не позволяет очистеть раздел "config" камера Hi3518C
Re: не позволяет очистеть раздел "config" камера Hi3518C
вот что получилось после загрузки моего конфига -все по моему вернулось назад в сети не видеться
resetting ...
U-Boot 2010.06 (May 19 2014 - 14:51:10)
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
In: serial
Out: serial
Err: serial
UpgradeSoftware:8346B000 V1.2
CheckUpgrade invalid maigc(0xd6f63aba, 0xaa5555aa)
Image Name: Linux-3.0.8
Data Size: 2890856 Bytes = 2.8 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (pub@BVT-SDK-SERVER3) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Tue Mar 11 17:36:34 HKT 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 200000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10160
Kernel command line: mem=40M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),3M(kernel),11776K(rootfs),512K(config)
Memory: 40MB = 40MB total
Memory: 35088k/35088k available, 5872k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc3000000 - 0xfe000000 ( 944 MB)
lowmem : 0xc0000000 - 0xc2800000 ( 40 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc0513000 (5032 kB)
.data : 0xc0514000 - 0xc0537fa0 ( 144 kB)
.bss : 0xc0537fc4 - 0xc0555240 ( 117 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.16)
msgmni has been set to 68
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000f80000 : "rootfs"
0x000000f80000-0x000001000000 : "config"
Fixed MDIO Bus: probed
himii: probed
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
▒VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 132K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (510): /proc/510/oom_adj is deprecated, please use /proc/510/oom_score_adj instead.
[RCS]: /etc/init.d/S10mpp
/etc/init.d/S10mpp: line 15: set_path_before: not found
/etc/init.d/S10mpp: line 16: set_path_before: not found
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20090030: 0x00000300 --> 0x00004F01
[END]
0x2005003c: 0x000001E0 --> 0x000001E2
[END]
----Sensor Type: ovb9712 ----
Set GPIO9_0
0x200F00C8: 0x00000001 --> 0x00000001
[END]
Set GPIO9_1
0x200F00CC: 0x00000001 --> 0x00000001
[END]
Set GPIO9_4
0x200F00D8: 0x00000001 --> 0x00000001
[END]
Set GPIO5_3
0x200F00C0: 0x00000001 --> 0x00000000
[END]
Set GPIO0_1
0x200F0124: 0x00000000 --> 0x00000000
[END]
Set GPIO0_2
0x200F0128: 0x00000000 --> 0x00000000
[END]
Set GPIO0_7
0x200F013C: 0x00000000 --> 0x00000001
[END]
Set GPIO0_3
0x200F012C: 0x00000000 --> 0x00000000
[END]
Set GPIO0_4
0x200F0130: 0x00000000 --> 0x00000000
[END]
0x200f0138: 0x00000001 --> 0x00000000
[END]
0x20140400: 0x00000020 --> 0x00000061
[END]
0x20140100: 0x00000040 --> 0x00000040
[END]
hi3518_base: module license 'Proprietary' taints kernel.
pa:82800000, va:c3200000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok! add for 24c04
gpio_0_base_addr_virtual:0xc3500000 !
Set Gpio0_6 dir to 1!
Set Gpio0_6 bit to 0!
Set Gpio0_6 bit to 1!
hi_gpio_init_hrtimer!
insmod: can't insert 'extdrv/ssp_ad9020.ko': No such file or directory
acodec inited!
insert audio
==== Your input Sensor type is ovb9712 ====
entry jb_hi_authen0104_init
DMS_Read0104Data failed
no ic ack
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 1, nodeamon= 0)
ln: /usr/lib/libnetpt.so: File exists
read log config ok
[RCS]: /etc/init.d/S80network
(none) login: [01-01-08:00:12][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-08:00:12][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-08:00:12][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
[01-01-08:00:12][TRACE][main] ========== HI3518 PLATFORM BAICMODULE Build:Dec 4 2014 15:23:08 ==============
#### I2C_24C04_Write_Data, nPart=0, nPos=120, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=122, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=124, nSizeSet=2
#### I2C_24C04_Write_Data, nPart=0, nPos=126, nSizeSet=2
#### I2C_24C04_Read_Data, nPart=0, nPos=120, nSizeGet=8
[01-01-08:00:12][TRACE][main] [0].g_authen_ic_raw_information.bSize [64]
[01-01-08:00:12][TRACE][main] [1].g_authen_ic_raw_information.bChannelCount [0x1]
[01-01-08:00:12][TRACE][main] [2].g_authen_ic_raw_information.wCompany [6]
[01-01-08:00:12][TRACE][main] [3].g_authen_ic_raw_information.wCpuType [19]
[01-01-08:00:12][TRACE][main] [4].g_authen_ic_raw_information.bAlarmInCount [1]
[01-01-08:00:12][TRACE][main] [5].g_authen_ic_raw_information.bAlarmOutCount [1]
[01-01-08:00:12][TRACE][main] [6].g_authen_ic_raw_information.dwSupOption [0]
[01-01-08:00:12][TRACE][main] [7].MAC [0x0:0x18:0xa9:0x73:0x83:0xc6]
[01-01-08:00:12][TRACE][main] [8].g_authen_ic_raw_information.bSerial [JBNV▒/▒T▒▒]
[01-01-08:00:12][TRACE][main] [9].g_authen_ic_raw_information.bImageSize [3]
[01-01-08:00:12][TRACE][main] [10].g_authen_ic_raw_information.byPCBType [0]
[01-01-08:00:12][TRACE][main] [11].g_authen_ic_raw_information.byPCBVer [2]
[01-01-08:00:12][TRACE][main] At88sc0104 check_encrypt suc .............................................
[01-01-08:00:12][TRACE][main] [jiabo video][APP]: chek encrypt chip ok!
[01-01-08:00:12][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-08:00:12][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-08:00:12][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-08:00:12][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-08:00:12][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-08:00:12][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-08:00:12][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-08:00:12][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
[01-01-08:00:12][ERR][main] can't open mt9d131
[01-01-08:00:12][ERR][main] can't open ov10630
[01-01-08:00:12][ERR][main] can't open ip2986
[01-01-08:00:12][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-08:00:12][ERR][main] can't open xf_ov2715
[01-01-08:00:12][ERR][main] can't open nvp2400
[01-01-08:00:12][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-08:00:12][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = sensortype=ovb9712,m_nHi3518VIChip = 30!
[01-01-08:00:12][TRACE][main] DMS_vadc_hi3518_Open-318: s32Ret=0x00000000,u32ChipId=0x3518E100!
[01-01-08:00:12][TRACE][main] :::::::::::::::::: VICHIP HI3518 OV9712B
[01-01-08:00:12][ERR][main] DMS_TW2866_VAD_Open Failed!
[01-01-08:00:12][TRACE][main] :::::::::::::::::: AICHIP JB_TLV320
[01-01-08:00:12][TRACE][main] nChannelNum [1], nKeyCheckRes [0]
[01-01-08:00:12][TRACE][main] end of free..
[01-01-08:00:12][TRACE][main] globelMalloc ChannelCount:1
[01-01-08:00:12][TRACE][main] end of malloc..
#### dms_read_protect_key_information_config 1983
[01-01-08:00:12][ERR][main] InitDefaultConfigFile: File(/jb_config/jb_rootfs/jb_default.config) is exist!
[01-01-08:00:12][TRACE][main] +++++++++==========++++++ g_fatal_param.default_flag = 181
[01-01-08:00:12][TRACE][main] +++++++++==========+++++ g_fatal_param.fatal_param_len = 12
[01-01-08:00:12][TRACE][main] [3]: initialize the system parameter with value.
