Помогите разобраться с ip камерой
Купил ip камеру у китайцев, прошивка карявая, не XM. Проц Hi3518EV200 а вот сенсор непонятно.
Нужна новая прошивка а на что искать, тоже непонятно.
ЛОГ
System startup
U-Boot 2010.06 (Aug 30 2017 - 16:48:06)
Check Flash Memory Controller v100 ... Found
test flag.
SPI Nor(cs 0) ID: 0xc2 0x20 0x17
Block:64KB Chip:8MB Name:"MX25L6436F"
SPI Nor total size: 8MB
Cannot found a valid SPI Nand Device
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
In: serial
Out: serial
Err: serial
8192 KiB hi_fmc at 0:0 is now current device
Image Name: Linux-3.4.35
Data Size: 2069296 Bytes = 2 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Booting Linux on physical CPU 0
Linux version 3.4.35 (root@ubuntu) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #61 Wed Aug 30 18:45:19 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518ev200
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7112
Kernel command line: mem=28M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:384k(boot),2048k(kernel),2560k(rootfs),320k(rom),-(app)
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 28MB = 28MB total
Memory: 24200k/24200k available, 4472k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0xc2000000 - 0xff000000 ( 976 MB)
lowmem : 0xc0000000 - 0xc1c00000 ( 28 MB)
.text : 0xc0008000 - 0xc03a0000 (3680 kB)
.init : 0xc03a0000 - 0xc03bcfc4 ( 116 kB)
.data : 0xc03be000 - 0xc03e46e0 ( 154 kB)
.bss : 0xc03e4704 - 0xc0413c98 ( 190 kB)
NR_IRQS:32
VIC @fe0d0000: id 0x00641190, vendor 0x41
sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms
Calibrating delay loop... 269.10 BogoMIPS (lpj=1345536)
Initializing cgroup subsys freezer
Setting up static identity map for 0x802b9a88 - 0x802b9ae0
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 30) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 25) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
hi-spi-master hi-spi-master.0: with 1 chip select slaves attached
hi-spi-master hi-spi-master.1: with 2 chip select slaves attached
Switching to clocksource timer0
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 47
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
Check Flash Memory Controller v100 ... Found.
5 cmdlinepart partitions found on MTD device hi_sfc
Creating 5 MTD partitions on "hi_sfc":
0x000000000000-0x000000060000 : "boot"
0x000000060000-0x000000260000 : "kernel"
0x000000260000-0x0000004e0000 : "rootfs"
0x0000004e0000-0x000000530000 : "rom"
0x000000530000-0x000000800000 : "app"
SPI Nand ID Table Version 2.2
himii: probed
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
dwc_otg: version 3.00a 10-AUG-2012
Core Release: 3.10a
Setting default values for core params
Using Buffer DMA mode
Periodic Transfer Interrupt Enhancement - disabled
Multiprocessor Interrupt Enhancement - disabled
OTG VER PARAM: 0, OTG VER FLAG: 0
Dedicated Tx FIFOs mode
i2c /dev entries driver
hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed!
hisi_i2c hisi_i2c.1: Hisilicon [i2c-1] probed!
hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed!
TCP: cubic registered
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 112K
usb 1-1: new high-speed USB device number 2 using hiusb-ehci
# GWELL IPC SYSTEM #
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
mke2fs 1.41.11 (14-Mar-2010)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
Stride=0 blocks, Stripe width=0 blocks
16384 inodes, 65536 blocks
3276 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67108864
8 block groups
8192 blocks per group, 8192 fragments per group
2048 inodes per group
Superblock backups stored on blocks:
8193, 24577, 40961, 57345
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 32 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
Password for root changed by root
HISI_IRDA-MF @Hi3518v100R001
hiir: init ok. ver=Jan 3 2007, 19:33:43.
uart1 init ok. ver=May 24 2007, 18:50:36.
usbcore: registered new interface driver rtl8188fu
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
mmz_start: 0x81c00000, mmz_size: 36M
Module himedia: init ok
hi3518e_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3518EV200...OK!
load tde.ko ...OK!
load region.ko ....OK!
load vgs.ko for Hi3518EV200...OK!
