Китайский Mini NVR
Re: Китайский Mini NVR
Сообщение kROOT » 03 фев 2014, 04:42
demon54 писал(а):Посмотрите телнетом.
ls /usr/etc -l
-rw-r--r-- 1 root root 57 Sep 15 15:42 3GCFG.xml
-rw-r--r-- 1 root root 39735 Nov 28 16:17 ALARMINCFG.xml
-rw-r--r-- 1 root root 895 Sep 15 15:41 ALARMOUTCFG.xml
-rw-r--r-- 1 root root 163 Dec 30 21:09 AUTOREBOOTCFG.xml
-rw-r--r-- 1 root root 2403 Sep 15 15:41 CHANNAME.xml
-rw-r--r-- 1 root root 28201 Feb 2 01:00 COMPRESSCFG.xml
-rw-r--r-- 1 root root 92 Sep 15 15:41 COMPRESSCFG_AUD.xml
-rw-r--r-- 1 root root 6690 Feb 2 01:00 DECODERCFG.xml
-rw-r--r-- 1 root root 751 Feb 2 01:00 DEVICECFG.xml
-rw-r--r-- 1 root root 55 Sep 15 15:41 EMAILCFG.xml
-rw-r--r-- 1 root root 1697 Sep 15 15:41 EXCEPTIONCFG.xml
-rw-r--r-- 1 root root 4 Jan 7 01:10 ExMode.dat
-rw-r--r-- 1 root root 1873 Feb 2 01:00 HDCFG.xml
-rw-r--r-- 1 root root 3175 Feb 2 01:00 HDGROUP_CFG.xml
-rw-r--r-- 1 root root 1119 Sep 15 15:41 MANAGERHOSTSCFG.xml
-rw-r--r-- 1 root root 71 Sep 15 15:41 MONITORCFG.xml
-rw-r--r-- 1 root root 10903 Nov 2 16:43 MULTILINEOSD.xml
-rw-r--r-- 1 root root 142 Jan 13 20:28 ManagerHost.xml
-rw-r--r-- 1 root root 349 Sep 15 15:41 NETAPPCFG.xml
-rw-r--r-- 1 root root 3463 Feb 2 01:00 NETCFG.xml
-rw-r--r-- 1 root root 477 Feb 2 01:01 NETDEVCFG.xml
-rw-r--r-- 1 root root 11 Sep 15 15:41 NVR_CRUISE.xml
-rw-r--r-- 1 root root 55226 Jan 26 15:24 PICCFG.xml
-rw-r--r-- 1 root root 27203 Jan 26 15:24 RECORDCFG.xml
-rw-r--r-- 1 root root 63 Sep 15 15:41 REMOTEADJUSTTIME.xml
-rw-r--r-- 1 root root 567 Sep 15 15:41 RS232CFG.xml
-rw-r--r-- 1 root root 67 Sep 15 15:41 RTSPCFG.xml
-rw-r--r-- 1 root root 0 Feb 2 01:00 SENSORCFG.xml
-rw-r--r-- 1 root root 28 Sep 15 15:41 SHOWSTRING.xml
-rw-r--r-- 1 root root 184 Sep 15 15:41 SNMPCFG.xml
-rw-r--r-- 1 root root 24 Sep 15 15:41 SPOTMODE.xml
-rw-r--r-- 1 root root 50 Nov 2 16:43 TVRECT.xml
-rw-r--r-- 1 root root 6041 Jan 22 14:22 USERCFG.xml
-rw-r--r-- 1 root root 64 Dec 30 21:01 UiAppCfg.xml
-rw-r--r-- 1 root root 252 Jan 13 20:24 WIFICFG.xml
-rw-r--r-- 1 root root 26 Jan 22 14:22 WIFIWORKMODE.xml
-rw-r--r-- 1 root root 0 Feb 2 01:00 ZONEANDDST.xml
drwxr-xr-x 3 root root 0 Dec 5 11:04 mmc
-rw-r--r-- 1 root root 63 Feb 2 01:01 myExceptionState.xml
-rw-r--r-- 1 root root 359 Dec 30 21:01 mycfg.xml
drwxrwxrwx 3 root root 0 Jan 1 1970 ppp
-rwxrwxrwx 1 root root 42 Feb 2 01:01 resolv.conf
drw-r--r-- 3 root root 0 Feb 2 01:00 sata
drwxr-xr-x 3 root root 0 Feb 2 01:00 tmp
-rw-r--r-- 1 root root 491 Jan 13 20:30 udhcpc_time.conf
drw-r--r-- 3 root root 0 Nov 2 13:44 usb
drwxrwxrwx 4 root root 0 Jan 1 1970 var
lrwxrwxrwx 1 root root 9 Jan 1 1970 web -> /root/web
# du /usr/etc
4 /usr/etc/mmc/mmc0/pic_dir
4 /usr/etc/mmc/mmc0/Log
16 /usr/etc/mmc/mmc0/lost+found
408 /usr/etc/mmc/mmc0/UsrLogFile
7016 /usr/etc/mmc/mmc0/pre_record
7452 /usr/etc/mmc/mmc0
7452 /usr/etc/mmc
13 /usr/etc/ppp/peers
13 /usr/etc/ppp
1 /usr/etc/tmp/qtembedded-0/fonts
1 /usr/etc/tmp
2 /usr/etc/var/run
0 /usr/etc/var/lock
2 /usr/etc/var
0 /usr/etc/usb/sda1
0 /usr/etc/usb
0 /usr/etc/sata
7669 /usr/etc
Kitano
Сообщение Kitano » 03 фев 2014, 06:18
По телнету тоже через uart кабель конектите?
