Прошивка HI3518с+IMX238
den23rus
Сообщение den23rus » 24 янв 2016, 20:26
Лог через терминал:
Image Name: Linux-3.0.8
Data Size: 1376244 Bytes = 1.3 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@lvjh-VirtualBox) (gcc version 4.4.1 (Hisilicon_v100(gc
c4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #1 Thu May 15 10:14:31 CST 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3518
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: mem=64M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfsty
pe=jffs2 mtdparts=hi_sfc:1M(boot),2M(kernel),3M(system),10M(application)
Memory: 64MB = 64MB total
Memory: 61492k/61492k available, 4044k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc4800000 - 0xfe000000 ( 920 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
.init : 0xc0008000 - 0xc001f000 ( 92 kB)
.text : 0xc001f000 - 0xc0338000 (3172 kB)
.data : 0xc0338000 - 0xc034cf00 ( 84 kB)
.bss : 0xc034cf24 - 0xc035cf98 ( 65 kB)
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 110MHz, resolution 9ns, wraps every 39045ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
JFFS2 version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 120
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
Spi id table Version 1.22
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
4 cmdlinepart partitions found on MTD device hi_sfc
Creating 4 MTD partitions on "hi_sfc":
0x000000100000-0x000000300000 : "kernel"
0x000000300000-0x000000600000 : "system"
0x000000600000-0x000001000000 : "application"
Fixed MDIO Bus: probed
himii: probed
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
TCP cubic registered
шVFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 92K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (302): /proc/302/oom_adj is deprecated, please use /proc/302/oom_score_adj
instead.
[RCS]: /etc/init.d/S80network
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=15 sec (nowayout= 0,
nodeamon= 1)
PHY: himii:01 - Link is Up - 100/Full
SYS_CHECK: 55 1 60
Enter Watch Mode!
hi3518_base: module license 'Proprietary' taints kernel.
pa:84000000, va:c4b00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load vou.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok!
insmod: can't insert 'extdrv/pwm.ko': File exists
Kernel: ssp initial ok!
acodec inited!
get saved parameter!
watchDog_open 21
watchDogStart(): OK!
set_net_phyaddr: (WIRE: 00:00:1b:02:f4:91) 0
dhcp_setup(WIRE): -1 192.168.1.168
DVS IP(WIRE): 192.168.1.104
EMAIL_Start(): Ok!
hello here#######
@@@@@@width=1280 height=1024
@@@@@@width=720 height=576
@@@@@@width=176 height=144
#@@@enter case PIC_HD720
@@@@@@width=1280 height=720
in start stvbconf:[0]=1966080 [1]=663552 [2]=55296 [3]=1474560 [4]=784
pMainEncParam->reserve=18 sub=4 third=0 VIDEO_ENCODING_MODE_PAL=0
-------Sony IMX138 Sensor Initial OK!-------
func(SAMPLE_COMM_ISP_Init::589 stImageAttr.u16FrameRate = 25)
before SAMPLE_COMM_VPSS_StartGroup:width=1280 height=1024
before SAMPLE_COMM_VPSS_EnableChn vpss=0:width=1280 height=1024
before SAMPLE_COMM_VPSS_EnableChn vpss=1:width=720 height=576
second width=720 height=576
stPicSize.u32Height = 144, stPicSize.u32Width = 176
venc 0 @@@ pic type=18
frame=25 vencParam->nKeyInterval = 1
debug @@@@@ set bitrate[18]:4096#####venc bitrate=4194304
venc 1 @@@ pic type=4
bitrate is:1048576
debug @@@@@ set bitrate[4]:1024#####venc bitrate=1048576
venc 2 @@@ pic type=0
frame=0 vencParam->nKeyInterval = 1
debug @@@@@ set bitrate[0]:0#####venc bitrate=0
[SAMPLE_COMM_VENC_Start1]-1084: HI_MPI_VENC_CreateChn [2] faild with 0xa0078003!
[Hi3518VinVencModuleSetup]-937: Start Venc failed!
[SAMPLE_COMM_VENC_Stop]-1612: HI_MPI_VENC_StopRecvPic vechn[2] failed with 0xa00
78005!
[SAMPLE_COMM_VENC_Stop]-1612: HI_MPI_VENC_StopRecvPic vechn[3] failed with 0xa00
78005!
[SAMPLE_COMM_VENC_Stop]-1612: HI_MPI_VENC_StopRecvPic vechn[4] failed with 0xa00
78005!