#### dms_read_device_config 363
#### dms_read_device_config 373,cfgbuf:{
"DeviceName": "IPCAM",
"DeviceID": 0,
"RecordLen": 5,
"Language": 1,
"RecycleRecord": 1,
"OverWritePeriod": 0,
"VideoStandard": 0,
"DateFormat": 1,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"SoftwareVersion": 67116582,
"SoftwareBuildDate": 538120468,
"DspSoftwareVersion": 0,
"DspSoftwareBuildDate": 0,
"PanelVersion": 0,
"PanelSoftwareBuildDate": 0,
"HardwareVersion": 67116582,
"HardwareBuildDate": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"SerialNumber": "JBNV▒/▒T▒▒",
"ServerCPUType": 3518,
"SysFlags": 25559049,
"ServerType": 100004,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"NetworkPortNum": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
#### dms_read_device_config 431
#### dms_read_server_user 488
#### dms_read_server_user 500
#### dms_read_server_user 590, i=0, stUserInfo.dwUserRight=-2147483633
#### dms_read_server_user 590, i=1, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=2, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=3, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=4, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=5, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=6, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=7, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=8, stUserInfo.dwUserRight=0
#### dms_read_server_user 590, i=9, stUserInfo.dwUserRight=0
#### dms_read_stream_info 625
#### dms_read_record_setting 762
#### dms_read_record_mode_param 853
#### dms_read_channel_cb_detection_config 2788
#### dms_read_channel_pic_param 2233
#### dms_read_channel_color 949
#### dms_read_channel_enhanced_color 1001
#### dms_read_channel_shelter 1067
#### dms_read_channel_motion_detect 1128
#### dms_read_channel_probe_alarm 1251
#### dms_read_channel_probe_alarm 1366
#### dms_read_Channel_AlarmOut 689
#### dms_read_channel_video_lost 1373
#### dms_read_channel_osd_info 1489
#### dms_read_exception_info 1579
#### dms_read_server_cominfo 1665
#### dms_read_server_com2info 1729
#### dms_read_default_ptz_Protocol 2063
#### dms_read_ftpupdata_param 1791
#### dms_read_record_upload 911
#### dms_read_notify_servers 1841
#### dms_read_pppoe_config 1882
#### dms_read_timezone_config 2382
#### dms_read_ddns_config 1930
#### dms_read_producer_setting_config 2021
#### dms_read_upnp_param 2448
[01-01-08:00:12][ERR][main] ____________Application will exit by signal:11,pid:768
[01-01-08:00:12][ERR][main] ____________Application exit thread name main
						resetting ...
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
"DeviceID": 0,
"RecordLen": 5,
"Language": 1,
"RecycleRecord": 1,
"VideoStandard": 0,
"DateFormat": 1,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"PanelVersion": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
https://dropmefiles.com/UC9zC" onclick="window.open(this.href);return false;
спасибо вечером залью и отпишусь
добрый вечер,вот залил третий вариант конфига.После перегрузки (reset) камера щелкнула затвором раза 2 и стала периодически появляться и пропадать в сети 192.168.1.100 порты 8200 или 554 ,но видео нет.Она постоянно перегружается,еще чего-то чуть чуть ей не нравится. Вот лог (повторы не выкладываю)
0 MiB
In: serial
Out: serial
Err: serial
hisilicon # tftp 82000000 newjffs23
Hisilicon ETH net controler
MAC: 00-00-23-34-45-66
TFTP from server 192.168.1.7; our IP address is 192.168.1.9
Download Filename 'newjffs23'.
Download to address: 0x82000000
Downloading: #################################################
done
Bytes transferred = 524288 (80000 hex)
hisilicon # sf probe 0;sf erase f80000 80000;sf write 82000000 f80000 80000
Erasing at 0x1000000 -- 100% complete.
Writing at 0x1000000 -- 100% complete.
hisilicon # reset
resetting ...
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
[01-01-08:00:13][TRACE][main] [0].g_authen_ic_raw_information.bSize [249]
[01-01-08:00:13][TRACE][main] [1].g_authen_ic_raw_information.bChannelCount [0x13]
[01-01-08:00:13][TRACE][main] [2].g_authen_ic_raw_information.wCompany [2624]
[01-01-08:00:13][TRACE][main] [3].g_authen_ic_raw_information.wCpuType [37945]
[01-01-08:00:13][TRACE][main] [4].g_authen_ic_raw_information.bAlarmInCount [15]
[01-01-08:00:13][TRACE][main] [5].g_authen_ic_raw_information.bAlarmOutCount [253]
[01-01-08:00:13][TRACE][main] [6].g_authen_ic_raw_information.dwSupOption [2853064643]
[01-01-08:00:13][TRACE][main] [7].MAC [0x0:0xb2:0x9b:0xa:0xf3:0xb7]
[01-01-08:00:13][TRACE][main] [8].g_authen_ic_raw_information.bSerial [▒▒▒W▒▒6▒▒▒S▒▒D*▒▒g@▒▒Z4▒
▒0▒▒=▒▒▒
▒▒tڨD▒▒]
[01-01-08:00:13][TRACE][main] [9].g_authen_ic_raw_information.bImageSize [68]
[01-01-08:00:13][TRACE][main] [10].g_authen_ic_raw_information.byPCBType [42]
[01-01-08:00:13][TRACE][main] [11].g_authen_ic_raw_information.byPCBVer [20]
[01-01-08:00:13][TRACE][main] At88sc0104 check_encrypt suc .............................................
[01-01-08:00:13][TRACE][main] [jiabo video][APP]: chek encrypt chip ok!
[01-01-08:00:13][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-08:00:13][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-08:00:13][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-08:00:13][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-08:00:13][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-08:00:13][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-08:00:13][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-08:00:13][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
[01-01-08:00:13][ERR][main] can't open mt9d131
[01-01-08:00:13][ERR][main] can't open ov10630
[01-01-08:00:13][ERR][main] can't open ip2986
[01-01-08:00:13][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-08:00:13][ERR][main] can't open xf_ov2715
[01-01-08:00:13][ERR][main] can't open nvp2400
[01-01-08:00:13][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-08:00:13][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = sensortype=ovb9712,m_nHi3518VIChip = 30!
[01-01-08:00:13][TRACE][main] DMS_vadc_hi3518_Open-318: s32Ret=0x00000000,u32ChipId=0x3518E100!
[01-01-08:00:13][TRACE][main] :::::::::::::::::: VICHIP HI3518 OV9712B
[01-01-08:00:13][ERR][main] DMS_TW2866_VAD_Open Failed!
[01-01-08:00:13][TRACE][main] :::::::::::::::::: AICHIP JB_TLV320
[01-01-08:00:13][TRACE][main] nChannelNum [1], nKeyCheckRes [0]
[01-01-08:00:13][TRACE][main] end of free..
[01-01-08:00:13][TRACE][main] globelMalloc ChannelCount:1
[01-01-08:00:13][TRACE][main] end of malloc..
[01-01-08:00:13][ERR][main] InitDefaultConfigFile: File(/jb_config/jb_rootfs/jb_default.config) is exist!
[01-01-08:00:13][TRACE][main] +++++++++==========++++++ g_fatal_param.default_flag = 181
[01-01-08:00:13][TRACE][main] +++++++++==========+++++ g_fatal_param.fatal_param_len = 12
[01-01-08:00:13][TRACE][main] [3]: initialize the system parameter with value.
Error before: [], cfgbuf:
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_server_network.config) fail(2)
[01-01-08:00:13][ERR][main] paramcfg.c(145) - 2 , No such file or directory
SystemCall_msg cli_pid 768
Enter Start_udhcpc_Func thread!
Exit Start_udhcpc_Func thread!
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_server_network.config) fail(2)
#### dms_read_server_network 305
"DeviceID": 0,
"RecordLen": 5,
"Language": 1,
"RecycleRecord": 1,
"VideoStandard": 0,
"DateFormat": 1,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"PanelVersion": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
#### dms_read_server_user 506
#### dms_read_server_user 508
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_server_user.config) fail(2)
[01-01-08:00:13][TRACE][main] ### Error, jb users.....
