Dahua IPC-HDBW2431R-ZS востановление
Lufftkonek
Сообщение Lufftkonek » 10 окт 2020, 01:31
Приветствую.Подскажите в чем может быть проблема.Пытаюсь востановить камеру через tftp сервер.Ip адрес настроен upgrade file сгенерирован.Прошивка распакована но не грузит. Лог через UART прилагаю.
Код: Выделить всё
U-Boot 2010.06-svn3845 (Dec 18 2016 - 09:32:48)
I2C:   ready
DRAM:  118 MiB
gBootLogPtr:00b80008.
spinor flash ID is 0x1940ef
partition file version 2
rootfstype squashfs root /dev/mtdblock5
gParameter[0]:node=bootargs, parameter=console=ttyS0,115200 mem=118M root=/dev/m        tdblock5 rootfstype=squashfs init=/linuxrc.
TEXT_BASE:01000000
Net:   Detected MACID:e0:50:8b:99:64:04
PHY:0x001cc816,addr:0x00
s3l phy RTL8201 init
MMC:   sdmmc init
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending throu        gh gateway 192.168.1.1
Download Filename 'upgrade_info_7db780a713a4.txt'.
Download to address: 0x5000000
Downloading: *
Retry count exceeded; starting again
Try again use backup_serverip
*** ERROR: `serverip' not set
Failed to get info.txt
Fail to get info file!
Init error!
Download Filename 'failed.txt'.
Download to address: 0x2000000
Downloading: *
state:ff,err_count:03
SPI probe: 32768 KiB W25Q256FV at 0:0 is now current device
## Booting kernel from Legacy Image at 02000000 ...
   Image Name:   Linux-3.10.73
   Created:      2017-02-16   5:53:38 UTC
   Data Size:    1485310 Bytes = 1.4 MiB
   Load Address: 00208000
   Entry Point:  00208000
   Verifying Checksum ... OK
   Loading Kernel Image ...OK
OK
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
crashflasg:1, logmagic:54410011.
Starting kernel ...
I2C:   ready
DRAM:  118 MiB
gParameter[0]:node=bootargs, parameter=console=ttyS0,115200 mem=118M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc.
TEXT_BASE:01000000
MMC:   sdmmc init
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Downloading: *
Init error!
Downloading: *
state:ff,err_count:04
OK
Starting kernel ...
I2C:   ready
DRAM:  118 MiB
TEXT_BASE:01000000
MMC:   sdmmc init
Downloading: *
Init error!
Downloading: *
state:ff,err_count:05
   Created:      2017-04-28   7:36:47 UTC
   Data Size:    916548 Bytes = 895.1 KiB
OK
get bootargs info failed
Starting kernel ...
init started: BusyBox v1.18.4 (2016-11-14 11:17:47 CST)
mount: mounting none on /proc/bus/usb failed: No such file or directory
mount: mounting tmpfs on /var failed: Invalid argument
mount: mounting /dev/mtdblock3 on /mnt/custom failed: Invalid argument
mount: mounting /dev/mtdblock4 on /mnt/pd failed: Invalid argument
mount: mounting /dev/mtdblock8 on /mnt/afix/autoFix failed: Invalid argument
mount: mounting /dev/mtdblock9 on /mnt/afix/autoFixBackup failed: Invalid argume        nt
BusyBox v1.18.4 (2016-11-14 11:17:47 CST) built-in shell (ash)
Revision: 20442
Enter 'help' for a list of built-in commands.
/bin/sh: can't access tty; job control turned off
~ # UPGRADED_MSG: Do memlock
[libpdi] Support backup partition !!!
