NVR8000-C04L064-A2
NVR8000-C04L064-A2
Здравствуйте!Прошу помочь опознать NVR и подобрать для него прошивку.На шильдике он называется NVR8000-C04L064-A2(ФОТО 1).Поиск по картинке показал название -Cyfron.
Re: NVR8000-C04L064-A2
DDR Training Suc
U-Boot 2010.06 (Nov 20 2018 - 14:20:47)
AUTH_INFO is 'HI3536_NVR'!
############## yuhj gd->bd->bi_dram[0].size = 2048MB
NAND: Check nand flash controller v610. found
Special NAND id table Version 1.36
Nand ID: 0xAD 0xF1 0x80 0x1D 0xAD 0xF1 0x80 0x1D
yuhj nand_dev not support!
yuhj best->ecctype = 3
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bit/512
128 MiB
Can't find a valid spi flash chip.
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
##yuhj master bootargs = 'asc_sn=0123f64a28d810edee44565232333531353034019100000000 mem=1216M board_type=0x191 local_av=1 single_cpu=0 have_face=0 mmz_addr=0x8c000000 mmz_size=64M double_fb=1 fb_color=32 console=ttyAMA0,115200 mtdparts=hinand:1024K(boot),12288K(kernel_m1),32768K(app_m2),40960K(res_m3),512K(slave_uboot_m4),4096K(slave_kernel_m5),6144K(slave_fs_m6),12288K(reserve_m7),20736K(config_m8),256K(logo_m9)'
##yuhj slave bootargs = 'mem=40M mmz_addr=0x92800000 mmz_size=728M console=ttyAMA0,115200'
NAND read: device 0 offset 0x7fc0000, size 0x40000
262144 bytes read: OK
jpeg decoding ...
<<addr=0x58000000, size=0x60000, vobuf=0x8f600000>>
mmu_enable
PicType: 6 ,Output Addr, Y: 8f600000,UV: 8f6c0000
yuhj HARD_DEC
<<imgwidth=1024, imgheight=768, linebytes=1024>>
decode success!!!!
decode jpeg!
stMaxRect.u32Width1024, stMaxRect.u32Height768.
VOU_DRV_Open:950
VOU_DRV_Open:1052
HDMI_INFO:DispFmt2HdmiTiming[367] ,Non CEA video timing:17
HDMI_INFO:Hdmi_PixelFreqSearch[119] ,u32Fmt17.
dev 0 opened!
video layer 0 opened!
##yuhj master bootcmd = 'nand read 0x42000000 0x100000 0xc00000;bootm 0x42000000;'
##yuhj slave bootcmd = 'nand read 0x91000000 0x5500000 0x80000;nand read 0x92000000 0x5580000 0x400000;nand read 0x93000000 0x5980000 0x600000;bootm 0x91000000 0x92000000 0x93000000;'
(Re)start USB...
USB: Starting the controller
scanning bus for devices... 1 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
load file fail!
yuhj slave_start
yuhj slave_command = 'nand read 0x91000000 0x5500000 0x80000;nand read 0x92000000 0x5580000 0x400000;nand read 0x93000000 0x5980000 0x600000;bootm 0x91000000 0x92000000 0x93000000;'
NAND read: device 0 offset 0x5500000, size 0x80000
524288 bytes read: OK
NAND read: device 0 offset 0x5580000, size 0x400000
4194304 bytes read: OK
NAND read: device 0 offset 0x5980000, size 0x600000
6291456 bytes read: OK
yuhj slave_cmd = 'bootm 91000000 92000000 93000000'
yuhj slave_bootaddr = 0x91000000, slave_kerneladdr = 0x92000000, slave_initrdaddr = 0x93000000
yuhj cmd_buf = 'setenv slave_cmd bootm 90007fc0 91100000'
yuhj cmd_buf = 'setenv slaveboot 91000000'
yuhj slave_start ok
Hit any key to stop autoboot: 1
hisilicon # c c <INTERRUPT>
hisilicon # c<INTERRUPT>
hisilicon # <INTERRUPT>
hisilicon # cc<INTERRUPT>
hisilicon # qqcqc<INTERRUPT>
hisilicon # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
ddr - ddr training function
decjpg - jpgd - decode jpeg picture.
md - memory display
mii - MII utility commands
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
setvobg - setvobg - set vo backgroud color.
- setvobg [dev color]
sf - SPI flash sub-system
startgx - startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvl - startvl - open video layer.
- startvl [layer addr stride x y w h]
startvo - startvo - open interface of vo device.
- startvo [dev type sync]
stopgx - stopgx - close graphics layer.
- stopgx [layer]
stopvl - stopvl - close video layer.
- stopvl [layer]
stopvo - stopvo - close interface of vo device.
- stopvo [dev]
update - update - update image
usb - USB sub-system
hisilicon # printenv
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.254.0
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
ethaddr=ec:10:d8:28:4a:f6
bootargs=asc_sn=0123f64a28d810edee44565232333531353034019100000000 mem=1216M board_type=0x191 local_av=1 single_cpu=0 have_face=0 mmz_addr=0x8c000000 mmz_size=64M double_fb=1 fb_color=32 console=ttyAMA0,115200 mtdparts=hinand:1024K(boot),12288K(kernel_m1),32768K(app_m2),40960K(res_m3),512K(slave_uboot_m4),4096K(slave_kernel_m5),6144K(slave_fs_m6),12288K(reserve_m7),20736K(config_m8),256K(logo_m9)
slave_bootargs=mem=40M mmz_addr=0x92800000 mmz_size=728M console=ttyAMA0,115200
slave_autostart=1
vobuf=0x8f600000
jpeg_size=0x60000
jpeg_addr=0x58000000
bootcmd=nand read 0x42000000 0x100000 0xc00000;bootm 0x42000000;
slave_bootcmd=nand read 0x91000000 0x5500000 0x80000;nand read 0x92000000 0x5580000 0x400000;nand read 0x93000000 0x5980000 0x600000;bootm 0x91000000 0x92000000 0x93000000;
verify=yes
ver=U-Boot 2010.06 (Nov 20 2018 - 14:20:47)
Environment size: 1023/262140 bytes
hisilicon #
hisilicon #
128 MiB
In: serial
Out: serial
Err: serial
jpeg decoding ...
mmu_enable
yuhj HARD_DEC
decode success!!!!
decode jpeg!
VOU_DRV_Open:950
VOU_DRV_Open:1052
dev 0 opened!
(Re)start USB...
load file fail!
yuhj slave_start
yuhj slave_start ok
hisilicon # help
cp - memory copy
md - memory display
- stopgx [layer]
- stopvl [layer]
- stopvo [dev]
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
slave_autostart=1
vobuf=0x8f600000
jpeg_size=0x60000
verify=yes
hisilicon #
hisilicon #
Благодаря ребятам из техподдержки Cyfron всё благополучно решилось