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_stream_info.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_record_setting.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/dms_server_cb_detection.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_streampic.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_color.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_enchanced_color.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_shelter.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_motion_detech.config) fail(2)
#### dms_read_channel_probe_alarm 1265
#### dms_read_channel_probe_alarm 1267, cfgbuf:
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_probe_alarm.config) fail(2)
#### dms_read_channel_probe_alarm 1270
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_video_lost.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_channel_osdinfo.config) fail(2)
#### dms_read_exception_info 1594
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_server_cominfo.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_server_com2info.config) fail(2)
[01-01-08:00:13][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_ftpupdata_param.config) fail(2)
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_pppoe_info.config) fail(2)
[01-01-08:00:14][ERR][main] paramcfg.c(145) - 2 , No such file or directory
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_timezone_param.config) fail(2)
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_ddns_info.config) fail(2)
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_producer_parameter_setting.config) fail(2)
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_upnp_param.config) fail(2)
#### dms_read_mobile_param 2511
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_mobile_param.config) fail(2)
#### dms_read_p2p_param 2556
#### dms_read_rtsp_param 2601
#### dms_read_snap_timer 2649
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_snap_timer.config) fail(2)
#### dms_read_ntp_param 2713
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/ntp_param.config) fail(2)
#### dms_read_sensor_type 2756
#### dms_read_sensor_type 2774, u32Sensor=30
#### dms_read_perimeter_config 2855
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_perimeter_param.config) fail(2)
#### dms_read_itevcontrol_config 2958
#### dms_read_tripwire_config 2999
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_tripwire_param.config) fail(2)
#### dms_read_videofool_config 3124
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_videofool_param.config) fail(2)
#### dms_read_wireless_wifi_param 2116
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/wireless_wifi_param.config) fail(2)
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/wireless_WPS_param.config) fail(2)
#### dms_read_wireless_tdscdma_param 2184
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/wireless_tdscdma_param.config) fail(2)
#### dms_read_email_param 3225
[01-01-08:00:14][ERR][main] file(paramcfg.c), line(144):jb_flash_read fopen file(/jb_config/jb_rootfs/jb_email_param.config) fail(2)
[01-01-08:00:14][TRACE][main] jiabo video startup watchdog ok
[01-01-08:00:14][TRACE][main] jb_set_wdt_timeout cur_margin is 3c
[01-01-08:00:14][TRACE][main] jb_get_wdt_timeout cur_margin is 3c
[01-01-08:00:14][TRACE][main] uiSensor=30
[01-01-08:00:14][TRACE][main] JB_Check_Sensor_Type: nCurVIChip=30,nLastViChip=30!
[01-01-08:00:14][TRACE][main] 1.wWidth1 = 352, wHeight1 = 240!
[01-01-08:00:14][TRACE][main] +++++++++++++++++ dwStreamFormat:6
[01-01-08:00:14][TRACE][main] 2.wWidth1 = 1280, wHeight1 = 720!
[01-01-08:00:14][TRACE][main] [DMS_DEV_GPIO_Init ,540]: 1.0--GPIO_I2C_GetDir nDevAddr:9 nRegAddr:0 nvalue:0
[01-01-08:00:14][TRACE][main] baud is 0
[01-01-08:00:14][TRACE][main] [lg][APP]: Start up tty OK!
[01-01-08:00:14][TRACE][main] Entry JB_initCodec
[01-01-08:00:14][TRACE][tty] ================== Entry thread detectTtyThread pthread_self 1086743744 getpid() 768
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_init 505: m_nHi3518VIChip = 30!
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_init 506: stImageAttr.u16Width = 1280!
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_init 507: stImageAttr.u16Height = 720!
[01-01-08:00:15][TRACE][main] DMS_Vadc_OV9712B_ISP_Init: stIspAeAttr.bByPassAE = 0!
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_ISP_OV9712_Init Success!
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_init: init success!
[01-01-08:00:15][TRACE][main] maxChNum=1, mode=0, enDeviceType=0
[01-01-08:00:15][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:117 VideoOsdInit....
[01-01-08:00:15][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:165 VideoOsdInit...ok
[01-01-08:00:15][TRACE][main] EnableVi ViDevId:0, ViChn:0
[01-01-08:00:15][TRACE][main] EnableVi stCapSize u32Width:1280, u32Height:720
[01-01-08:00:15][TRACE][main] EnableVi stDestSize u32Width:1280, u32Height:720
[01-01-08:00:15][TRACE][main] bit_rate:3072,framerate:25,Quality:0,gop_size:50,RateType:1
[01-01-08:00:15][TRACE][main] InitVenc VpssGrp:0 VpssChn:0 VeGrpChn:0 VeChn:0
[01-01-08:00:15][TRACE][main] InitVenc encode stream 0:0 format is 6 u32BitRate:3072
[01-01-08:00:15][TRACE][main] Enable Encode VeGroup:0 VeChn:0 ViDev:0 ViChn:0
[01-01-08:00:15][TRACE][main] DMS_Enable_Encode OK!!!!!!!!!!!!!!!!
[01-01-08:00:15][TRACE][main] bit_rate:512,framerate:9,Quality:0,gop_size:50,RateType:1
[01-01-08:00:15][TRACE][main] InitVenc VpssGrp:0 VpssChn:1 VeGrpChn:1 VeChn:1
[01-01-08:00:15][TRACE][main] InitVenc encode stream 0:1 format is 15 u32BitRate:512
[01-01-08:00:15][TRACE][main] Enable Encode VeGroup:1 VeChn:1 ViDev:0 ViChn:1
[01-01-08:00:15][TRACE][main] jb_init_venc DMS_SECOND_STREAM OK ##################
[01-01-08:00:15][TRACE][main] MD chinnel 0 OK
[01-01-08:00:15][ERR][main] jbcodec.c(1756) - 2 , No such file or directory
[01-01-08:00:15][ERR][main] jbcodec.c(1617) - 2 , No such file or directory
[01-01-08:00:15][TRACE][main] JB_Video_Update_OSD--pInfo->dwChannel=0!
[01-01-08:00:15][TRACE][main] pInfo->stOsd[0].bOsdEnable = 0!
[01-01-08:00:15][TRACE][main] pInfo->stOsd[1].bOsdEnable = 0!
[01-01-08:00:15][TRACE][main] pInfo->stOsd[2].bOsdEnable = 0!
[01-01-08:00:15][TRACE][main] pInfo->stOsd[3].bOsdEnable = 0!
[01-01-08:00:15][TRACE][main] pInfo->stOsd[4].bOsdEnable = 0!
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00400000 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetAIAttr val:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000001 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000002 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000004 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000008 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000200 nVal:0
[01-01-08:00:15][TRACE][main] stSharpenAttr.bEnable=1,stSharpenAttr.bManualEnable=0!
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000800 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetDenoiseAttr bEnable:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000020 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetAWBAttr u8RGStrength:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000040 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetAWBAttr u8BGStrength:0
[01-01-08:00:15][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00004000 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetMEAttr u32ExpLine:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00008000 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetMEAttr u32ExpLine:512,val:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00010000 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00020000 nVal:0
[01-01-08:00:15][TRACE][main] HI_MPI_ISP_SetMEAttr bManualAGainEnable:1 s32DGain:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00040000 nVal:0
[01-01-08:00:15][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00080000 nVal:0
[01-01-08:00:15][TRACE][main] DMS_vadc_hi3518_DNSet enDNAction:0 bManul:0 WaitDNAction:2, tNow:15 LastDNActionTime:0
[01-01-08:00:15][TRACE][main] DMS_DEV_GPIO_SetIRCutState_Ex-986: nDay=0!
[01-01-08:00:16][TRACE][main] Set ircut to day mode!