ISP Mod init!
load viu.ko for Hi3518EV200...OK!
load vpss.ko ....OK!
load vou.ko ....OK!
load hifb.ko OK!
load rc.ko for Hi3518EV200...OK!
load venc.ko for Hi3518EV200...OK!
load chnl.ko for Hi3518EV200...OK!
load h264e.ko for Hi3518EV200...OK!
load jpege.ko for Hi3518EV200...OK!
load ive.ko for Hi3518EV200...OK!
==== Your input Sensor type is sc1145 ====
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x200f006C: 0x00000001 --> 0x00000000
[END]
0x200f0040: 0x00000000 --> 0x00000002
[END]
0x200f0044: 0x00000000 --> 0x00000002
[END]
0x200f007c: 0x00000000 --> 0x00000001
[END]
0x200f0080: 0x00000000 --> 0x00000001
[END]
0x200f0084: 0x00000000 --> 0x00000001
[END]
0x200f0088: 0x00000000 --> 0x00000001
[END]
0x200f008c: 0x00000000 --> 0x00000002
[END]
0x200f0090: 0x00000000 --> 0x00000002
[END]
0x200f0094: 0x00000000 --> 0x00000001
[END]
0x2003002c: 0x000C4003 --> 0x000B4001
[END]
acodec inited!
insert audio
mipi_init
init phy power successful!
load hi_mipi driver successful!
startup 0 0
no key detect
vStarNpc:
Auto login as root ...
Jan 1 00:00:08 login[983]: root login on 'ttyS000'
Welcome to HiLinux.
# /rom/erobotremotecontrolsetting.ini does not exist!!
default Language=0:
dwReootfsVersion:2
insmod: can't insert '/npc/patch/wdt.ko': File exists
load adc driver
watchdog_fd:3
open watchdog ok.
*********fun:vHarewareFunctionInit************
dwNetLed = 0 dwAlarmLed = 0; dwDefenseLed = 0; dwRecLed = 0
have 0 exist
*********vGpioMultipleInit********
0x200F006C: 0x00000000 --> 0x00000000
[END]
0x200F0100: 0x00000000 --> 0x00000001
[END]
0x200F0104: 0x00000000 --> 0x00000001
[END]
0x200F00F8: 0x00000000 --> 0x00000001
[END]
0x200F00EC: 0x00000000 --> 0x00000001
[END]
0x200F00F0: 0x00000000 --> 0x00000001
[END]
0x200F00F4: 0x00000000 --> 0x00000001
[END]
0x200F00C0: 0x00000000 --> 0x00000003
[END]
0x200F00C8: 0x00000000 --> 0x00000003
[END]
0x200F00CC: 0x00000000 --> 0x00000003
[END]
0x200F00D0: 0x00000000 --> 0x00000003
[END]
0x200F0844: 0x00000090 --> 0x00000080
[END]
0x200F0840: 0x00000040 --> 0x00000000
[END]
0x200F0098: 0x00000001 --> 0x00000000
[END]
0x200F00FC: 0x00000000 --> 0x00000001
[END]
0x200F0004: 0x00000000 --> 0x00000001
[END]
/rom/Certificate.bin exist.
fgCrcOk1:1 fgCrcOk2:1
Certificate: rom file ok, eeprom ok
info: RTC has been used before, no need to init it
<1>Sun ??? 0 00:00:00 0000
<3>Wed Dec 31 23:59:59 1969
open file push language file failed:: No such file or directory
open file DEFAULT push language file failed:: No such file or directory
0x200F0040: 0x00000002 --> 0x00000002
[END]
0x200F0044: 0x00000002 --> 0x00000002
[END]
<<<pGetSetting()->bLanguage = 0 *************vCMOSPowerUp**************
hi_i2c_wait_rxfifo_notempty->273:
abort! int_raw_status: 0x550!
hi_i2c_abortprocess->87:
tx_abrt_src is 1.
tx_abrt_src is 1.
dwCMOSPID:0x1
...............addr.0x3107...buf.0....
...............addr.0x3108...buf.0....
[sensor_init] dwCMOSFormat:1
SC1135 960p 30fps sensor init OK!
===SC1135 sensor init success!040=====
################## CMOS TYPE = CMOS_TYPE_SC1135!
