MCVR6208 слетела web морда, неудачное восстановление.
Gura
Re: MCVR6208 слетела web морда, неудачное восстановление.
Сообщение Gura » 30 сен 2019, 12:19
Не указывается. Он сам все знает.
hisilicon # eracfg
erase offset:0x4d00000,size:0x300000
Skipping bad block at-- 4% complete.
0x04e40000
0x04e60000
0x04e80000
0x04ea0000
0x04ec0000
0x04ee0000
0x04f00000
0x04f20000
0x04f40000
0x04f60000
0x04f80000
Skipping bad block at-- 54% complete.
0x04fc0000
0x04fe0000
Erasing at 0x5100000 -- 100% complete.
erase offset:0x4a00000,size:0x300000
Erasing at 0x4ce0000 -- 100% complete.
connect frondboard!
resetting ...
System startup
U-Boot 2010.06-svn3096 (Sep 19 2018 - 01:01:33)
Check Flash Memory Controller v100 ... Found
SPI Nand ID Table Version 1.7
SPI Nand(cs 0) ID: 0xef 0xaa 0x21 Name:"W25N01GV"
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bit/512
SPI Nand total size: 128MB
In: serial
Out: serial
Err: serial
chip type hi3531a
DPLL:400Mhz DDR:1600Mhz
APLL:1100Mhz VPLL0:297Mhz
dh_flash_update_init
nand_curr_device 0
name boot+env offset 0x00000000 len 0x00400000
name kernel offset 0x00400000 len 0x00400000
name rootfs offset 0x00800000 len 0x01380000
name updateflag offset 0x01b80000 len 0x00100000
name sysbackup offset 0x01c80000 len 0x01800000
name web offset 0x03480000 len 0x00a00000
name custom offset 0x03e80000 len 0x00080000
name logo offset 0x03f00000 len 0x00100000
name record1 offset 0x04000000 len 0x00500000
name record2 offset 0x04500000 len 0x00500000
name bcfg offset 0x04a00000 len 0x00300000
name config offset 0x04d00000 len 0x00300000
BDB: partid = b; addr = 0x4d00000
BDB: partid = b; addr = 0x4d20000
BDB: partid = b; addr = 0x4d40000
BDB: partid = b; addr = 0x4d60000
BDB: partid = b; addr = 0x4d80000
BDB: partid = b; addr = 0x4da0000
BDB: partid = b; addr = 0x4dc0000
BDB: partid = b; addr = 0x4de0000
BDB: partid = b; addr = 0x4e00000
BDB: partid = b; addr = 0x4e40000
BDB: partid = b; addr = 0x4e60000
BDB: partid = b; addr = 0x4e80000
BDB: partid = b; addr = 0x4ea0000
BDB: partid = b; addr = 0x4ec0000
BDB: partid = b; addr = 0x4ee0000
BDB: partid = b; addr = 0x4f00000
BDB: partid = b; addr = 0x4f20000
BDB: partid = b; addr = 0x4f40000
BDB: partid = b; addr = 0x4f60000
BDB: partid = b; addr = 0x4f80000
BDB: partid = b; addr = 0x4fc0000
BDB: partid = b; addr = 0x4fe0000
miiphy_link,524,7949
miiphy_duplex,416,1
miiphy_speed,345,1
ETH0: PHY(phyaddr=1, mii) link UP: DUPLEX=HALF : SPEED=10M
MAC: скрыл
phy id:0x3625e62
nice find PHY B50612E on higmac
hwid_gpio_val=0x0
hwid_gpio_val=0x0
hwid_gpio_val=0x0
hwid_gpio_val=0x0
hwid_gpio_val=0x0
hwid_gpio_val=0x0
sysbackup
get_update_state,265,55,ff
get_update_state,265,aa,ff
get_update_state,265,5a,ff
*** INFO *** dul-backup state: NORMAL BOOT fail=0.
Erasing at 0x1ba0000 -- 100% complete.
miiphy_duplex,416,1
miiphy_speed,345,1
ETH0: PHY(phyaddr=1, rgmii) link UP: DUPLEX=FULL : SPEED=100M
MAC: 3C-EF-8C-42-D0-48
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'Iскрыл.txt'.
Download to address: 0x41000000
Downloading: T T T
Retry count exceeded; starting again
tftp receive failed ,please check net environment
NAND read: device 0 offset 0x400000, size 0x800000
8388608 bytes read: OK
## Booting kernel from Legacy Image at 41000000 ...
Image Name: Linux-3.10.0
Data Size: 2517136 Bytes = 2.4 MiB
Load Address: 40008000
Entry Point: 40008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Если я правильно понял флешка посыпалась?
fobos
Сообщение fobos » 30 сен 2019, 14:00
возможно...я перечитал ваш первый пост, в котором вы пишите, что залили прошивку от ТП через rs232, а в printenv нет команды для заливки partion table.bin ...вопрос: как вы его заливали?
fobos
Сообщение fobos » 30 сен 2019, 14:06
если 100% правильно залили partion table.bin, тогда флешь под замену
Gura
Сообщение Gura » 30 сен 2019, 15:03
Я не говорил что заливал его, я сказал что он есть. Команды были стандартные.
run dc
run du
run dr
run dw
fobos
Сообщение fobos » 30 сен 2019, 15:35
получается, что в любом случае нужен программатор
Gura
Сообщение Gura » 30 сен 2019, 16:37
Что даст программатор? Как правильно заливается partion table.bin? Или речь идет о полном клоне? Можно подробнее о методике снятия дампа и создания клона? Видимо многие спрашивают одно и тоже но в шапке форума не нашел....
fobos
Сообщение fobos » 30 сен 2019, 17:27
программатор даст возможность залить дамп и partion table.bin, что в свою очередь должно! привести к восстановлению работоспособности регов. Если у вас есть другой вариант залить partion table.bin - попробуйте его
Gura
Сообщение Gura » 30 сен 2019, 18:26
Понял Вас! Спасибо за развернутый ответ!
timon99
Сообщение timon99 » 01 окт 2019, 12:52
Данная память недавно добавлена по моей просьбе в список программатора ТРИТОН Петровым
Gura
Сообщение Gura » 01 окт 2019, 18:37
timon99 писал(а):
01 окт 2019, 12:52
Спасибо за информацию !!! :good:
Gura
Сообщение Gura » 02 окт 2019, 08:58
Уважаемый Fobos, появилась возможность считать /прошить damp (нашел где можно попользовать программатор).
Как я и говорил есть прошивка и partition table от производителя. Но при этом есть непреодолимое желание сделать клон с рабочего устройства (MAC и ID поменяю позже, используя printenv). Могли бы Вы рассказать как это грамотно делается по шагам, (интересует именно снятие дампа с рабочего устройства,чтобы ничего не запороть)
Заранее спасибо.
fobos
Сообщение fobos » 02 окт 2019, 18:41
ставите флешь в программатор, программатор должен ее корректно определить, считываете с нее данные, делаете верификацию и в случае отсутствия несовпадений считаете процедуру выполненной, в противном случае повторяете считывание сначала