[01-01-08:00:16][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-08:00:16][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00100000 nVal:0
[01-01-08:00:16][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000400 nVal:0
[01-01-08:00:16][TRACE][main] jb_start_adec--wType=19!
[01-01-08:00:18][TRACE][main] jb_start_aenc--wType=19!
[01-01-08:00:18][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_AI_Init @@@@@@@@@
[01-01-08:00:18][TRACE][main] 1_____gain_mic=0x0b!_____
[01-01-08:00:18][TRACE][main] 2_____gain_mic=0x00!_____
[01-01-08:00:18][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_Aenc_Init @@@@@@@@@
[01-01-08:00:18][TRACE][main] Befor JB_Video_jpegThread_Initial
[01-01-08:00:18][TRACE][main] JB_Video_jpegThread_Initial create JB_Video_jpegThread
[01-01-08:00:18][TRACE][main] Leave JB_initCodec
[01-01-08:00:18][TRACE][main] jiabo video startup rtc ok
[01-01-08:00:18][TRACE][main] ================== thread JB_Video_jpegThread pthread_self 1140241600 getpid() 768
[01-01-08:00:18][TRACE][main] ================== thread JB_Video_Auto_jpegThread pthread_self 1149625536 getpid() 768
[01-01-08:00:18][TRACE][JpegSnap] ................... Entry Video_jpegThread
[12-31-12:00:18][TRACE][main] DMS_InsertLog
[12-31-12:00:18][TRACE][main] PRODUCT_IP_SET-DEFAULT-1!
[12-31-12:00:18][TRACE][dms_alarmproces] ================== thread dms_alarmprocess_thread pthread_self 1177031872 getpid() 768
[12-31-12:00:18][TRACE][dms_exceptalarm] ================== thread dms_exceptalarmprocess_thread pthread_self 1185772736 getpid() 768
[12-31-12:00:18][TRACE][main] ================== thread JB_Alarm_Thread pthread_self 1167811776 getpid() 768
[12-31-12:00:18][TRACE][main] NAME-DEFAULT--1!
[12-31-12:00:18][TRACE][main] cmd = ifconfig eth0 hw ether 00:b2:9b:0a:f3:b7!
[12-31-12:00:18][TRACE][main] set_net_phyaddr cmd [ifconfig eth0 hw ether 00:b2:9b:0a:f3:b7]
ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.16.1) started
Sending discover...
[12-31-12:00:19][TRACE][main] ================== thread sysTimeThread pthread_self 1158436032 getpid() 768
PHY: himii:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[12-31-12:00:20][TRACE][sysTime] dhcp_tick=1!
[12-31-12:00:21][ERR][dms_alarmproces] jbalarmpro.c(689) - 0 , Success
[12-31-12:00:21][TRACE][sysTime] dhcp_tick=2!
Sending discover...
[12-31-12:00:22][TRACE][dms_alarmproces] file(jbalarmpro.c), line(692) fatal this system will restart !!!
Entry REC_StopAllRecord
[12-31-12:00:22][TRACE][dms_alarmproces] this system will be restarted now !!!
[12-31-12:00:22][TRACE][sysTime] dhcp_tick=3!
[12-31-12:00:22][TRACE][dms_alarmproces] [DMS_UpdateLog]--index=79,start:1970-1-1 0:0:0,run:1970-1-1 0:0:0,system reboot!!
SystemCall_msg cli_pid 879
Sending select for 192.168.1.100...
Lease of 192.168.1.100 obtained, lease time 7200
deleting routers
route: SIOCDELRT: No such process
adding dns 192.168.1.1
[12-31-12:00:22][TRACE][main] system udhcpc -n return 0,g_bkill_dhcp=0
[12-31-12:00:22][TRACE][main] 1.Get Network IP :192.168.1.100
[12-31-12:00:22][TRACE][main] 1.Get NetMask IP :255.255.255.0
[12-31-12:00:22][TRACE][main] 1.Get Gateway IP :192.168.1.1
[12-31-12:00:22][TRACE][main] Get DNSServer IP :192.168.1.1
[12-31-12:00:22][TRACE][dms_alarmproces] jb_set_wdt_timeout cur_margin is 1
[12-31-12:00:22][ERR][dms_alarmproces] jbalarmpro.c(689) - 0 , Success
[12-31-12:00:22][TRACE][main] @@@@@@@@@ port=80
Thttpd Module Build:Oct 31 2014 11:33:27
[12-31-12:00:22][TRACE][main] g_iconv = 34512352!
thttpd_start port:80
[12-31-12:00:22][TRACE][main] p1=IPCAM, size1 = 5!
[12-31-12:00:22][TRACE][main] p2=IPCAM, size2 = 1018!
[12-31-12:00:22][TRACE][main] timer:0,outputbytes:105,writebytes:105,totalbytes:105!
[12-31-12:00:22][TRACE][main] <!--
var vPort = 8200;
var vUPnPPort = 8200;
var vDevIP = "192.168.1.100";
var ServerName = "IPCAM";
[12-31-12:00:22][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbsysinit.c, 117
@@@@@@@@@@DDNSServer_Start 16 DDNS START!!!!!!!!
[12-31-12:00:23][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1303
NewDDNSSetting.stDDNS[0].nUpdateTime=0!
[12-31-12:00:23][TRACE][main] ================== thread JB_MailSend_Thread pthread_self 1222706368 getpid() 768
nSleepCount=60!
[12-31-12:00:23][TRACE][MailSend] Send Email Thread Begin Run.
[12-31-12:00:23][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1076
[12-31-12:00:23][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT jbnet.c, 1166(port:8200)
VS_BUF Module Build:May 22 2014 13:55:25
[12-31-12:00:23][TRACE][main] ================== thread TcpListenNatThread pthread_self 1233421504 getpid() 768
[12-31-12:00:23][TRACE][TcpListenNatThr] TcpListenNatThread Thread Start.
[12-31-12:00:23][TRACE][UdpSend] ================== thread UdpSendThread pthread_self 1241842880 getpid() 768
[12-31-12:00:23][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1271858368 getpid() 768
[12-31-12:00:23][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1280320704 getpid() 768
[12-31-12:00:23][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1288815808 getpid() 768
[12-31-12:00:23][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1254683840 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpMsgQuitThread pthread_self 1297441984 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpDataSendThread pthread_self 1305941184 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpDataSendThread pthread_self 1314858176 getpid() 768
PresetManage_Load: fopen failed:/jb_config/jb_rootfs/channel0_preset.config!
CruiseManage_Load: fopen failed:/jb_config/jb_rootfs/channel0_cruise.config!
ptzmng_control 25, dwCommand=13,dwParam=0
Call point:0, speed:0
[12-31-12:00:23][TRACE][main] ================== thread TcpDataSendThread pthread_self 1324188864 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpDataSendThread pthread_self 1332798656 getpid() 768
[12-31-12:00:23][ERR][main] ================== thread TcpMsgRecvThread pthread_self 1263219904 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpDataSendThread pthread_self 1342207168 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread ListenThread pthread_self 1368569024 getpid() 768
0x00 0x00 0x00 0x01 0x67 0x4d 0x00 0x1f 0x95 0xa8 0x14 0x01 0x6e 0x40
profile_level_id : 4d001f !