[libpdi]  Flashtype = 3,patSize = 40000,rwSize = 10000,ersSize = 10000
pPartionId = 9
eth0:
MAC: <e0:50:8b:99:64:04>
[libpdi] ERROR  (save_Attr_file|1269): open failed for PRIO[libpdi] set eth0 as        defaultEth
IP: <192.168.1.108>             netmask: <255.255.255.0>
[libpdi] ERROR  (save_Attr_file|1269): open failed for HOSTIP[libpdi] ERROR  (PD        I_rtcWriteSram|162): Fail to ioctl rtc
[libpdi] ERROR  (SaveEthAttrInFile|1368): Fail to write ip paramenters
[libpdi] ERROR  (save_Attr_file|1269): open failed for SUBMASK[libpdi] ERROR  (P        DI_rtcWriteSram|162): Fail to ioctl rtc
SOCK_PACKET: Address family not supported by protocol
[libpdi] [libPDI] Gateway: <192.168.1.1>
[libpdi] SetGateWay success
[libpdi] ERROR  (save_Attr_file|1269): open failed for GATEWAYIP[libpdi] ERROR        (PDI_rtcWriteSram|162): Fail to ioctl rtc
[libpdi] [libPDI] Name: upgraded, bulid date: Apr 13 2015 15:03:44, svn: 492
UPGRADED_MSG: start download file!
UPG▒
Re: Dahua IPC-HDBW2431R-ZS востановление
Сообщение dede » 10 окт 2020, 09:19
вас ни капли эти строки не смущают???
Lufftkonek
Сообщение Lufftkonek » 10 окт 2020, 09:33
Спасибо что обратили внимание. Смущает. Странно что выставив IP он не сменился. Причем я его 3 раза перепровирял. Буду ещё пробовать
Lufftkonek
Сообщение Lufftkonek » 13 окт 2020, 01:17
В общем не пускал брандмауэр. Прошивка загружается но ядро не может запустится и просто виснет.Пробывл грузить DH_IPC-HX2X3X-Rhea_MultiLang_PN_Stream2_V2.800.0000013.0.R.191202 и NP версию.Реакции 0
Лог прошивки
Код: Выделить всё
I2C:   ready
DRAM:  118 MiB
TEXT_BASE:01000000
MMC:   sdmmc init
Downloading: *
Init error!
Downloading: *
state:ff,err_count:00
Wrong Image Format for bootm command
ERROR: can't get kernel image!
try:kload 0x2000000 succeed!
   Created:      2019-11-27  10:36:14 UTC
   Data Size:    1571472 Bytes = 1.5 MiB
OK
Starting kernel ...
I2C:   ready
DRAM:  118 MiB
TEXT_BASE:01000000
MMC:   sdmmc init
Downloading: #################################################
done
Bytes transferred = 201 (c9 hex)
Download Filename 'romfs-x.squashfs.img'.
done
Bytes transferred = 3303672 (3268f8 hex)
## Checking Image at 02000000 ...
   Legacy image found
   Image Name:   romfs
   Created:      2019-12-02   7:54:39 UTC
   Data Size:    3303608 Bytes = 3.2 MiB
   Load Address: 01b80000
   Entry Point:  01fd0000
Programing start at: 0x01b80000
SPI probe: 32768 KiB W25Q256FV at 0:1 is now current device
write : 100%
done
Download Filename 'kernel.img'.
done
Bytes transferred = 1576064 (180c80 hex)
   Legacy image found
   Image Name:   kernel
   Created:      2019-12-02   7:45:28 UTC
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    1576000 Bytes = 1.5 MiB
   Load Address: 01040000
   Entry Point:  01200000
Programing start at: 0x01040000
write : 100%
done
Download Filename 'user-x.squashfs.img'.
done
Bytes transferred = 13224184 (c9c8f8 hex)
   Legacy image found
   Image Name:   user
   Created:      2019-12-02   7:54:15 UTC
   Image Type:   ARM Linux Standalone Program (uncompressed)
   Data Size:    13224120 Bytes = 12.6 MiB
   Load Address: 000f0000
   Entry Point:  01000000
Programing start at: 0x000f0000
write : 100%
done
Download Filename 'web-x.squashfs.img'.
done
Bytes transferred = 4888824 (4a98f8 hex)
   Legacy image found
   Image Name:   web
   Created:      2019-12-02   7:53:49 UTC
   Data Size:    4888760 Bytes = 4.7 MiB
   Load Address: 01200000
   Entry Point:  01880000
Programing start at: 0x01200000
write : 100%
done
Download Filename 'partition-x.cramfs.img'.
