Сообщение
								 pelentron » 23 окт 2017, 15:54
			U-Boot 2010.06-svn339 (Jan 11 2016 - 09:29:05)
SPI Nor(cs 0) ID: 0xc2 0x20 0x18
Block:64KB Chip:16MB Name:"MX25L128XX"
SPI Nor total size: 16MB
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) link UP: DUPLEX=FULL : SPEED=100M
MAC:   00-0B-3F-00-00-01
Press CTRL-C to abort autoboot in 2 seconds16384 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev  vo:0 intf_type:36 out_sync:16
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 2552, type 1
find_squashfs_file: name boot, start_block 0, offset 2656, type 1
read inode: name boot, sb 0, of 2656, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 2584, type 2
read inode: name zImage.img, sb 0, of 2584, type 2
### FS load complete: 2366136 bytes loaded to 0x82000000
   Image Name:   linux
   Data Size:    2366072 Bytes = 2.3 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
