nvr n7932F hi3535 помогите найти прошивку
fobos
Re: nvr n7932F hi3535 помогите найти прошивку
Сообщение fobos » 03 авг 2017, 23:51
покажите help и printenv
OpLpEpG
Сообщение OpLpEpG » 07 авг 2017, 06:50
Начало загрузки, видно что сеть мертва
Код: Выделить всё
U-Boot 2010.06-svn344 (Jan 21 2016 - 18:23:38)
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
Set lock level: 3, start of bottom address
Spi is locked. lock address[0x0 => 0x40000]
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NOFOUND PHY
PHY not link!
Press CTRL-C to abort autoboot in 0 secondshisilicon # <INTERRUPT>
help
Код: Выделить всё
hisilicon # help
?       - alias for 'help'
base    - print or set address offset
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
ddr     - ddr training function
decjpg  - jpgd   - decode jpeg picture.
fatls   - list files in a directory (default /)
fload   - fload  - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
go      - start application at address 'addr'
help    - print command description/usage
lip     - lip      - set local ip address but not save to flash
lload   - lload  - load logo file
loadb   - load binary file over serial line (kermit mode)
loady   - load binary file over serial line (ymodem mode)
logoload- logoload  - load binary file from a filesystem image for system boot
loop    - infinite loop on address range
mac     - mac      - set mac address and save to flash
md      - memory display
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
setenv  - set environment variables
setvobg - setvobg   - set vo backgroud color.
        - setvobg [dev color]
sf      - SPI flash sub-system
sip     - sip      - set server ip address but not save to flash
startgx - startgx   - open graphics layer.
        - startgx [layer addr stride x y w h]
startvo - startvo   - open interface of vo device.
        - startvo [dev type sync]
stopgx  - stopgx   - close graphics layer.
        - stopgx [layer]
stopvo  - stopvo   - close interface of vo device.
        - stopvo [dev]
tftp    - tftp  - download or upload image via network using TFTP protocol
usb     - USB sub-system
printenv
Код: Выделить всё
hisilicon # printenv
bootcmd=sf probe 0;sf read 84000000 f20000 20000;logoload 0x84000000;decjpg;sf read 84000000 50000 4A0000;fload 84000000;bootm 0x82000000
baudrate=115200
bootfile="uImage"
restore=1
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=180M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=cramfs mtdparts=hi_sfc:320K(boot),4736K(romfs),5824K(usr),1536K(web),3072K(custom),128K(logo),768K(mtd)
appVideoStandard=PAL
appSystemLanguage=Russian
bootdelay=5
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn344 (Jan 21 2016 - 18:23:38)
Environment size: 1358/65532 bytes
hisilicon #
ping
Код: Выделить всё
hisilicon # ping 8.8.8.8
miiphy_register: non unique device name '0:2'
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NULL device name!
NOFOUND PHY
PHY not link!
ping failed; host 8.8.8.8 is not alive
hisilicon #
Сообщение dede » 07 авг 2017, 07:26
ну попробуйте как вы написали, через fatload, только ".bin" файл с прошивкой сразу скормить, скорее всего, нельзя. Нужно распаковать и каждый файл отдельно.
Потом еще env нужно почистить будет, если прошивка не поможет и конфиг почистить.
В bootargs mem=180M возможно проблема как раз в этом, поставить поменьше надо
Allpeno
Сообщение Allpeno » 07 авг 2017, 17:41
После отладки, поставил погонять, 2 недели работала отлично.
Тут ураган, вырубили свет, ИБП сколько то протянул и сдох. Включаю, на экране как в первый раз, всё на китайском... Начинаю менять настройки, сохраняю, зависон...!
Снял флешку, на программаторе пытался прошить, пишет ошибка. Короче сдохла флеш! Курю...! :)
fobos
Сообщение fobos » 07 авг 2017, 23:15
что-то не пойму...у Вас же 07.08 в регистраторе флешь определилась корректно? на программаторе ID флеши определяется?...может просто неконтакт в адаптере программатора?
Allpeno
Сообщение Allpeno » 08 авг 2017, 01:20
fobos писал(а):что-то не пойму...у Вас же 07.08 в регистраторе флешь определилась корректно? на программаторе ID флеши определяется?...может просто неконтакт в адаптере программатора?
...если это мне, то не 07.08, а 23.07!
Ошибку выдал в конце записи. Думаю, флеш мудрит с самого начала!
OpLpEpG
Сообщение OpLpEpG » 08 авг 2017, 08:05
dede писал(а):ну попробуйте как вы написали, через fatload, только ".bin" файл с прошивкой сразу скормить, скорее всего, нельзя. Нужно распаковать и каждый файл отдельно.
Так прошивать?
Код: Выделить всё
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
mw.b 0x82000000 ff 1000000;fatload usb 0 0x82000000 update.img;sf probe 0;flwrite
не могу найти хелп по команде flwrite как бы не стереть лишнего
dede писал(а): Потом еще env нужно почистить будет, если прошивка не поможет и конфиг почистить.
Можно ли, без обновления прошивки, из uboot вернуть заводские настройки, или выполнить загрузку с заводскими настройками?
Подробнее бы про то как и что чистить
Сообщение dede » 08 авг 2017, 09:44
Да, так, кроме update.img у вас такого файла явно нету.
fireman
Сообщение fireman » 09 авг 2017, 11:43
dede писал(а):Да, так, кроме update.img у вас такого файла явно нету.
это полный дамп, естественно его нет в стандартной прошивке.
Сообщение dede » 09 авг 2017, 14:39
Это не полный дамп, не вводите в заблуждение
OpLpEpG
Сообщение OpLpEpG » 10 авг 2017, 13:54
Открыл спор с этим продавцом, Китаец надеюсь вышлет качественную версию платы, пока экспериментировать с прошивкой, чисткой не буду, вдруг скажет выслать глючный nvr обратно.
OpLpEpG
Сообщение OpLpEpG » 10 авг 2017, 14:24
Вопрос по этой плате но не совсем по теме из uboot на команду ping имею вот что:
Код: Выделить всё
NULL device name!
NULL device name!
NOFOUND PHY
PHY not link!
hisilicon #
Там стоит Atheros AR8035-A -на ощупь очень горячая, я так понимаю ей хана. Имеет смысл возиться, заказывать её и менять, я к тому какая вероятность того, что сдохла только одна эта микросхема вдруг сдохли порты процессора (USB работает) или что еще.