done
Bytes transferred = 6392 (18f8 hex)
   Legacy image found
   Image Name:   partition
   Created:      2019-12-02   7:45:27 UTC
   Data Size:    6328 Bytes = 6.2 KiB
   Load Address: 000e0000
   Entry Point:  000f0000
Programing start at: 0x000e0000
write : 100%
done
Download Filename 'custom-x.squashfs.img'.
done
Bytes transferred = 751864 (b78f8 hex)
   Legacy image found
   Image Name:   custom
   Created:      2019-12-02   8:01:29 UTC
   Data Size:    751800 Bytes = 734.2 KiB
   Load Address: 018a0000
   Entry Point:  01970000
Programing start at: 0x018a0000
write : 100%
done
Download Filename 'pd-x.squashfs.img'.
done
Bytes transferred = 55544 (d8f8 hex)
   Legacy image found
   Image Name:   pd
   Created:      2019-12-02   8:01:27 UTC
   Data Size:    55480 Bytes = 54.2 KiB
   Load Address: 01880000
   Entry Point:  018a0000
Programing start at: 0x01880000
write : 100%
done
Download Filename '.FLASHING_DONE_STOP_TFTP_NOW'.
Downloading: #
done
cmdLine console=ttyS0,115200 mem=118M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
Download Filename 'success.txt'.
Downloading: *
TFTP error: (0)Erasing SPI flash...
Writing to SPI flash...
done
OK
Starting kernel ...
И вот второй лог
Код: Выделить всё
Ncat: Version 7.40 ( https://nmap.org/ncat )
Ncat: Listening on 192.168.254.254:5002
TEXT_BASE:01000000
MMC:   sdmmc init
gh gateway 192.168.1.1Download Filename 'upgrade_info_7db780a713a4.txt'.Download
Downloading: *
done
gh gateway 192.168.1.1Download Filename 'romfs-x.squashfs.img'.Download to addre
ss: 0x2000000
Downloading: *
done
   Legacy image found
   Image Name:   romfs
write : 100%
done
gh gateway 192.168.1.1Download Filename 'kernel.img'.Download to address: 0x2000
000
Downloading: *
done
   Legacy image found
   Image Name:   kernel
write : 100%
done
gh gateway 192.168.1.1Download Filename 'user-x.squashfs.img'.Download to addres
s: 0x2000000
Downloading: *
done
   Legacy image found
   Image Name:   user
write : 100%
done
gh gateway 192.168.1.1Download Filename 'web-x.squashfs.img'.Download to address
: 0x2000000
Downloading: *
done
   Legacy image found
   Image Name:   web
write : 100%
done
gh gateway 192.168.1.1Download Filename 'partition-x.cramfs.img'.Download to add
ress: 0x2000000
Downloading: *
done
   Legacy image found
write : 100%
done
gh gateway 192.168.1.1Download Filename 'custom-x.squashfs.img'.Download to addr
ess: 0x2000000
Downloading: *
done
   Legacy image found
   Image Name:   custom
write : 100%
done
gh gateway 192.168.1.1Download Filename 'pd-x.squashfs.img'.Download to address:
 0x2000000
Downloading: *
done
   Legacy image found
   Image Name:   pd
write : 100%
done
gh gateway 192.168.1.1Download Filename '.FLASHING_DONE_STOP_TFTP_NOW'.Download
Downloading: *
done
it=/linuxrc
fobos
Сообщение fobos » 13 окт 2020, 05:47
показывайте серийник
Lufftkonek
Сообщение Lufftkonek » 13 окт 2020, 08:04
Вот фото серийника.3E0581BPAA00020
Серийник самой камеры.
fobos
Сообщение fobos » 15 окт 2020, 23:12
https://cloud.mail.ru/public/5Q4p/5BpYfWojG сначала обновите загрузчик, а потом сделайте update... остановите загрузку, введите
setenv dh_keyboard 0
saveenv
reset
и покажите полный лог загрузки...я думаю, что у вас аппаратная проблема.
Lufftkonek
Сообщение Lufftkonek » 19 окт 2020, 00:37
Большое спасибо за помощь. Все отлично залилось.Слетел HWID. Сохраненный из лога HWID прописал и все запустилось нормально.
