Прошивка HI3518с+IMX238
den23rus
Re: Прошивка HI3518с+IMX238
Сообщение den23rus » 25 янв 2016, 23:05
Рабочая прошивка: https://yadi.sk/d/qAWav18onjGqe" onclick="window.open(this.href);return false;
Нерабочая камера:
hisilicon # printenv
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
netmask=255.255.255.0
bootfile="uImage"
bootcmd=sf probe 0;sf read 0x82000000 0x100000 0x200000;bootm 0x82000000
bootargs=mem=64M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),2M(kernel),3M(system),10M(application)
ipaddr=192.168.15.140
serverip=192.168.15.136
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06 (Mar 11 2014 - 17:33:21)
Environment size: 448/262140 bytes
den23rus
Сообщение den23rus » 25 янв 2016, 23:08
Рабочая камера:
bootdelay=1
baudrate=115200
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
den23rus
Сообщение den23rus » 25 янв 2016, 23:13
Лог загрузки рабочей камеры:
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
In: serial
Out: serial
Err: serial
Image Name: Linux-3.0.8
Data Size: 1376244 Bytes = 1.3 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@lvjh-VirtualBox) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Thu May 15 10:14:31 CST 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: mem=64M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),2M(kernel),3M(system),10M(application)
Memory: 64MB = 64MB total
Memory: 61492k/61492k available, 4044k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc4800000 - 0xfe000000 ( 920 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
.init : 0xc0008000 - 0xc001f000 ( 92 kB)
.text : 0xc001f000 - 0xc0338000 (3172 kB)
.Fixed MDIO Bus: probed
34cf00 ( 84 kB)
.bss : 0xc034cf24 - 0xc035cf98 ( 65 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 110MHz, resolution 9ns, wraps every 39045ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
fuse init (API version 7.16)
msgmni has been set to 120
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000300000 : "kernel"
0x000000300000-0x000000600000 : "system"
0x000000600000-0x000001000000 : "application"
himii: probed
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
TCP cubic registered
øVFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 92K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (302): /proc/302/oom_adj is deprecated, please use /proc/302/oom_score_adj instead.
[RCS]: /etc/init.d/S80network
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=15 sec (nowayout= 0, nodeamon= 1)
SYS_CHECK: 55 1 3
Enter Watch Mode!
hi3518_base: module license 'Proprietary' taints kernel.
pa:84000000, va:c4b00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load vou.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok!
insmod: can't insert 'extdrv/pwm.ko': File exists
Kernel: ssp initial ok!
acodec inited!
get saved parameter!
watchDog_open 21
watchDogStart(): OK!
set_net_phyaddr: (WIRE: 00:00:1b:02:f6:b6) 0
dhcp_setup(WIRE): -1 192.168.1.168
DVS IP(WIRE): 192.168.1.168
EMAIL_Start(): Ok!
hello here#######
@@@@@@width=1280 height=1024
@@@@@@width=720 height=576
@@@@@@width=352 height=288
#@@@enter case PIC_HD720
@@@@@@width=1280 height=720
in start stvbconf:[0]=1966080 [1]=663552 [2]=184320 [3]=1474560 [4]=784
pMainEncParam->reserve=18 sub=4 third=1 VIDEO_ENCODING_MODE_PAL=0
-------Sony IMX138 Sensor Initial OK!-------
func(SAMPLE_COMM_ISP_Init::589 stImageAttr.u16FrameRate = 25)
before SAMPLE_COMM_VPSS_StartGroup:width=1280 height=1024
before SAMPLE_COMM_VPSS_EnableChn vpss=0:width=1280 height=1024
before SAMPLE_COMM_VPSS_EnableChn vpss=1:width=720 height=576
second width=720 height=576
stPicSize.u32Height = 288, stPicSize.u32Width = 352
venc 0 @@@ pic type=18
frame=25 vencParam->nKeyInterval = 1
debug @@@@@ set bitrate[18]:4096#####venc bitrate=4194304
venc 1 @@@ pic type=4
bitrate is:1048576
debug @@@@@ set bitrate[4]:1024#####venc bitrate=1048576
venc 2 @@@ pic type=1
frame=20 vencParam->nKeyInterval = 1
bitrate is:524288
debug @@@@@ set bitrate[1]:512#####venc bitrate=524288
vadcDrv_SetBrightness value=128
vadcDrv_SetContrast
func(vadcDrv_SetContrast::2129 val = 53)
after set saturation
return @@@
vadcDrv_SetBackLightLevel 1757: drc enable = 0
fun=RTSP_Init,line=1845 RTSP:----- RTSP_Init
param.param.encOSD.nChannel = 0::2::0::0::32::
param.param.encOSD.nChannel = 0::2::0::0::16::
func(mdMacroConvertExt::825 width = 640 , height = 480 )
videoEncModuleStartup() OK!
