DS-2CD2442FWD-IW проблема с прошивкой
aavan
Сообщение aavan » 06 фев 2021, 18:51
Доброго всем!Отказали сразу 2 камеры DS-2CD2442FWD-IW.Пропали из сети и на лицевой стороне загорелись все светодиоды.SADP не видит.Кнопка rst. не помогла.на шильдике sv 5.5.0_170725.на сервере хиквижна нашел такую,но обновляться через tftp камера не стала.подключил uart:
help & printenv
U-Boot 3.1.6-269644 (Jul 6 2017-10:47:55)
boards:296717
Boot From: NAND 2048 RC
SYS_CONFIG: 0x3006005B POC: 101
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2442FWD-IW
Hit Ctrl+u to stop autoboot: 2
HKVS # help
The following commands are supported:
boot erase help reset
setenv printenv saveenv updateb
upf update format go
mii gpio ping
Use 'help' to get help on a specific command
HKVS # printenv
ipaddr=192.0.0.64
serverip=192.0.0.128
gatewayip=0.0.0.0
netmask=255.255.255.0
ethaddr=b4:a3:82:5b:f8:17
loadaddr=0x00208000
bootfile=hImage
bootcmd=null
bootargs=console=ttyS0
bootdelay=2
HKVS #
log:
boards:296717
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
Hit Ctrl+u to stop autoboot: 1
Hit Ctrl+u to stop autoboot: 0
|NUL eth|
cmd 'null' is not supported.
nand booting ...
booting from pri part...
load kernel...
init started: BusyBox v1.19.3 (2017-07-20 11:10:26 CST)
starting pid 46, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
diagnose_way = 15, repair_way = 1, interval = 60
route: ioctl 0x890c failed: No such process
Default method to init without VIN drivers...
Cat this file to find out what VIN can be supported.
Default init without lens driver
Use default settings
/home/script/init.sh: line 553: which: not found
[ 17.971168] [ kernel version: svn-300837 ]
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x76ab1000
loading /home/firmware/orccode.bin...addr = 0x76ab1000, size = 0x171cca
loading /home/firmware/orcme.bin...addr = 0x76db1000, size = 0x51644
loading /home/firmware/default_binary.bin...addr = 0x76e51000, size = 0x40000
ucode (S2L) version = 2017/5/25 271820.271498
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus 0 .
netprocess Infomation:
version: 5.10.2 [20:30:33-Jul 18 2017]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 299284
Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017)
Enter DB_main-------------------
shared memory address is: 0x76b96000, sizeof(DEVICECONFIG) = 959848
wait davinci set default...
[02-06 19:55:00][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[02-06 19:55:00][pid:557][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[02-06 19:55:00][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[02-06 19:55:00][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!!
copy default.cls ok.
[02-06 19:55:01][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[02-06 19:55:01][pid:557][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[02-06 19:55:01][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[02-06 19:55:01][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[02-06 19:55:02][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[02-06 19:55:02][pid:557][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[02-06 19:55:02][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[02-06 19:55:02][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
shared memory address is: 0x76930000, sizeof(DEV_CAPABILITY) = 258664
[02-06 19:55:02][pid:571][HW_IF][ERROR]ioctl error errno=5
[02-06 19:55:02][pid:571][SYSINIT][ERROR]hwif_getsecinfo failed.
[02-06 19:55:02][pid:571][SYSINIT][ERROR]sys app init failed to reboot!
[02-06 19:55:03][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[02-06 19:55:03][pid:557][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[02-06 19:55:03][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[02-06 19:55:03][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[02-06 19:55:04][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[02-06 19:55:04][pid:557][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[02-06 19:55:04][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[02-06 19:55:04][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 28.768604] Restarting system.
[4l
boards:296717
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
Hit Ctrl+u to stop autoboot:2
и вот что имею после прошивки командой:
boards:296717
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
HKVS # update
'update' is a ambiguous command! Exec the shortest command
[ INFO][MIN]TFTP: TFTP from server 192.0.0.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
[ INFO][MIN]TFTP: ################################################################################
[ INFO][MIN]TFTP: Download File [OK]
[ INFO][MIN]BURN: File size is 32106942 bytes (31354 KB)
[ INFO][MIN]BURN: Writing Flash
[ INFO][MIN]BURN: ..............................................................................................................
