Лог рабочего:
Код: Выделить всё
U-Boot 2010.06 (Dec 05 2013 - 16:53:16)
Spi(cs1) ID: 0xC2 0x20 0x19 0xC2 0x20 0x19
Spi(cs1): Block:64KB Chip:32MB Name:"MX25L25635E/735E/635F"
In:    serial
Out:   serial
Err:   serial
32768 KiB hi_sfc at 0:0 is now current device
mmu_enable
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
dev 0 set background color!
dev 2 set background color!
dev 0 opened!
dev 2 opened!
graphic layer 0 opened!
graphic layer 2 opened!
(Re)start USB...
USB:   scanning bus for devices... 1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  0
   Image Name:   Linux-3.0.8
   Data Size:    1567336 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@sqy-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #81 Fri Oct 17 16:20:03 CST 2014
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 37338
Kernel command line: mem=147M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:320K(uboot),1536K(kernel),4M(rfs),25792K(app),768K(config),256K(logo)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 147MB = 147MB total
Memory: 144904k/144904k available, 5624k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc9800000 - 0xfe000000   ( 840 MB)
    lowmem  : 0xc0000000 - 0xc9300000   ( 147 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0023000   ( 108 kB)
      .text : 0xc0023000 - 0xc03b0000   (3636 kB)
      .data : 0xc03b0000 - 0xc03cbac0   ( 111 kB)
       .bss : 0xc03cbae4 - 0xc0418020   ( 306 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms
Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560)
console [ttyAMA0] enabled
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
L2cache cache controller enabled
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 283
encryption fail
no ack
sha204_sn is 1
sha204_sn is 23
sha204_sn is 16
sha204_sn is 86
sha204_sn is 4e
sha204_sn is a9
sha204_sn is 9
sha204_sn is 46
sha204_sn is ee
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
no ack
count is 255
no ack
no ack
no ack
no ack
sha204_devinfo  is 44 i is 0
sha204_devinfo  is 56 i is 1
sha204_devinfo  is 52 i is 2
sha204_devinfo  is 32 i is 3
sha204_devinfo  is 33 i is 4
sha204_devinfo  is 35 i is 5
sha204_devinfo  is 31 i is 6
sha204_devinfo  is 35 i is 7
sha204_devinfo  is 30 i is 8
sha204_devinfo  is 34 i is 9
sha204_devinfo  is 1 i is 10
sha204_devinfo  is 55 i is 11
sha204_devinfo  is 11 i is 12
g_sha204_delay_time is 20
sha204_sn is 1
sha204_sn is 23
sha204_sn is 16
sha204_sn is 86
sha204_sn is 4e
sha204_sn is a9
sha204_sn is 9
sha204_sn is 46
sha204_sn is ee
sha204_devinfo  is 0 i is 12
sha204_devinfo  is 0 i is 13
sha204_devinfo  is 0 i is 14
sha204_devinfo  is 0 i is 15
TempKey  is 9
TempKey  is 69
TempKey  is 29
TempKey  is 64
TempKey  is b9
TempKey  is 67
TempKey  is 2
TempKey  is 4e
TempKey  is 17
TempKey  is df
TempKey  is a9
TempKey  is 4e
TempKey  is 3d
TempKey  is 6a
TempKey  is f2
TempKey  is ca
TempKey  is be
TempKey  is 22
TempKey  is 2c
TempKey  is 3
TempKey  is 85
TempKey  is ca
TempKey  is 8d
TempKey  is f6
TempKey  is ba
TempKey  is 21
TempKey  is 86
TempKey  is 2c
TempKey  is 1f
TempKey  is 69
TempKey  is 4e
TempKey  is bc
encryption ok
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:32MB
spi size: 0x33554432
chip num: 1
6 cmdlinepart partitions found on MTD device hi_sfc
Creating 6 MTD partitions on "hi_sfc":
0x000000000000-0x000000050000 : "uboot"
0x000000050000-0x0000001d0000 : "kernel"
0x0000001d0000-0x0000005d0000 : "rfs"
0x0000005d0000-0x000001f00000 : "app"
0x000001f00000-0x000001fc0000 : "config"
0x000001fc0000-0x000002000000 : "logo"
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: 42:D5:2B:5E:7B:6C
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
usbhid: USB HID core driver
TCP cubic registered
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 108K
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Jan  1 00:00:03 udevd (487): /proc/487/oom_adj is deprecated, please use /proc/487/oom_score_adj instead.