[SAMPLE_COMM_VPSS_DisableChn]-230: SAMPLE_COMM_VPSS_DisableChn failed with 0xa00
88010
videoEncSetup(videoEncAppModule.c 2032) Failed!
videoEncModuleStartup() Failed!
Через putty не пускает требует пароль.
Фото платы как в теме HI3516+IMX232
Можно ли прошить через терминал?
iTuneDVR
Re: Прошивка HI3518с+IMX238
Сообщение iTuneDVR » 24 янв 2016, 21:09
Остановить загрузку можно?
Какая прошивка подходит для данного устройства?
den23rus
Сообщение den23rus » 24 янв 2016, 21:37
Как его останавливать?
Прошивка IMX238_3518C_X_4.1.47.4 такая ставиться.
Похожая проблема была пару тройкой постами ниже тока я не пойму как он сделал)
iTuneDVR
Сообщение iTuneDVR » 25 янв 2016, 00:30
Про прошивку имелось ввиду ссылку на неё на нормальный ресурс длительного хранения без идиотской рекламы. Для всех это будет удобно.
Там камера была рабочая и он зашел в телнет, если мы говорим об одном и том же, но опять же лучше ссылку на тот пост, раз оно похожее, но что-то непонятно!
Возможно, в этих камерах остановка заглушена, или её пока никто не нашёл!
den23rus
Сообщение den23rus » 25 янв 2016, 11:46
http://forum.videon.spb.ru/viewtopic.php?f=20&t=8286" onclick="window.open(this.href);return false;
Фото платы как у меня.
Ссылка на прошивку https://yadi.sk/d/wtlXibFBngtcq" onclick="window.open(this.href);return false;
iTuneDVR
Сообщение iTuneDVR » 25 янв 2016, 12:14
den23rus писал(а):http://forum.videon.spb.ru/viewtopic.php?f=20&t=8286
Так по ссылке на фото, там расписано всё как и куда он что грузил.
Если сложно, то может быть рядом есть какой-то сервис куда можно отдать для поднятия, чтобы не сломать совсем!
В прошивке этой раздел application, вот его наверное на место и надо вставить, по аналогии
Та.к. остальное загрузчик и ядро работоспособны!
den23rus
Сообщение den23rus » 25 янв 2016, 12:51
Проще отослать китайцам, если на то пошло. )
iTuneDVR
Сообщение iTuneDVR » 25 янв 2016, 15:04
den23rus писал(а):Проще отослать китайцам, если на то пошло. )
Ну тебе видней. Вариант предложен, но он там ведь не с прошивки восстанавливал а с другого образа такой-же камеры.
А из твоего файла прошивки надо наверное отрезать первые 0x190 байт до 0x85 0x19 0x03 0x20 и с оставшейся частью можно поиграться в телнете
den23rus
Сообщение den23rus » 25 янв 2016, 17:08
так доступ через телнет закрыт пароль подобрать не получилось. Можно ли прошивать через терминал или нет?
iTuneDVR
Сообщение iTuneDVR » 25 янв 2016, 17:28
den23rus писал(а):так доступ через телнет закрыт пароль подобрать не получилось. Можно ли прошивать через терминал или нет?
Ну у человека-то там другая ситуация и остановка загрузки и телнет.
Надо поискать полный дамп на именно такую камеру, поглядеть на хэш и поискать варианты!
И можно будет наверное! ;)
den23rus
Сообщение den23rus » 25 янв 2016, 22:23
Слил прошивку с рабочей камеры:
sf probe 0
sf read 0x82000000 0x000000100000 0xf00000
tftp 0x82000000 fw.img 0xf00000
Потом залил:
sf probe 0
sf erase 0x100000 0xf00000
sf write 0x82000000 0x100000 0xf00000
Лог теперь:
U-Boot 2010.06 (Mar 11 2014 - 17:33:21)
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1): Block:64KB Chip:16MB NamIn: serial
OIn: serial
Out: serial
Err: serial
Wrong Image Format for bootm command
ERROR: can't get kernel image!
hisilicon #
iTuneDVR
Сообщение iTuneDVR » 25 янв 2016, 22:57
Ну вот, есть движуха уже!
На рабочей камере загзузка начало как идёт, что там по printenv? Что тут?
Файл какого размера fw.img?
И его содержимое конечно же в студию! :)