[ INFO][MIN]BURN: Write Flash [OK]
***** UPDATE COMPLETE *****
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# help
Support Commands:
taskShow printPart prtHardInfo
getPreviewStatus setIp setV6ip
setGateway dspStatus outputClose
outputOpen getDebug setDebug
debugLog getIrstate getMtu
camCmd getCamVer getIrstate
getLux getMcuInfo getMotion
getRawdata setIrcmd setRectFrame
updateCamera setLaserMode getLaserMode
setIrMode getIrMode setBaiguangMode
getBaiguangMode setYTLock InquireFanSwitch
StartLaser CloseLaser LaserMotReset
EnlargeCur ReduceCur SetCur
LaserMotDirect LaserTeleOffset LaserWideOffset
InqSwitch InqCurrent InqCurMotDirect
getMcuStateInfo setFastFocus getTrackStatus
getSelfcheckResult setLdcMode getLdcMode
getPreviewStatus appCmd camCmd
ezoomlens_start_t2_test prtLensCurve getLensCurve
getIp gdbcfg {Test1}
{Test2} {Test3} {Test4}
{TestN} {TestY} getIsp
getISP getisp setIsp
setISP setisp regread
regwrite setAgingMode getAgingMode
setAgingTime getAgingTime setLensZoomPos
getLensZoomPos dm365 ss
showKey showServer showUpnp
showStatus showDefence setLBS
setAlarm cloudService t1
ifconfig netstat ping
ping6 top iostat
mpstat ps reset
dmesg exit getDateInfo
diagnose help
# reset
The system is goi
Sent SIGKILL to all processes
Requesting system reboot
list of davinci system commands. после перезагрузки не появляется
хотелось бы понять в чем затык и что делать дальше.
aavan
Re: DS-2CD2442FWD-IW проблема с прошивкой
Сообщение aavan » 07 фев 2021, 15:55
по команде upf камера ищет на tftp сервере файл mImage и не найдя сообщает об ощибке
error: upm.(error: tftp.)!
update mini system [FAIL]!error: upf.
!!!!! UPDATE FAIL !!!!!
HKVS # update
[ INFO][MIN]BURN: File size is 34011619 bytes (33214 KB)
[ INFO][MIN]BURN: ..................................................................................................................
aavan
Сообщение aavan » 12 фев 2021, 12:42
командировка окончилась.Есть время заняться камерами.Судя по отсутствию ответов,да и смотря на количество подобных тем на разных сайтах окончившихся ничем,вопрос сложный.На обьекте в работе ещё несколько камер из одной партии с пациентом,так что проблем с нахождением дампа нет.Но слить пока не могу,мой программатор не поддерживает nand.сегодня закажу у китайцев,,но когда получу х.з.Отсюда вопрос- есть ли возможность слить дамп через tftp?И ещё-возможно ли что камера не загружается из за отсутствия HWID или серийника?Такая проблема у меня была во время восстановления IP камеры дахуа.Заранее благодарен ответившим.
aavan
Сообщение aavan » 15 авг 2021, 12:31
Так все и заглохло?А камер таких на ремонте уже 8 шт.Программатор с Али не дошел,китайцы извинились,обьяснив проблемой с логистикой.Перезаказал
VirtualLink
Сообщение VirtualLink » 16 авг 2021, 10:41
aavan писал(а):
06 фев 2021, 18:51
Уже видел такое!
Криптомодуль кончился!
aavan
Сообщение aavan » 16 авг 2021, 18:30
Во всех восьми?Или это запланированная отложенная неисправность?Как это лечится?а что за настройки предлагаются провести по окончании прошивки?
VirtualLink
Сообщение VirtualLink » 17 авг 2021, 12:25
aavan писал(а):
16 авг 2021, 18:30
Если вывод такой же, то да!
Может быть, а может быть и нет!
Лечат раз пишут!
aavan
Сообщение aavan » 18 авг 2021, 06:12
Лаконично,но малоинформативно.Хотелось бы подробнее о лечении.
aavan
Сообщение aavan » 14 окт 2021, 11:59
За прошедшее время отказали ещё 11 шт,4 удалось отремонтировать(проблемы PoE),а 7 выдают все то же самое как выше.До обьекта далеко,зима на носу,решили занести модель камеры в чёрный список и заменить все скопом.на той неделе поеду менять
VirtualLink
Сообщение VirtualLink » 15 окт 2021, 12:18
Запрограммированное устаревание?!
4-е были не связаны с другими, либо проблема PoE выводит из строя!
Заноси тогда весь бренд!