*************vCMOSPowerDown**************
cEmailAddr[0] is 0xffcEmailAddr:
*************vNetMg_Init******************
+++++++++++++vKey_DrvProc+++++++++++++++
chmod: /npc/OnvifFile/Authentication.xml: No space left on device
chmod: /npc/OnvifFile/Device.xml: No space left on device
chmod: /npc/OnvifFile/Fault.xml: No space left on device
chmod: /npc/OnvifFile/GetAudioEncoderConfiguration.xml: No space left on device
chmod: /npc/OnvifFile/GetAudioEncoderConfigurationOptions.xml: No space left on device
chmod: /npc/OnvifFile/GetCapabilities.xml: No space left on device
chmod: /npc/OnvifFile/GetDeviceInformation.xml: No space left on device
chmod: /npc/OnvifFile/GetNetworkInterfaces.xml: No space left on device
chmod: /npc/OnvifFile/GetProfiles.xml: No space left on device
chmod: /npc/OnvifFile/GetServices.xml: No space left on device
chmod: /npc/OnvifFile/GetSnapshotUri.xml: No space left on device
chmod: /npc/OnvifFile/GetStreamUri.xml: No space left on device
chmod: /npc/OnvifFile/GetSystemDateAndTime.xml: No space left on device
chmod: /npc/OnvifFile/GetVideoEncoderConfiguration.xml: No space left on device
chmod: /npc/OnvifFile/GetVideoEncoderConfigurationOptions.xml: No space left on device
chmod: /npc/OnvifFile/GetVideoSourceConfiguration.xml: No space left on device
chmod: /npc/OnvifFile/GetVideoSources.xml: No space left on device
chmod: /npc/OnvifFile/NetworkVideo.xml: No space left on device
chmod: /npc/OnvifFile/OnvifSetTimeTempFile.xml: No space left on device
chmod: /npc/OnvifFile/SetSystemDateAndTime.xml: No space left on device
chmod: /npc/OnvifFile/SetTimeTempFile.xml: No space left on device
chmod: /npc/OnvifFile/SetVideoEncoderConfiguration.xml: No space left on device
chmod: /npc/OnvifFile/tptz_ContinuousMove.xml: No space left on device
chmod: /npc/OnvifFile/tptz_GetConfigurationOptions.xml: No space left on device
width:960, height:960
[vOnvifInit 77]create thread -1231584048
[vOnvifInit 79]create thread -1232632624
vRtspServderThreadStar star!
Disk init
vDiskProc begin
vHandSelectThreadStar star!
accept ******************
*********step 1: mpp init start*********
HI_MPI_VB_SetConf ok.
HI_MPI_VB_Init ok.
HI_MPI_SYS_SetConf ok.
HI_MPI_SYS_Init ok.
************mpp init over************
[HI_MPI_AI_SetPubAttr]: ok
[HI_MPI_AI_Enable]: ok
[HI_MPI_AI_EnableChn](AiChn:0): ok
[HI_MPI_AI_GetChnParam]: ok
[HI_MPI_AI_SetChnParam]: ok
sHiRegCmd.dwBaseAddr = 0x20120000 0xc4
sHiRegCmd.dwBaseAddr = 0x20120000 0xc8
Enter UISsInit
Exit UISsInit
#### read ap wifi password:0000000000000000
===== Now AT24CXX used 255 Bytes=====
dwGetKey() = 22,dwUIState = 0
keylong = 2
dwGetKey() = 73,dwUIState = 0
fgEth0Support = 1,fgRa0Support = 1
Support eth0!
udhcpc (v1.20.2) started
Sending discover...
START AP MODE!