0x00 0x00 0x00 0x01 0x68 0xee 0x3c 0x80
[12-31-12:00:23][TRACE][main] ================== thread UdpPortListenThread pthread_self 1359992000 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread TcpDataQuitThread pthread_self 1351337152 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread JB_AVCaptureThread pthread_self 1377375424 getpid() 768
[12-31-12:00:23][TRACE][AVCapture] ================== thread JB_AVCaptureThread pthread_self 1377375424 getpid() 768
[12-31-12:00:23][TRACE][AVCapture] ============================ JB_AVCaptureThread(1:1:0)
[12-31-12:00:23][TRACE][main] jb debug : create audio encoder[0] thread ok
[12-31-12:00:23][TRACE][main] ================== thread JB_AEncFrameThread pthread_self 1386570944 getpid() 768
[12-31-12:00:23][TRACE][main] ########## JB_AEncFrameThread aenc_chn = 0
0x00 0x00 0x00 0x01 0x06 0xe5 0x01 0xf7 0x80
SPS len:10, PPS len:4, SEL len:5
SPS BASE64 value:Z00AH5WoFAFuQA==
SPS_PPS_BASE64 value:type:0,Z00AH5WoFAFuQA==,aO48gA==
SPS_PPS_BASE64 len:type:0,25
0x00 0x00 0x00 0x01 0x67 0x4d 0x00 0x1e 0x95 0xa8 0x28 0x0b 0xfe 0x54
profile_level_id : 4d001e !
0x00 0x00 0x00 0x01 0x06 0xe5 0x01 0xd9 0x80
SPS BASE64 value:Z00AHpWoKAv+VA==
SPS_PPS_BASE64 value:type:1,Z00AHpWoKAv+VA==,aO48gA==
SPS_PPS_BASE64 len:type:1,25
[12-31-12:00:23][TRACE][main] JB_Wireless_Wifi_Start,wifi dev product id:2
[12-31-12:00:23][TRACE][main] fun:load_drivers line:1060,unsupport device:2!
Hd_mng Module Build:Oct 20 2014 15:25:22
[12-31-12:00:23][TRACE][ARP] ================== thread start_arp pthread_self 1423021248 getpid() 768
[12-31-12:00:23][TRACE][ARP] TTTTTTTTTTTTTTTTTTTTTTTTTT eth0 192.168.1.100 192.168.1.100 jbarping.c, 119
[12-31-12:00:23][TRACE][main] ================== thread jb_upnp_thread pthread_self 1413895360 getpid() 768
[12-31-12:00:23][TRACE][main] ================== thread wifiDaemon pthread_self 1405412544 getpid() 768
[12-31-12:00:23][TRACE][main] dms_sysnetapi_inter_start(78) ########## Config nPlatManufacture(3) != ln nPlatManufacture(0) buff:lrwxrwxrwx 1 root root 34 Dec 31 12:00 /usr/lib/libnetpt.so -> /usr/netview/app/lib/libnetpt.so.3
libmt version: v0.4build20090319-1732
HI_MT_Init: g_pMTConfig->rtspsvr.listen_port=554!
s32ValidChnNum:3,u32TotalUserNum=6!
src/hi_buf_abstract/hi_buffer_abstract.c:HI_BufAbstract_Init(166)-LIVE_MODE_1CHN1USER-success
Hi_mtrans Module Build:Sep 29 2014 17:12:22
MTRANS Init:conn num=6 minport-maxport=6000-7000,pack len=1452.
Start HI_VOD_Init.vod Successed.
HI_MT_StartSvr: g_pMTConfig->rtspsvr.listen_port=554!
rtsp listen port: 554!
open file error
RTSP Live svr Init ok.
Start MediaTrans.rtsp_streamsvr Successed.
[12-31-12:00:23][ERR][main] Get stat on /usr/netview/app/lib/libnetpt.so.0 Error:No such file or directory
[12-31-12:00:23][TRACE][main] [lg][APP]: initSystem OK!
[12-31-12:00:23][TRACE][main] MTMNT Init cfg chnid 11 , max connect num 2, bufsize 0,wChannelNum:1
[12-31-12:00:23][TRACE][main] the live mode is:0
rtsp_o_http Live svr Init ok.
RtspOhttp init Successeful!.
HI_ICGI_Register_Proc(62): Register rtsp process function.
[12-31-12:00:23][TRACE][main] !!!!!!########### onvif_discover dwWebPort:80 dwServerVersion:67116582 !!!!!!!!!!!
Onvif discovery server Module Build:Nov 7 2014 10:12:19
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:21
[12-31-12:00:23][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0xcdbbc
HI_ICGI_Register_Proc(62): Register onvif process function.
Onvif Module Build:Nov 5 2014 11:42:26
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:6
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:17
=============== Entry lib_xmai_start Dec 3 2014 15:02:57
[12-31-12:00:23][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x555f28
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:23
HI_ICGI_Register_Proc(62): Register cgi process function.
[12-31-12:00:23][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x53ba08
!!!!!!!!!!!init_cgi sucessful end !!!!!!!!!!!!!!!!!!
############# REC_Init (Dec 2 2014 15:17:50) #############
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:10
check record...
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:26
<line:70 fun:mobile_OWSP_Start [mobile]> OWSP Server(mobile) Port:0
<line:37 fun:MobileServer_Start [mobile]> MobileServer_Start Success
[12-31-12:00:23][TRACE][main] szServer: .!
p2p_server_int pdevicename = . openp2pflag = 1
p2p_server_int pusername = admin ppassword = admin
IOTC_Initialize VERSION[10A0800]...
IOTC_Get_Version version = 10a0800 avversion = 1040400
Leave REC_StopAllRecord
[12-31-12:00:23][TRACE][dms_alarmproces] file(jbalarmpro.c), line(692) fatal this system will restart !!!
[12-31-12:00:23][TRACE][dms_alarmproces] this system will be restarted now !!!
[12-31-12:00:23][ERR][dms_alarmproces] jbalarmpro.c(689) - 0 , Success
ANTS_SERVER Module Build:Dec 4 2014 15:20:51
[12-31-12:00:23][TRACE][main] dms_sysnetapi_open successed handle:flag:20
[12-31-12:00:23][TRACE][main] DMS_NET_REG_ALARMCALLBACK Param:0x40c038
[ANTS][./src/libants.cpp:00002942:antsNetServiceStart] Initialize Begin
[I8-SERVER] [src/AntsServerSDK.cpp
ANTS_SERVER_Initialize] Call Begin
FUN:gfxGetParameterLINE:1229 ANTS_MID_GET_DEVICECFG
[I8-SERVER] [src/AntsServer.cpp:00000547:StartThread] Create MainThread Handle 0x60a054c0
[I8-SERVER] [src/AntsServer.cpp:00000548:StartThread] Create HeartThread Handle 0x612614c0
[I8-SERVER] [src/AntsSVRBroadCastSession.cpp:47:CSVRBroadCastSession] BroadCast RecvPort[10000] SendPort[20000]
[I8-SERVER] [src/AntsSVRBroadCastSession.cpp:54:CSVRBroadCastSession] Create BroadCastThread [0x61a974c0]
ANTS_SERVER_Initialize] Create AlarmThread 0x623174c0
ANTS_SERVER_Initialize] Call End
[ANTS][./src/libants.cpp:00002944:antsNetServiceStart] Initialize
[ANTS][./src/libants.cpp:00002945:antsNetServiceStart] Initialize End
0 MiB
In: serial
Out: serial
Err: serial
done
hisilicon # reset
resetting ...
0 MiB
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
▒0▒▒=▒▒▒
▒▒tڨD▒▒]
"DeviceID": 0,
"RecordLen": 5,
"Language": 1,
"RecycleRecord": 1,
"VideoStandard": 0,
"DateFormat": 1,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"PanelVersion": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
Sending discover...
Sending discover...
deleting routers
var vPort = 8200;
nSleepCount=60!
open file error
check record...
- Fluffykrsk
Что за камера вообще? Может дамп на неё есть у кого. Напишите хоть модель...
Судя по логу запуск практически нормальный теперь. Нет некоторых конфигов и камера не создаёт их что ли.. Если найду где-то эти конфиги,то добавлю, а иначе - искать похожую для образца.
модель IH10A ONVIF
1mp
продавец уже с дулся,могу фото выложить.
На плате HI1358E-9712-AN указано.