ircutStart(): Ok!
NETSDK_ServerSetup(1 4000 234.5.6.7) OK!
avInfo.nImageWidth = 1280
avInfo.nImageHeight = 1024
NETSDK_ServerStart() OK!
fun=SeaFileServer_Init,line=1927
fun=ddnsStart,line=1545
set policy:Invalid argument
ddnsStart(): OK!
stparam.Server = time.nist.gov;stparam.nOnFlag = 1
[05/May/2014:00:00:00 +0000] boa: server version Boa/0.94.13
[05/May/2014:00:00:00 +0000] boa: server built Nov 13 2014 at 13:06:18.
[05/May/2014:00:00:00 +0000] boa: starting server pid=535, port 80
Onvif_server is running...
Platform: HI
Console: enable
Devname: eth0
Authentication: tiny
Webservice port: 8999
Version: V2.1 Build Nov 18 2014
certification_param.nReserve = 1)
Longse server is running...
Platform: HI
Console: enable
Devname: eth0
Server port: 10000
onvif server ok
fun=P2P_Init,line=941
############P2P SERVICE SUCCESS################
#IPCAMERA Initialize OK!
sn: 9842900000003
start NatCommunicationImpl::Initialize!
start creat mServerControl!
NatCommunicationImpl::Login ..
client start connect server...
onvifSnapshotFun start
Wrote 72323 bytes to the file.
gethostbyname error
connect lookupARecords failed
Error: connect server failed .serverName=www.freeipc.com
mServerControl->connect failed..
Login to http://www.freeipc.com" onclick="window.open(this.href);return false; failed
~ServerControl() in
gethostbyname: Unknown host
can't find fd in m_transMap
~ServerControl() exit
Stop MessageIO
iTuneDVR
Сообщение iTuneDVR » 26 янв 2016, 01:36
Правильно слей образ весь и без загрузчика и выложи посмотреть.
А потом правильно еще раз загрузи на вторую камеру.
Бывает, что область на SPI надо стирать перед записью!
den23rus
Сообщение den23rus » 26 янв 2016, 11:11
Какая команда для того что бы слить без загрузчика и потом залить
den23rus
Сообщение den23rus » 26 янв 2016, 11:32
Решил попробовать по этому мануалу затер бут походу:
http://felipe.astroza.cl/hacking-hi3518 ... ip-camera/" onclick="window.open(this.href);return false;
Теперь камера не реагирует на терминал и на линк, поедет назад на родину)
Осталось ещё 4 подопытных)
Кокой командой залить прошивку не трогая этот бутт эмейдж. На других подопытных пока этой проблемы нет
iTuneDVR
Сообщение iTuneDVR » 26 янв 2016, 12:22
В соседней ветке же всё указано и по твоему логу загрузки тоже видны адреса областей и что в них находится.
Дампы сливай как полный с нулевого адреса до конца размера флеша, и с начала следующего раздела за загрузчиком и до конца - размер загрузчика. А заливать надо образ как раз по адресу начала второго раздела за загрузчиком, предварительно с ним проделав erase раз это spi.
Ну раз камера на руках не повиснет, а поедет на родину, то эксперементируй! ;)