demon54
Сообщение demon54 » 03 фев 2014, 06:46
Kitano писал(а):По телнету тоже через uart кабель конектите?
Нет. Телнет - это протокол через ethernet. uart - это последовательный интерфейс (com порт) с уровнями ttl.
Полезнее подключаться через uart. На него сыплется почти весь процесс загрузки. И то что не будет видно через телнет, будет видно через uart.
Когда у меня NVR перестал грузиться , через uart было видно, что линукс ругается на нехватку места.
Kitano
Сообщение Kitano » 03 фев 2014, 07:51
А как узнать ip рега? он же не грузится и по старому адресу не конектится.
Сообщение kROOT » 03 фев 2014, 08:11
Kitano писал(а):А как узнать ip рега? он же не грузится и по старому адресу не конектится.
скорее всего никак. если вдруг рег стал получать адрес по DHCP то этот адрес можно получить из роутера.
если подключен напрямую к компу и у обоих устройств адреса в одной сети, то через команду arp -a
но скорее всего доступ только через uart
Roman
Сообщение Roman » 03 фев 2014, 09:22
Есть куча программ, сканирующих сетку и выводящие адреса и параметры всех устройств, которые в этой сетке найдены.
Ну и у производителя устройства как правило должна быть утилита, которая его ищет в локалке и позволяет выставлять нужный адрес.
mishaл750
Сообщение mishaл750 » 03 фев 2014, 10:11
Если глянуть в инструкцию, там написан адрес 192.168.1.188 кажись, хотя я воткнул в роутер то отзывается по адресу выше.
mishaл750
Сообщение mishaл750 » 03 фев 2014, 19:43
Нашел файл pre_record в usr/etc/, размер файла больше 400 кб, удалил и nvr запустился.
Kitano
Сообщение Kitano » 03 фев 2014, 20:04
Я уже и сканером ip искал, и разные сети пробовал, и родной утилитой рега искал. Вобщем надо кабель купить и не мучатся, через uart сделать.
Сообщение kROOT » 04 фев 2014, 06:09
Kitano писал(а):Я уже и сканером ip искал, и разные сети пробовал, и родной утилитой рега искал. Вобщем надо кабель купить и не мучатся, через uart сделать.
я же написал, что это практически бесполезное занятие. не может рег просто так взять и изменить свой адрес, если сам не сбрасывал на заводские настройки. а если сбрасывал,то на заводском адресе должно быть. UART по любому нужен, не дорогое устройство и еще может пригодится, чтобы поднять роутер-кирпич.
Сообщение kROOT » 04 фев 2014, 06:14
mishaл750 писал(а):Нашел файл pre_record в usr/etc/, размер файла больше 400 кб, удалил и nvr запустился.
у меня чтото подобное тоже было. pre_record это временный файл видеозаписи, который вставляется в начало видео при детекторе движения если установлена соответствующая опция.
есть 2 варианта решения проблемы - отключить предварительную запись или при запуске ОС в регистраторе удалять такие временные файлы автоматом
я UART которым восстанавливал, отдал, заказанные еще не пришли, так что экспериментировать не буду.
Olestas
Сообщение Olestas » 04 фев 2014, 11:06
А сколько же там места в системном разделе? Так мало? Как у первых андроидов :D