						1mp
dede,спасибо за желание помочь,если не получится восстановить родную прошивку,я бы рискнул залить чужую прошивку от XM, например, под аналогичное железо.
А в веб вообще можно попасть с каким-либо конфигом? Чтобы потом сделать сброс на заводские.
Апдейт прошивки у меня есть, но способов запуска я не знаю, разве что в вебе будет выбор файла..
Я допустил ошибку при формировании образа... вот этот конфиг должен быть рабочим на 98% https://dropmefiles.com/kk1MQ" onclick="window.open(this.href);return false;
добрый день,вот когда вы прислали самый первый конфиг,тогда камера соглашалась на своей проге делать почти все, в том числе и обновление прошивки,а во всех более поздних - только видется в сети.Сегодня вечером залью последний вариант и отпишусь.
dede,вот залил 3 вариант конфига.Камера стабильно появилась в сети,позволяет менять любые настройки,сбрасывал на заводские - изображение не появилось.Есть возможность обновить прошивку хоть через веб морду,хоть через родную прогу. Выкладываю лог (залил 3 вариант и перегрузился)
0 MiB
In: serial
Out: serial
Err: serial
CheckUpgrade invalid maigc(0xc6c63a3a, 0xaa5555aa)
OK
Starting kernel ...
Machine: hi3518
TCP reno registered
brd: module loaded
loop: module loaded
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
himii: probed
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
[END]
[END]
jffs2_scan_dirent_node(): Node CRC failed on node at 0x0000000c: Read 0x3c308060, calculated 0x61341ac0
jffs2_scan_eraseblock(): Node at 0x00000040 {0x1985, 0xe002, 0x00000082) has invalid CRC 0x525c0094 (calculated 0xcbd14ac7)
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000044: 0x0082 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000048: 0x0094 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000004c: 0x0002 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000050: 0x0001 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000054: 0x81a4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000058: 0x03e8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000060: 0x1064 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000064: 0x1064 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000068: 0x1064 instead
Further such events for this erase block will not be printed
Set GPIO9_0
[END]
Set GPIO9_1
[END]
Set GPIO9_4
[END]
Set GPIO5_3
[END]
Set GPIO0_1
[END]
Set GPIO0_2
[END]
Set GPIO0_7
[END]
Set GPIO0_3
[END]
Set GPIO0_4
[END]
[END]
[END]
[END]
ISP Mod init!
load vda.ko ....OK!
acodec inited!
insert audio
no ic ack
read log config ok
(none) login: [01-01-06:00:12][TRACE][JB_HI3511_DVS.o] SYSTEMLOG Init
[01-01-06:00:12][TRACE][JB_HI3511_DVS.o] ========== HI3518 PLATFORM APP V4 Build:Dec 4 2014 15:24:02 pid:768 ==============
[01-01-06:00:12][TRACE][JB_HI3511_DVS.o] MIAN APP Build:Dec 4 2014 15:24:02
[01-01-06:00:12][TRACE][main] ========== HI3518 PLATFORM BAICMODULE Build:Dec 4 2014 15:23:08 ==============
wait write ack ok timeout--4097!
[error -- File: ic_at0104.c, Line: 403, Function: CheckIsOnline] Check Is Online Failed Return 0
[01-01-06:00:36][TRACE][main] check_encrypt err .............................................(-1)
[01-01-06:00:36][TRACE][main] MAC [0x0:0xaa:0x1d:0x98:0xa3:0x2a]
[01-01-06:00:36][WARNING][main] [jiabo video][APP]: chek encrypt chip fail!
[01-01-06:00:36][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 78
[01-01-06:00:36][TRACE][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs485 ok
[01-01-06:00:36][TRACE][main] dev_tty.c:65 [DMS_DEV_TTY_Open] [01-01-06:00:36][TRACE][main] TTY open /dev/ttyAMA3 failed:No such device or address
[01-01-06:00:36][TRACE][main] TTTTTTTTTTTTTTTTTTTTTTTTTT basic_tty.c, 120
[01-01-06:00:36][WARNING][main] ##jiabo video: +++++++++++++++++++++++++++++++++ open rs232 fail
[01-01-06:00:36][TRACE][main] open /dev/hi_i2c(m_i2cfd=5) success!
[01-01-06:00:36][TRACE][main] open /dev/hi_gpio(m_gpiofd=6) success!
[01-01-06:00:36][ERR][main] can't open mt9d131
[01-01-06:00:36][ERR][main] can't open ov10630
[01-01-06:00:36][ERR][main] can't open ip2986
[01-01-06:00:36][ERR][main] DMS_TW9910_VAD_Open Failed!
[01-01-06:00:36][ERR][main] can't open xf_ov2715
[01-01-06:00:36][ERR][main] can't open nvp2400
[01-01-06:00:36][TRACE][main] Check OV9712-iRet = 0,value = 0x9711!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_Open: szBuffer = sensortype=ovb9712,m_nHi3518VIChip = 30!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_Open-318: s32Ret=0x00000000,u32ChipId=0x3518E100!
[01-01-06:00:36][TRACE][main] :::::::::::::::::: VICHIP HI3518 OV9712B
[01-01-06:00:36][ERR][main] DMS_TW2866_VAD_Open Failed!
[01-01-06:00:36][TRACE][main] :::::::::::::::::: AICHIP JB_TLV320
[01-01-06:00:36][TRACE][main] nChannelNum [1], nKeyCheckRes [1]
[01-01-06:00:36][TRACE][main] end of free..
[01-01-06:00:36][TRACE][main] globelMalloc ChannelCount:1
[01-01-06:00:36][TRACE][main] end of malloc..
[01-01-06:00:36][ERR][main] InitDefaultConfigFile: File(/jb_config/jb_rootfs/jb_default.config) is exist!
[01-01-06:00:36][TRACE][main] +++++++++==========++++++ g_fatal_param.default_flag = 181
[01-01-06:00:36][TRACE][main] +++++++++==========+++++ g_fatal_param.fatal_param_len = 12
[01-01-06:00:36][TRACE][main] [3]: initialize the system parameter with value.
"DeviceID": 0,
"RecordLen": 10,
"Language": 0,
"RecycleRecord": 1,
"VideoStandard": 1,
"DateFormat": 0,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"PanelVersion": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"SerialNumber": "",
"SysFlags": 1,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
[01-01-06:00:36][TRACE][main] jiabo video startup watchdog ok
[01-01-06:00:36][TRACE][main] jb_set_wdt_timeout cur_margin is 3c
[01-01-06:00:36][TRACE][main] jb_get_wdt_timeout cur_margin is 3c
[01-01-06:00:36][TRACE][main] uiSensor=30
[01-01-06:00:36][TRACE][main] JB_Check_Sensor_Type: nCurVIChip=30,nLastViChip=30!
[01-01-06:00:36][TRACE][main] 1.wWidth1 = 1280, wHeight1 = 720!
[01-01-06:00:36][TRACE][main] 2.wWidth1 = 1280, wHeight1 = 720!
[01-01-06:00:36][TRACE][main] [DMS_DEV_GPIO_Init ,540]: 1.0--GPIO_I2C_GetDir nDevAddr:2 nRegAddr:2 nvalue:0
[01-01-06:00:36][TRACE][main] baud is 2400
[01-01-06:00:36][TRACE][main] [lg][APP]: Start up tty OK!
[01-01-06:00:36][TRACE][main] Entry JB_initCodec
[01-01-06:00:36][TRACE][tty] ================== Entry thread detectTtyThread pthread_self 1086239936 getpid() 768
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_init 505: m_nHi3518VIChip = 30!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_init 506: stImageAttr.u16Width = 1280!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_init 507: stImageAttr.u16Height = 720!
[01-01-06:00:36][TRACE][main] DMS_Vadc_OV9712B_ISP_Init: stIspAeAttr.bByPassAE = 0!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_ISP_OV9712_Init Success!
