Код: Выделить всё
Hit ctrl+u to stop autoboot: 0
HKVS $ setenv ';u'
using update v3...
### CRAMFS load complete: 4415536 bytes loaded to 0x42000000
the uImage support update_v3.
Verifying RSA ... OK
## Booting kernel from Legacy Image at 42000000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 4.843088] init(1) called reboot syscall, cmd: 0x0.
Thu Jan 1 00:00:04 UTC 1970
mv: can't rename 'ubi*': No such file or directory
Starting udev: [ OK ]
Jun 21 17:55:15 udevd-work[125]: kernel-provided name 'sdb' and NAME= 'sda' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[127]: kernel-provided name 'sdb3' and NAME= 'sda3' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[126]: kernel-provided name 'sdb2' and NAME= 'sda2' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[125]: kernel-provided name 'sdb1' and NAME= 'sda1' disagree, please use SYMLINK+= or change the kernel to provide the proper name
This program will download and upgrade software.
* ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY! *
* Don't reset machine,or anything that interrupt it. *
* The upgrade process must finish in 10 minutes! *
* If this program fails,machine might be unusable, *
* and you will need to reflash again. *
* If you find this too risky,power off machine now. *
waiting for net_link [10]...
waiting for net_link [9]...
[ 9.238210] hi_gmac_v200 100a0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
ftp server not exit[-111]!
tftp transmit over,file size[8192][ 0.008 MB].
################################ [ 8.000 MB]
################################ [16.000 MB]
################################ [24.000 MB]
################################ [32.000 MB]
################################ [40.000 MB]
################################ [48.000 MB]
################################ [56.000 MB]
tftp transmit over,file size[61562988][58.728 MB].
mmap failed.
failed(-14)!
Press ENTER key to reboot