Configuration file: /etc/Wireless/RTL8188/hostapd.conf
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0xc19c48
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan0 with hwaddr 88:83:5d:2d:02:96 and ssid 'GW_AP_11278647'
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid ignore_broadcast_ssid:0, GW_AP_11278647,14
rtl871x_set_acl
udhcpd: bad line 7: 1 tokens found, 2 needed
udhcpd: bad line 12: 1 tokens found, 2 needed
udhcpd: bad line 20: 1 tokens found, 2 needed
udhcpd: bad line 34: 1 tokens found, 2 needed
udhcpd: bad line 44: 1 tokens found, 2 needed
udhcpd: bad line 52: 1 tokens found, 2 needed
udhcpd: bad line 60: 1 tokens found, 2 needed
udhcpd: bad line 66: 1 tokens found, 2 needed
udhcpd: bad line 74: 1 tokens found, 2 needed
udhcpd: bad line 80: 1 tokens found, 2 needed
udhcpd: bad line 90: 1 tokens found, 2 needed
udhcpd (v1.20.2) started
': No such file or directorycpd.leases
AP start! udhcpd pid = 1070
sleep over!dwNowNetSel = 1
dwGetKey() = 295,dwUIState = 0
route: resolving dev
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
ЛОГ
System startup
test flag.
MMC:
In: serial
Out: serial
Err: serial
OK
Starting kernel ...
NR_IRQS:32
brd: module loaded
himii: probed
Core Release: 3.10a
Filesystem label=
OS type: Linux
First data block=1
8 block groups
load tde.ko ...OK!
ISP Mod init!
load vou.ko ....OK!
load hifb.ko OK!
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
acodec inited!
insert audio
mipi_init
startup 0 0
no key detect
vStarNpc:
Welcome to HiLinux.
default Language=0:
dwReootfsVersion:2
load adc driver
watchdog_fd:3
open watchdog ok.
have 0 exist
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
[END]
tx_abrt_src is 1.
tx_abrt_src is 1.
dwCMOSPID:0x1
Disk init
vDiskProc begin
HI_MPI_VB_Init ok.
HI_MPI_SYS_Init ok.
Enter UISsInit
Exit UISsInit
keylong = 2
Support eth0!
Sending discover...
START AP MODE!
drv->ifindex=3
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_acl
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Re: Помогите разобраться с ip камерой
Хотелось бы прошить прошивкой от XM
Помогите пожалуйста!
Подаю питание на камеру и снимаю лог.
Нажымаю на любую клавишу, согласно строке в логе (Hit any key to stop autoboot: 0)
листинг не останавливается.
Почему вы думаете, что можно просто заливать прошивки, которые вам понравились?
Покупал камеру у постоянного продавца (kadymay.com, https://kadymay.en.alibaba.com/product/ ... Angle.html" onclick="window.open(this.href);return false;). Брал как опытный образец (посмотреть какие функции, как работает). В итоге функций 0, выбросить жалко да и "опытный образец" появился. Пишу своему менеджеру дайте новую прошивку на нее, он в ответ мол зборка не наша постараюсь взять прошивку и прислать, но что-то там не получилось прошивку не прислал. Камера работает только с мобильным приложением yoosee, зашол на их сайт, прошу прошивку в ответ "0". Разобрал камеру проц. Hi3518EV200 сенсор вроде как SC1135 (по логу непонятно там присутствует и SC1145). нашол такую сборку в XM (http://www.xiongmaitech.com/en/index.ph ... 77/178/208" onclick="window.open(this.href);return false;) из-за того и думаю может получится ее прошить прошивкой от XM. Спасибо за ответ
- Вложения
- Parameters for IPG-H131S-WS-E36.pdf
- (256.97 КБ) 278 скачиваний
Внешний вид сенсора как SC1135
это же опытный образец, потестироавли - непонравилось - выкинули. еще раз убедились что лучше брать ХМ.
Добрый день, оно-то так но выбросить жалко да и поучится на ней можно, хуже ей от этого не будет. Есть шанс поднять камеру.
Модуль Hi3518EV200 стоит 300-400р, рабочий час специалиста 1000р, но опыт бесценен ))) А опыт полученный путем самостоятельных исследований еще и укрепляется в памяти, так что выбор за вами.
А из этого модуля еще можно извлечь флэш память и защитные диоды, поэксперементировать с выпаиванием матрицы и еще много интересного ))
Как остановить загрузку? нажимаю любую клавишу, согласно строке в логе(Hit any key to stop autoboot: 0), но загрузка не останавливается.
viewtopic.php?p=103282#p103282" onclick="window.open(this.href);return false;
Этот пост я читал, и все что там предлагали я делал, но толку никакого. если замкнуть ТХ и RX ехо есть.