[01-01-06:00:36][TRACE][main] DMS_vadc_hi3518_init: init success!
[01-01-06:00:36][TRACE][main] maxChNum=1, mode=1, enDeviceType=0
[01-01-06:00:36][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:117 VideoOsdInit....
[01-01-06:00:36][TRACE][main] FILE:HI3511Osd.c FUNCTION:VideoOsdInit LINE:165 VideoOsdInit...ok
[01-01-06:00:36][TRACE][main] EnableVi ViDevId:0, ViChn:0
[01-01-06:00:36][TRACE][main] EnableVi stCapSize u32Width:1280, u32Height:720
[01-01-06:00:36][TRACE][main] EnableVi stDestSize u32Width:1280, u32Height:720
[01-01-06:00:37][TRACE][main] bit_rate:3072,framerate:25,Quality:0,gop_size:50,RateType:1
[01-01-06:00:37][TRACE][main] InitVenc VpssGrp:0 VpssChn:0 VeGrpChn:0 VeChn:0
[01-01-06:00:37][TRACE][main] InitVenc encode stream 0:0 format is 6 u32BitRate:3072
[01-01-06:00:37][TRACE][main] Enable Encode VeGroup:0 VeChn:0 ViDev:0 ViChn:0
[01-01-06:00:37][TRACE][main] DMS_Enable_Encode OK!!!!!!!!!!!!!!!!
[01-01-06:00:37][TRACE][main] bit_rate:512,framerate:9,Quality:0,gop_size:50,RateType:1
[01-01-06:00:37][TRACE][main] InitVenc VpssGrp:0 VpssChn:1 VeGrpChn:1 VeChn:1
[01-01-06:00:37][TRACE][main] InitVenc encode stream 0:1 format is 15 u32BitRate:512
[01-01-06:00:37][TRACE][main] Enable Encode VeGroup:1 VeChn:1 ViDev:0 ViChn:1
[01-01-06:00:37][TRACE][main] jb_init_venc DMS_SECOND_STREAM OK ##################
[01-01-06:00:37][TRACE][main] MD chinnel 0 OK
[01-01-06:00:37][TRACE][main] init_hi_video_mask[0]: bshow(0),start_x(0), start_y(0), width(0), hight(0)
[01-01-06:00:37][TRACE][main] DMS_Video_Mask-hiVencWidth=1280, hiVencHeight=720!
[01-01-06:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:ShowVideoOsd_Time LINE:1008 ShowVideoOsd_Time...chn=0, type=0...
[01-01-06:00:37][TRACE][main] xoffset=18,yoffset=12,w=304,h=32!
[01-01-06:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:OsdCreateRegion LINE:2699 OsdCreateRegion chngroup 0:index(0),handle(0)
[01-01-06:00:37][TRACE][main] main group is 0 sub is 1
[01-01-06:00:37][TRACE][main] SUB setosd
[01-01-06:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:ShowVideoOsd_Time LINE:1008 ShowVideoOsd_Time...chn=0, type=1...
[01-01-06:00:37][TRACE][main] xoffset=9,yoffset=6,w=304,h=32!
[01-01-06:00:37][TRACE][main] FILE:HI3511Osd.c FUNCTION:OsdCreateRegion LINE:2699 OsdCreateRegion chngroup 1:index(0),handle(8)
[01-01-06:00:37][TRACE][main] JB_Video_Update_OSD--pInfo->dwChannel=0!
[01-01-06:00:37][TRACE][main] pInfo->stOsd[0].bOsdEnable = 0!
[01-01-06:00:37][TRACE][main] pInfo->stOsd[1].bOsdEnable = 0!
[01-01-06:00:37][TRACE][main] pInfo->stOsd[2].bOsdEnable = 0!
[01-01-06:00:37][TRACE][main] pInfo->stOsd[3].bOsdEnable = 0!
[01-01-06:00:37][TRACE][main] pInfo->stOsd[4].bOsdEnable = 0!
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00400000 nVal:0
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetAIAttr val:0
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000001 nVal:50
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000002 nVal:50
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000004 nVal:128
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000008 nVal:50
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000200 nVal:128
[01-01-06:00:37][TRACE][main] stSharpenAttr.bEnable=1,stSharpenAttr.bManualEnable=0!
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000800 nVal:1
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetDenoiseAttr bEnable:1
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00001000 nVal:44
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetDenoiseAttr u8ThreshTarget:44
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000020 nVal:128
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetAWBAttr u8RGStrength:128
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000040 nVal:128
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetAWBAttr u8BGStrength:128
[01-01-06:00:37][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00004000 nVal:1
[01-01-06:00:37][TRACE][main] HI_MPI_ISP_SetMEAttr u32ExpLine:1
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00010000 nVal:1
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00020000 nVal:8
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00040000 nVal:0
[01-01-06:00:37][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00080000 nVal:0
[01-01-06:00:37][TRACE][main] DMS_vadc_hi3518_DNSet enDNAction:0 bManul:0 WaitDNAction:2, tNow:37 LastDNActionTime:0
[01-01-06:00:37][TRACE][main] DMS_DEV_GPIO_SetIRCutState_Ex-986: nDay=0!
[01-01-06:00:38][TRACE][main] Set ircut to day mode!
[01-01-06:00:38][ERR][main] DMS_Vadc_OV9712B_ISP_SetColor(1224) not support cmd:256
[01-01-06:00:38][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00100000 nVal:0
[01-01-06:00:38][TRACE][main] vadc_ov9712.c: DMS_Vadc_OV9712B_ISP_SetColor nCmd:0x00000400 nVal:0
[01-01-06:00:38][TRACE][main] jb_start_adec--wType=19!
[01-01-06:00:39][TRACE][main] jb_start_aenc--wType=19!
[01-01-06:00:39][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_AI_Init @@@@@@@@@
[01-01-06:00:39][TRACE][main] 1_____gain_mic=0x0b!_____
[01-01-06:00:39][TRACE][main] 2_____gain_mic=0x00!_____
[01-01-06:00:39][TRACE][main] @@@@@@@@@@@@@@@@ Hi3518 DMS_Aenc_Init @@@@@@@@@
[01-01-06:00:39][TRACE][main] Befor JB_Video_jpegThread_Initial
[01-01-06:00:39][TRACE][main] JB_Video_jpegThread_Initial create JB_Video_jpegThread
[01-01-06:00:39][TRACE][main] Leave JB_initCodec
[01-01-06:00:39][TRACE][main] jiabo video startup rtc ok
[01-01-06:00:40][TRACE][main] ================== thread JB_Video_jpegThread pthread_self 1134372032 getpid() 768
[01-01-06:00:40][TRACE][main] ================== thread JB_Video_Auto_jpegThread pthread_self 1142904000 getpid() 768
[01-01-06:00:40][TRACE][JpegSnap] ................... Entry Video_jpegThread
[01-01-06:00:40][TRACE][main] DMS_InsertLog
[01-01-06:00:40][TRACE][main] PRODUCT_IP_SET-DEFAULT-1!
[01-01-06:00:40][TRACE][dms_alarmproces] ================== thread dms_alarmprocess_thread pthread_self 1168594112 getpid() 768
[01-01-06:00:40][TRACE][main] ================== thread JB_Alarm_Thread pthread_self 1159791808 getpid() 768
[01-01-06:00:40][TRACE][dms_exceptalarm] ================== thread dms_exceptalarmprocess_thread pthread_self 1177236672 getpid() 768
[01-01-06:00:40][TRACE][JpegSnap] InitVenc VpssGrp:0 VpssChn:0 VeGrpChn:3 VeChn:3
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.bByFrame = 1
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.bVIField = 0
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.u32BufSize = 1382400
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.u32Priority = 1
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.u32PicWidth = 1280
[01-01-06:00:40][TRACE][JpegSnap] stJpegAttr.u32PicHeight = 720
[01-01-06:00:40][TRACE][JpegSnap] Enable Encode VeGroup:3 VeChn:3 ViDev:0 ViChn:0
[01-01-06:00:40][TRACE][JpegSnap] DMS_Enable_Encode OK!!!!!!!!!!!!!!!!