udevd[487]: main: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S03ants
init hotplug
start hotplug ok
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01361ba0: 0xc859 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01361ba4: 0x1004 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01361ba8: 0x7d7d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01361bac: 0x0080 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x01361bb0: 0xa529 instead
SDK_TYPE type is 8d1
hi3520D_base: module license 'Proprietary' taints kernel.
Hisilicon UMAP device driver interface: v3.00
load sys.ko for Hi3520D...OK!
Load tde.ko ...OK!
load venc.ko for Hi3520D...OK!
load group.ko for Hi3520D...OK!
load chnl.ko for Hi3520D...OK!
load h264e.ko for Hi3520D...OK!
load rc.ko for Hi3520D...OK!
load jpege.ko for Hi3520D...OK!
load viu.ko for Hi3520D...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
rm: can't remove '/root/DeviceDisplay.xml': No such file or directory
rm: can't remove '/root/res_xml/DeviceDisplay.xml': No such file or directory
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load jpeg6b.ko success.         (SDK_VERSION:[jpeg6bv1.0] Build Time:[Jul 30 2013, 17:13:35])
HISI_IRDA-MF @Hi3520Dv100R00
hiir: init ok. ver=Nov 26 2013, 15:14:13.
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
rtusb init rt2870 --->
usbcore: registered new interface driver rt2870
PPP generic driver version 2.4.2
rm: can't remove '/usr/etc/config.tar.gz': No such file or directory
mkdir: can't create directory '/usr/etc/tmp': File exists
mkdir: can't create directory '/usr/etc/var': File exists
mkdir: can't create directory '/usr/etc/var/run': File exists
mkdir: can't create directory '/usr/etc/var/lock': File exists
mkdir: can't create directory '/usr/etc/ppp': File exists
mkdir: can't create directory '/usr/etc/ppp/peers': File exists
rm: can't remove '/usr/etc/tmp/qtembedded-0/fonts/fontdb': No such file or directory
ln: /usr/etc/web/web: File exists
cp: can't stat '/usr/sbin/wcdma-chat-disconnect': No such file or directory
/etc/init.d/S03ants: line 56: /etc/startusb: not found
[RCS]: /etc/init.d/S80network
Auto login as root ...
Sep 13 09:11:15 login[818]: root login on 'ttyS000'
Welcome to HiLinux.
# begin dvr//////////////////////////////////////////////////////////////
argc 2, argv ./ants_dvr
 open /usr/etc/mycfg.xml
 open /root/res_xml/Keyboard.xml
 open /tmp/qtembedded-0//fonts//fontdb.tmp
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/gulim_17_50.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/microsoft_sans_serif_12_75.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/yh_17_50.qpf2
DBG[embedded/qscreenlinuxfb_qws.cpp connect▒▒350]       QLinuxFbScreen::connect :0
DBG[embedded/qscreenlinuxfb_qws.cpp connect▒▒379]
 open /dev/fb0
DBG[embedded/qscreenlinuxfb_qws.cpp connect▒▒397]       open device /dev/fb0 success
DBG[embedded/qscreenlinuxfb_qws.cpp connect▒▒425]
 open /root/DeviceDisplay.xml
и т.д.
Код: Выделить всё
In:    serial
Out:   serial
Err:   serial
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
(Re)start USB...
OK
Starting kernel ...
Machine: hi3520d
TCP reno registered
encryption fail
count is 0
sha204p_receive_response failed
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
count is 0
