
decode success!!!!
## Booting kernel from Legacy Image at 80080000 ...
Image Name: hilinux
Data Size: 1372644 Bytes = 1.3 MB
Load Address: c0800000
Entry Point: c0800000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux........................................................................................ done, booting the kernel.
Linux version 2.6.24-rt1-hi3515v100 (root@localhost.localdomain) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #1 Wed Sep 1 16:50:11 CST 2010
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3515v100
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: busclk=220000000 mem=32M console=ttyAMA0,115200 root=1f01 rootfstype=jffs2 mtdparts=physmap-flash.0:2M(boot),6M(rootfs),7M(app),128K(para),512K(logo),128K(kt_mac) pcimod=host pciclksel=1
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 29596KB available (2508K code, 237K data, 92K init)
HI_VERSION=LINUX_2_6_24-M01C06FB02F @Hi3515v100R001_C_0_0_0 2010-08-11 17:51:09
net_namespace: 64 bytes
Hisilicon clock system V0.01
SCSI subsystem initialized
Time: hisi_timer1 clocksource has been installed.
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
JFFS2 version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
yaffs Sep 1 2010 16:44:46 Installing.
io scheduler noop registered
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
uart:2: ttyAMA2 at MMIO 0x200b0000 (irq = 13) is a AMBA/PL011
uart:3: ttyAMA3 at MMIO 0x200c0000 (irq = 13) is a AMBA/PL011
RAMDISK driver initialized: 4 RAM disks of 16384K size 4096 blocksize
loop: module loaded
physmap platform flash device: 04000000 at 80000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
6 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 6 MTD partitions on "physmap-flash.0":
0x00000000-0x00200000 : "boot"
0x00200000-0x00800000 : "rootfs"
0x00800000-0x00f00000 : "app"
0x00f00000-0x00f20000 : "para"
0x00f20000-0x00fa0000 : "logo"
0x00fa0000-0x00fc0000 : "kt_mac"
hi3515v100-ehci hi3515v100-ehci.0: hi3515v100-ehci
hi3515v100-ehci hi3515v100-ehci.0: new USB bus registered, assigned bus number 1
hi3515v100-ehci hi3515v100-ehci.0: irq 23, io mem 0x100b0000
hi3515v100-ehci hi3515v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hi3515v100-ohci hi3515v100-ohci.0: hi3515v100-ohci
hi3515v100-ohci hi3515v100-ohci.0: new USB bus registered, assigned bus number 2
hi3515v100-ohci hi3515v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
TCP cubic registered
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 92K
init started: BusyBox v1.1.2 (2008.09.26-11:18+0000) multi-call binary
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S3515init
Hisilicon ETH net controler(ver Mar 25 2011 18:49:05).
Hisilicon ETH MDIO Bus: probed
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: 46:04:A9:93:BB:98
*** Board tools : ver0.0.1_20060106 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20110104: 0x00009654 --> 0x00009654
0x20110100: 0x00000887 --> 0x00000887
0x2011010c: 0x00000003 --> 0x00000003
0x20110110: 0x00000007 --> 0x00010303
0x20110114: 0x00000007 --> 0x00010303
0x20110118: 0x00010F01 --> 0x00000007
0x2011011c: 0x00010F01 --> 0x00000007
0x20110128: 0x00010020 --> 0x00010020
0x2011012c: 0x000103A2 --> 0x00010601
0x20110130: 0x00000005 --> 0x00010803
0x20110134: 0x00000007 --> 0x00000007
0x20110138: 0x00010804 --> 0x00010804
0x2011013c: 0x00000007 --> 0x00000007
0x20050078: 0x00000000 --> 0x00008002
0x20050054: 0x00004000 --> 0x00001573
0x200f0094: 0x00000000 --> 0x00000001
0x200f0098: 0x00000000 --> 0x00000001
hi3515 if defined
add0a is 1f
tw2865 0x50 set to PAL mode ok!
init chip_addr80 ok
warning: tw2865 0x52 i2c_read err, val:0xff!!!
hi3515 if defined
add0a is 1f
tw2865 0x52 set to PAL mode ok!
tw2865 driver init successful!
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[Aug 11 2010, 18:11:30]
hifb info: video:vram2_size=900000,vram3_size=80000,vram0_size=10000000,vram1_size=1024,vram4_size=1024
hifb info: succeed in registering the fb0: ovl2 frame buffer device
hifb info: succeed in registering the fb1: ovl3 frame buffer device
hifb info: succeed in registering the fb2: ovl0 frame buffer device
hifb info: succeed in registering the fb3: ovl1 frame buffer device
hifb info: succeed in registering the fb4: ovl4 frame buffer device
TDE_MAIN_VERSION[v2.0.0.0] Build Time[Aug 11 2010, 18:11:32]
TDE_ADP_VERSION[hi3515adp v2.0.0.0] Build Time[Aug 11 2010, 18:11:32]
tde run on master arm
tde run for graphic service
tde map reg:basePhyAddr:20140000 baseVirAddr:c2878000 size:3000
Chip Version: Hi35150100
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
Driver 'sd' needs updating - please use bus_type methods
scsi0 : hi3515-ahci-device
scsi1 : hi3515-ahci-device
ata1: SATA max UDMA/133 irq 29
ata2: SATA max UDMA/133 irq 29
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
mice: PS/2 mouse device common for all mice
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
HISI_IRDA-MF @Hi3515v100R001_C_0_0_0 2010-08-11 17:54:08
hiir: init ok. ver=Aug 11 2010, 17:54:09.
Data CRC e37b6868 != calculated CRC 0bb422b1 for node at 002e1d94
M - 16.
Логу доверия тоже нет: на борту TW2866
M - 16.
Проц приказал долго жить.
Зато нашёл близнеца - Falcon Eye FE-004H Light
потроха идентичные.
потроха идентичные.
так что проблема решена? прошивка есть??? решение есть???M - 16. писал(а):Принесли недозагружающийся четырёхканальник.
так все таки прошивка есть??
M - 16.
Посмотрю на работе завтра.
Falcon Eye FE-004H Light прошивка интересно подойдет?? к этому чуду sd-9604ad-a кто нибудь в курсе???
sd-9604ad-a нужна прошивка к этому чуду! короче завис логотип может для начала сделать reset? где инструкцию взять?
- Fluffykrsk
На Sarmatt DSR 803-h похожа, но там АЦП TW2868, а тут я так понял 2866.
На Optimus REC-1008E тоже похожа (АЦП не знаю какое там), но там дамп 8Мб весит.
Внешне смахивают по шасси, понятно, что 8-ки это.
У вас память точно на 16Мб?
Дохлый дамп сливали?
На FE-004H у меня есть какие-то заплатки, но по тексту FE-004H Light фигурирует, фиг знает чем они отличаются, аппараты старые.
посмотри пожалуйста!M - 16. писал(а):Посмотрю на работе завтра.
M - 16.
Поискал, не нашёл