[01-01-06:00:40][TRACE][JpegSnap] Get-stJpegParam.u32Qfactor = 90!
[01-01-06:00:40][TRACE][JpegSnap] Set-u32Quality[2] = 80!
[01-01-06:00:40][TRACE][JpegSnap] ShowSnapVideoOsd VeGrpChn:3
[01-01-06:00:40][TRACE][main] NAME-DEFAULT--1!
[01-01-06:00:40][TRACE][JpegSnap] FILE:HI3511Osd.c FUNCTION:ShowSnapVideoOsd LINE:2542 Put bitmap to region 0 failed while displaying 0xa0128003
[01-01-06:00:40][TRACE][JpegSnap] ShowSnapVideoOsd--OK
[01-01-06:00:40][TRACE][JpegSnap] ShowSnapVideo_Text--OK
[01-01-06:00:40][TRACE][main] cmd = ifconfig eth0 hw ether 00:aa:1d:98:a3:2a!
[01-01-06:00:40][TRACE][JpegSnap] DMS VENC SNAPSHOT len:198291
[01-01-06:00:40][TRACE][JpegSnap] DeleteSnapVideo_Text--OK
[01-01-06:00:40][TRACE][JpegSnap] DeleteSnapVideoOsd--OK
[01-01-06:00:40][TRACE][JpegSnap] Video Jpeg Snap toclientMsg->nID [0] nChannel:0 nErrorCode:7 nCommand:536870921
[01-01-06:00:40][TRACE][snap_process_th] snap_process_thread 206, start procADDRCONF(NETDEV_UP): eth0: link is not ready
ess data.SnapTarget:0x8,g_snapnum:1
[01-01-06:00:40][TRACE][main] set_net_phyaddr cmd [ifconfig eth0 hw ether 00:aa:1d:98:a3:2a]
[01-01-06:00:40][ERR][snap_process_th] jbnet.c(520) - 0 , Success
Sending discover...
[01-01-06:00:41][TRACE][main] ================== thread sysTimeThread pthread_self 1151321280 getpid() 768
[01-01-06:00:42][TRACE][sysTime] dhcp_tick=1!
SYS_GetLocalCurPts hi_sched_clock error u64TimeNow=1285090,u64TimeLast=42940962380
[01-01-06:00:43][TRACE][sysTime] dhcp_tick=2!
Sending discover...
[01-01-06:00:44][TRACE][sysTime] dhcp_tick=3!
[01-01-06:00:45][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:45][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:45][TRACE][sysTime] dhcp_tick=4!
[01-01-06:00:46][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:46][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:46][TRACE][sysTime] dhcp_tick=5!
Sending discover...
[01-01-06:00:47][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:47][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:47][TRACE][sysTime] dhcp_tick=6!
[01-01-06:00:48][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:48][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:48][TRACE][sysTime] dhcp_tick=7!
[01-01-06:00:49][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:49][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:49][TRACE][sysTime] dhcp_tick=8!
[01-01-06:00:50][ERR][AlarmMng] jbnet.c(520) - 0 , Success
[01-01-06:00:50][ERR][AlarmMng] jbalarmpro.c(88) - 0 , Success
[01-01-06:00:50][TRACE][sysTime] dhcp_tick=9!
						U-Boot 2010.06 (May 19 2014 - 14:51:10)
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
In: serial
Out: serial
Err: serial
UpgradeSoftware:8346B000 V1.2
Image Name: Linux-3.0.8
Data Size: 2890856 Bytes = 2.8 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (pub@BVT-SDK-SERVER3) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Tue Mar 11 17:36:34 HKT 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 200000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10160
Kernel command line: mem=40M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:1M(boot),3M(kernel),11776K(rootfs),512K(config)
Memory: 40MB = 40MB total
Memory: 35088k/35088k available, 5872k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc3000000 - 0xfe000000 ( 944 MB)
lowmem : 0xc0000000 - 0xc2800000 ( 40 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc0513000 (5032 kB)
.data : 0xc0514000 - 0xc0537fa0 ( 144 kB)
.bss : 0xc0537fc4 - 0xc0555240 ( 117 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.16)
msgmni has been set to 68
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000f80000 : "rootfs"
0x000000f80000-0x000001000000 : "config"
Fixed MDIO Bus: probed
himii: probed
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
▒VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 132K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (510): /proc/510/oom_adj is deprecated, please use /proc/510/oom_score_adj instead.
[RCS]: /etc/init.d/S10mpp
/etc/init.d/S10mpp: line 15: set_path_before: not found
/etc/init.d/S10mpp: line 16: set_path_before: not found
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20090030: 0x00000300 --> 0x00004F01
[END]
0x2005003c: 0x000001E0 --> 0x000001E2
[END]
----Sensor Type: ovb9712 ----
Set GPIO9_0
0x200F00C8: 0x00000001 --> 0x00000001
[END]
Set GPIO9_1
0x200F00CC: 0x00000001 --> 0x00000001
[END]
Set GPIO9_4
0x200F00D8: 0x00000001 --> 0x00000001
[END]
Set GPIO5_3
0x200F00C0: 0x00000001 --> 0x00000000
[END]
Set GPIO0_1
0x200F0124: 0x00000000 --> 0x00000000
[END]
Set GPIO0_2
0x200F0128: 0x00000000 --> 0x00000000
[END]
Set GPIO0_7
0x200F013C: 0x00000000 --> 0x00000001
[END]
Set GPIO0_3
0x200F012C: 0x00000000 --> 0x00000000
[END]
Set GPIO0_4
0x200F0130: 0x00000000 --> 0x00000000
[END]
0x200f0138: 0x00000001 --> 0x00000000
[END]
0x20140400: 0x00000020 --> 0x00000061
[END]
0x20140100: 0x00000040 --> 0x00000040
[END]
hi3518_base: module license 'Proprietary' taints kernel.
pa:82800000, va:c3200000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok! add for 24c04
gpio_0_base_addr_virtual:0xc3500000 !
Set Gpio0_6 dir to 1!
Set Gpio0_6 bit to 0!
Set Gpio0_6 bit to 1!
hi_gpio_init_hrtimer!
insmod: can't insert 'extdrv/ssp_ad9020.ko': No such file or directory
acodec inited!
insert audio
==== Your input Sensor type is ovb9712 ====
entry jb_hi_authen0104_init
DMS_Read0104Data failed
no ic ack
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 1, nodeamon= 0)
ln: /usr/lib/libnetpt.so: File exists
read log config ok
[RCS]: /etc/init.d/S80network
"DeviceID": 0,
"RecordLen": 10,
"Language": 0,
"RecycleRecord": 1,
"VideoStandard": 1,
"DateFormat": 0,
"DateSprtr": 1,
"TimeFmt": 0,
"ConfigWizard": 0,
"PanelVersion": 0,
"WebVersion": 0,
"WebBuildDate": 0,
"SerialNumber": "",
"SysFlags": 1,
"VideoInNum": 1,
"AudioInNum": 1,
"AlarmInNum": 1,
"AlarmOutNum": 1,
"DiskNum": 0,
"RS232Num": 0,
"RS485Num": 0,
"DecordChans": 0,
"VGANum": 0,
"USBNum": 0,
"DiskCtrlNum": 0,
"AuxOutNum": 0,
"StreamNum": 0
Sending discover...
Sending discover...
Sending discover...
Re: не позволяет очистеть раздел "config" камера Hi3518C
Вы говорили, что в настройках видно видео, я так понимаю, там, где настраивается датчик движения и тд, мини-превьюшки были. Сейчас они есть?
